RTEMS 6.1
PMU_LDO_PLL - PMU_LDO_PLL_REGISTER
#define ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_ENABLE_MASK   (0x1U)
#define ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_ENABLE_SHIFT   (0U)
#define ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_ENABLE_SHIFT)) & ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_ENABLE_MASK)
#define ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_CONTROL_MODE_MASK   (0x2U)
#define ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_CONTROL_MODE_SHIFT   (1U)
#define ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_CONTROL_MODE(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_CONTROL_MODE_SHIFT)) & ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_CONTROL_MODE_MASK)
#define ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_TOGGLE_MASK   (0x10000U)
#define ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_TOGGLE_SHIFT   (16U)
#define ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_TOGGLE(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_TOGGLE_SHIFT)) & ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_TOGGLE_MASK)
#define ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_BUSY_MASK   (0x40000000U)
#define ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_BUSY_SHIFT   (30U)
#define ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_BUSY(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_BUSY_SHIFT)) & ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_BUSY_MASK)
PMU_BIAS_CTRL - PMU_BIAS_CTRL_REGISTER
#define ANADIG_PMU_PMU_BIAS_CTRL_WB_CFG_1P8_MASK   (0x1FFFU)
#define ANADIG_PMU_PMU_BIAS_CTRL_WB_CFG_1P8_SHIFT   (0U)
#define ANADIG_PMU_PMU_BIAS_CTRL_WB_CFG_1P8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL_WB_CFG_1P8_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL_WB_CFG_1P8_MASK)
#define ANADIG_PMU_PMU_BIAS_CTRL_WB_VDD_SEL_1P8_MASK   (0x4000U)
#define ANADIG_PMU_PMU_BIAS_CTRL_WB_VDD_SEL_1P8_SHIFT   (14U)
#define ANADIG_PMU_PMU_BIAS_CTRL_WB_VDD_SEL_1P8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL_WB_VDD_SEL_1P8_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL_WB_VDD_SEL_1P8_MASK)
PMU_BIAS_CTRL2 - PMU_BIAS_CTRL2_REGISTER
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_MD_MASK   (0x3FEU)
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_MD_SHIFT   (1U)
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_MD(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_MD_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_MD_MASK)
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_PWR_SW_EN_1P8_MASK   (0x1C00U)
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_PWR_SW_EN_1P8_SHIFT   (10U)
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_PWR_SW_EN_1P8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_WB_PWR_SW_EN_1P8_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_WB_PWR_SW_EN_1P8_MASK)
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_ADJ_1P8_MASK   (0x1FE000U)
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_ADJ_1P8_SHIFT   (13U)
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_ADJ_1P8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_WB_ADJ_1P8_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_WB_ADJ_1P8_MASK)
#define ANADIG_PMU_PMU_BIAS_CTRL2_RBB_SOC_CONTROL_MODE_MASK   (0x400000U)
#define ANADIG_PMU_PMU_BIAS_CTRL2_RBB_SOC_CONTROL_MODE_SHIFT   (22U)
#define ANADIG_PMU_PMU_BIAS_CTRL2_RBB_SOC_CONTROL_MODE(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_RBB_SOC_CONTROL_MODE_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_RBB_SOC_CONTROL_MODE_MASK)
#define ANADIG_PMU_PMU_BIAS_CTRL2_RBB_LPSR_CONTROL_MODE_MASK   (0x800000U)
#define ANADIG_PMU_PMU_BIAS_CTRL2_RBB_LPSR_CONTROL_MODE_SHIFT   (23U)
#define ANADIG_PMU_PMU_BIAS_CTRL2_RBB_LPSR_CONTROL_MODE(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_RBB_LPSR_CONTROL_MODE_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_RBB_LPSR_CONTROL_MODE_MASK)
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_EN_MASK   (0x1000000U)
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_EN_SHIFT   (24U)
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_EN(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_WB_EN_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_WB_EN_MASK)
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_DIG_OUT_MASK   (0x2000000U)
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_DIG_OUT_SHIFT   (25U)
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_DIG_OUT(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_DIG_OUT_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_DIG_OUT_MASK)
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_OK_MASK   (0x4000000U)
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_OK_SHIFT   (26U)
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_OK(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_WB_OK_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_WB_OK_MASK)
PMU_REF_CTRL - PMU_REF_CTRL_REGISTER
#define ANADIG_PMU_PMU_REF_CTRL_REF_AI_TOGGLE_MASK   (0x1U)
#define ANADIG_PMU_PMU_REF_CTRL_REF_AI_TOGGLE_SHIFT   (0U)
#define ANADIG_PMU_PMU_REF_CTRL_REF_AI_TOGGLE(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_REF_CTRL_REF_AI_TOGGLE_SHIFT)) & ANADIG_PMU_PMU_REF_CTRL_REF_AI_TOGGLE_MASK)
#define ANADIG_PMU_PMU_REF_CTRL_REF_AI_BUSY_MASK   (0x2U)
#define ANADIG_PMU_PMU_REF_CTRL_REF_AI_BUSY_SHIFT   (1U)
#define ANADIG_PMU_PMU_REF_CTRL_REF_AI_BUSY(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_REF_CTRL_REF_AI_BUSY_SHIFT)) & ANADIG_PMU_PMU_REF_CTRL_REF_AI_BUSY_MASK)
#define ANADIG_PMU_PMU_REF_CTRL_REF_ENABLE_MASK   (0x4U)
#define ANADIG_PMU_PMU_REF_CTRL_REF_ENABLE_SHIFT   (2U)
#define ANADIG_PMU_PMU_REF_CTRL_REF_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_REF_CTRL_REF_ENABLE_SHIFT)) & ANADIG_PMU_PMU_REF_CTRL_REF_ENABLE_MASK)
#define ANADIG_PMU_PMU_REF_CTRL_REF_CONTROL_MODE_MASK   (0x8U)
#define ANADIG_PMU_PMU_REF_CTRL_REF_CONTROL_MODE_SHIFT   (3U)
#define ANADIG_PMU_PMU_REF_CTRL_REF_CONTROL_MODE(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_REF_CTRL_REF_CONTROL_MODE_SHIFT)) & ANADIG_PMU_PMU_REF_CTRL_REF_CONTROL_MODE_MASK)
#define ANADIG_PMU_PMU_REF_CTRL_EN_PLL_VOL_REF_BUFFER_MASK   (0x10U)
#define ANADIG_PMU_PMU_REF_CTRL_EN_PLL_VOL_REF_BUFFER_SHIFT   (4U)
#define ANADIG_PMU_PMU_REF_CTRL_EN_PLL_VOL_REF_BUFFER(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_REF_CTRL_EN_PLL_VOL_REF_BUFFER_SHIFT)) & ANADIG_PMU_PMU_REF_CTRL_EN_PLL_VOL_REF_BUFFER_MASK)
PMU_POWER_DETECT_CTRL - PMU_POWER_DETECT_CTRL_REGISTER
#define ANADIG_PMU_PMU_POWER_DETECT_CTRL_CKGB_LPSR1P0_MASK   (0x100U)
#define ANADIG_PMU_PMU_POWER_DETECT_CTRL_CKGB_LPSR1P0_SHIFT   (8U)
#define ANADIG_PMU_PMU_POWER_DETECT_CTRL_CKGB_LPSR1P0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_POWER_DETECT_CTRL_CKGB_LPSR1P0_SHIFT)) & ANADIG_PMU_PMU_POWER_DETECT_CTRL_CKGB_LPSR1P0_MASK)
LDO_PLL_ENABLE_SP - LDO_PLL_ENABLE_SP_REGISTER
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT0_MASK)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT1_MASK)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT2_MASK   (0x4U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT   (2U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT2_MASK)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT3_MASK   (0x8U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT   (3U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT3_MASK)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT4_MASK   (0x10U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT   (4U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT4_MASK)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT5_MASK   (0x20U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT   (5U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT5_MASK)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT6_MASK   (0x40U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT   (6U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT6_MASK)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT7_MASK   (0x80U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT   (7U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT7_MASK)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT8_MASK   (0x100U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT   (8U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT8_MASK)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT9_MASK   (0x200U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT   (9U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT9_MASK)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT10_MASK   (0x400U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT   (10U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT10_MASK)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT11_MASK   (0x800U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT   (11U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT11_MASK)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT12_MASK   (0x1000U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT   (12U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT12_MASK)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT13_MASK   (0x2000U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT   (13U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT13_MASK)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT14_MASK   (0x4000U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT   (14U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT14_MASK)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT15_MASK   (0x8000U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT   (15U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT15_MASK)
LDO_LPSR_ANA_ENABLE_SP - LDO_LPSR_ANA_ENABLE_SP_REGISTER
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT0_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT1_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT2_MASK   (0x4U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT   (2U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT2_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT3_MASK   (0x8U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT   (3U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT3_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT4_MASK   (0x10U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT   (4U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT4_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT5_MASK   (0x20U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT   (5U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT5_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT6_MASK   (0x40U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT   (6U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT6_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT7_MASK   (0x80U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT   (7U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT7_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT8_MASK   (0x100U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT   (8U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT8_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT9_MASK   (0x200U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT   (9U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT9_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT10_MASK   (0x400U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT   (10U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT10_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT11_MASK   (0x800U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT   (11U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT11_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT12_MASK   (0x1000U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT   (12U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT12_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT13_MASK   (0x2000U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT   (13U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT13_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT14_MASK   (0x4000U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT   (14U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT14_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT15_MASK   (0x8000U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT   (15U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT15_MASK)
LDO_LPSR_ANA_LP_MODE_SP - LDO_LPSR_ANA_LP_MODE_SP_REGISTER
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT0_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT1_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT2_MASK   (0x4U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT2_SHIFT   (2U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT2_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT3_MASK   (0x8U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT3_SHIFT   (3U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT3_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT4_MASK   (0x10U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT4_SHIFT   (4U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT4_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT5_MASK   (0x20U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT5_SHIFT   (5U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT5_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT6_MASK   (0x40U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT6_SHIFT   (6U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT6_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT7_MASK   (0x80U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT7_SHIFT   (7U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT7_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT8_MASK   (0x100U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT8_SHIFT   (8U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT8_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT9_MASK   (0x200U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT9_SHIFT   (9U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT9_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT10_MASK   (0x400U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT10_SHIFT   (10U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT10_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT11_MASK   (0x800U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT11_SHIFT   (11U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT11_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT12_MASK   (0x1000U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT12_SHIFT   (12U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT12_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT13_MASK   (0x2000U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT13_SHIFT   (13U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT13_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT14_MASK   (0x4000U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT14_SHIFT   (14U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT14_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT15_MASK   (0x8000U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT15_SHIFT   (15U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT15_MASK)
LDO_LPSR_ANA_TRACKING_EN_SP - LDO_LPSR_ANA_TRACKING_EN_SP_REGISTER
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_MASK   (0x4U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_SHIFT   (2U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_MASK   (0x8U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_SHIFT   (3U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_MASK   (0x10U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_SHIFT   (4U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_MASK   (0x20U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_SHIFT   (5U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_MASK   (0x40U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_SHIFT   (6U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_MASK   (0x80U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_SHIFT   (7U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_MASK   (0x100U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_SHIFT   (8U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_MASK   (0x200U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_SHIFT   (9U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_MASK   (0x400U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_SHIFT   (10U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_MASK   (0x800U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_SHIFT   (11U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_MASK   (0x1000U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_SHIFT   (12U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_MASK   (0x2000U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_SHIFT   (13U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_MASK   (0x4000U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_SHIFT   (14U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_MASK   (0x8000U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_SHIFT   (15U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_MASK)
LDO_LPSR_ANA_BYPASS_EN_SP - LDO_LPSR_ANA_BYPASS_EN_SP_REGISTER
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_MASK   (0x4U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_SHIFT   (2U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_MASK   (0x8U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_SHIFT   (3U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_MASK   (0x10U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_SHIFT   (4U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_MASK   (0x20U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_SHIFT   (5U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_MASK   (0x40U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_SHIFT   (6U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_MASK   (0x80U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_SHIFT   (7U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_MASK   (0x100U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_SHIFT   (8U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_MASK   (0x200U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_SHIFT   (9U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_MASK   (0x400U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_SHIFT   (10U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_MASK   (0x800U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_SHIFT   (11U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_MASK   (0x1000U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_SHIFT   (12U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_MASK   (0x2000U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_SHIFT   (13U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_MASK   (0x4000U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_SHIFT   (14U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_MASK   (0x8000U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_SHIFT   (15U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_MASK)
LDO_LPSR_ANA_STBY_EN_SP - LDO_LPSR_ANA_STBY_EN_SP_REGISTER
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT0_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT1_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT2_MASK   (0x4U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT   (2U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT2_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT3_MASK   (0x8U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT   (3U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT3_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT4_MASK   (0x10U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT   (4U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT4_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT5_MASK   (0x20U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT   (5U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT5_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT6_MASK   (0x40U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT   (6U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT6_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT7_MASK   (0x80U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT   (7U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT7_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT8_MASK   (0x100U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT   (8U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT8_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT9_MASK   (0x200U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT   (9U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT9_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT10_MASK   (0x400U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT   (10U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT10_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT11_MASK   (0x800U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT   (11U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT11_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT12_MASK   (0x1000U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT   (12U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT12_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT13_MASK   (0x2000U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT   (13U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT13_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT14_MASK   (0x4000U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT   (14U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT14_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT15_MASK   (0x8000U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT   (15U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT15_MASK)
LDO_LPSR_DIG_ENABLE_SP - LDO_LPSR_DIG_ENABLE_SP_REGISTER
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT0_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT1_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT2_MASK   (0x4U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT   (2U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT2_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT3_MASK   (0x8U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT   (3U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT3_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT4_MASK   (0x10U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT   (4U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT4_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT5_MASK   (0x20U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT   (5U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT5_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT6_MASK   (0x40U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT   (6U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT6_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT7_MASK   (0x80U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT   (7U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT7_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT8_MASK   (0x100U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT   (8U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT8_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT9_MASK   (0x200U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT   (9U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT9_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT10_MASK   (0x400U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT   (10U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT10_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT11_MASK   (0x800U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT   (11U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT11_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT12_MASK   (0x1000U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT   (12U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT12_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT13_MASK   (0x2000U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT   (13U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT13_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT14_MASK   (0x4000U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT   (14U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT14_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT15_MASK   (0x8000U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT   (15U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT15_MASK)
LDO_LPSR_DIG_TRG_SP0 - LDO_LPSR_DIG_TRG_SP0_REGISTER
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT0_MASK   (0xFFU)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT0_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT1_MASK   (0xFF00U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT1_SHIFT   (8U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT1_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT2_MASK   (0xFF0000U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT2_SHIFT   (16U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT2_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT3_MASK   (0xFF000000U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT3_SHIFT   (24U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT3_MASK)
LDO_LPSR_DIG_TRG_SP1 - LDO_LPSR_DIG_TRG_SP1_REGISTER
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT4_MASK   (0xFFU)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT4_SHIFT   (0U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT4_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT5_MASK   (0xFF00U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT5_SHIFT   (8U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT5_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT6_MASK   (0xFF0000U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT6_SHIFT   (16U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT6_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT7_MASK   (0xFF000000U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT7_SHIFT   (24U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT7_MASK)
LDO_LPSR_DIG_TRG_SP2 - LDO_LPSR_DIG_TRG_SP2_REGISTER
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT8_MASK   (0xFFU)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT8_SHIFT   (0U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT8_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT9_MASK   (0xFF00U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT9_SHIFT   (8U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT9_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT10_MASK   (0xFF0000U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT10_SHIFT   (16U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT10_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT11_MASK   (0xFF000000U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT11_SHIFT   (24U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT11_MASK)
