RTEMS 6.1
PMU_LDO_LPSR_ANA - PMU_LDO_LPSR_ANA_REGISTER
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_REG_LP_EN_MASK   (0x1U)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_REG_LP_EN_SHIFT   (0U)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_REG_LP_EN(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_REG_LP_EN_SHIFT)) & ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_REG_LP_EN_MASK)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_REG_DISABLE_MASK   (0x4U)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_REG_DISABLE_SHIFT   (2U)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_REG_DISABLE(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_REG_DISABLE_SHIFT)) & ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_REG_DISABLE_MASK)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_PULL_DOWN_2MA_EN_MASK   (0x8U)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_PULL_DOWN_2MA_EN_SHIFT   (3U)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_PULL_DOWN_2MA_EN(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_PULL_DOWN_2MA_EN_SHIFT)) & ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_PULL_DOWN_2MA_EN_MASK)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_LPSR_ANA_CONTROL_MODE_MASK   (0x10U)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_LPSR_ANA_CONTROL_MODE_SHIFT   (4U)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_LPSR_ANA_CONTROL_MODE(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_LPSR_ANA_CONTROL_MODE_SHIFT)) & ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_LPSR_ANA_CONTROL_MODE_MASK)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_BYPASS_MODE_EN_MASK   (0x20U)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_BYPASS_MODE_EN_SHIFT   (5U)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_BYPASS_MODE_EN(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_BYPASS_MODE_EN_SHIFT)) & ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_BYPASS_MODE_EN_MASK)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_STANDBY_EN_MASK   (0x40U)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_STANDBY_EN_SHIFT   (6U)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_STANDBY_EN(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_STANDBY_EN_SHIFT)) & ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_STANDBY_EN_MASK)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_ALWAYS_4MA_PULLDOWN_EN_MASK   (0x100U)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_ALWAYS_4MA_PULLDOWN_EN_SHIFT   (8U)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_ALWAYS_4MA_PULLDOWN_EN(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_ALWAYS_4MA_PULLDOWN_EN_SHIFT)) & ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_ALWAYS_4MA_PULLDOWN_EN_MASK)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_TRACK_MODE_EN_MASK   (0x80000U)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_TRACK_MODE_EN_SHIFT   (19U)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_TRACK_MODE_EN(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_TRACK_MODE_EN_SHIFT)) & ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_TRACK_MODE_EN_MASK)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_PULL_DOWN_20UA_EN_MASK   (0x100000U)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_PULL_DOWN_20UA_EN_SHIFT   (20U)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_PULL_DOWN_20UA_EN(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_PULL_DOWN_20UA_EN_SHIFT)) & ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_PULL_DOWN_20UA_EN_MASK)
PMU_LDO_LPSR_DIG_2 - PMU_LDO_LPSR_DIG_2_REGISTER
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_2_VOLTAGE_STEP_INC_MASK   (0x3U)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_2_VOLTAGE_STEP_INC_SHIFT   (0U)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_2_VOLTAGE_STEP_INC(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_2_VOLTAGE_STEP_INC_SHIFT)) & ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_2_VOLTAGE_STEP_INC_MASK)
PMU_LDO_LPSR_DIG - PMU_LDO_LPSR_DIG_REGISTER
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_REG_EN_MASK   (0x4U)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_REG_EN_SHIFT   (2U)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_REG_EN(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_REG_EN_SHIFT)) & ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_REG_EN_MASK)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_LPSR_DIG_CONTROL_MODE_MASK   (0x20U)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_LPSR_DIG_CONTROL_MODE_SHIFT   (5U)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_LPSR_DIG_CONTROL_MODE(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_LPSR_DIG_CONTROL_MODE_SHIFT)) & ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_LPSR_DIG_CONTROL_MODE_MASK)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_STANDBY_EN_MASK   (0x40U)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_STANDBY_EN_SHIFT   (6U)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_STANDBY_EN(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_STANDBY_EN_SHIFT)) & ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_STANDBY_EN_MASK)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_TRACKING_MODE_MASK   (0x20000U)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_TRACKING_MODE_SHIFT   (17U)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_TRACKING_MODE(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_TRACKING_MODE_SHIFT)) & ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_TRACKING_MODE_MASK)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_BYPASS_MODE_MASK   (0x40000U)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_BYPASS_MODE_SHIFT   (18U)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_BYPASS_MODE(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_BYPASS_MODE_SHIFT)) & ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_BYPASS_MODE_MASK)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_VOLTAGE_SELECT_MASK   (0x1F00000U)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_VOLTAGE_SELECT_SHIFT   (20U)
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_VOLTAGE_SELECT(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_VOLTAGE_SELECT_SHIFT)) & ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_VOLTAGE_SELECT_MASK)
◆ ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_ALWAYS_4MA_PULLDOWN_EN [1/2]
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_ALWAYS_4MA_PULLDOWN_EN (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_ALWAYS_4MA_PULLDOWN_EN_SHIFT)) & ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_ALWAYS_4MA_PULLDOWN_EN_MASK)
ALWAYS_4MA_PULLDOWN_EN - always_4ma_pulldown_en
◆ ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_ALWAYS_4MA_PULLDOWN_EN [2/2]
◆ ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_BYPASS_MODE_EN [1/2]
