RTEMS 6.1
#define ADC_ETC_TRIGn_CTRL_COUNT   (8U)
#define ADC_ETC_TRIGn_COUNTER_COUNT   (8U)
#define ADC_ETC_TRIGn_CHAIN_1_0_COUNT   (8U)
#define ADC_ETC_TRIGn_CHAIN_3_2_COUNT   (8U)
#define ADC_ETC_TRIGn_CHAIN_5_4_COUNT   (8U)
#define ADC_ETC_TRIGn_CHAIN_7_6_COUNT   (8U)
#define ADC_ETC_TRIGn_RESULT_1_0_COUNT   (8U)
#define ADC_ETC_TRIGn_RESULT_3_2_COUNT   (8U)
#define ADC_ETC_TRIGn_RESULT_5_4_COUNT   (8U)
#define ADC_ETC_TRIGn_RESULT_7_6_COUNT   (8U)
CTRL - ADC_ETC Global Control Register
#define ADC_ETC_CTRL_TRIG_ENABLE_MASK   (0xFFU)
#define ADC_ETC_CTRL_TRIG_ENABLE_SHIFT   (0U)
#define ADC_ETC_CTRL_TRIG_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_CTRL_TRIG_ENABLE_SHIFT)) & ADC_ETC_CTRL_TRIG_ENABLE_MASK)
#define ADC_ETC_CTRL_EXT0_TRIG_ENABLE_MASK   (0x100U)
#define ADC_ETC_CTRL_EXT0_TRIG_ENABLE_SHIFT   (8U)
#define ADC_ETC_CTRL_EXT0_TRIG_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_CTRL_EXT0_TRIG_ENABLE_SHIFT)) & ADC_ETC_CTRL_EXT0_TRIG_ENABLE_MASK)
#define ADC_ETC_CTRL_EXT0_TRIG_PRIORITY_MASK   (0xE00U)
#define ADC_ETC_CTRL_EXT0_TRIG_PRIORITY_SHIFT   (9U)
#define ADC_ETC_CTRL_EXT0_TRIG_PRIORITY(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_CTRL_EXT0_TRIG_PRIORITY_SHIFT)) & ADC_ETC_CTRL_EXT0_TRIG_PRIORITY_MASK)
#define ADC_ETC_CTRL_EXT1_TRIG_ENABLE_MASK   (0x1000U)
#define ADC_ETC_CTRL_EXT1_TRIG_ENABLE_SHIFT   (12U)
#define ADC_ETC_CTRL_EXT1_TRIG_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_CTRL_EXT1_TRIG_ENABLE_SHIFT)) & ADC_ETC_CTRL_EXT1_TRIG_ENABLE_MASK)
#define ADC_ETC_CTRL_EXT1_TRIG_PRIORITY_MASK   (0xE000U)
#define ADC_ETC_CTRL_EXT1_TRIG_PRIORITY_SHIFT   (13U)
#define ADC_ETC_CTRL_EXT1_TRIG_PRIORITY(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_CTRL_EXT1_TRIG_PRIORITY_SHIFT)) & ADC_ETC_CTRL_EXT1_TRIG_PRIORITY_MASK)
#define ADC_ETC_CTRL_PRE_DIVIDER_MASK   (0xFF0000U)
#define ADC_ETC_CTRL_PRE_DIVIDER_SHIFT   (16U)
#define ADC_ETC_CTRL_PRE_DIVIDER(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_CTRL_PRE_DIVIDER_SHIFT)) & ADC_ETC_CTRL_PRE_DIVIDER_MASK)
#define ADC_ETC_CTRL_DMA_MODE_SEL_MASK   (0x20000000U)
#define ADC_ETC_CTRL_DMA_MODE_SEL_SHIFT   (29U)
#define ADC_ETC_CTRL_DMA_MODE_SEL(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_CTRL_DMA_MODE_SEL_SHIFT)) & ADC_ETC_CTRL_DMA_MODE_SEL_MASK)
#define ADC_ETC_CTRL_TSC_BYPASS_MASK   (0x40000000U)
#define ADC_ETC_CTRL_TSC_BYPASS_SHIFT   (30U)
#define ADC_ETC_CTRL_TSC_BYPASS(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_CTRL_TSC_BYPASS_SHIFT)) & ADC_ETC_CTRL_TSC_BYPASS_MASK)
#define ADC_ETC_CTRL_SOFTRST_MASK   (0x80000000U)
#define ADC_ETC_CTRL_SOFTRST_SHIFT   (31U)
#define ADC_ETC_CTRL_SOFTRST(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_CTRL_SOFTRST_SHIFT)) & ADC_ETC_CTRL_SOFTRST_MASK)
DONE0_1_IRQ - ETC DONE0 and DONE1 IRQ State Register
#define ADC_ETC_DONE0_1_IRQ_TRIG0_DONE0_MASK   (0x1U)
#define ADC_ETC_DONE0_1_IRQ_TRIG0_DONE0_SHIFT   (0U)
#define ADC_ETC_DONE0_1_IRQ_TRIG0_DONE0(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE0_1_IRQ_TRIG0_DONE0_SHIFT)) & ADC_ETC_DONE0_1_IRQ_TRIG0_DONE0_MASK)
#define ADC_ETC_DONE0_1_IRQ_TRIG1_DONE0_MASK   (0x2U)
#define ADC_ETC_DONE0_1_IRQ_TRIG1_DONE0_SHIFT   (1U)
#define ADC_ETC_DONE0_1_IRQ_TRIG1_DONE0(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE0_1_IRQ_TRIG1_DONE0_SHIFT)) & ADC_ETC_DONE0_1_IRQ_TRIG1_DONE0_MASK)
#define ADC_ETC_DONE0_1_IRQ_TRIG2_DONE0_MASK   (0x4U)
#define ADC_ETC_DONE0_1_IRQ_TRIG2_DONE0_SHIFT   (2U)
#define ADC_ETC_DONE0_1_IRQ_TRIG2_DONE0(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE0_1_IRQ_TRIG2_DONE0_SHIFT)) & ADC_ETC_DONE0_1_IRQ_TRIG2_DONE0_MASK)
#define ADC_ETC_DONE0_1_IRQ_TRIG3_DONE0_MASK   (0x8U)
#define ADC_ETC_DONE0_1_IRQ_TRIG3_DONE0_SHIFT   (3U)
#define ADC_ETC_DONE0_1_IRQ_TRIG3_DONE0(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE0_1_IRQ_TRIG3_DONE0_SHIFT)) & ADC_ETC_DONE0_1_IRQ_TRIG3_DONE0_MASK)
#define ADC_ETC_DONE0_1_IRQ_TRIG4_DONE0_MASK   (0x10U)
#define ADC_ETC_DONE0_1_IRQ_TRIG4_DONE0_SHIFT   (4U)
#define ADC_ETC_DONE0_1_IRQ_TRIG4_DONE0(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE0_1_IRQ_TRIG4_DONE0_SHIFT)) & ADC_ETC_DONE0_1_IRQ_TRIG4_DONE0_MASK)
#define ADC_ETC_DONE0_1_IRQ_TRIG5_DONE0_MASK   (0x20U)
#define ADC_ETC_DONE0_1_IRQ_TRIG5_DONE0_SHIFT   (5U)
#define ADC_ETC_DONE0_1_IRQ_TRIG5_DONE0(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE0_1_IRQ_TRIG5_DONE0_SHIFT)) & ADC_ETC_DONE0_1_IRQ_TRIG5_DONE0_MASK)