LDO_LPSR_DIG_TRG_SP3 - LDO_LPSR_DIG_TRG_SP3_REGISTER
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT12_MASK   (0xFFU)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT12_SHIFT   (0U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT12_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT13_MASK   (0xFF00U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT13_SHIFT   (8U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT13_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT14_MASK   (0xFF0000U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT14_SHIFT   (16U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT14_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT15_MASK   (0xFF000000U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT15_SHIFT   (24U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT15_MASK)
LDO_LPSR_DIG_LP_MODE_SP - LDO_LPSR_DIG_LP_MODE_SP_REGISTER
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT0_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT1_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT2_MASK   (0x4U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT2_SHIFT   (2U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT2_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT3_MASK   (0x8U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT3_SHIFT   (3U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT3_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT4_MASK   (0x10U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT4_SHIFT   (4U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT4_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT5_MASK   (0x20U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT5_SHIFT   (5U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT5_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT6_MASK   (0x40U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT6_SHIFT   (6U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT6_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT7_MASK   (0x80U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT7_SHIFT   (7U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT7_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT8_MASK   (0x100U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT8_SHIFT   (8U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT8_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT9_MASK   (0x200U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT9_SHIFT   (9U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT9_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT10_MASK   (0x400U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT10_SHIFT   (10U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT10_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT11_MASK   (0x800U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT11_SHIFT   (11U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT11_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT12_MASK   (0x1000U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT12_SHIFT   (12U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT12_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT13_MASK   (0x2000U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT13_SHIFT   (13U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT13_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT14_MASK   (0x4000U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT14_SHIFT   (14U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT14_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT15_MASK   (0x8000U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT15_SHIFT   (15U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT15_MASK)
LDO_LPSR_DIG_TRACKING_EN_SP - LDO_LPSR_DIG_TRACKING_EN_SP_REGISTER
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_MASK   (0x4U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_SHIFT   (2U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_MASK   (0x8U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_SHIFT   (3U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_MASK   (0x10U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_SHIFT   (4U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_MASK   (0x20U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_SHIFT   (5U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_MASK   (0x40U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_SHIFT   (6U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_MASK   (0x80U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_SHIFT   (7U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_MASK   (0x100U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_SHIFT   (8U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_MASK   (0x200U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_SHIFT   (9U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_MASK   (0x400U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_SHIFT   (10U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_MASK   (0x800U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_SHIFT   (11U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_MASK   (0x1000U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_SHIFT   (12U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_MASK   (0x2000U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_SHIFT   (13U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_MASK   (0x4000U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_SHIFT   (14U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_MASK   (0x8000U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_SHIFT   (15U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_MASK)
LDO_LPSR_DIG_BYPASS_EN_SP - LDO_LPSR_DIG_BYPASS_EN_SP_REGISTER
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_MASK   (0x4U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_SHIFT   (2U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_MASK   (0x8U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_SHIFT   (3U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_MASK   (0x10U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_SHIFT   (4U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_MASK   (0x20U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_SHIFT   (5U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_MASK   (0x40U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_SHIFT   (6U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_MASK   (0x80U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_SHIFT   (7U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_MASK   (0x100U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_SHIFT   (8U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_MASK   (0x200U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_SHIFT   (9U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_MASK   (0x400U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_SHIFT   (10U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_MASK   (0x800U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_SHIFT   (11U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_MASK   (0x1000U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_SHIFT   (12U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_MASK   (0x2000U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_SHIFT   (13U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_MASK   (0x4000U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_SHIFT   (14U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_MASK   (0x8000U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_SHIFT   (15U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_MASK)
LDO_LPSR_DIG_STBY_EN_SP - LDO_LPSR_DIG_STBY_EN_SP_REGISTER
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT0_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT1_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT2_MASK   (0x4U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT   (2U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT2_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT3_MASK   (0x8U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT   (3U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT3_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT4_MASK   (0x10U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT   (4U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT4_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT5_MASK   (0x20U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT   (5U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT5_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT6_MASK   (0x40U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT   (6U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT6_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT7_MASK   (0x80U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT   (7U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT7_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT8_MASK   (0x100U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT   (8U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT8_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT9_MASK   (0x200U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT   (9U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT9_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT10_MASK   (0x400U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT   (10U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT10_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT11_MASK   (0x800U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT   (11U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT11_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT12_MASK   (0x1000U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT   (12U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT12_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT13_MASK   (0x2000U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT   (13U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT13_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT14_MASK   (0x4000U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT   (14U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT14_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT15_MASK   (0x8000U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT   (15U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT15_MASK)
BANDGAP_ENABLE_SP - BANDGAP_ENABLE_SP_REGISTER
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT0_MASK)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT1_MASK)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT2_MASK   (0x4U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT   (2U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT2_MASK)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT3_MASK   (0x8U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT   (3U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT3_MASK)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT4_MASK   (0x10U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT   (4U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT4_MASK)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT5_MASK   (0x20U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT   (5U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT5_MASK)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT6_MASK   (0x40U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT   (6U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT6_MASK)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT7_MASK   (0x80U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT   (7U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT7_MASK)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT8_MASK   (0x100U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT   (8U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT8_MASK)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT9_MASK   (0x200U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT   (9U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT9_MASK)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT10_MASK   (0x400U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT   (10U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT10_MASK)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT11_MASK   (0x800U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT   (11U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT11_MASK)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT12_MASK   (0x1000U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT   (12U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT12_MASK)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT13_MASK   (0x2000U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT   (13U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT13_MASK)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT14_MASK   (0x4000U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT   (14U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT14_MASK)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT15_MASK   (0x8000U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT   (15U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT15_MASK)
RBB_SOC_ENABLE_SP - RBB_SOC_ENABLE_SP_REGISTER
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT0_MASK)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT1_MASK)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT2_MASK   (0x4U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT   (2U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT2_MASK)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT3_MASK   (0x8U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT   (3U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT3_MASK)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT4_MASK   (0x10U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT   (4U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT4_MASK)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT5_MASK   (0x20U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT   (5U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT5_MASK)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT6_MASK   (0x40U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT   (6U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT6_MASK)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT7_MASK   (0x80U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT   (7U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT7_MASK)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT8_MASK   (0x100U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT   (8U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT8_MASK)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT9_MASK   (0x200U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT   (9U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT9_MASK)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT10_MASK   (0x400U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT   (10U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT10_MASK)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT11_MASK   (0x800U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT   (11U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT11_MASK)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT12_MASK   (0x1000U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT   (12U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT12_MASK)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT13_MASK   (0x2000U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT   (13U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT13_MASK)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT14_MASK   (0x4000U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT   (14U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT14_MASK)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT15_MASK   (0x8000U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT   (15U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT15_MASK)
RBB_LPSR_ENABLE_SP - RBB_LPSR_ENABLE_SP_REGISTER
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT0_MASK)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT1_MASK)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT2_MASK   (0x4U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT   (2U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT2_MASK)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT3_MASK   (0x8U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT   (3U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT3_MASK)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT4_MASK   (0x10U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT   (4U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT4_MASK)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT5_MASK   (0x20U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT   (5U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT5_MASK)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT6_MASK   (0x40U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT   (6U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT6_MASK)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT7_MASK   (0x80U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT   (7U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT7_MASK)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT8_MASK   (0x100U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT   (8U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT8_MASK)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT9_MASK   (0x200U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT   (9U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT9_MASK)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT10_MASK   (0x400U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT   (10U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT10_MASK)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT11_MASK   (0x800U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT   (11U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT11_MASK)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT12_MASK   (0x1000U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT   (12U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT12_MASK)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT13_MASK   (0x2000U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT   (13U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT13_MASK)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT14_MASK   (0x4000U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT   (14U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT14_MASK)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT15_MASK   (0x8000U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT   (15U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT15_MASK)
BANDGAP_STBY_EN_SP - BANDGAP_STBY_EN_SP_REGISTER
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT0_MASK)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT1_MASK)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT2_MASK   (0x4U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT   (2U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT2_MASK)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT3_MASK   (0x8U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT   (3U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT3_MASK)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT4_MASK   (0x10U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT   (4U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT4_MASK)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT5_MASK   (0x20U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT   (5U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT5_MASK)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT6_MASK   (0x40U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT   (6U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT6_MASK)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT7_MASK   (0x80U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT   (7U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT7_MASK)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT8_MASK   (0x100U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT   (8U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT8_MASK)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT9_MASK   (0x200U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT   (9U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT9_MASK)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT10_MASK   (0x400U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT   (10U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT10_MASK)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT11_MASK   (0x800U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT   (11U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT11_MASK)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT12_MASK   (0x1000U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT   (12U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT12_MASK)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT13_MASK   (0x2000U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT   (13U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT13_MASK)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT14_MASK   (0x4000U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT   (14U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT14_MASK)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT15_MASK   (0x8000U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT   (15U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT15_MASK)
PLL_LDO_STBY_EN_SP - PLL_LDO_STBY_EN_SP_REGISTER
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT0_MASK)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT1_MASK)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT2_MASK   (0x4U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT   (2U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT2_MASK)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT3_MASK   (0x8U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT   (3U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT3_MASK)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT4_MASK   (0x10U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT   (4U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT4_MASK)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT5_MASK   (0x20U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT   (5U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT5_MASK)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT6_MASK   (0x40U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT   (6U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT6_MASK)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT7_MASK   (0x80U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT   (7U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT7_MASK)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT8_MASK   (0x100U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT   (8U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT8_MASK)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT9_MASK   (0x200U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT   (9U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT9_MASK)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT10_MASK   (0x400U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT   (10U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT10_MASK)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT11_MASK   (0x800U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT   (11U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT11_MASK)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT12_MASK   (0x1000U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT   (12U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT12_MASK)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT13_MASK   (0x2000U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT   (13U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT13_MASK)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT14_MASK   (0x4000U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT   (14U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT14_MASK)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT15_MASK   (0x8000U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT   (15U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT15_MASK)
RBB_SOC_STBY_EN_SP - RBB_SOC_STBY_EN_SP_REGISTER
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT0_MASK)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT1_MASK)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT2_MASK   (0x4U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT   (2U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT2_MASK)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT3_MASK   (0x8U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT   (3U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT3_MASK)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT4_MASK   (0x10U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT   (4U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT4_MASK)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT5_MASK   (0x20U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT   (5U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT5_MASK)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT6_MASK   (0x40U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT   (6U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT6_MASK)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT7_MASK   (0x80U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT   (7U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT7_MASK)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT8_MASK   (0x100U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT   (8U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT8_MASK)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT9_MASK   (0x200U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT   (9U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT9_MASK)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT10_MASK   (0x400U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT   (10U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT10_MASK)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT11_MASK   (0x800U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT   (11U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT11_MASK)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT12_MASK   (0x1000U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT   (12U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT12_MASK)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT13_MASK   (0x2000U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT   (13U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT13_MASK)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT14_MASK   (0x4000U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT   (14U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT14_MASK)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT15_MASK   (0x8000U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT   (15U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT15_MASK)
