RTEMS 6.1
HAL ADC macro to manage HAL ADC handle, IT and flags.
#define __HAL_ADC_RESET_HANDLE_STATE(__HANDLE__)    ((__HANDLE__)->State = HAL_ADC_STATE_RESET)
 Reset ADC handle state.
#define __HAL_ADC_ENABLE_IT(__HANDLE__, __INTERRUPT__)    (((__HANDLE__)->Instance->IER) |= (__INTERRUPT__))
 Enable ADC interrupt.
#define __HAL_ADC_DISABLE_IT(__HANDLE__, __INTERRUPT__)    (((__HANDLE__)->Instance->IER) &= ~(__INTERRUPT__))
 Disable ADC interrupt.
#define __HAL_ADC_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__)    (((__HANDLE__)->Instance->IER & (__INTERRUPT__)) == (__INTERRUPT__))
 Checks if the specified ADC interrupt source is enabled or disabled.
#define __HAL_ADC_GET_FLAG(__HANDLE__, __FLAG__)    ((((__HANDLE__)->Instance->ISR) & (__FLAG__)) == (__FLAG__))
 Check whether the specified ADC flag is set or not.
#define __HAL_ADC_CLEAR_FLAG(__HANDLE__, __FLAG__)    (((__HANDLE__)->Instance->ISR) = (__FLAG__))
 Clear the specified ADC flag.
◆ __HAL_ADC_CLEAR_FLAG
#define __HAL_ADC_CLEAR_FLAG (   __HANDLE__,
  __FLAG__
Parameters
__HANDLE__ADC handle
__FLAG__ADC flag This parameter can be one of the following values:
Return values
None
◆ __HAL_ADC_DISABLE_IT
#define __HAL_ADC_DISABLE_IT (   __HANDLE__,
  __INTERRUPT__
Parameters
__INTERRUPT__ADC Interrupt This parameter can be one of the following values:
  • ADC_IT_RDY ADC Ready interrupt source
  • ADC_IT_EOSMP ADC End of Sampling interrupt source
  • ADC_IT_EOC ADC End of Regular Conversion interrupt source
  • ADC_IT_EOS ADC End of Regular sequence of Conversions interrupt source
  • ADC_IT_OVR ADC overrun interrupt source
  • ADC_IT_JEOC ADC End of Injected Conversion interrupt source
  • ADC_IT_JEOS ADC End of Injected sequence of Conversions interrupt source
  • ADC_IT_AWD1 ADC Analog watchdog 1 interrupt source (main analog watchdog)
  • ADC_IT_AWD2 ADC Analog watchdog 2 interrupt source (additional analog watchdog)
  • ADC_IT_AWD3 ADC Analog watchdog 3 interrupt source (additional analog watchdog)
  • ADC_IT_JQOVF ADC Injected Context Queue Overflow interrupt source.
Return values
None
◆ __HAL_ADC_ENABLE_IT
#define __HAL_ADC_ENABLE_IT (   __HANDLE__,
  __INTERRUPT__
Parameters
Return values
None
◆ __HAL_ADC_GET_FLAG
#define __HAL_ADC_GET_FLAG (   __HANDLE__,
  __FLAG__
Parameters
Return values
Stateof flag (TRUE or FALSE).
◆ __HAL_ADC_GET_IT_SOURCE
#define __HAL_ADC_GET_IT_SOURCE (   __HANDLE__,
  __INTERRUPT__
Parameters
__INTERRUPT__ADC interrupt source to check This parameter can be one of the following values:
Return values
Stateof interruption (SET or RESET)
◆ __HAL_ADC_RESET_HANDLE_STATE
#define __HAL_ADC_RESET_HANDLE_STATE (   __HANDLE__)     ((__HANDLE__)->State = HAL_ADC_STATE_RESET)
Parameters
Return values
None