#define ADC_ETC_DONE0_1_IRQ_TRIG6_DONE0_MASK   (0x40U)
#define ADC_ETC_DONE0_1_IRQ_TRIG6_DONE0_SHIFT   (6U)
#define ADC_ETC_DONE0_1_IRQ_TRIG6_DONE0(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE0_1_IRQ_TRIG6_DONE0_SHIFT)) & ADC_ETC_DONE0_1_IRQ_TRIG6_DONE0_MASK)
#define ADC_ETC_DONE0_1_IRQ_TRIG7_DONE0_MASK   (0x80U)
#define ADC_ETC_DONE0_1_IRQ_TRIG7_DONE0_SHIFT   (7U)
#define ADC_ETC_DONE0_1_IRQ_TRIG7_DONE0(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE0_1_IRQ_TRIG7_DONE0_SHIFT)) & ADC_ETC_DONE0_1_IRQ_TRIG7_DONE0_MASK)
#define ADC_ETC_DONE0_1_IRQ_TRIG0_DONE1_MASK   (0x10000U)
#define ADC_ETC_DONE0_1_IRQ_TRIG0_DONE1_SHIFT   (16U)
#define ADC_ETC_DONE0_1_IRQ_TRIG0_DONE1(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE0_1_IRQ_TRIG0_DONE1_SHIFT)) & ADC_ETC_DONE0_1_IRQ_TRIG0_DONE1_MASK)
#define ADC_ETC_DONE0_1_IRQ_TRIG1_DONE1_MASK   (0x20000U)
#define ADC_ETC_DONE0_1_IRQ_TRIG1_DONE1_SHIFT   (17U)
#define ADC_ETC_DONE0_1_IRQ_TRIG1_DONE1(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE0_1_IRQ_TRIG1_DONE1_SHIFT)) & ADC_ETC_DONE0_1_IRQ_TRIG1_DONE1_MASK)
#define ADC_ETC_DONE0_1_IRQ_TRIG2_DONE1_MASK   (0x40000U)
#define ADC_ETC_DONE0_1_IRQ_TRIG2_DONE1_SHIFT   (18U)
#define ADC_ETC_DONE0_1_IRQ_TRIG2_DONE1(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE0_1_IRQ_TRIG2_DONE1_SHIFT)) & ADC_ETC_DONE0_1_IRQ_TRIG2_DONE1_MASK)
#define ADC_ETC_DONE0_1_IRQ_TRIG3_DONE1_MASK   (0x80000U)
#define ADC_ETC_DONE0_1_IRQ_TRIG3_DONE1_SHIFT   (19U)
#define ADC_ETC_DONE0_1_IRQ_TRIG3_DONE1(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE0_1_IRQ_TRIG3_DONE1_SHIFT)) & ADC_ETC_DONE0_1_IRQ_TRIG3_DONE1_MASK)
#define ADC_ETC_DONE0_1_IRQ_TRIG4_DONE1_MASK   (0x100000U)
#define ADC_ETC_DONE0_1_IRQ_TRIG4_DONE1_SHIFT   (20U)
#define ADC_ETC_DONE0_1_IRQ_TRIG4_DONE1(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE0_1_IRQ_TRIG4_DONE1_SHIFT)) & ADC_ETC_DONE0_1_IRQ_TRIG4_DONE1_MASK)
#define ADC_ETC_DONE0_1_IRQ_TRIG5_DONE1_MASK   (0x200000U)
#define ADC_ETC_DONE0_1_IRQ_TRIG5_DONE1_SHIFT   (21U)
#define ADC_ETC_DONE0_1_IRQ_TRIG5_DONE1(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE0_1_IRQ_TRIG5_DONE1_SHIFT)) & ADC_ETC_DONE0_1_IRQ_TRIG5_DONE1_MASK)
#define ADC_ETC_DONE0_1_IRQ_TRIG6_DONE1_MASK   (0x400000U)
#define ADC_ETC_DONE0_1_IRQ_TRIG6_DONE1_SHIFT   (22U)
#define ADC_ETC_DONE0_1_IRQ_TRIG6_DONE1(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE0_1_IRQ_TRIG6_DONE1_SHIFT)) & ADC_ETC_DONE0_1_IRQ_TRIG6_DONE1_MASK)
#define ADC_ETC_DONE0_1_IRQ_TRIG7_DONE1_MASK   (0x800000U)
#define ADC_ETC_DONE0_1_IRQ_TRIG7_DONE1_SHIFT   (23U)
#define ADC_ETC_DONE0_1_IRQ_TRIG7_DONE1(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE0_1_IRQ_TRIG7_DONE1_SHIFT)) & ADC_ETC_DONE0_1_IRQ_TRIG7_DONE1_MASK)
DONE2_3_ERR_IRQ - ETC DONE_2 and DONE_ERR IRQ State Register
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG0_DONE2_MASK   (0x1U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG0_DONE2_SHIFT   (0U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG0_DONE2(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG0_DONE2_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG0_DONE2_MASK)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG1_DONE2_MASK   (0x2U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG1_DONE2_SHIFT   (1U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG1_DONE2(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG1_DONE2_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG1_DONE2_MASK)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG2_DONE2_MASK   (0x4U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG2_DONE2_SHIFT   (2U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG2_DONE2(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG2_DONE2_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG2_DONE2_MASK)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG3_DONE2_MASK   (0x8U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG3_DONE2_SHIFT   (3U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG3_DONE2(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG3_DONE2_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG3_DONE2_MASK)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG4_DONE2_MASK   (0x10U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG4_DONE2_SHIFT   (4U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG4_DONE2(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG4_DONE2_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG4_DONE2_MASK)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG5_DONE2_MASK   (0x20U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG5_DONE2_SHIFT   (5U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG5_DONE2(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG5_DONE2_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG5_DONE2_MASK)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG6_DONE2_MASK   (0x40U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG6_DONE2_SHIFT   (6U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG6_DONE2(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG6_DONE2_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG6_DONE2_MASK)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG7_DONE2_MASK   (0x80U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG7_DONE2_SHIFT   (7U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG7_DONE2(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG7_DONE2_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG7_DONE2_MASK)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG0_ERR_MASK   (0x10000U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG0_ERR_SHIFT   (16U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG0_ERR(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG0_ERR_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG0_ERR_MASK)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG1_ERR_MASK   (0x20000U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG1_ERR_SHIFT   (17U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG1_ERR(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG1_ERR_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG1_ERR_MASK)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG2_ERR_MASK   (0x40000U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG2_ERR_SHIFT   (18U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG2_ERR(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG2_ERR_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG2_ERR_MASK)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG3_ERR_MASK   (0x80000U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG3_ERR_SHIFT   (19U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG3_ERR(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG3_ERR_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG3_ERR_MASK)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG4_ERR_MASK   (0x100000U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG4_ERR_SHIFT   (20U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG4_ERR(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG4_ERR_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG4_ERR_MASK)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG5_ERR_MASK   (0x200000U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG5_ERR_SHIFT   (21U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG5_ERR(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG5_ERR_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG5_ERR_MASK)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG6_ERR_MASK   (0x400000U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG6_ERR_SHIFT   (22U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG6_ERR(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG6_ERR_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG6_ERR_MASK)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG7_ERR_MASK   (0x800000U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG7_ERR_SHIFT   (23U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG7_ERR(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG7_ERR_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG7_ERR_MASK)
DMA_CTRL - ETC DMA control Register
#define ADC_ETC_DMA_CTRL_TRIG0_ENABLE_MASK   (0x1U)
#define ADC_ETC_DMA_CTRL_TRIG0_ENABLE_SHIFT   (0U)
#define ADC_ETC_DMA_CTRL_TRIG0_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DMA_CTRL_TRIG0_ENABLE_SHIFT)) & ADC_ETC_DMA_CTRL_TRIG0_ENABLE_MASK)
#define ADC_ETC_DMA_CTRL_TRIG1_ENABLE_MASK   (0x2U)
#define ADC_ETC_DMA_CTRL_TRIG1_ENABLE_SHIFT   (1U)
#define ADC_ETC_DMA_CTRL_TRIG1_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DMA_CTRL_TRIG1_ENABLE_SHIFT)) & ADC_ETC_DMA_CTRL_TRIG1_ENABLE_MASK)
#define ADC_ETC_DMA_CTRL_TRIG2_ENABLE_MASK   (0x4U)
#define ADC_ETC_DMA_CTRL_TRIG2_ENABLE_SHIFT   (2U)