RBB_LPSR_STBY_EN_SP - RBB_LPSR_STBY_EN_SP_REGISTER
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT0_MASK)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT1_MASK)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT2_MASK   (0x4U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT   (2U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT2_MASK)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT3_MASK   (0x8U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT   (3U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT3_MASK)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT4_MASK   (0x10U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT   (4U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT4_MASK)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT5_MASK   (0x20U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT   (5U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT5_MASK)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT6_MASK   (0x40U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT   (6U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT6_MASK)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT7_MASK   (0x80U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT   (7U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT7_MASK)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT8_MASK   (0x100U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT   (8U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT8_MASK)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT9_MASK   (0x200U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT   (9U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT9_MASK)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT10_MASK   (0x400U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT   (10U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT10_MASK)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT11_MASK   (0x800U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT   (11U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT11_MASK)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT12_MASK   (0x1000U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT   (12U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT12_MASK)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT13_MASK   (0x2000U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT   (13U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT13_MASK)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT14_MASK   (0x4000U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT   (14U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT14_MASK)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT15_MASK   (0x8000U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT   (15U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT15_MASK)
RBB_LPSR_CONFIGURE - RBB_LPSR_CONFIGURE_REGISTER
#define ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_PW_MASK   (0xFU)
#define ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_PW_SHIFT   (0U)
#define ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_PW(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_PW_SHIFT)) & ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_PW_MASK)
#define ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_NW_MASK   (0xF0U)
#define ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_NW_SHIFT   (4U)
#define ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_NW(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_NW_SHIFT)) & ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_NW_MASK)
#define ANADIG_PMU_RBB_LPSR_CONFIGURE_OSCILLATOR_BITS_MASK   (0x700U)
#define ANADIG_PMU_RBB_LPSR_CONFIGURE_OSCILLATOR_BITS_SHIFT   (8U)
#define ANADIG_PMU_RBB_LPSR_CONFIGURE_OSCILLATOR_BITS(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_CONFIGURE_OSCILLATOR_BITS_SHIFT)) & ANADIG_PMU_RBB_LPSR_CONFIGURE_OSCILLATOR_BITS_MASK)
#define ANADIG_PMU_RBB_LPSR_CONFIGURE_REGULATOR_STRENGTH_MASK   (0x3800U)
#define ANADIG_PMU_RBB_LPSR_CONFIGURE_REGULATOR_STRENGTH_SHIFT   (11U)
#define ANADIG_PMU_RBB_LPSR_CONFIGURE_REGULATOR_STRENGTH(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_CONFIGURE_REGULATOR_STRENGTH_SHIFT)) & ANADIG_PMU_RBB_LPSR_CONFIGURE_REGULATOR_STRENGTH_MASK)
RBB_SOC_CONFIGURE - RBB_SOC_CONFIGURE_REGISTER
#define ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_PW_MASK   (0xFU)
#define ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_PW_SHIFT   (0U)
#define ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_PW(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_PW_SHIFT)) & ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_PW_MASK)
#define ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_NW_MASK   (0xF0U)
#define ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_NW_SHIFT   (4U)
#define ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_NW(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_NW_SHIFT)) & ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_NW_MASK)
#define ANADIG_PMU_RBB_SOC_CONFIGURE_OSCILLATOR_BITS_MASK   (0x700U)
#define ANADIG_PMU_RBB_SOC_CONFIGURE_OSCILLATOR_BITS_SHIFT   (8U)
#define ANADIG_PMU_RBB_SOC_CONFIGURE_OSCILLATOR_BITS(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_CONFIGURE_OSCILLATOR_BITS_SHIFT)) & ANADIG_PMU_RBB_SOC_CONFIGURE_OSCILLATOR_BITS_MASK)
#define ANADIG_PMU_RBB_SOC_CONFIGURE_REGULATOR_STRENGTH_MASK   (0x3800U)
#define ANADIG_PMU_RBB_SOC_CONFIGURE_REGULATOR_STRENGTH_SHIFT   (11U)
#define ANADIG_PMU_RBB_SOC_CONFIGURE_REGULATOR_STRENGTH(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_CONFIGURE_REGULATOR_STRENGTH_SHIFT)) & ANADIG_PMU_RBB_SOC_CONFIGURE_REGULATOR_STRENGTH_MASK)
REFTOP_OTP_TRIM_VALUE - REFTOP_OTP_TRIM_VALUE_REGISTER
#define ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_IBZTCADJ_MASK   (0x7U)
#define ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_IBZTCADJ_SHIFT   (0U)
#define ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_IBZTCADJ(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_IBZTCADJ_SHIFT)) & ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_IBZTCADJ_MASK)
#define ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_VBGADJ_MASK   (0x38U)
#define ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_VBGADJ_SHIFT   (3U)
#define ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_VBGADJ(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_VBGADJ_SHIFT)) & ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_VBGADJ_MASK)
#define ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_TRIM_EN_MASK   (0x40U)
#define ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_TRIM_EN_SHIFT   (6U)
#define ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_TRIM_EN(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_TRIM_EN_SHIFT)) & ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_TRIM_EN_MASK)
LPSR_1P8_LDO_OTP_TRIM_VALUE - LPSR_1P8_LDO_OTP_TRIM_VALUE_REGISTER
#define ANADIG_PMU_LPSR_1P8_LDO_OTP_TRIM_VALUE_LPSR_LDO_1P8_TRIM_MASK   (0x3U)
#define ANADIG_PMU_LPSR_1P8_LDO_OTP_TRIM_VALUE_LPSR_LDO_1P8_TRIM_SHIFT   (0U)
#define ANADIG_PMU_LPSR_1P8_LDO_OTP_TRIM_VALUE_LPSR_LDO_1P8_TRIM(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LPSR_1P8_LDO_OTP_TRIM_VALUE_LPSR_LDO_1P8_TRIM_SHIFT)) & ANADIG_PMU_LPSR_1P8_LDO_OTP_TRIM_VALUE_LPSR_LDO_1P8_TRIM_MASK)
#define ANADIG_PMU_LPSR_1P8_LDO_OTP_TRIM_VALUE_LPSR_LDO_1P8_TRIM_EN_MASK   (0x4U)
#define ANADIG_PMU_LPSR_1P8_LDO_OTP_TRIM_VALUE_LPSR_LDO_1P8_TRIM_EN_SHIFT   (2U)
#define ANADIG_PMU_LPSR_1P8_LDO_OTP_TRIM_VALUE_LPSR_LDO_1P8_TRIM_EN(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LPSR_1P8_LDO_OTP_TRIM_VALUE_LPSR_LDO_1P8_TRIM_EN_SHIFT)) & ANADIG_PMU_LPSR_1P8_LDO_OTP_TRIM_VALUE_LPSR_LDO_1P8_TRIM_EN_MASK)
PMU_LDO_PLL - PMU_LDO_PLL_REGISTER
#define ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_ENABLE_MASK   (0x1U)
#define ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_ENABLE_SHIFT   (0U)
#define ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_ENABLE_SHIFT)) & ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_ENABLE_MASK)
#define ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_CONTROL_MODE_MASK   (0x2U)
#define ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_CONTROL_MODE_SHIFT   (1U)
#define ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_CONTROL_MODE(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_CONTROL_MODE_SHIFT)) & ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_CONTROL_MODE_MASK)
#define ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_TOGGLE_MASK   (0x10000U)
#define ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_TOGGLE_SHIFT   (16U)
#define ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_TOGGLE(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_TOGGLE_SHIFT)) & ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_TOGGLE_MASK)
#define ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_BUSY_MASK   (0x40000000U)
#define ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_BUSY_SHIFT   (30U)
#define ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_BUSY(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_BUSY_SHIFT)) & ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_BUSY_MASK)
PMU_BIAS_CTRL - PMU_BIAS_CTRL_REGISTER
#define ANADIG_PMU_PMU_BIAS_CTRL_WB_CFG_1P8_MASK   (0x1FFFU)
#define ANADIG_PMU_PMU_BIAS_CTRL_WB_CFG_1P8_SHIFT   (0U)
#define ANADIG_PMU_PMU_BIAS_CTRL_WB_CFG_1P8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL_WB_CFG_1P8_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL_WB_CFG_1P8_MASK)
#define ANADIG_PMU_PMU_BIAS_CTRL_WB_VDD_SEL_1P8_MASK   (0x4000U)
#define ANADIG_PMU_PMU_BIAS_CTRL_WB_VDD_SEL_1P8_SHIFT   (14U)
#define ANADIG_PMU_PMU_BIAS_CTRL_WB_VDD_SEL_1P8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL_WB_VDD_SEL_1P8_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL_WB_VDD_SEL_1P8_MASK)
PMU_BIAS_CTRL2 - PMU_BIAS_CTRL2_REGISTER
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_MD_MASK   (0x3FEU)
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_MD_SHIFT   (1U)
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_MD(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_MD_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_MD_MASK)
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_PWR_SW_EN_1P8_MASK   (0x1C00U)
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_PWR_SW_EN_1P8_SHIFT   (10U)
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_PWR_SW_EN_1P8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_WB_PWR_SW_EN_1P8_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_WB_PWR_SW_EN_1P8_MASK)
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_ADJ_1P8_MASK   (0x1FE000U)
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_ADJ_1P8_SHIFT   (13U)
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_ADJ_1P8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_WB_ADJ_1P8_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_WB_ADJ_1P8_MASK)
#define ANADIG_PMU_PMU_BIAS_CTRL2_RBB_SOC_CONTROL_MODE_MASK   (0x400000U)
#define ANADIG_PMU_PMU_BIAS_CTRL2_RBB_SOC_CONTROL_MODE_SHIFT   (22U)
#define ANADIG_PMU_PMU_BIAS_CTRL2_RBB_SOC_CONTROL_MODE(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_RBB_SOC_CONTROL_MODE_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_RBB_SOC_CONTROL_MODE_MASK)
#define ANADIG_PMU_PMU_BIAS_CTRL2_RBB_LPSR_CONTROL_MODE_MASK   (0x800000U)
#define ANADIG_PMU_PMU_BIAS_CTRL2_RBB_LPSR_CONTROL_MODE_SHIFT   (23U)
#define ANADIG_PMU_PMU_BIAS_CTRL2_RBB_LPSR_CONTROL_MODE(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_RBB_LPSR_CONTROL_MODE_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_RBB_LPSR_CONTROL_MODE_MASK)
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_EN_MASK   (0x1000000U)
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_EN_SHIFT   (24U)
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_EN(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_WB_EN_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_WB_EN_MASK)
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_DIG_OUT_MASK   (0x2000000U)
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_DIG_OUT_SHIFT   (25U)
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_DIG_OUT(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_DIG_OUT_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_DIG_OUT_MASK)
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_OK_MASK   (0x4000000U)
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_OK_SHIFT   (26U)
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_OK(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_WB_OK_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_WB_OK_MASK)
PMU_REF_CTRL - PMU_REF_CTRL_REGISTER
#define ANADIG_PMU_PMU_REF_CTRL_REF_AI_TOGGLE_MASK   (0x1U)
#define ANADIG_PMU_PMU_REF_CTRL_REF_AI_TOGGLE_SHIFT   (0U)
#define ANADIG_PMU_PMU_REF_CTRL_REF_AI_TOGGLE(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_REF_CTRL_REF_AI_TOGGLE_SHIFT)) & ANADIG_PMU_PMU_REF_CTRL_REF_AI_TOGGLE_MASK)
#define ANADIG_PMU_PMU_REF_CTRL_REF_AI_BUSY_MASK   (0x2U)
#define ANADIG_PMU_PMU_REF_CTRL_REF_AI_BUSY_SHIFT   (1U)
#define ANADIG_PMU_PMU_REF_CTRL_REF_AI_BUSY(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_REF_CTRL_REF_AI_BUSY_SHIFT)) & ANADIG_PMU_PMU_REF_CTRL_REF_AI_BUSY_MASK)
#define ANADIG_PMU_PMU_REF_CTRL_REF_ENABLE_MASK   (0x4U)
#define ANADIG_PMU_PMU_REF_CTRL_REF_ENABLE_SHIFT   (2U)
#define ANADIG_PMU_PMU_REF_CTRL_REF_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_REF_CTRL_REF_ENABLE_SHIFT)) & ANADIG_PMU_PMU_REF_CTRL_REF_ENABLE_MASK)
#define ANADIG_PMU_PMU_REF_CTRL_REF_CONTROL_MODE_MASK   (0x8U)
#define ANADIG_PMU_PMU_REF_CTRL_REF_CONTROL_MODE_SHIFT   (3U)
#define ANADIG_PMU_PMU_REF_CTRL_REF_CONTROL_MODE(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_REF_CTRL_REF_CONTROL_MODE_SHIFT)) & ANADIG_PMU_PMU_REF_CTRL_REF_CONTROL_MODE_MASK)
#define ANADIG_PMU_PMU_REF_CTRL_EN_PLL_VOL_REF_BUFFER_MASK   (0x10U)
#define ANADIG_PMU_PMU_REF_CTRL_EN_PLL_VOL_REF_BUFFER_SHIFT   (4U)
#define ANADIG_PMU_PMU_REF_CTRL_EN_PLL_VOL_REF_BUFFER(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_REF_CTRL_EN_PLL_VOL_REF_BUFFER_SHIFT)) & ANADIG_PMU_PMU_REF_CTRL_EN_PLL_VOL_REF_BUFFER_MASK)
PMU_POWER_DETECT_CTRL - PMU_POWER_DETECT_CTRL_REGISTER
#define ANADIG_PMU_PMU_POWER_DETECT_CTRL_CKGB_LPSR1P0_MASK   (0x100U)
#define ANADIG_PMU_PMU_POWER_DETECT_CTRL_CKGB_LPSR1P0_SHIFT   (8U)
#define ANADIG_PMU_PMU_POWER_DETECT_CTRL_CKGB_LPSR1P0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_POWER_DETECT_CTRL_CKGB_LPSR1P0_SHIFT)) & ANADIG_PMU_PMU_POWER_DETECT_CTRL_CKGB_LPSR1P0_MASK)
LDO_PLL_ENABLE_SP - LDO_PLL_ENABLE_SP_REGISTER
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT0_MASK)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT1_MASK)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT2_MASK   (0x4U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT   (2U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT2_MASK)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT3_MASK   (0x8U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT   (3U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT3_MASK)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT4_MASK   (0x10U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT   (4U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT4_MASK)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT5_MASK   (0x20U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT   (5U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT5_MASK)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT6_MASK   (0x40U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT   (6U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT6_MASK)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT7_MASK   (0x80U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT   (7U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT7_MASK)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT8_MASK   (0x100U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT   (8U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT8_MASK)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT9_MASK   (0x200U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT   (9U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT9_MASK)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT10_MASK   (0x400U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT   (10U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT10_MASK)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT11_MASK   (0x800U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT   (11U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT11_MASK)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT12_MASK   (0x1000U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT   (12U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT12_MASK)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT13_MASK   (0x2000U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT   (13U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT13_MASK)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT14_MASK   (0x4000U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT   (14U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT14_MASK)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT15_MASK   (0x8000U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT   (15U)
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT15_MASK)
LDO_LPSR_ANA_ENABLE_SP - LDO_LPSR_ANA_ENABLE_SP_REGISTER
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT0_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT1_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT2_MASK   (0x4U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT   (2U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT2_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT3_MASK   (0x8U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT   (3U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT3_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT4_MASK   (0x10U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT   (4U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT4_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT5_MASK   (0x20U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT   (5U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT5_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT6_MASK   (0x40U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT   (6U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT6_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT7_MASK   (0x80U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT   (7U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT7_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT8_MASK   (0x100U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT   (8U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT8_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT9_MASK   (0x200U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT   (9U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT9_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT10_MASK   (0x400U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT   (10U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT10_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT11_MASK   (0x800U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT   (11U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT11_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT12_MASK   (0x1000U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT   (12U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT12_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT13_MASK   (0x2000U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT   (13U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT13_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT14_MASK   (0x4000U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT   (14U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT14_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT15_MASK   (0x8000U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT   (15U)
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT15_MASK)
LDO_LPSR_ANA_LP_MODE_SP - LDO_LPSR_ANA_LP_MODE_SP_REGISTER
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT0_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT1_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT2_MASK   (0x4U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT2_SHIFT   (2U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT2_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT3_MASK   (0x8U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT3_SHIFT   (3U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT3_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT4_MASK   (0x10U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT4_SHIFT   (4U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT4_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT5_MASK   (0x20U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT5_SHIFT   (5U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT5_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT6_MASK   (0x40U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT6_SHIFT   (6U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT6_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT7_MASK   (0x80U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT7_SHIFT   (7U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT7_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT8_MASK   (0x100U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT8_SHIFT   (8U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT8_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT9_MASK   (0x200U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT9_SHIFT   (9U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT9_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT10_MASK   (0x400U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT10_SHIFT   (10U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT10_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT11_MASK   (0x800U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT11_SHIFT   (11U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT11_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT12_MASK   (0x1000U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT12_SHIFT   (12U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT12_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT13_MASK   (0x2000U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT13_SHIFT   (13U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT13_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT14_MASK   (0x4000U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT14_SHIFT   (14U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT14_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT15_MASK   (0x8000U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT15_SHIFT   (15U)
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT15_MASK)
LDO_LPSR_ANA_TRACKING_EN_SP - LDO_LPSR_ANA_TRACKING_EN_SP_REGISTER
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_MASK   (0x4U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_SHIFT   (2U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_MASK   (0x8U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_SHIFT   (3U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_MASK   (0x10U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_SHIFT   (4U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_MASK   (0x20U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_SHIFT   (5U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_MASK   (0x40U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_SHIFT   (6U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_MASK   (0x80U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_SHIFT   (7U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_MASK   (0x100U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_SHIFT   (8U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_MASK   (0x200U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_SHIFT   (9U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_MASK   (0x400U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_SHIFT   (10U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_MASK   (0x800U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_SHIFT   (11U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_MASK   (0x1000U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_SHIFT   (12U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_MASK   (0x2000U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_SHIFT   (13U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_MASK   (0x4000U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_SHIFT   (14U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_MASK   (0x8000U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_SHIFT   (15U)
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_MASK)
LDO_LPSR_ANA_BYPASS_EN_SP - LDO_LPSR_ANA_BYPASS_EN_SP_REGISTER
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_MASK   (0x4U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_SHIFT   (2U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_MASK   (0x8U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_SHIFT   (3U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_MASK   (0x10U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_SHIFT   (4U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_MASK   (0x20U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_SHIFT   (5U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_MASK   (0x40U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_SHIFT   (6U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_MASK   (0x80U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_SHIFT   (7U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_MASK   (0x100U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_SHIFT   (8U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_MASK   (0x200U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_SHIFT   (9U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_MASK   (0x400U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_SHIFT   (10U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_MASK   (0x800U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_SHIFT   (11U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_MASK   (0x1000U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_SHIFT   (12U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_MASK   (0x2000U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_SHIFT   (13U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_MASK   (0x4000U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_SHIFT   (14U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_MASK   (0x8000U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_SHIFT   (15U)