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_BYPASS_MODE_EN (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_BYPASS_MODE_EN_SHIFT)) & ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_BYPASS_MODE_EN_MASK)
BYPASS_MODE_EN - bypass_mode_en
◆ ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_BYPASS_MODE_EN [2/2]
◆ ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_LPSR_ANA_CONTROL_MODE [1/2]
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_LPSR_ANA_CONTROL_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_LPSR_ANA_CONTROL_MODE_SHIFT)) & ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_LPSR_ANA_CONTROL_MODE_MASK)
LPSR_ANA_CONTROL_MODE - LPSR_ANA_CONTROL_MODE 0b0..SW Control 0b1..HW Control
◆ ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_LPSR_ANA_CONTROL_MODE [2/2]
◆ ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_PULL_DOWN_20UA_EN [1/2]
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_PULL_DOWN_20UA_EN (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_PULL_DOWN_20UA_EN_SHIFT)) & ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_PULL_DOWN_20UA_EN_MASK)
PULL_DOWN_20UA_EN - pull_down_20ua_en
◆ ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_PULL_DOWN_20UA_EN [2/2]
◆ ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_PULL_DOWN_2MA_EN [1/2]
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_PULL_DOWN_2MA_EN (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_PULL_DOWN_2MA_EN_SHIFT)) & ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_PULL_DOWN_2MA_EN_MASK)
PULL_DOWN_2MA_EN - pull_down_2ma_en
◆ ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_PULL_DOWN_2MA_EN [2/2]
◆ ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_REG_DISABLE [1/2]
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_REG_DISABLE (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_REG_DISABLE_SHIFT)) & ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_REG_DISABLE_MASK)
REG_DISABLE - reg_disable
◆ ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_REG_DISABLE [2/2]
◆ ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_REG_LP_EN [1/2]
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_REG_LP_EN (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_REG_LP_EN_SHIFT)) & ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_REG_LP_EN_MASK)
REG_LP_EN - reg_lp_en
◆ ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_REG_LP_EN [2/2]
◆ ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_STANDBY_EN [1/2]
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_STANDBY_EN (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_STANDBY_EN_SHIFT)) & ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_STANDBY_EN_MASK)
STANDBY_EN - standby_en
◆ ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_STANDBY_EN [2/2]
◆ ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_TRACK_MODE_EN [1/2]
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_TRACK_MODE_EN (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_TRACK_MODE_EN_SHIFT)) & ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_TRACK_MODE_EN_MASK)
TRACK_MODE_EN - Track Mode Enable 0b0..Normal use 0b1..Switch preparation
◆ ANADIG_LDO_SNVS_PMU_LDO_LPSR_ANA_TRACK_MODE_EN [2/2]
◆ ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_2_VOLTAGE_STEP_INC [1/2]
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_2_VOLTAGE_STEP_INC (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_2_VOLTAGE_STEP_INC_SHIFT)) & ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_2_VOLTAGE_STEP_INC_MASK)
VOLTAGE_STEP_INC - voltage_step_inc
◆ ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_2_VOLTAGE_STEP_INC [2/2]
◆ ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_BYPASS_MODE [1/2]
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_BYPASS_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_BYPASS_MODE_SHIFT)) & ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_BYPASS_MODE_MASK)
BYPASS_MODE - bypass_mode
◆ ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_BYPASS_MODE [2/2]
◆ ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_LPSR_DIG_CONTROL_MODE [1/2]
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_LPSR_DIG_CONTROL_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_LPSR_DIG_CONTROL_MODE_SHIFT)) & ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_LPSR_DIG_CONTROL_MODE_MASK)
LPSR_DIG_CONTROL_MODE - LPSR_DIG_CONTROL_MODE 0b0..SW Control 0b1..HW Control
◆ ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_LPSR_DIG_CONTROL_MODE [2/2]
◆ ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_REG_EN [1/2]
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_REG_EN (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_REG_EN_SHIFT)) & ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_REG_EN_MASK)
REG_EN - ENABLE_ILIMIT
◆ ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_REG_EN [2/2]
◆ ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_STANDBY_EN [1/2]
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_STANDBY_EN (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_STANDBY_EN_SHIFT)) & ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_STANDBY_EN_MASK)
◆ ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_STANDBY_EN [2/2]
◆ ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_TRACKING_MODE [1/2]
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_TRACKING_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_TRACKING_MODE_SHIFT)) & ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_TRACKING_MODE_MASK)
TRACKING_MODE - tracking_mode
◆ ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_TRACKING_MODE [2/2]
◆ ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_VOLTAGE_SELECT [1/2]
#define ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_VOLTAGE_SELECT (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_VOLTAGE_SELECT_SHIFT)) & ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_VOLTAGE_SELECT_MASK)
VOLTAGE_SELECT - VOLTAGE_SELECT 0b00000..Stable Voltage (range) 0b00001..Stable Voltage (range) 0b00010..Stable Voltage (range) 0b00011..Stable Voltage (range) 0b00100..Stable Voltage (range) 0b00101..Stable Voltage (range) 0b00110..Stable Voltage (range) 0b00111..Stable Voltage (range) 0b01000..Stable Voltage (range) 0b01001..Stable Voltage (range) 0b01010..Stable Voltage (range) 0b01011..Stable Voltage (range) 0b01100..Stable Voltage (range) 0b01101..Stable Voltage (range) 0b01110..Stable Voltage (range) 0b01111..Stable Voltage (range) 0b10000..Stable Voltage (range) 0b10001..Stable Voltage (range) 0b10010..Stable Voltage (range) 0b10011..Stable Voltage (range) 0b10100..Stable Voltage (range) 0b10101..Stable Voltage (range) 0b10110..Stable Voltage (range) 0b10111..Stable Voltage (range) 0b11000..Stable Voltage (range) 0b11001..Stable Voltage (range) 0b11010..Stable Voltage (range) 0b11011..Stable Voltage (range) 0b11100..Stable Voltage (range) 0b11101..Stable Voltage (range) 0b11110..Stable Voltage (range) 0b11111..Stable Voltage (range)
◆ ANADIG_LDO_SNVS_PMU_LDO_LPSR_DIG_VOLTAGE_SELECT [2/2]