#define ADC_ETC_DMA_CTRL_TRIG2_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DMA_CTRL_TRIG2_ENABLE_SHIFT)) & ADC_ETC_DMA_CTRL_TRIG2_ENABLE_MASK)
#define ADC_ETC_DMA_CTRL_TRIG3_ENABLE_MASK   (0x8U)
#define ADC_ETC_DMA_CTRL_TRIG3_ENABLE_SHIFT   (3U)
#define ADC_ETC_DMA_CTRL_TRIG3_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DMA_CTRL_TRIG3_ENABLE_SHIFT)) & ADC_ETC_DMA_CTRL_TRIG3_ENABLE_MASK)
#define ADC_ETC_DMA_CTRL_TRIG4_ENABLE_MASK   (0x10U)
#define ADC_ETC_DMA_CTRL_TRIG4_ENABLE_SHIFT   (4U)
#define ADC_ETC_DMA_CTRL_TRIG4_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DMA_CTRL_TRIG4_ENABLE_SHIFT)) & ADC_ETC_DMA_CTRL_TRIG4_ENABLE_MASK)
#define ADC_ETC_DMA_CTRL_TRIG5_ENABLE_MASK   (0x20U)
#define ADC_ETC_DMA_CTRL_TRIG5_ENABLE_SHIFT   (5U)
#define ADC_ETC_DMA_CTRL_TRIG5_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DMA_CTRL_TRIG5_ENABLE_SHIFT)) & ADC_ETC_DMA_CTRL_TRIG5_ENABLE_MASK)
#define ADC_ETC_DMA_CTRL_TRIG6_ENABLE_MASK   (0x40U)
#define ADC_ETC_DMA_CTRL_TRIG6_ENABLE_SHIFT   (6U)
#define ADC_ETC_DMA_CTRL_TRIG6_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DMA_CTRL_TRIG6_ENABLE_SHIFT)) & ADC_ETC_DMA_CTRL_TRIG6_ENABLE_MASK)
#define ADC_ETC_DMA_CTRL_TRIG7_ENABLE_MASK   (0x80U)
#define ADC_ETC_DMA_CTRL_TRIG7_ENABLE_SHIFT   (7U)
#define ADC_ETC_DMA_CTRL_TRIG7_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DMA_CTRL_TRIG7_ENABLE_SHIFT)) & ADC_ETC_DMA_CTRL_TRIG7_ENABLE_MASK)
#define ADC_ETC_DMA_CTRL_TRIG0_REQ_MASK   (0x10000U)
#define ADC_ETC_DMA_CTRL_TRIG0_REQ_SHIFT   (16U)
#define ADC_ETC_DMA_CTRL_TRIG0_REQ(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DMA_CTRL_TRIG0_REQ_SHIFT)) & ADC_ETC_DMA_CTRL_TRIG0_REQ_MASK)
#define ADC_ETC_DMA_CTRL_TRIG1_REQ_MASK   (0x20000U)
#define ADC_ETC_DMA_CTRL_TRIG1_REQ_SHIFT   (17U)
#define ADC_ETC_DMA_CTRL_TRIG1_REQ(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DMA_CTRL_TRIG1_REQ_SHIFT)) & ADC_ETC_DMA_CTRL_TRIG1_REQ_MASK)
#define ADC_ETC_DMA_CTRL_TRIG2_REQ_MASK   (0x40000U)
#define ADC_ETC_DMA_CTRL_TRIG2_REQ_SHIFT   (18U)
#define ADC_ETC_DMA_CTRL_TRIG2_REQ(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DMA_CTRL_TRIG2_REQ_SHIFT)) & ADC_ETC_DMA_CTRL_TRIG2_REQ_MASK)
#define ADC_ETC_DMA_CTRL_TRIG3_REQ_MASK   (0x80000U)
#define ADC_ETC_DMA_CTRL_TRIG3_REQ_SHIFT   (19U)
#define ADC_ETC_DMA_CTRL_TRIG3_REQ(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DMA_CTRL_TRIG3_REQ_SHIFT)) & ADC_ETC_DMA_CTRL_TRIG3_REQ_MASK)
#define ADC_ETC_DMA_CTRL_TRIG4_REQ_MASK   (0x100000U)
#define ADC_ETC_DMA_CTRL_TRIG4_REQ_SHIFT   (20U)
#define ADC_ETC_DMA_CTRL_TRIG4_REQ(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DMA_CTRL_TRIG4_REQ_SHIFT)) & ADC_ETC_DMA_CTRL_TRIG4_REQ_MASK)
#define ADC_ETC_DMA_CTRL_TRIG5_REQ_MASK   (0x200000U)
#define ADC_ETC_DMA_CTRL_TRIG5_REQ_SHIFT   (21U)
#define ADC_ETC_DMA_CTRL_TRIG5_REQ(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DMA_CTRL_TRIG5_REQ_SHIFT)) & ADC_ETC_DMA_CTRL_TRIG5_REQ_MASK)
#define ADC_ETC_DMA_CTRL_TRIG6_REQ_MASK   (0x400000U)
#define ADC_ETC_DMA_CTRL_TRIG6_REQ_SHIFT   (22U)
#define ADC_ETC_DMA_CTRL_TRIG6_REQ(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DMA_CTRL_TRIG6_REQ_SHIFT)) & ADC_ETC_DMA_CTRL_TRIG6_REQ_MASK)
#define ADC_ETC_DMA_CTRL_TRIG7_REQ_MASK   (0x800000U)
#define ADC_ETC_DMA_CTRL_TRIG7_REQ_SHIFT   (23U)
#define ADC_ETC_DMA_CTRL_TRIG7_REQ(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DMA_CTRL_TRIG7_REQ_SHIFT)) & ADC_ETC_DMA_CTRL_TRIG7_REQ_MASK)
TRIGn_CTRL - ETC_TRIG Control Register
#define ADC_ETC_TRIGn_CTRL_SW_TRIG_MASK   (0x1U)
#define ADC_ETC_TRIGn_CTRL_SW_TRIG_SHIFT   (0U)
#define ADC_ETC_TRIGn_CTRL_SW_TRIG(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CTRL_SW_TRIG_SHIFT)) & ADC_ETC_TRIGn_CTRL_SW_TRIG_MASK)
#define ADC_ETC_TRIGn_CTRL_TRIG_MODE_MASK   (0x10U)
#define ADC_ETC_TRIGn_CTRL_TRIG_MODE_SHIFT   (4U)
#define ADC_ETC_TRIGn_CTRL_TRIG_MODE(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CTRL_TRIG_MODE_SHIFT)) & ADC_ETC_TRIGn_CTRL_TRIG_MODE_MASK)
#define ADC_ETC_TRIGn_CTRL_TRIG_CHAIN_MASK   (0x700U)
#define ADC_ETC_TRIGn_CTRL_TRIG_CHAIN_SHIFT   (8U)
#define ADC_ETC_TRIGn_CTRL_TRIG_CHAIN(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CTRL_TRIG_CHAIN_SHIFT)) & ADC_ETC_TRIGn_CTRL_TRIG_CHAIN_MASK)
#define ADC_ETC_TRIGn_CTRL_TRIG_PRIORITY_MASK   (0x7000U)
#define ADC_ETC_TRIGn_CTRL_TRIG_PRIORITY_SHIFT   (12U)
#define ADC_ETC_TRIGn_CTRL_TRIG_PRIORITY(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CTRL_TRIG_PRIORITY_SHIFT)) & ADC_ETC_TRIGn_CTRL_TRIG_PRIORITY_MASK)