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_MASK)
LDO_LPSR_ANA_STBY_EN_SP - LDO_LPSR_ANA_STBY_EN_SP_REGISTER
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT0_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT1_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT2_MASK   (0x4U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT   (2U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT2_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT3_MASK   (0x8U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT   (3U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT3_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT4_MASK   (0x10U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT   (4U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT4_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT5_MASK   (0x20U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT   (5U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT5_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT6_MASK   (0x40U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT   (6U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT6_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT7_MASK   (0x80U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT   (7U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT7_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT8_MASK   (0x100U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT   (8U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT8_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT9_MASK   (0x200U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT   (9U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT9_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT10_MASK   (0x400U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT   (10U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT10_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT11_MASK   (0x800U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT   (11U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT11_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT12_MASK   (0x1000U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT   (12U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT12_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT13_MASK   (0x2000U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT   (13U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT13_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT14_MASK   (0x4000U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT   (14U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT14_MASK)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT15_MASK   (0x8000U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT   (15U)
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT15_MASK)
LDO_LPSR_DIG_ENABLE_SP - LDO_LPSR_DIG_ENABLE_SP_REGISTER
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT0_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT1_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT2_MASK   (0x4U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT   (2U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT2_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT3_MASK   (0x8U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT   (3U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT3_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT4_MASK   (0x10U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT   (4U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT4_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT5_MASK   (0x20U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT   (5U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT5_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT6_MASK   (0x40U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT   (6U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT6_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT7_MASK   (0x80U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT   (7U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT7_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT8_MASK   (0x100U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT   (8U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT8_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT9_MASK   (0x200U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT   (9U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT9_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT10_MASK   (0x400U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT   (10U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT10_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT11_MASK   (0x800U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT   (11U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT11_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT12_MASK   (0x1000U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT   (12U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT12_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT13_MASK   (0x2000U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT   (13U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT13_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT14_MASK   (0x4000U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT   (14U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT14_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT15_MASK   (0x8000U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT   (15U)
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT15_MASK)
LDO_LPSR_DIG_TRG_SP0 - LDO_LPSR_DIG_TRG_SP0_REGISTER
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT0_MASK   (0xFFU)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT0_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT1_MASK   (0xFF00U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT1_SHIFT   (8U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT1_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT2_MASK   (0xFF0000U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT2_SHIFT   (16U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT2_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT3_MASK   (0xFF000000U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT3_SHIFT   (24U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT3_MASK)
LDO_LPSR_DIG_TRG_SP1 - LDO_LPSR_DIG_TRG_SP1_REGISTER
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT4_MASK   (0xFFU)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT4_SHIFT   (0U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT4_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT5_MASK   (0xFF00U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT5_SHIFT   (8U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT5_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT6_MASK   (0xFF0000U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT6_SHIFT   (16U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT6_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT7_MASK   (0xFF000000U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT7_SHIFT   (24U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT7_MASK)
LDO_LPSR_DIG_TRG_SP2 - LDO_LPSR_DIG_TRG_SP2_REGISTER
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT8_MASK   (0xFFU)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT8_SHIFT   (0U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT8_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT9_MASK   (0xFF00U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT9_SHIFT   (8U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT9_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT10_MASK   (0xFF0000U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT10_SHIFT   (16U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT10_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT11_MASK   (0xFF000000U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT11_SHIFT   (24U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT11_MASK)
LDO_LPSR_DIG_TRG_SP3 - LDO_LPSR_DIG_TRG_SP3_REGISTER
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT12_MASK   (0xFFU)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT12_SHIFT   (0U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT12_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT13_MASK   (0xFF00U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT13_SHIFT   (8U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT13_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT14_MASK   (0xFF0000U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT14_SHIFT   (16U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT14_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT15_MASK   (0xFF000000U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT15_SHIFT   (24U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT15_MASK)
LDO_LPSR_DIG_LP_MODE_SP - LDO_LPSR_DIG_LP_MODE_SP_REGISTER
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT0_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT1_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT2_MASK   (0x4U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT2_SHIFT   (2U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT2_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT3_MASK   (0x8U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT3_SHIFT   (3U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT3_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT4_MASK   (0x10U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT4_SHIFT   (4U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT4_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT5_MASK   (0x20U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT5_SHIFT   (5U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT5_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT6_MASK   (0x40U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT6_SHIFT   (6U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT6_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT7_MASK   (0x80U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT7_SHIFT   (7U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT7_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT8_MASK   (0x100U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT8_SHIFT   (8U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT8_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT9_MASK   (0x200U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT9_SHIFT   (9U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT9_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT10_MASK   (0x400U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT10_SHIFT   (10U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT10_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT11_MASK   (0x800U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT11_SHIFT   (11U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT11_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT12_MASK   (0x1000U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT12_SHIFT   (12U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT12_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT13_MASK   (0x2000U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT13_SHIFT   (13U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT13_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT14_MASK   (0x4000U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT14_SHIFT   (14U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT14_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT15_MASK   (0x8000U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT15_SHIFT   (15U)
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT15_MASK)
LDO_LPSR_DIG_TRACKING_EN_SP - LDO_LPSR_DIG_TRACKING_EN_SP_REGISTER
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_MASK   (0x4U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_SHIFT   (2U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_MASK   (0x8U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_SHIFT   (3U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_MASK   (0x10U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_SHIFT   (4U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_MASK   (0x20U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_SHIFT   (5U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_MASK   (0x40U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_SHIFT   (6U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_MASK   (0x80U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_SHIFT   (7U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_MASK   (0x100U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_SHIFT   (8U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_MASK   (0x200U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_SHIFT   (9U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_MASK   (0x400U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_SHIFT   (10U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_MASK   (0x800U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_SHIFT   (11U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_MASK   (0x1000U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_SHIFT   (12U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_MASK   (0x2000U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_SHIFT   (13U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_MASK   (0x4000U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_SHIFT   (14U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_MASK   (0x8000U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_SHIFT   (15U)
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_MASK)
LDO_LPSR_DIG_BYPASS_EN_SP - LDO_LPSR_DIG_BYPASS_EN_SP_REGISTER
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_MASK   (0x4U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_SHIFT   (2U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_MASK   (0x8U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_SHIFT   (3U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_MASK   (0x10U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_SHIFT   (4U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_MASK   (0x20U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_SHIFT   (5U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_MASK   (0x40U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_SHIFT   (6U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_MASK   (0x80U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_SHIFT   (7U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_MASK   (0x100U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_SHIFT   (8U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_MASK   (0x200U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_SHIFT   (9U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_MASK   (0x400U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_SHIFT   (10U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_MASK   (0x800U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_SHIFT   (11U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_MASK   (0x1000U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_SHIFT   (12U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_MASK   (0x2000U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_SHIFT   (13U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_MASK   (0x4000U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_SHIFT   (14U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_MASK   (0x8000U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_SHIFT   (15U)
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_MASK)
LDO_LPSR_DIG_STBY_EN_SP - LDO_LPSR_DIG_STBY_EN_SP_REGISTER
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT0_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT1_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT2_MASK   (0x4U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT   (2U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT2_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT3_MASK   (0x8U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT   (3U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT3_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT4_MASK   (0x10U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT   (4U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT4_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT5_MASK   (0x20U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT   (5U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT5_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT6_MASK   (0x40U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT   (6U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT6_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT7_MASK   (0x80U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT   (7U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT7_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT8_MASK   (0x100U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT   (8U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT8_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT9_MASK   (0x200U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT   (9U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT9_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT10_MASK   (0x400U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT   (10U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT10_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT11_MASK   (0x800U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT   (11U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT11_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT12_MASK   (0x1000U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT   (12U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT12_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT13_MASK   (0x2000U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT   (13U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT13_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT14_MASK   (0x4000U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT   (14U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT14_MASK)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT15_MASK   (0x8000U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT   (15U)
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT15_MASK)
BANDGAP_ENABLE_SP - BANDGAP_ENABLE_SP_REGISTER
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT0_MASK)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT1_MASK)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT2_MASK   (0x4U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT   (2U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT2_MASK)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT3_MASK   (0x8U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT   (3U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT3_MASK)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT4_MASK   (0x10U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT   (4U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT4_MASK)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT5_MASK   (0x20U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT   (5U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT5_MASK)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT6_MASK   (0x40U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT   (6U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT6_MASK)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT7_MASK   (0x80U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT   (7U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT7_MASK)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT8_MASK   (0x100U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT   (8U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT8_MASK)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT9_MASK   (0x200U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT   (9U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT9_MASK)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT10_MASK   (0x400U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT   (10U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT10_MASK)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT11_MASK   (0x800U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT   (11U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT11_MASK)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT12_MASK   (0x1000U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT   (12U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT12_MASK)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT13_MASK   (0x2000U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT   (13U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT13_MASK)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT14_MASK   (0x4000U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT   (14U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT14_MASK)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT15_MASK   (0x8000U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT   (15U)
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT15_MASK)
RBB_SOC_ENABLE_SP - RBB_SOC_ENABLE_SP_REGISTER
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT0_MASK)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT1_MASK)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT2_MASK   (0x4U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT   (2U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT2_MASK)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT3_MASK   (0x8U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT   (3U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT3_MASK)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT4_MASK   (0x10U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT   (4U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT4_MASK)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT5_MASK   (0x20U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT   (5U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT5_MASK)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT6_MASK   (0x40U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT   (6U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT6_MASK)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT7_MASK   (0x80U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT   (7U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT7_MASK)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT8_MASK   (0x100U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT   (8U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT8_MASK)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT9_MASK   (0x200U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT   (9U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT9_MASK)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT10_MASK   (0x400U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT   (10U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT10_MASK)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT11_MASK   (0x800U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT   (11U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT11_MASK)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT12_MASK   (0x1000U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT   (12U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT12_MASK)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT13_MASK   (0x2000U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT   (13U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT13_MASK)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT14_MASK   (0x4000U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT   (14U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT14_MASK)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT15_MASK   (0x8000U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT   (15U)
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT15_MASK)
RBB_LPSR_ENABLE_SP - RBB_LPSR_ENABLE_SP_REGISTER
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT0_MASK)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT1_MASK)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT2_MASK   (0x4U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT   (2U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT2_MASK)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT3_MASK   (0x8U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT   (3U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT3_MASK)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT4_MASK   (0x10U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT   (4U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT4_MASK)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT5_MASK   (0x20U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT   (5U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT5_MASK)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT6_MASK   (0x40U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT   (6U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT6_MASK)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT7_MASK   (0x80U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT   (7U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT7_MASK)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT8_MASK   (0x100U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT   (8U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT8_MASK)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT9_MASK   (0x200U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT   (9U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT9_MASK)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT10_MASK   (0x400U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT   (10U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT10_MASK)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT11_MASK   (0x800U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT   (11U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT11_MASK)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT12_MASK   (0x1000U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT   (12U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT12_MASK)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT13_MASK   (0x2000U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT   (13U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT13_MASK)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT14_MASK   (0x4000U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT   (14U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT14_MASK)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT15_MASK   (0x8000U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT   (15U)
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT15_MASK)
BANDGAP_STBY_EN_SP - BANDGAP_STBY_EN_SP_REGISTER
