RTEMS 6.1
This validation test suite contains a test case which triggers a fatal error during system initialization. More...
Modules | |
| spec:/bsp/sparc/leon3/val/fatal-cache-snooping-disabled-secondary | |
| Tests a fatal error. | |
Files | |
| file | ts-fatal-sparc-leon3-cache-snooping-disabled-secondary.c |
| #define | FATAL_SYSINIT_RUN BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Run |
| #define | CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER |
| #define | CONFIGURE_MAXIMUM_PROCESSORS 2 |
| const char | rtems_test_name [] = "TestsuitesBspsFatalSparcLeon3CacheSnoopingDisabledSecondary" |
| Each test must define a test name string. | |