#define ADC_ETC_TRIGn_CTRL_SYNC_MODE_MASK   (0x10000U)
#define ADC_ETC_TRIGn_CTRL_SYNC_MODE_SHIFT   (16U)
#define ADC_ETC_TRIGn_CTRL_SYNC_MODE(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CTRL_SYNC_MODE_SHIFT)) & ADC_ETC_TRIGn_CTRL_SYNC_MODE_MASK)
TRIGn_COUNTER - ETC_TRIG Counter Register
#define ADC_ETC_TRIGn_COUNTER_INIT_DELAY_MASK   (0xFFFFU)
#define ADC_ETC_TRIGn_COUNTER_INIT_DELAY_SHIFT   (0U)
#define ADC_ETC_TRIGn_COUNTER_INIT_DELAY(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_COUNTER_INIT_DELAY_SHIFT)) & ADC_ETC_TRIGn_COUNTER_INIT_DELAY_MASK)
#define ADC_ETC_TRIGn_COUNTER_SAMPLE_INTERVAL_MASK   (0xFFFF0000U)
#define ADC_ETC_TRIGn_COUNTER_SAMPLE_INTERVAL_SHIFT   (16U)
#define ADC_ETC_TRIGn_COUNTER_SAMPLE_INTERVAL(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_COUNTER_SAMPLE_INTERVAL_SHIFT)) & ADC_ETC_TRIGn_COUNTER_SAMPLE_INTERVAL_MASK)
TRIGn_CHAIN_1_0 - ETC_TRIG Chain 0/1 Register
#define ADC_ETC_TRIGn_CHAIN_1_0_CSEL0_MASK   (0xFU)
#define ADC_ETC_TRIGn_CHAIN_1_0_CSEL0_SHIFT   (0U)
#define ADC_ETC_TRIGn_CHAIN_1_0_CSEL0(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_1_0_CSEL0_SHIFT)) & ADC_ETC_TRIGn_CHAIN_1_0_CSEL0_MASK)
#define ADC_ETC_TRIGn_CHAIN_1_0_HWTS0_MASK   (0xFF0U)
#define ADC_ETC_TRIGn_CHAIN_1_0_HWTS0_SHIFT   (4U)
#define ADC_ETC_TRIGn_CHAIN_1_0_HWTS0(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_1_0_HWTS0_SHIFT)) & ADC_ETC_TRIGn_CHAIN_1_0_HWTS0_MASK)
#define ADC_ETC_TRIGn_CHAIN_1_0_B2B0_MASK   (0x1000U)
#define ADC_ETC_TRIGn_CHAIN_1_0_B2B0_SHIFT   (12U)
#define ADC_ETC_TRIGn_CHAIN_1_0_B2B0(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_1_0_B2B0_SHIFT)) & ADC_ETC_TRIGn_CHAIN_1_0_B2B0_MASK)
#define ADC_ETC_TRIGn_CHAIN_1_0_IE0_MASK   (0x6000U)
#define ADC_ETC_TRIGn_CHAIN_1_0_IE0_SHIFT   (13U)
#define ADC_ETC_TRIGn_CHAIN_1_0_IE0(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_1_0_IE0_SHIFT)) & ADC_ETC_TRIGn_CHAIN_1_0_IE0_MASK)
#define ADC_ETC_TRIGn_CHAIN_1_0_CSEL1_MASK   (0xF0000U)
#define ADC_ETC_TRIGn_CHAIN_1_0_CSEL1_SHIFT   (16U)
#define ADC_ETC_TRIGn_CHAIN_1_0_CSEL1(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_1_0_CSEL1_SHIFT)) & ADC_ETC_TRIGn_CHAIN_1_0_CSEL1_MASK)
#define ADC_ETC_TRIGn_CHAIN_1_0_HWTS1_MASK   (0xFF00000U)
#define ADC_ETC_TRIGn_CHAIN_1_0_HWTS1_SHIFT   (20U)
#define ADC_ETC_TRIGn_CHAIN_1_0_HWTS1(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_1_0_HWTS1_SHIFT)) & ADC_ETC_TRIGn_CHAIN_1_0_HWTS1_MASK)
#define ADC_ETC_TRIGn_CHAIN_1_0_B2B1_MASK   (0x10000000U)
#define ADC_ETC_TRIGn_CHAIN_1_0_B2B1_SHIFT   (28U)
#define ADC_ETC_TRIGn_CHAIN_1_0_B2B1(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_1_0_B2B1_SHIFT)) & ADC_ETC_TRIGn_CHAIN_1_0_B2B1_MASK)
#define ADC_ETC_TRIGn_CHAIN_1_0_IE1_MASK   (0x60000000U)
#define ADC_ETC_TRIGn_CHAIN_1_0_IE1_SHIFT   (29U)
#define ADC_ETC_TRIGn_CHAIN_1_0_IE1(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_1_0_IE1_SHIFT)) & ADC_ETC_TRIGn_CHAIN_1_0_IE1_MASK)
TRIGn_CHAIN_3_2 - ETC_TRIG Chain 2/3 Register
#define ADC_ETC_TRIGn_CHAIN_3_2_CSEL2_MASK   (0xFU)
#define ADC_ETC_TRIGn_CHAIN_3_2_CSEL2_SHIFT   (0U)
#define ADC_ETC_TRIGn_CHAIN_3_2_CSEL2(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_3_2_CSEL2_SHIFT)) & ADC_ETC_TRIGn_CHAIN_3_2_CSEL2_MASK)
#define ADC_ETC_TRIGn_CHAIN_3_2_HWTS2_MASK   (0xFF0U)
#define ADC_ETC_TRIGn_CHAIN_3_2_HWTS2_SHIFT   (4U)
#define ADC_ETC_TRIGn_CHAIN_3_2_HWTS2(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_3_2_HWTS2_SHIFT)) & ADC_ETC_TRIGn_CHAIN_3_2_HWTS2_MASK)
#define ADC_ETC_TRIGn_CHAIN_3_2_B2B2_MASK   (0x1000U)
#define ADC_ETC_TRIGn_CHAIN_3_2_B2B2_SHIFT   (12U)
#define ADC_ETC_TRIGn_CHAIN_3_2_B2B2(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_3_2_B2B2_SHIFT)) & ADC_ETC_TRIGn_CHAIN_3_2_B2B2_MASK)
#define ADC_ETC_TRIGn_CHAIN_3_2_IE2_MASK   (0x6000U)
#define ADC_ETC_TRIGn_CHAIN_3_2_IE2_SHIFT   (13U)
#define ADC_ETC_TRIGn_CHAIN_3_2_IE2(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_3_2_IE2_SHIFT)) & ADC_ETC_TRIGn_CHAIN_3_2_IE2_MASK)
#define ADC_ETC_TRIGn_CHAIN_3_2_CSEL3_MASK   (0xF0000U)
#define ADC_ETC_TRIGn_CHAIN_3_2_CSEL3_SHIFT   (16U)
#define ADC_ETC_TRIGn_CHAIN_3_2_CSEL3(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_3_2_CSEL3_SHIFT)) & ADC_ETC_TRIGn_CHAIN_3_2_CSEL3_MASK)
#define ADC_ETC_TRIGn_CHAIN_3_2_HWTS3_MASK   (0xFF00000U)
#define ADC_ETC_TRIGn_CHAIN_3_2_HWTS3_SHIFT   (20U)