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT0_MASK)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT1_MASK)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT2_MASK   (0x4U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT   (2U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT2_MASK)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT3_MASK   (0x8U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT   (3U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT3_MASK)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT4_MASK   (0x10U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT   (4U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT4_MASK)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT5_MASK   (0x20U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT   (5U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT5_MASK)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT6_MASK   (0x40U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT   (6U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT6_MASK)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT7_MASK   (0x80U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT   (7U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT7_MASK)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT8_MASK   (0x100U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT   (8U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT8_MASK)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT9_MASK   (0x200U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT   (9U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT9_MASK)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT10_MASK   (0x400U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT   (10U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT10_MASK)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT11_MASK   (0x800U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT   (11U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT11_MASK)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT12_MASK   (0x1000U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT   (12U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT12_MASK)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT13_MASK   (0x2000U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT   (13U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT13_MASK)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT14_MASK   (0x4000U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT   (14U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT14_MASK)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT15_MASK   (0x8000U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT   (15U)
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT15_MASK)
PLL_LDO_STBY_EN_SP - PLL_LDO_STBY_EN_SP_REGISTER
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT0_MASK)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT1_MASK)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT2_MASK   (0x4U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT   (2U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT2_MASK)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT3_MASK   (0x8U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT   (3U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT3_MASK)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT4_MASK   (0x10U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT   (4U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT4_MASK)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT5_MASK   (0x20U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT   (5U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT5_MASK)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT6_MASK   (0x40U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT   (6U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT6_MASK)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT7_MASK   (0x80U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT   (7U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT7_MASK)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT8_MASK   (0x100U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT   (8U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT8_MASK)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT9_MASK   (0x200U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT   (9U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT9_MASK)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT10_MASK   (0x400U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT   (10U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT10_MASK)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT11_MASK   (0x800U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT   (11U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT11_MASK)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT12_MASK   (0x1000U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT   (12U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT12_MASK)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT13_MASK   (0x2000U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT   (13U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT13_MASK)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT14_MASK   (0x4000U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT   (14U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT14_MASK)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT15_MASK   (0x8000U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT   (15U)
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT15_MASK)
RBB_SOC_STBY_EN_SP - RBB_SOC_STBY_EN_SP_REGISTER
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT0_MASK)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT1_MASK)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT2_MASK   (0x4U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT   (2U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT2_MASK)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT3_MASK   (0x8U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT   (3U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT3_MASK)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT4_MASK   (0x10U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT   (4U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT4_MASK)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT5_MASK   (0x20U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT   (5U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT5_MASK)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT6_MASK   (0x40U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT   (6U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT6_MASK)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT7_MASK   (0x80U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT   (7U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT7_MASK)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT8_MASK   (0x100U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT   (8U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT8_MASK)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT9_MASK   (0x200U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT   (9U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT9_MASK)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT10_MASK   (0x400U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT   (10U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT10_MASK)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT11_MASK   (0x800U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT   (11U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT11_MASK)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT12_MASK   (0x1000U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT   (12U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT12_MASK)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT13_MASK   (0x2000U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT   (13U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT13_MASK)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT14_MASK   (0x4000U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT   (14U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT14_MASK)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT15_MASK   (0x8000U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT   (15U)
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT15_MASK)
RBB_LPSR_STBY_EN_SP - RBB_LPSR_STBY_EN_SP_REGISTER
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT0_MASK   (0x1U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT   (0U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT0(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT0_MASK)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT1_MASK   (0x2U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT   (1U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT1(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT1_MASK)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT2_MASK   (0x4U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT   (2U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT2(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT2_MASK)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT3_MASK   (0x8U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT   (3U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT3(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT3_MASK)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT4_MASK   (0x10U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT   (4U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT4(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT4_MASK)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT5_MASK   (0x20U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT   (5U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT5(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT5_MASK)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT6_MASK   (0x40U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT   (6U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT6(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT6_MASK)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT7_MASK   (0x80U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT   (7U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT7(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT7_MASK)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT8_MASK   (0x100U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT   (8U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT8(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT8_MASK)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT9_MASK   (0x200U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT   (9U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT9(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT9_MASK)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT10_MASK   (0x400U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT   (10U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT10(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT10_MASK)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT11_MASK   (0x800U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT   (11U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT11(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT11_MASK)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT12_MASK   (0x1000U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT   (12U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT12(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT12_MASK)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT13_MASK   (0x2000U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT   (13U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT13(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT13_MASK)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT14_MASK   (0x4000U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT   (14U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT14(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT14_MASK)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT15_MASK   (0x8000U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT   (15U)
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT15(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT15_MASK)
RBB_LPSR_CONFIGURE - RBB_LPSR_CONFIGURE_REGISTER
#define ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_PW_MASK   (0xFU)
#define ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_PW_SHIFT   (0U)
#define ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_PW(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_PW_SHIFT)) & ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_PW_MASK)
#define ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_NW_MASK   (0xF0U)
#define ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_NW_SHIFT   (4U)
#define ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_NW(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_NW_SHIFT)) & ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_NW_MASK)
#define ANADIG_PMU_RBB_LPSR_CONFIGURE_OSCILLATOR_BITS_MASK   (0x700U)
#define ANADIG_PMU_RBB_LPSR_CONFIGURE_OSCILLATOR_BITS_SHIFT   (8U)
#define ANADIG_PMU_RBB_LPSR_CONFIGURE_OSCILLATOR_BITS(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_CONFIGURE_OSCILLATOR_BITS_SHIFT)) & ANADIG_PMU_RBB_LPSR_CONFIGURE_OSCILLATOR_BITS_MASK)
#define ANADIG_PMU_RBB_LPSR_CONFIGURE_REGULATOR_STRENGTH_MASK   (0x3800U)
#define ANADIG_PMU_RBB_LPSR_CONFIGURE_REGULATOR_STRENGTH_SHIFT   (11U)
#define ANADIG_PMU_RBB_LPSR_CONFIGURE_REGULATOR_STRENGTH(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_CONFIGURE_REGULATOR_STRENGTH_SHIFT)) & ANADIG_PMU_RBB_LPSR_CONFIGURE_REGULATOR_STRENGTH_MASK)
RBB_SOC_CONFIGURE - RBB_SOC_CONFIGURE_REGISTER
#define ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_PW_MASK   (0xFU)
#define ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_PW_SHIFT   (0U)
#define ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_PW(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_PW_SHIFT)) & ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_PW_MASK)
#define ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_NW_MASK   (0xF0U)
#define ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_NW_SHIFT   (4U)
#define ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_NW(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_NW_SHIFT)) & ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_NW_MASK)
#define ANADIG_PMU_RBB_SOC_CONFIGURE_OSCILLATOR_BITS_MASK   (0x700U)
#define ANADIG_PMU_RBB_SOC_CONFIGURE_OSCILLATOR_BITS_SHIFT   (8U)
#define ANADIG_PMU_RBB_SOC_CONFIGURE_OSCILLATOR_BITS(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_CONFIGURE_OSCILLATOR_BITS_SHIFT)) & ANADIG_PMU_RBB_SOC_CONFIGURE_OSCILLATOR_BITS_MASK)
#define ANADIG_PMU_RBB_SOC_CONFIGURE_REGULATOR_STRENGTH_MASK   (0x3800U)
#define ANADIG_PMU_RBB_SOC_CONFIGURE_REGULATOR_STRENGTH_SHIFT   (11U)
#define ANADIG_PMU_RBB_SOC_CONFIGURE_REGULATOR_STRENGTH(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_CONFIGURE_REGULATOR_STRENGTH_SHIFT)) & ANADIG_PMU_RBB_SOC_CONFIGURE_REGULATOR_STRENGTH_MASK)
REFTOP_OTP_TRIM_VALUE - REFTOP_OTP_TRIM_VALUE_REGISTER
#define ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_IBZTCADJ_MASK   (0x7U)
#define ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_IBZTCADJ_SHIFT   (0U)
#define ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_IBZTCADJ(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_IBZTCADJ_SHIFT)) & ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_IBZTCADJ_MASK)
#define ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_VBGADJ_MASK   (0x38U)
#define ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_VBGADJ_SHIFT   (3U)
#define ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_VBGADJ(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_VBGADJ_SHIFT)) & ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_VBGADJ_MASK)
#define ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_TRIM_EN_MASK   (0x40U)
#define ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_TRIM_EN_SHIFT   (6U)
#define ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_TRIM_EN(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_TRIM_EN_SHIFT)) & ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_TRIM_EN_MASK)
LPSR_1P8_LDO_OTP_TRIM_VALUE - LPSR_1P8_LDO_OTP_TRIM_VALUE_REGISTER
#define ANADIG_PMU_LPSR_1P8_LDO_OTP_TRIM_VALUE_LPSR_LDO_1P8_TRIM_MASK   (0x3U)
#define ANADIG_PMU_LPSR_1P8_LDO_OTP_TRIM_VALUE_LPSR_LDO_1P8_TRIM_SHIFT   (0U)
#define ANADIG_PMU_LPSR_1P8_LDO_OTP_TRIM_VALUE_LPSR_LDO_1P8_TRIM(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LPSR_1P8_LDO_OTP_TRIM_VALUE_LPSR_LDO_1P8_TRIM_SHIFT)) & ANADIG_PMU_LPSR_1P8_LDO_OTP_TRIM_VALUE_LPSR_LDO_1P8_TRIM_MASK)
#define ANADIG_PMU_LPSR_1P8_LDO_OTP_TRIM_VALUE_LPSR_LDO_1P8_TRIM_EN_MASK   (0x4U)
#define ANADIG_PMU_LPSR_1P8_LDO_OTP_TRIM_VALUE_LPSR_LDO_1P8_TRIM_EN_SHIFT   (2U)
#define ANADIG_PMU_LPSR_1P8_LDO_OTP_TRIM_VALUE_LPSR_LDO_1P8_TRIM_EN(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LPSR_1P8_LDO_OTP_TRIM_VALUE_LPSR_LDO_1P8_TRIM_EN_SHIFT)) & ANADIG_PMU_LPSR_1P8_LDO_OTP_TRIM_VALUE_LPSR_LDO_1P8_TRIM_EN_MASK)
◆ ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT0 [1/2]
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT0 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT0_MASK)
ON_OFF_SETPOINT0 - ON_OFF_SETPOINT0 0b0..ON 0b1..OFF
◆ ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT0 [2/2]
◆ ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT1 [1/2]
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT1 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT1_MASK)
ON_OFF_SETPOINT1 - ON_OFF_SETPOINT1 0b0..ON 0b1..OFF
◆ ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT1 [2/2]
◆ ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT10 [1/2]
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT10 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT10_MASK)
ON_OFF_SETPOINT10 - ON_OFF_SETPOINT10 0b0..ON 0b1..OFF
◆ ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT10 [2/2]
◆ ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT11 [1/2]
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT11 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT11_MASK)
ON_OFF_SETPOINT11 - ON_OFF_SETPOINT11 0b0..ON 0b1..OFF
◆ ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT11 [2/2]
◆ ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT12 [1/2]
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT12 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT12_MASK)
ON_OFF_SETPOINT12 - ON_OFF_SETPOINT12 0b0..ON 0b1..OFF
◆ ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT12 [2/2]
◆ ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT13 [1/2]
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT13 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT13_MASK)
ON_OFF_SETPOINT13 - ON_OFF_SETPOINT13 0b0..ON 0b1..OFF
◆ ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT13 [2/2]
◆ ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT14 [1/2]
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT14 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT14_MASK)
ON_OFF_SETPOINT14 - ON_OFF_SETPOINT14 0b0..ON 0b1..OFF
◆ ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT14 [2/2]
◆ ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT15 [1/2]
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT15 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT15_MASK)
ON_OFF_SETPOINT15 - ON_OFF_SETPOINT15 0b0..ON 0b1..OFF
◆ ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT15 [2/2]
◆ ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT2 [1/2]
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT2 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT2_MASK)
ON_OFF_SETPOINT2 - ON_OFF_SETPOINT2 0b0..ON 0b1..OFF
◆ ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT2 [2/2]
◆ ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT3 [1/2]
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT3 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT3_MASK)
ON_OFF_SETPOINT3 - ON_OFF_SETPOINT3 0b0..ON 0b1..OFF
◆ ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT3 [2/2]
◆ ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT4 [1/2]
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT4 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT4_MASK)
ON_OFF_SETPOINT4 - ON_OFF_SETPOINT4 0b0..ON 0b1..OFF
◆ ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT4 [2/2]
◆ ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT5 [1/2]
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT5 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT5_MASK)
ON_OFF_SETPOINT5 - ON_OFF_SETPOINT5 0b0..ON 0b1..OFF
◆ ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT5 [2/2]
◆ ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT6 [1/2]
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT6 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT6_MASK)
ON_OFF_SETPOINT6 - ON_OFF_SETPOINT5 0b0..ON 0b1..OFF
◆ ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT6 [2/2]
◆ ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT7 [1/2]
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT7 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT7_MASK)
ON_OFF_SETPOINT7 - ON_OFF_SETPOINT7 0b0..ON 0b1..OFF
◆ ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT7 [2/2]
◆ ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT8 [1/2]
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT8 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT8_MASK)
ON_OFF_SETPOINT8 - ON_OFF_SETPOINT8 0b0..ON 0b1..OFF
◆ ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT8 [2/2]
◆ ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT9 [1/2]
#define ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT9 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT9_MASK)
ON_OFF_SETPOINT9 - ON_OFF_SETPOINT9 0b0..ON 0b1..OFF
◆ ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT9 [2/2]
◆ ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT0 [1/2]
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT0 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT0_MASK)
STBY_EN_SETPOINT0 - STBY_EN_SETPOINT 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT0 [2/2]
◆ ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT1 [1/2]
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT1 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT1_MASK)
STBY_EN_SETPOINT1 - STBY_EN_SETPOINT 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT1 [2/2]
◆ ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT10 [1/2]
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT10 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT10_MASK)
STBY_EN_SETPOINT10 - STBY_EN_SETPOINT 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT10 [2/2]
◆ ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT11 [1/2]
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT11 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT11_MASK)
STBY_EN_SETPOINT11 - STBY_EN_SETPOINT 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT11 [2/2]
◆ ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT12 [1/2]
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT12 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT12_MASK)
STBY_EN_SETPOINT12 - STBY_EN_SETPOINT 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT12 [2/2]
◆ ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT13 [1/2]
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT13 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT13_MASK)
STBY_EN_SETPOINT13 - STBY_EN_SETPOINT 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT13 [2/2]
◆ ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT14 [1/2]
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT14 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT14_MASK)
STBY_EN_SETPOINT14 - STBY_EN_SETPOINT 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT14 [2/2]
◆ ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT15 [1/2]
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT15 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT15_MASK)
STBY_EN_SETPOINT15 - STBY_EN_SETPOINT 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT15 [2/2]
◆ ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT2 [1/2]
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT2 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT2_MASK)
STBY_EN_SETPOINT2 - STBY_EN_SETPOINT 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT2 [2/2]
◆ ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT3 [1/2]
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT3 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT3_MASK)
STBY_EN_SETPOINT3 - STBY_EN_SETPOINT 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT3 [2/2]
◆ ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT4 [1/2]
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT4 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT4_MASK)
STBY_EN_SETPOINT4 - STBY_EN_SETPOINT 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT4 [2/2]
◆ ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT5 [1/2]
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT5 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT5_MASK)
STBY_EN_SETPOINT5 - STBY_EN_SETPOINT 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT5 [2/2]
◆ ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT6 [1/2]
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT6 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT6_MASK)
STBY_EN_SETPOINT6 - STBY_EN_SETPOINT 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT6 [2/2]
◆ ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT7 [1/2]
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT7 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT7_MASK)
STBY_EN_SETPOINT7 - STBY_EN_SETPOINT 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT7 [2/2]
◆ ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT8 [1/2]
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT8 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT8_MASK)
STBY_EN_SETPOINT8 - STBY_EN_SETPOINT 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT8 [2/2]
◆ ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT9 [1/2]
#define ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT9 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT9_MASK)
STBY_EN_SETPOINT9 - STBY_EN_SETPOINT 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT9 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT0 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT0 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_MASK)
BYPASS_EN_SETPOINT0 - BYPASS_EN_SETPOINT0 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT0 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT1 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT1 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_MASK)
BYPASS_EN_SETPOINT1 - BYPASS_EN_SETPOINT1 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT1 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT10 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT10 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_MASK)