#define ADC_ETC_TRIGn_CHAIN_3_2_HWTS3(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_3_2_HWTS3_SHIFT)) & ADC_ETC_TRIGn_CHAIN_3_2_HWTS3_MASK)
#define ADC_ETC_TRIGn_CHAIN_3_2_B2B3_MASK   (0x10000000U)
#define ADC_ETC_TRIGn_CHAIN_3_2_B2B3_SHIFT   (28U)
#define ADC_ETC_TRIGn_CHAIN_3_2_B2B3(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_3_2_B2B3_SHIFT)) & ADC_ETC_TRIGn_CHAIN_3_2_B2B3_MASK)
#define ADC_ETC_TRIGn_CHAIN_3_2_IE3_MASK   (0x60000000U)
#define ADC_ETC_TRIGn_CHAIN_3_2_IE3_SHIFT   (29U)
#define ADC_ETC_TRIGn_CHAIN_3_2_IE3(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_3_2_IE3_SHIFT)) & ADC_ETC_TRIGn_CHAIN_3_2_IE3_MASK)
TRIGn_CHAIN_5_4 - ETC_TRIG Chain 4/5 Register
#define ADC_ETC_TRIGn_CHAIN_5_4_CSEL4_MASK   (0xFU)
#define ADC_ETC_TRIGn_CHAIN_5_4_CSEL4_SHIFT   (0U)
#define ADC_ETC_TRIGn_CHAIN_5_4_CSEL4(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_5_4_CSEL4_SHIFT)) & ADC_ETC_TRIGn_CHAIN_5_4_CSEL4_MASK)
#define ADC_ETC_TRIGn_CHAIN_5_4_HWTS4_MASK   (0xFF0U)
#define ADC_ETC_TRIGn_CHAIN_5_4_HWTS4_SHIFT   (4U)
#define ADC_ETC_TRIGn_CHAIN_5_4_HWTS4(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_5_4_HWTS4_SHIFT)) & ADC_ETC_TRIGn_CHAIN_5_4_HWTS4_MASK)
#define ADC_ETC_TRIGn_CHAIN_5_4_B2B4_MASK   (0x1000U)
#define ADC_ETC_TRIGn_CHAIN_5_4_B2B4_SHIFT   (12U)
#define ADC_ETC_TRIGn_CHAIN_5_4_B2B4(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_5_4_B2B4_SHIFT)) & ADC_ETC_TRIGn_CHAIN_5_4_B2B4_MASK)
#define ADC_ETC_TRIGn_CHAIN_5_4_IE4_MASK   (0x6000U)
#define ADC_ETC_TRIGn_CHAIN_5_4_IE4_SHIFT   (13U)
#define ADC_ETC_TRIGn_CHAIN_5_4_IE4(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_5_4_IE4_SHIFT)) & ADC_ETC_TRIGn_CHAIN_5_4_IE4_MASK)
#define ADC_ETC_TRIGn_CHAIN_5_4_CSEL5_MASK   (0xF0000U)
#define ADC_ETC_TRIGn_CHAIN_5_4_CSEL5_SHIFT   (16U)
#define ADC_ETC_TRIGn_CHAIN_5_4_CSEL5(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_5_4_CSEL5_SHIFT)) & ADC_ETC_TRIGn_CHAIN_5_4_CSEL5_MASK)
#define ADC_ETC_TRIGn_CHAIN_5_4_HWTS5_MASK   (0xFF00000U)
#define ADC_ETC_TRIGn_CHAIN_5_4_HWTS5_SHIFT   (20U)
#define ADC_ETC_TRIGn_CHAIN_5_4_HWTS5(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_5_4_HWTS5_SHIFT)) & ADC_ETC_TRIGn_CHAIN_5_4_HWTS5_MASK)
#define ADC_ETC_TRIGn_CHAIN_5_4_B2B5_MASK   (0x10000000U)
#define ADC_ETC_TRIGn_CHAIN_5_4_B2B5_SHIFT   (28U)
#define ADC_ETC_TRIGn_CHAIN_5_4_B2B5(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_5_4_B2B5_SHIFT)) & ADC_ETC_TRIGn_CHAIN_5_4_B2B5_MASK)
#define ADC_ETC_TRIGn_CHAIN_5_4_IE5_MASK   (0x60000000U)
#define ADC_ETC_TRIGn_CHAIN_5_4_IE5_SHIFT   (29U)
#define ADC_ETC_TRIGn_CHAIN_5_4_IE5(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_5_4_IE5_SHIFT)) & ADC_ETC_TRIGn_CHAIN_5_4_IE5_MASK)
TRIGn_CHAIN_7_6 - ETC_TRIG Chain 6/7 Register
#define ADC_ETC_TRIGn_CHAIN_7_6_CSEL6_MASK   (0xFU)
#define ADC_ETC_TRIGn_CHAIN_7_6_CSEL6_SHIFT   (0U)
#define ADC_ETC_TRIGn_CHAIN_7_6_CSEL6(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_7_6_CSEL6_SHIFT)) & ADC_ETC_TRIGn_CHAIN_7_6_CSEL6_MASK)
#define ADC_ETC_TRIGn_CHAIN_7_6_HWTS6_MASK   (0xFF0U)
#define ADC_ETC_TRIGn_CHAIN_7_6_HWTS6_SHIFT   (4U)
#define ADC_ETC_TRIGn_CHAIN_7_6_HWTS6(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_7_6_HWTS6_SHIFT)) & ADC_ETC_TRIGn_CHAIN_7_6_HWTS6_MASK)
#define ADC_ETC_TRIGn_CHAIN_7_6_B2B6_MASK   (0x1000U)
#define ADC_ETC_TRIGn_CHAIN_7_6_B2B6_SHIFT   (12U)
#define ADC_ETC_TRIGn_CHAIN_7_6_B2B6(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_7_6_B2B6_SHIFT)) & ADC_ETC_TRIGn_CHAIN_7_6_B2B6_MASK)
#define ADC_ETC_TRIGn_CHAIN_7_6_IE6_MASK   (0x6000U)
#define ADC_ETC_TRIGn_CHAIN_7_6_IE6_SHIFT   (13U)
#define ADC_ETC_TRIGn_CHAIN_7_6_IE6(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_7_6_IE6_SHIFT)) & ADC_ETC_TRIGn_CHAIN_7_6_IE6_MASK)
#define ADC_ETC_TRIGn_CHAIN_7_6_CSEL7_MASK   (0xF0000U)
#define ADC_ETC_TRIGn_CHAIN_7_6_CSEL7_SHIFT   (16U)
#define ADC_ETC_TRIGn_CHAIN_7_6_CSEL7(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_7_6_CSEL7_SHIFT)) & ADC_ETC_TRIGn_CHAIN_7_6_CSEL7_MASK)
#define ADC_ETC_TRIGn_CHAIN_7_6_HWTS7_MASK   (0xFF00000U)
#define ADC_ETC_TRIGn_CHAIN_7_6_HWTS7_SHIFT   (20U)
#define ADC_ETC_TRIGn_CHAIN_7_6_HWTS7(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_7_6_HWTS7_SHIFT)) & ADC_ETC_TRIGn_CHAIN_7_6_HWTS7_MASK)
#define ADC_ETC_TRIGn_CHAIN_7_6_B2B7_MASK   (0x10000000U)
#define ADC_ETC_TRIGn_CHAIN_7_6_B2B7_SHIFT   (28U)