BYPASS_EN_SETPOINT10 - BYPASS_EN_SETPOINT10 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT10 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT11 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT11 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_MASK)
BYPASS_EN_SETPOINT11 - BYPASS_EN_SETPOINT11 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT11 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT12 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT12 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_MASK)
BYPASS_EN_SETPOINT12 - BYPASS_EN_SETPOINT12 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT12 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT13 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT13 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_MASK)
BYPASS_EN_SETPOINT13 - BYPASS_EN_SETPOINT13 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT13 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT14 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT14 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_MASK)
BYPASS_EN_SETPOINT14 - BYPASS_EN_SETPOINT14 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT14 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT15 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT15 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_MASK)
BYPASS_EN_SETPOINT15 - BYPASS_EN_SETPOINT15 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT15 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT2 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT2 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_MASK)
BYPASS_EN_SETPOINT2 - BYPASS_EN_SETPOINT2 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT2 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT3 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT3 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_MASK)
BYPASS_EN_SETPOINT3 - BYPASS_EN_SETPOINT3 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT3 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT4 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT4 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_MASK)
BYPASS_EN_SETPOINT4 - BYPASS_EN_SETPOINT4 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT4 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT5 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT5 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_MASK)
BYPASS_EN_SETPOINT5 - BYPASS_EN_SETPOINT5 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT5 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT6 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT6 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_MASK)
BYPASS_EN_SETPOINT6 - BYPASS_EN_SETPOINT6 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT6 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT7 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT7 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_MASK)
BYPASS_EN_SETPOINT7 - BYPASS_EN_SETPOINT7 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT7 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT8 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT8 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_MASK)
BYPASS_EN_SETPOINT8 - BYPASS_EN_SETPOINT 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT8 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT9 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT9 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_MASK)
BYPASS_EN_SETPOINT9 - BYPASS_EN_SETPOINT9 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT9 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT0 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT0 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT0_MASK)
◆ ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT0 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT1 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT1 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT1_MASK)
◆ ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT1 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT10 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT10 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT10_MASK)
◆ ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT10 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT11 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT11 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT11_MASK)
◆ ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT11 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT12 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT12 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT12_MASK)
◆ ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT12 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT13 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT13 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT13_MASK)
◆ ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT13 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT14 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT14 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT14_MASK)
◆ ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT14 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT15 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT15 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT15_MASK)
◆ ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT15 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT2 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT2 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT2_MASK)
◆ ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT2 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT3 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT3 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT3_MASK)
◆ ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT3 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT4 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT4 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT4_MASK)
◆ ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT4 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT5 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT5 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT5_MASK)
◆ ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT5 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT6 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT6 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT6_MASK)
ON_OFF_SETPOINT6 - ON_OFF_SETPOINT6 0b0..ON 0b1..OFF
◆ ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT6 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT7 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT7 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT7_MASK)
◆ ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT7 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT8 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT8 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT8_MASK)
◆ ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT8 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT9 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT9 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT9_MASK)
◆ ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT9 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT0 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT0 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT0_MASK)
LP_MODE_SETPOINT0 - LP_MODE_SETPOINT0 0b0..LP 0b1..HP
◆ ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT0 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT1 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT1 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT1_MASK)
LP_MODE_SETPOINT1 - LP_MODE_SETPOINT1 0b0..LP 0b1..HP
◆ ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT1 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT10 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT10 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT10_MASK)
LP_MODE_SETPONIT10 - LP_MODE_SETPOINT10 0b0..LP 0b1..HP
◆ ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT10 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT11 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT11 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT11_MASK)
LP_MODE_SETPONIT11 - LP_MODE_SETPOINT11 0b0..LP 0b1..HP
◆ ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT11 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT12 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT12 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT12_MASK)
LP_MODE_SETPONIT12 - LP_MODE_SETPOINT12 0b0..LP 0b1..HP
◆ ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT12 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT13 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT13 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT13_MASK)
LP_MODE_SETPONIT13 - LP_MODE_SETPOINT13 0b0..LP 0b1..HP
◆ ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT13 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT14 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT14 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT14_MASK)
LP_MODE_SETPONIT14 - LP_MODE_SETPOINT14 0b0..LP 0b1..HP
◆ ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT14 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT15 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT15 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT15_MASK)
LP_MODE_SETPONIT15 - LP_MODE_SETPOINT15 0b0..LP 0b1..HP
◆ ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT15 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT2 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT2 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT2_MASK)
LP_MODE_SETPONIT2 - LP_MODE_SETPOINT2 0b0..LP 0b1..HP
◆ ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT2 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT3 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT3 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT3_MASK)
LP_MODE_SETPONIT3 - LP_MODE_SETPOINT3 0b0..LP 0b1..HP
◆ ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT3 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT4 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT4 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT4_MASK)
LP_MODE_SETPONIT4 - LP_MODE_SETPOINT4 0b0..LP 0b1..HP
◆ ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT4 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT5 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT5 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT5_MASK)
LP_MODE_SETPONIT5 - LP_MODE_SETPOINT5 0b0..LP 0b1..HP
◆ ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT5 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT6 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT6 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT6_MASK)
LP_MODE_SETPONIT6 - LP_MODE_SETPOINT6 0b0..LP 0b1..HP
◆ ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT6 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT7 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT7 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT7_MASK)
LP_MODE_SETPONIT7 - LP_MODE_SETPOINT7 0b0..LP 0b1..HP
◆ ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT7 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT8 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT8 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT8_MASK)
LP_MODE_SETPONIT8 - LP_MODE_SETPOINT8 0b0..LP 0b1..HP
◆ ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT8 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT9 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT9 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT9_MASK)
LP_MODE_SETPONIT9 - LP_MODE_SETPOINT9 0b0..LP 0b1..HP
◆ ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT9 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT0 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT0 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT0_MASK)
STBY_EN_SETPOINT0 - STBY_EN_SETPOINT0 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT0 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT1 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT1 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT1_MASK)
STBY_EN_SETPOINT1 - STBY_EN_SETPOINT1 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT1 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT10 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT10 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT10_MASK)
STBY_EN_SETPOINT10 - STBY_EN_SETPOINT10 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT10 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT11 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT11 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT11_MASK)
STBY_EN_SETPOINT11 - STBY_EN_SETPOINT11 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT11 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT12 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT12 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT12_MASK)
STBY_EN_SETPOINT12 - STBY_EN_SETPOINT12 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT12 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT13 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT13 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT13_MASK)
STBY_EN_SETPOINT13 - STBY_EN_SETPOINT13 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT13 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT14 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT14 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT14_MASK)
STBY_EN_SETPOINT14 - STBY_EN_SETPOINT14 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT14 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT15 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT15 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT15_MASK)
STBY_EN_SETPOINT15 - STBY_EN_SETPOINT15 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT15 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT2 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT2 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT2_MASK)
STBY_EN_SETPOINT2 - STBY_EN_SETPOINT2 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT2 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT3 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT3 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT3_MASK)
STBY_EN_SETPOINT3 - STBY_EN_SETPOINT3 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT3 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT4 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT4 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT4_MASK)
STBY_EN_SETPOINT4 - STBY_EN_SETPOINT4 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT4 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT5 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT5 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT5_MASK)
STBY_EN_SETPOINT5 - STBY_EN_SETPOINT5 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT5 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT6 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT6 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT6_MASK)
STBY_EN_SETPOINT6 - STBY_EN_SETPOINT6 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT6 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT7 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT7 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT7_MASK)
STBY_EN_SETPOINT7 - STBY_EN_SETPOINT7 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT7 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT8 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT8 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT8_MASK)
STBY_EN_SETPOINT8 - STBY_EN_SETPOINT8 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT8 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT9 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT9 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT9_MASK)
STBY_EN_SETPOINT9 - STBY_EN_SETPOINT9 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT9 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT0 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT0 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_MASK)
TRACKING_EN_SETPOINT0 - TRACKING_EN_SETPOINT0 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT0 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT1 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT1 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_MASK)
TRACKING_EN_SETPOINT1 - TRACKING_EN_SETPOINT1 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT1 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT10 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT10 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_MASK)
TRACKING_EN_SETPOINT10 - TRACKING_EN_SETPOINT10 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT10 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT11 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT11 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_MASK)
TRACKING_EN_SETPOINT11 - TRACKING_EN_SETPOINT11 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT11 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT12 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT12 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_MASK)
TRACKING_EN_SETPOINT12 - TRACKING_EN_SETPOINT12 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT12 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT13 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT13 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_MASK)
TRACKING_EN_SETPOINT13 - TRACKING_EN_SETPOINT13 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT13 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT14 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT14 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_MASK)
TRACKING_EN_SETPOINT14 - TRACKING_EN_SETPOINT14 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT14 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT15 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT15 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_MASK)
TRACKING_EN_SETPOINT15 - TRACKING_EN_SETPOINT15 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT15 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT2 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT2 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_MASK)
TRACKING_EN_SETPOINT2 - TRACKING_EN_SETPOINT2 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT2 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT3 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT3 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_MASK)
TRACKING_EN_SETPOINT3 - TRACKING_EN_SETPOINT3 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT3 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT4 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT4 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_MASK)
TRACKING_EN_SETPOINT4 - TRACKING_EN_SETPOINT4 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT4 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT5 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT5 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_MASK)
TRACKING_EN_SETPOINT5 - TRACKING_EN_SETPOINT5 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT5 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT6 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT6 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_MASK)
TRACKING_EN_SETPOINT6 - TRACKING_EN_SETPOINT6 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT6 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT7 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT7 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_MASK)
TRACKING_EN_SETPOINT7 - TRACKING_EN_SETPOINT7 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT7 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT8 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT8 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_MASK)
TRACKING_EN_SETPOINT8 - TRACKING_EN_SETPOINT8 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT8 [2/2]
◆ ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT9 [1/2]
#define ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT9 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_MASK)
TRACKING_EN_SETPOINT9 - TRACKING_EN_SETPOINT9 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT9 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT0 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT0 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT0 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT1 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT1 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT1 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT10 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT10 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT10 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT11 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT11 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT11 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT12 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT12 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT12 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT13 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT13 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT13 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT14 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT14 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT14 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT15 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT15 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT15 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT2 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT2 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT2 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT3 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT3 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT3 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT4 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT4 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT4 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT5 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT5 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT5 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT6 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT6 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT6 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT7 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT7 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT7 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT8 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT8 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_MASK)
BYPASS_EN_SETPOINT8 - BYPASS_EN_SETPOINT8 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT8 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT9 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT9 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT9 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT0 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT0 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT0_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT0 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT1 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT1 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT1_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT1 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT10 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT10 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT10_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT10 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT11 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT11 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT11_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT11 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT12 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT12 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT12_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT12 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT13 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT13 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT13_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT13 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT14 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT14 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT14_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT14 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT15 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT15 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT15_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT15 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT2 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT2 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT2_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT2 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT3 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT3 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT3_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT3 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT4 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT4 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT4_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT4 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT5 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT5 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT5_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT5 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT6 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT6 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT6_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT6 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT7 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT7 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT7_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT7 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT8 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT8 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT8_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT8 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT9 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT9 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT9_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT9 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT0 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT0 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT0_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT0 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT1 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT1 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT1_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT1 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT10 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT10 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT10_MASK)
LP_MODE_SETPOINT10 - LP_MODE_SETPOINT10 0b0..LP 0b1..HP
◆ ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT10 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT11 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT11 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT11_MASK)
LP_MODE_SETPOINT11 - LP_MODE_SETPOINT11 0b0..LP 0b1..HP
◆ ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT11 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT12 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT12 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT12_MASK)
LP_MODE_SETPOINT12 - LP_MODE_SETPOINT12 0b0..LP 0b1..HP
◆ ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT12 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT13 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT13 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT13_MASK)
LP_MODE_SETPOINT13 - LP_MODE_SETPOINT13 0b0..LP 0b1..HP
◆ ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT13 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT14 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT14 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT14_MASK)
LP_MODE_SETPOINT14 - LP_MODE_SETPOINT14 0b0..LP 0b1..HP
◆ ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT14 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT15 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT15 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT15_MASK)
LP_MODE_SETPOINT15 - LP_MODE_SETPOINT15 0b0..LP 0b1..HP
◆ ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT15 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT2 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT2 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT2_MASK)
LP_MODE_SETPOINT2 - LP_MODE_SETPOINT2 0b0..LP 0b1..HP
◆ ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT2 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT3 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT3 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT3_MASK)
LP_MODE_SETPOINT3 - LP_MODE_SETPOINT3 0b0..LP 0b1..HP
◆ ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT3 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT4 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT4 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT4_MASK)
LP_MODE_SETPOINT4 - LP_MODE_SETPOINT4 0b0..LP 0b1..HP
◆ ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT4 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT5 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT5 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT5_MASK)
LP_MODE_SETPOINT5 - LP_MODE_SETPOINT5 0b0..LP 0b1..HP
◆ ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT5 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT6 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT6 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT6_MASK)
LP_MODE_SETPOINT6 - LP_MODE_SETPOINT6 0b0..LP 0b1..HP
◆ ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT6 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT7 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT7 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT7_MASK)
LP_MODE_SETPOINT7 - LP_MODE_SETPOINT7 0b0..LP 0b1..HP
◆ ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT7 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT8 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT8 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT8_MASK)
LP_MODE_SETPOINT8 - LP_MODE_SETPOINT8 0b0..LP 0b1..HP
◆ ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT8 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT9 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT9 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT9_MASK)
LP_MODE_SETPOINT9 - LP_MODE_SETPOINT9 0b0..LP 0b1..HP
◆ ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT9 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT0 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT0 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT0_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT0 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT1 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT1 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT1_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT1 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT10 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT10 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT10_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT10 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT11 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT11 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT11_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT11 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT12 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT12 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT12_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT12 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT13 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT13 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT13_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT13 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT14 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT14 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT14_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT14 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT15 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT15 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT15_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT15 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT2 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT2 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT2_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT2 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT3 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT3 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT3_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT3 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT4 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT4 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT4_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT4 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT5 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT5 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT5_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT5 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT6 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT6 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT6_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT6 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT7 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT7 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT7_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT7 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT8 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT8 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT8_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT8 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT9 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT9 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT9_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT9 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT0 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT0 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT0 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT1 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT1 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT1 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT10 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT10 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT10 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT11 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT11 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT11 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT12 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT12 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT12 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT13 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT13 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT13 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT14 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT14 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT14 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT15 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT15 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT15 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT2 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT2 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT2 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT3 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT3 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT3 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT4 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT4 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT4 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT5 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT5 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT5 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT6 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT6 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT6 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT7 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT7 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT7 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT8 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT8 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT8 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT9 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT9 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_MASK)
◆ ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT9 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT0 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT0 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT0_MASK)
VOLTAGE_SETPOINT0 - VOLTAGE_SETPOINT0
◆ ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT0 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT1 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT1 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT1_MASK)
VOLTAGE_SETPOINT1 - VOLTAGE_SETPOINT1
◆ ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT1 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT2 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT2 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT2_MASK)
VOLTAGE_SETPOINT2 - VOLTAGE_SETPOINT2
◆ ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT2 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT3 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT3 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT3_MASK)
VOLTAGE_SETPOINT3 - VOLTAGE_SETPOINT3
◆ ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT3 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT4 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT4 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT4_MASK)
VOLTAGE_SETPOINT4 - VOLTAGE_SETPOINT4
◆ ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT4 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT5 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT5 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT5_MASK)
VOLTAGE_SETPOINT5 - VOLTAGE_SETPOINT5
◆ ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT5 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT6 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT6 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT6_MASK)
VOLTAGE_SETPOINT6 - VOLTAGE_SETPOINT6
◆ ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT6 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT7 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT7 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT7_MASK)
VOLTAGE_SETPOINT7 - VOLTAGE_SETPOINT7
◆ ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT7 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT10 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT10 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT10_MASK)
VOLTAGE_SETPOINT10 - VOLTAGE_SETPOINT10
◆ ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT10 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT11 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT11 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT11_MASK)
VOLTAGE_SETPOINT11 - VOLTAGE_SETPOINT11
◆ ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT11 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT8 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT8 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT8_MASK)
VOLTAGE_SETPOINT8 - VOLTAGE_SETPOINT8
◆ ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT8 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT9 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT9 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT9_MASK)
VOLTAGE_SETPOINT9 - VOLTAGE_SETPOINT9
◆ ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT9 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT12 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT12 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT12_MASK)
VOLTAGE_SETPOINT12 - VOLTAGE_SETPOINT12
◆ ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT12 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT13 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT13 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT13_MASK)
VOLTAGE_SETPOINT13 - VOLTAGE_SETPOINT13
◆ ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT13 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT14 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT14 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT14_MASK)
VOLTAGE_SETPOINT14 - VOLTAGE_SETPOINT14
◆ ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT14 [2/2]
◆ ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT15 [1/2]
#define ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT15 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT15_MASK)
VOLTAGE_SETPOINT15 - VOLTAGE_SETPOINT15
◆ ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT15 [2/2]
◆ ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT0 [1/2]
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT0 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT0_MASK)
ON_OFF_SETPOINT0 - ON_OFF_SETPOINT0 0b0..ON 0b1..OFF
◆ ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT0 [2/2]
◆ ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT1 [1/2]
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT1 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT1_MASK)
ON_OFF_SETPOINT1 - ON_OFF_SETPOINT1 0b0..ON 0b1..OFF
◆ ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT1 [2/2]
◆ ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT10 [1/2]
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT10 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT10_MASK)
ON_OFF_SETPOINT10 - ON_OFF_SETPOINT10 0b0..ON 0b1..OFF
◆ ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT10 [2/2]
◆ ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT11 [1/2]
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT11 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT11_MASK)
ON_OFF_SETPOINT11 - ON_OFF_SETPOINT11 0b0..ON 0b1..OFF
◆ ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT11 [2/2]
◆ ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT12 [1/2]
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT12 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT12_MASK)
ON_OFF_SETPOINT12 - ON_OFF_SETPOINT12 0b0..ON 0b1..OFF
◆ ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT12 [2/2]
◆ ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT13 [1/2]
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT13 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT13_MASK)
ON_OFF_SETPOINT13 - ON_OFF_SETPOINT13 0b0..ON 0b1..OFF
◆ ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT13 [2/2]
◆ ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT14 [1/2]
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT14 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT14_MASK)
ON_OFF_SETPOINT14 - ON_OFF_SETPOINT14 0b0..ON 0b1..OFF
◆ ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT14 [2/2]
◆ ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT15 [1/2]
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT15 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT15_MASK)
ON_OFF_SETPOINT15 - ON_OFF_SETPOINT15 0b0..ON 0b1..OFF
◆ ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT15 [2/2]
◆ ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT2 [1/2]
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT2 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT2_MASK)
ON_OFF_SETPOINT2 - ON_OFF_SETPOINT2 0b0..ON 0b1..OFF
◆ ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT2 [2/2]
◆ ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT3 [1/2]
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT3 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT3_MASK)
ON_OFF_SETPOINT3 - ON_OFF_SETPOINT3 0b0..ON 0b1..OFF
◆ ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT3 [2/2]
◆ ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT4 [1/2]
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT4 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT4_MASK)
ON_OFF_SETPOINT4 - ON_OFF_SETPOINT4 0b0..ON 0b1..OFF
◆ ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT4 [2/2]
◆ ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT5 [1/2]
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT5 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT5_MASK)
ON_OFF_SETPOINT5 - ON_OFF_SETPOINT5 0b0..ON 0b1..OFF
◆ ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT5 [2/2]
◆ ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT6 [1/2]
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT6 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT6_MASK)
ON_OFF_SETPOINT6 - ON_OFF_SETPOINT6 0b0..ON 0b1..OFF
◆ ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT6 [2/2]
◆ ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT7 [1/2]
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT7 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT7_MASK)
ON_OFF_SETPOINT7 - ON_OFF_SETPOINT7 0b0..ON 0b1..OFF
◆ ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT7 [2/2]
◆ ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT8 [1/2]
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT8 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT8_MASK)
ON_OFF_SETPOINT8 - ON_OFF_SETPOINT8 0b0..ON 0b1..OFF
◆ ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT8 [2/2]
◆ ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT9 [1/2]
#define ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT9 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT9_MASK)
ON_OFF_SETPOINT9 - ON_OFF_SETPOINT9 0b0..ON 0b1..OFF
◆ ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT9 [2/2]
◆ ANADIG_PMU_LPSR_1P8_LDO_OTP_TRIM_VALUE_LPSR_LDO_1P8_TRIM [1/2]
#define ANADIG_PMU_LPSR_1P8_LDO_OTP_TRIM_VALUE_LPSR_LDO_1P8_TRIM (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LPSR_1P8_LDO_OTP_TRIM_VALUE_LPSR_LDO_1P8_TRIM_SHIFT)) & ANADIG_PMU_LPSR_1P8_LDO_OTP_TRIM_VALUE_LPSR_LDO_1P8_TRIM_MASK)
LPSR_LDO_1P8_TRIM - LPSR_LDO_1P8_TRIM
◆ ANADIG_PMU_LPSR_1P8_LDO_OTP_TRIM_VALUE_LPSR_LDO_1P8_TRIM [2/2]
◆ ANADIG_PMU_LPSR_1P8_LDO_OTP_TRIM_VALUE_LPSR_LDO_1P8_TRIM_EN [1/2]
#define ANADIG_PMU_LPSR_1P8_LDO_OTP_TRIM_VALUE_LPSR_LDO_1P8_TRIM_EN (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LPSR_1P8_LDO_OTP_TRIM_VALUE_LPSR_LDO_1P8_TRIM_EN_SHIFT)) & ANADIG_PMU_LPSR_1P8_LDO_OTP_TRIM_VALUE_LPSR_LDO_1P8_TRIM_EN_MASK)
LPSR_LDO_1P8_TRIM_EN - LPSR_LDO_1P8_TRIM_EN
◆ ANADIG_PMU_LPSR_1P8_LDO_OTP_TRIM_VALUE_LPSR_LDO_1P8_TRIM_EN [2/2]
◆ ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT0 [1/2]
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT0 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT0_MASK)
STBY_EN_SETPOINT0 - Standby mode 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT0 [2/2]
◆ ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT1 [1/2]
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT1 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT1_MASK)
STBY_EN_SETPOINT1 - Standby mode 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT1 [2/2]
◆ ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT10 [1/2]
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT10 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT10_MASK)
STBY_EN_SETPOINT10 - Standby mode 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT10 [2/2]
◆ ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT11 [1/2]
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT11 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT11_MASK)
STBY_EN_SETPOINT11 - Standby mode 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT11 [2/2]
◆ ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT12 [1/2]
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT12 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT12_MASK)
STBY_EN_SETPOINT12 - Standby mode 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT12 [2/2]
◆ ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT13 [1/2]
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT13 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT13_MASK)
STBY_EN_SETPOINT13 - Standby mode 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT13 [2/2]
◆ ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT14 [1/2]
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT14 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT14_MASK)
STBY_EN_SETPOINT14 - Standby mode 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT14 [2/2]
◆ ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT15 [1/2]
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT15 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT15_MASK)
STBY_EN_SETPOINT15 - Standby mode 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT15 [2/2]
◆ ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT2 [1/2]
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT2 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT2_MASK)
STBY_EN_SETPOINT2 - Standby mode 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT2 [2/2]
◆ ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT3 [1/2]
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT3 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT3_MASK)
STBY_EN_SETPOINT3 - Standby mode 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT3 [2/2]
◆ ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT4 [1/2]
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT4 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT4_MASK)
STBY_EN_SETPOINT4 - Standby mode 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT4 [2/2]
◆ ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT5 [1/2]
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT5 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT5_MASK)
STBY_EN_SETPOINT5 - Standby mode 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT5 [2/2]
◆ ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT6 [1/2]
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT6 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT6_MASK)
STBY_EN_SETPOINT6 - Standby mode 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT6 [2/2]
◆ ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT7 [1/2]
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT7 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT7_MASK)
STBY_EN_SETPOINT7 - Standby mode 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT7 [2/2]
◆ ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT8 [1/2]
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT8 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT8_MASK)
STBY_EN_SETPOINT8 - Standby mode 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT8 [2/2]
◆ ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT9 [1/2]
#define ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT9 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT9_MASK)
STBY_EN_SETPOINT9 - Standby mode 0b0..Disabled 0b1..Enabled
◆ ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT9 [2/2]
◆ ANADIG_PMU_PMU_BIAS_CTRL2_RBB_LPSR_CONTROL_MODE [1/2]
#define ANADIG_PMU_PMU_BIAS_CTRL2_RBB_LPSR_CONTROL_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_RBB_LPSR_CONTROL_MODE_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_RBB_LPSR_CONTROL_MODE_MASK)
RBB_LPSR_CONTROL_MODE - RBB_LPSR_CONTROL_MODE 0b0..SW Control 0b1..HW Control
◆ ANADIG_PMU_PMU_BIAS_CTRL2_RBB_LPSR_CONTROL_MODE [2/2]
◆ ANADIG_PMU_PMU_BIAS_CTRL2_RBB_SOC_CONTROL_MODE [1/2]
#define ANADIG_PMU_PMU_BIAS_CTRL2_RBB_SOC_CONTROL_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_RBB_SOC_CONTROL_MODE_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_RBB_SOC_CONTROL_MODE_MASK)
RBB_SOC_CONTROL_MODE - RBB_SOC_CONTROL_MODE 0b0..SW Control 0b1..HW Control
◆ ANADIG_PMU_PMU_BIAS_CTRL2_RBB_SOC_CONTROL_MODE [2/2]
◆ ANADIG_PMU_PMU_BIAS_CTRL2_WB_ADJ_1P8 [1/2]
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_ADJ_1P8 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_WB_ADJ_1P8_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_WB_ADJ_1P8_MASK)
WB_ADJ_1P8 - wb_adj_1p8 0b00000000..Cref= 0fF Cspl= 0fF DeltaC= 0fF 0b00000001..Cref= 0fF Cspl= 30fF DeltaC= -30fF 0b00000010..Cref= 0fF Cspl= 43fF DeltaC= -43fF 0b00000011..Cref= 0fF Cspl= 62fF DeltaC=-62fF 0b00000100..Cref= 0fF Cspl=105fF DeltaC=-105fF 0b00000101..Cref= 30fF Cspl= 0fF DeltaC= 30fF 0b00000110..Cref= 30fF Cspl= 43fF DeltaC= -12fF 0b00000111..Cref= 30fF Cspl=105fF DeltaC= -75fF 0b00001000..Cref= 43fF Cspl= 0fF DeltaC= 43fF 0b00001001..Cref= 43fF Cspl= 30fF DeltaC= 13fF 0b00001010..Cref= 43fF Cspl= 62fF DeltaC= -19fF 0b00001011..Cref= 62fF Cspl= 0fF DeltaC= 62fF 0b00001100..Cref= 62fF Cspl= 43fF DeltaC= 19fF 0b00001101..Cref=105fF Cspl= 0fF DeltaC= 105fF 0b00001110..Cref=105fF Cspl=30fF DeltaC= 75fF 0b00001111..Cref=0fF Cspl=0fF DeltaC= 0fF
◆ ANADIG_PMU_PMU_BIAS_CTRL2_WB_ADJ_1P8 [2/2]
◆ ANADIG_PMU_PMU_BIAS_CTRL2_WB_EN [1/2]
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_EN (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_WB_EN_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_WB_EN_MASK)
WB_EN - wb_en
◆ ANADIG_PMU_PMU_BIAS_CTRL2_WB_EN [2/2]
WB_EN - wb_en
◆ ANADIG_PMU_PMU_BIAS_CTRL2_WB_OK [1/2]
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_OK (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_WB_OK_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_WB_OK_MASK)
WB_OK - Digital Output pin.
◆ ANADIG_PMU_PMU_BIAS_CTRL2_WB_OK [2/2]
◆ ANADIG_PMU_PMU_BIAS_CTRL2_WB_PWR_SW_EN_1P8 [1/2]
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_PWR_SW_EN_1P8 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_WB_PWR_SW_EN_1P8_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_WB_PWR_SW_EN_1P8_MASK)
WB_PWR_SW_EN_1P8 - MODSEL_wb_tst_md_1p8 0b010..BB 0b100..BB
◆ ANADIG_PMU_PMU_BIAS_CTRL2_WB_PWR_SW_EN_1P8 [2/2]
◆ ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_DIG_OUT [1/2]
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_DIG_OUT (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_DIG_OUT_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_DIG_OUT_MASK)
WB_TST_DIG_OUT - Digital output
◆ ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_DIG_OUT [2/2]
◆ ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_MD [1/2]
#define ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_MD (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_MD_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_MD_MASK)
WB_TST_MD - TMOD_wb_tst_md_1p8
◆ ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_MD [2/2]
◆ ANADIG_PMU_PMU_BIAS_CTRL_WB_CFG_1P8 [1/2]
#define ANADIG_PMU_PMU_BIAS_CTRL_WB_CFG_1P8 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL_WB_CFG_1P8_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL_WB_CFG_1P8_MASK)
WB_CFG_1P8 - wb_cfg_1p8
◆ ANADIG_PMU_PMU_BIAS_CTRL_WB_CFG_1P8 [2/2]
◆ ANADIG_PMU_PMU_BIAS_CTRL_WB_VDD_SEL_1P8 [1/2]
#define ANADIG_PMU_PMU_BIAS_CTRL_WB_VDD_SEL_1P8 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL_WB_VDD_SEL_1P8_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL_WB_VDD_SEL_1P8_MASK)
WB_VDD_SEL_1P8 - wb_vdd_sel_1p8 0b0..VDD_LV1 0b1..VDD_LV2
◆ ANADIG_PMU_PMU_BIAS_CTRL_WB_VDD_SEL_1P8 [2/2]
◆ ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_BUSY [1/2]
#define ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_BUSY (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_BUSY_SHIFT)) & ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_BUSY_MASK)
LDO_PLL_AI_BUSY - ldo_pll_busy
◆ ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_BUSY [2/2]
◆ ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_TOGGLE [1/2]
#define ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_TOGGLE (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_TOGGLE_SHIFT)) & ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_TOGGLE_MASK)
LDO_PLL_AI_TOGGLE - ldo_pll_ai_toggle
◆ ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_TOGGLE [2/2]
◆ ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_CONTROL_MODE [1/2]
#define ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_CONTROL_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_CONTROL_MODE_SHIFT)) & ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_CONTROL_MODE_MASK)
LDO_PLL_CONTROL_MODE - LDO_PLL_CONTROL_MODE 0b0..SW Control 0b1..HW Control
◆ ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_CONTROL_MODE [2/2]
◆ ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_ENABLE [1/2]
#define ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_ENABLE (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_ENABLE_SHIFT)) & ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_ENABLE_MASK)
LDO_PLL_ENABLE - LDO_PLL_ENABLE
◆ ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_ENABLE [2/2]
◆ ANADIG_PMU_PMU_POWER_DETECT_CTRL_CKGB_LPSR1P0 [1/2]
#define ANADIG_PMU_PMU_POWER_DETECT_CTRL_CKGB_LPSR1P0 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_POWER_DETECT_CTRL_CKGB_LPSR1P0_SHIFT)) & ANADIG_PMU_PMU_POWER_DETECT_CTRL_CKGB_LPSR1P0_MASK)
CKGB_LPSR1P0 - ckgb_lpsr1p0
◆ ANADIG_PMU_PMU_POWER_DETECT_CTRL_CKGB_LPSR1P0 [2/2]
◆ ANADIG_PMU_PMU_REF_CTRL_EN_PLL_VOL_REF_BUFFER [1/2]
#define ANADIG_PMU_PMU_REF_CTRL_EN_PLL_VOL_REF_BUFFER (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_REF_CTRL_EN_PLL_VOL_REF_BUFFER_SHIFT)) & ANADIG_PMU_PMU_REF_CTRL_EN_PLL_VOL_REF_BUFFER_MASK)
EN_PLL_VOL_REF_BUFFER - en_pll_vol_ref_buffer
◆ ANADIG_PMU_PMU_REF_CTRL_EN_PLL_VOL_REF_BUFFER [2/2]
◆ ANADIG_PMU_PMU_REF_CTRL_REF_AI_BUSY [1/2]
#define ANADIG_PMU_PMU_REF_CTRL_REF_AI_BUSY (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_REF_CTRL_REF_AI_BUSY_SHIFT)) & ANADIG_PMU_PMU_REF_CTRL_REF_AI_BUSY_MASK)
REF_AI_BUSY - ref_ai_busy
◆ ANADIG_PMU_PMU_REF_CTRL_REF_AI_BUSY [2/2]
◆ ANADIG_PMU_PMU_REF_CTRL_REF_AI_TOGGLE [1/2]
#define ANADIG_PMU_PMU_REF_CTRL_REF_AI_TOGGLE (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_REF_CTRL_REF_AI_TOGGLE_SHIFT)) & ANADIG_PMU_PMU_REF_CTRL_REF_AI_TOGGLE_MASK)
REF_AI_TOGGLE - ref_ai_toggle
◆ ANADIG_PMU_PMU_REF_CTRL_REF_AI_TOGGLE [2/2]
◆ ANADIG_PMU_PMU_REF_CTRL_REF_CONTROL_MODE [1/2]
#define ANADIG_PMU_PMU_REF_CTRL_REF_CONTROL_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_REF_CTRL_REF_CONTROL_MODE_SHIFT)) & ANADIG_PMU_PMU_REF_CTRL_REF_CONTROL_MODE_MASK)
REF_CONTROL_MODE - REF_CONTROL_MODE 0b0..SW Control 0b1..HW Control
◆ ANADIG_PMU_PMU_REF_CTRL_REF_CONTROL_MODE [2/2]
◆ ANADIG_PMU_PMU_REF_CTRL_REF_ENABLE [1/2]
#define ANADIG_PMU_PMU_REF_CTRL_REF_ENABLE (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_REF_CTRL_REF_ENABLE_SHIFT)) & ANADIG_PMU_PMU_REF_CTRL_REF_ENABLE_MASK)
REF_ENABLE - REF_ENABLE
◆ ANADIG_PMU_PMU_REF_CTRL_REF_ENABLE [2/2]
◆ ANADIG_PMU_RBB_LPSR_CONFIGURE_OSCILLATOR_BITS [1/2]
#define ANADIG_PMU_RBB_LPSR_CONFIGURE_OSCILLATOR_BITS (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_CONFIGURE_OSCILLATOR_BITS_SHIFT)) & ANADIG_PMU_RBB_LPSR_CONFIGURE_OSCILLATOR_BITS_MASK)
OSCILLATOR_BITS - oscillator_bits
◆ ANADIG_PMU_RBB_LPSR_CONFIGURE_OSCILLATOR_BITS [2/2]
◆ ANADIG_PMU_RBB_LPSR_CONFIGURE_REGULATOR_STRENGTH [1/2]
#define ANADIG_PMU_RBB_LPSR_CONFIGURE_REGULATOR_STRENGTH (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_CONFIGURE_REGULATOR_STRENGTH_SHIFT)) & ANADIG_PMU_RBB_LPSR_CONFIGURE_REGULATOR_STRENGTH_MASK)
REGULATOR_STRENGTH - regulator_strength
◆ ANADIG_PMU_RBB_LPSR_CONFIGURE_REGULATOR_STRENGTH [2/2]
◆ ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_NW [1/2]
#define ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_NW (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_NW_SHIFT)) & ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_NW_MASK)
WB_CFG_NW - wb_cfg_nw
◆ ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_NW [2/2]
◆ ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_PW [1/2]
#define ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_PW (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_PW_SHIFT)) & ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_PW_MASK)
WB_CFG_PW - wb_cfg_pw
◆ ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_PW [2/2]
◆ ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT0 [1/2]
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT0 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT0_MASK)
◆ ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT0 [2/2]
◆ ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT1 [1/2]
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT1 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT1_MASK)
◆ ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT1 [2/2]
◆ ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT10 [1/2]
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT10 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT10_MASK)
◆ ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT10 [2/2]
◆ ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT11 [1/2]
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT11 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT11_MASK)
◆ ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT11 [2/2]
◆ ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT12 [1/2]
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT12 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT12_MASK)
◆ ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT12 [2/2]
◆ ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT13 [1/2]
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT13 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT13_MASK)
◆ ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT13 [2/2]
◆ ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT14 [1/2]
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT14 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT14_MASK)
◆ ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT14 [2/2]
◆ ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT15 [1/2]
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT15 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT15_MASK)
◆ ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT15 [2/2]
◆ ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT2 [1/2]
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT2 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT2_MASK)
◆ ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT2 [2/2]
◆ ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT3 [1/2]
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT3 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT3_MASK)
◆ ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT3 [2/2]
◆ ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT4 [1/2]
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT4 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT4_MASK)
◆ ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT4 [2/2]
◆ ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT5 [1/2]
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT5 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT5_MASK)
◆ ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT5 [2/2]
◆ ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT6 [1/2]
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT6 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT6_MASK)
◆ ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT6 [2/2]
◆ ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT7 [1/2]
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT7 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT7_MASK)
◆ ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT7 [2/2]
◆ ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT8 [1/2]
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT8 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT8_MASK)
◆ ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT8 [2/2]
◆ ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT9 [1/2]
#define ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT9 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT9_MASK)
◆ ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT9 [2/2]
◆ ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT0 [1/2]
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT0 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT0_MASK)
◆ ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT0 [2/2]
◆ ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT1 [1/2]
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT1 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT1_MASK)
◆ ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT1 [2/2]
◆ ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT10 [1/2]
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT10 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT10_MASK)
◆ ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT10 [2/2]
◆ ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT11 [1/2]
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT11 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT11_MASK)
◆ ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT11 [2/2]
◆ ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT12 [1/2]
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT12 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT12_MASK)
◆ ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT12 [2/2]
◆ ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT13 [1/2]
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT13 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT13_MASK)
◆ ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT13 [2/2]
◆ ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT14 [1/2]
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT14 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT14_MASK)
◆ ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT14 [2/2]
◆ ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT15 [1/2]
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT15 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT15_MASK)
◆ ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT15 [2/2]
◆ ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT2 [1/2]
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT2 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT2_MASK)
◆ ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT2 [2/2]
◆ ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT3 [1/2]
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT3 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT3_MASK)
◆ ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT3 [2/2]
◆ ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT4 [1/2]
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT4 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT4_MASK)
◆ ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT4 [2/2]
◆ ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT5 [1/2]
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT5 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT5_MASK)
◆ ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT5 [2/2]
◆ ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT6 [1/2]
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT6 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT6_MASK)
◆ ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT6 [2/2]
◆ ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT7 [1/2]
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT7 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT7_MASK)
◆ ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT7 [2/2]
◆ ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT8 [1/2]
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT8 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT8_MASK)
◆ ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT8 [2/2]
◆ ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT9 [1/2]
#define ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT9 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT9_MASK)
◆ ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT9 [2/2]
◆ ANADIG_PMU_RBB_SOC_CONFIGURE_OSCILLATOR_BITS [1/2]
#define ANADIG_PMU_RBB_SOC_CONFIGURE_OSCILLATOR_BITS (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_CONFIGURE_OSCILLATOR_BITS_SHIFT)) & ANADIG_PMU_RBB_SOC_CONFIGURE_OSCILLATOR_BITS_MASK)
◆ ANADIG_PMU_RBB_SOC_CONFIGURE_OSCILLATOR_BITS [2/2]
◆ ANADIG_PMU_RBB_SOC_CONFIGURE_REGULATOR_STRENGTH [1/2]
#define ANADIG_PMU_RBB_SOC_CONFIGURE_REGULATOR_STRENGTH (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_CONFIGURE_REGULATOR_STRENGTH_SHIFT)) & ANADIG_PMU_RBB_SOC_CONFIGURE_REGULATOR_STRENGTH_MASK)
◆ ANADIG_PMU_RBB_SOC_CONFIGURE_REGULATOR_STRENGTH [2/2]
◆ ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_NW [1/2]
#define ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_NW (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_NW_SHIFT)) & ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_NW_MASK)
◆ ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_NW [2/2]
◆ ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_PW [1/2]
#define ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_PW (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_PW_SHIFT)) & ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_PW_MASK)
◆ ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_PW [2/2]
◆ ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT0 [1/2]
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT0 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT0_MASK)
◆ ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT0 [2/2]
◆ ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT1 [1/2]
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT1 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT1_MASK)
◆ ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT1 [2/2]
◆ ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT10 [1/2]
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT10 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT10_MASK)
◆ ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT10 [2/2]
◆ ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT11 [1/2]
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT11 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT11_MASK)
◆ ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT11 [2/2]
◆ ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT12 [1/2]
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT12 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT12_MASK)
◆ ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT12 [2/2]
◆ ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT13 [1/2]
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT13 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT13_MASK)
◆ ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT13 [2/2]
◆ ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT14 [1/2]
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT14 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT14_MASK)
◆ ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT14 [2/2]
◆ ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT15 [1/2]
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT15 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT15_MASK)
◆ ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT15 [2/2]
◆ ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT2 [1/2]
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT2 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT2_MASK)
◆ ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT2 [2/2]
◆ ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT3 [1/2]
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT3 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT3_MASK)
◆ ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT3 [2/2]
◆ ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT4 [1/2]
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT4 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT4_MASK)
◆ ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT4 [2/2]
◆ ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT5 [1/2]
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT5 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT5_MASK)
◆ ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT5 [2/2]
◆ ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT6 [1/2]
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT6 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT6_MASK)
◆ ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT6 [2/2]
◆ ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT7 [1/2]
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT7 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT7_MASK)
◆ ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT7 [2/2]
◆ ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT8 [1/2]
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT8 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT8_MASK)
◆ ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT8 [2/2]
◆ ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT9 [1/2]
#define ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT9 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT9_MASK)
◆ ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT9 [2/2]
◆ ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT0 [1/2]
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT0 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT0_MASK)
◆ ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT0 [2/2]
◆ ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT1 [1/2]
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT1 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT1_MASK)
◆ ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT1 [2/2]
◆ ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT10 [1/2]
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT10 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT10_MASK)
◆ ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT10 [2/2]
◆ ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT11 [1/2]
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT11 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT11_MASK)
◆ ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT11 [2/2]
◆ ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT12 [1/2]
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT12 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT12_MASK)
◆ ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT12 [2/2]
◆ ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT13 [1/2]
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT13 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT13_MASK)
◆ ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT13 [2/2]
◆ ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT14 [1/2]
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT14 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT14_MASK)
◆ ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT14 [2/2]
◆ ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT15 [1/2]
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT15 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT15_MASK)
◆ ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT15 [2/2]
◆ ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT2 [1/2]
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT2 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT2_MASK)
◆ ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT2 [2/2]
◆ ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT3 [1/2]
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT3 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT3_MASK)
◆ ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT3 [2/2]
◆ ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT4 [1/2]
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT4 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT4_MASK)
◆ ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT4 [2/2]
◆ ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT5 [1/2]
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT5 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT5_MASK)
◆ ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT5 [2/2]
◆ ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT6 [1/2]
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT6 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT6_MASK)
◆ ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT6 [2/2]
◆ ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT7 [1/2]
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT7 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT7_MASK)
◆ ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT7 [2/2]
◆ ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT8 [1/2]
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT8 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT8_MASK)
◆ ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT8 [2/2]
◆ ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT9 [1/2]
#define ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT9 (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT9_MASK)
◆ ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT9 [2/2]
◆ ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_IBZTCADJ [1/2]
#define ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_IBZTCADJ (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_IBZTCADJ_SHIFT)) & ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_IBZTCADJ_MASK)
REFTOP_IBZTCADJ - REFTOP_IBZTCADJ
◆ ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_IBZTCADJ [2/2]
◆ ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_TRIM_EN [1/2]
#define ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_TRIM_EN (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_TRIM_EN_SHIFT)) & ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_TRIM_EN_MASK)
REFTOP_TRIM_EN - REFTOP_TRIM_EN
◆ ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_TRIM_EN [2/2]
◆ ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_VBGADJ [1/2]
#define ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_VBGADJ (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_VBGADJ_SHIFT)) & ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_VBGADJ_MASK)
REFTOP_VBGADJ - REFTOP_VBGADJ
◆ ANADIG_PMU_REFTOP_OTP_TRIM_VALUE_REFTOP_VBGADJ [2/2]