#define ADC_ETC_TRIGn_CHAIN_7_6_B2B7(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_7_6_B2B7_SHIFT)) & ADC_ETC_TRIGn_CHAIN_7_6_B2B7_MASK)
#define ADC_ETC_TRIGn_CHAIN_7_6_IE7_MASK   (0x60000000U)
#define ADC_ETC_TRIGn_CHAIN_7_6_IE7_SHIFT   (29U)
#define ADC_ETC_TRIGn_CHAIN_7_6_IE7(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_7_6_IE7_SHIFT)) & ADC_ETC_TRIGn_CHAIN_7_6_IE7_MASK)
TRIGn_RESULT_1_0 - ETC_TRIG Result Data 1/0 Register
#define ADC_ETC_TRIGn_RESULT_1_0_DATA0_MASK   (0xFFFU)
#define ADC_ETC_TRIGn_RESULT_1_0_DATA0_SHIFT   (0U)
#define ADC_ETC_TRIGn_RESULT_1_0_DATA0(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_RESULT_1_0_DATA0_SHIFT)) & ADC_ETC_TRIGn_RESULT_1_0_DATA0_MASK)
#define ADC_ETC_TRIGn_RESULT_1_0_DATA1_MASK   (0xFFF0000U)
#define ADC_ETC_TRIGn_RESULT_1_0_DATA1_SHIFT   (16U)
#define ADC_ETC_TRIGn_RESULT_1_0_DATA1(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_RESULT_1_0_DATA1_SHIFT)) & ADC_ETC_TRIGn_RESULT_1_0_DATA1_MASK)
TRIGn_RESULT_3_2 - ETC_TRIG Result Data 3/2 Register
#define ADC_ETC_TRIGn_RESULT_3_2_DATA2_MASK   (0xFFFU)
#define ADC_ETC_TRIGn_RESULT_3_2_DATA2_SHIFT   (0U)
#define ADC_ETC_TRIGn_RESULT_3_2_DATA2(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_RESULT_3_2_DATA2_SHIFT)) & ADC_ETC_TRIGn_RESULT_3_2_DATA2_MASK)
#define ADC_ETC_TRIGn_RESULT_3_2_DATA3_MASK   (0xFFF0000U)
#define ADC_ETC_TRIGn_RESULT_3_2_DATA3_SHIFT   (16U)
#define ADC_ETC_TRIGn_RESULT_3_2_DATA3(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_RESULT_3_2_DATA3_SHIFT)) & ADC_ETC_TRIGn_RESULT_3_2_DATA3_MASK)
TRIGn_RESULT_5_4 - ETC_TRIG Result Data 5/4 Register
#define ADC_ETC_TRIGn_RESULT_5_4_DATA4_MASK   (0xFFFU)
#define ADC_ETC_TRIGn_RESULT_5_4_DATA4_SHIFT   (0U)
#define ADC_ETC_TRIGn_RESULT_5_4_DATA4(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_RESULT_5_4_DATA4_SHIFT)) & ADC_ETC_TRIGn_RESULT_5_4_DATA4_MASK)
#define ADC_ETC_TRIGn_RESULT_5_4_DATA5_MASK   (0xFFF0000U)
#define ADC_ETC_TRIGn_RESULT_5_4_DATA5_SHIFT   (16U)
#define ADC_ETC_TRIGn_RESULT_5_4_DATA5(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_RESULT_5_4_DATA5_SHIFT)) & ADC_ETC_TRIGn_RESULT_5_4_DATA5_MASK)
TRIGn_RESULT_7_6 - ETC_TRIG Result Data 7/6 Register
#define ADC_ETC_TRIGn_RESULT_7_6_DATA6_MASK   (0xFFFU)
#define ADC_ETC_TRIGn_RESULT_7_6_DATA6_SHIFT   (0U)
#define ADC_ETC_TRIGn_RESULT_7_6_DATA6(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_RESULT_7_6_DATA6_SHIFT)) & ADC_ETC_TRIGn_RESULT_7_6_DATA6_MASK)
#define ADC_ETC_TRIGn_RESULT_7_6_DATA7_MASK   (0xFFF0000U)
#define ADC_ETC_TRIGn_RESULT_7_6_DATA7_SHIFT   (16U)
#define ADC_ETC_TRIGn_RESULT_7_6_DATA7(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_RESULT_7_6_DATA7_SHIFT)) & ADC_ETC_TRIGn_RESULT_7_6_DATA7_MASK)
DONE2_3_ERR_IRQ - ETC DONE_2, DONE_3 and DONE_ERR IRQ State Register
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG0_DONE3_MASK   (0x100U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG0_DONE3_SHIFT   (8U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG0_DONE3(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG0_DONE3_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG0_DONE3_MASK)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG1_DONE3_MASK   (0x200U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG1_DONE3_SHIFT   (9U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG1_DONE3(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG1_DONE3_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG1_DONE3_MASK)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG2_DONE3_MASK   (0x400U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG2_DONE3_SHIFT   (10U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG2_DONE3(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG2_DONE3_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG2_DONE3_MASK)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG3_DONE3_MASK   (0x800U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG3_DONE3_SHIFT   (11U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG3_DONE3(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG3_DONE3_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG3_DONE3_MASK)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG4_DONE3_MASK   (0x1000U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG4_DONE3_SHIFT   (12U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG4_DONE3(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG4_DONE3_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG4_DONE3_MASK)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG5_DONE3_MASK   (0x2000U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG5_DONE3_SHIFT   (13U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG5_DONE3(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG5_DONE3_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG5_DONE3_MASK)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG6_DONE3_MASK   (0x4000U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG6_DONE3_SHIFT   (14U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG6_DONE3(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG6_DONE3_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG6_DONE3_MASK)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG7_DONE3_MASK   (0x8000U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG7_DONE3_SHIFT   (15U)
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG7_DONE3(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG7_DONE3_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG7_DONE3_MASK)
#define ADC_ETC_TRIGn_CTRL_CHAINx_DONE_MASK   (0xFF000000U)
#define ADC_ETC_TRIGn_CTRL_CHAINx_DONE_SHIFT   (24U)
#define ADC_ETC_TRIGn_CTRL_CHAINx_DONE(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CTRL_CHAINx_DONE_SHIFT)) & ADC_ETC_TRIGn_CTRL_CHAINx_DONE_MASK)
#define ADC_ETC_TRIGn_CHAIN_1_0_IE0_EN_MASK   (0x8000U)
#define ADC_ETC_TRIGn_CHAIN_1_0_IE0_EN_SHIFT   (15U)
#define ADC_ETC_TRIGn_CHAIN_1_0_IE0_EN(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_1_0_IE0_EN_SHIFT)) & ADC_ETC_TRIGn_CHAIN_1_0_IE0_EN_MASK)
#define ADC_ETC_TRIGn_CHAIN_1_0_IE1_EN_MASK   (0x80000000U)
#define ADC_ETC_TRIGn_CHAIN_1_0_IE1_EN_SHIFT   (31U)
#define ADC_ETC_TRIGn_CHAIN_1_0_IE1_EN(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_1_0_IE1_EN_SHIFT)) & ADC_ETC_TRIGn_CHAIN_1_0_IE1_EN_MASK)
#define ADC_ETC_TRIGn_CHAIN_3_2_IE2_EN_MASK   (0x8000U)
#define ADC_ETC_TRIGn_CHAIN_3_2_IE2_EN_SHIFT   (15U)
#define ADC_ETC_TRIGn_CHAIN_3_2_IE2_EN(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_3_2_IE2_EN_SHIFT)) & ADC_ETC_TRIGn_CHAIN_3_2_IE2_EN_MASK)
#define ADC_ETC_TRIGn_CHAIN_3_2_IE3_EN_MASK   (0x80000000U)
#define ADC_ETC_TRIGn_CHAIN_3_2_IE3_EN_SHIFT   (31U)
#define ADC_ETC_TRIGn_CHAIN_3_2_IE3_EN(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_3_2_IE3_EN_SHIFT)) & ADC_ETC_TRIGn_CHAIN_3_2_IE3_EN_MASK)
#define ADC_ETC_TRIGn_CHAIN_5_4_IE4_EN_MASK   (0x8000U)
#define ADC_ETC_TRIGn_CHAIN_5_4_IE4_EN_SHIFT   (15U)
#define ADC_ETC_TRIGn_CHAIN_5_4_IE4_EN(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_5_4_IE4_EN_SHIFT)) & ADC_ETC_TRIGn_CHAIN_5_4_IE4_EN_MASK)
#define ADC_ETC_TRIGn_CHAIN_5_4_IE5_EN_MASK   (0x80000000U)
#define ADC_ETC_TRIGn_CHAIN_5_4_IE5_EN_SHIFT   (31U)
#define ADC_ETC_TRIGn_CHAIN_5_4_IE5_EN(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_5_4_IE5_EN_SHIFT)) & ADC_ETC_TRIGn_CHAIN_5_4_IE5_EN_MASK)
#define ADC_ETC_TRIGn_CHAIN_7_6_IE6_EN_MASK   (0x8000U)
#define ADC_ETC_TRIGn_CHAIN_7_6_IE6_EN_SHIFT   (15U)
#define ADC_ETC_TRIGn_CHAIN_7_6_IE6_EN(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_7_6_IE6_EN_SHIFT)) & ADC_ETC_TRIGn_CHAIN_7_6_IE6_EN_MASK)
#define ADC_ETC_TRIGn_CHAIN_7_6_IE7_EN_MASK   (0x80000000U)
#define ADC_ETC_TRIGn_CHAIN_7_6_IE7_EN_SHIFT   (31U)
#define ADC_ETC_TRIGn_CHAIN_7_6_IE7_EN(x)   (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_7_6_IE7_EN_SHIFT)) & ADC_ETC_TRIGn_CHAIN_7_6_IE7_EN_MASK)
◆ ADC_ETC_CTRL_DMA_MODE_SEL [1/3]
#define ADC_ETC_CTRL_DMA_MODE_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_CTRL_DMA_MODE_SEL_SHIFT)) & ADC_ETC_CTRL_DMA_MODE_SEL_MASK)
DMA_MODE_SEL 0b0..Trig DMA_REQ with latched signal, REQ will be cleared when ACK and source request cleared. 0b1..Trig DMA_REQ with pulsed signal, REQ will be cleared by ACK only.
◆ ADC_ETC_CTRL_DMA_MODE_SEL [2/3]
◆ ADC_ETC_CTRL_DMA_MODE_SEL [3/3]
◆ ADC_ETC_CTRL_EXT0_TRIG_ENABLE
#define ADC_ETC_CTRL_EXT0_TRIG_ENABLE (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_CTRL_EXT0_TRIG_ENABLE_SHIFT)) & ADC_ETC_CTRL_EXT0_TRIG_ENABLE_MASK)
EXT0_TRIG_ENABLE 0b0..disable external TSC0 trigger. 0b1..enable external TSC0 trigger.
◆ ADC_ETC_CTRL_EXT1_TRIG_ENABLE
#define ADC_ETC_CTRL_EXT1_TRIG_ENABLE (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_CTRL_EXT1_TRIG_ENABLE_SHIFT)) & ADC_ETC_CTRL_EXT1_TRIG_ENABLE_MASK)
EXT1_TRIG_ENABLE 0b0..disable external TSC1 trigger. 0b1..enable external TSC1 trigger.
◆ ADC_ETC_CTRL_SOFTRST [1/3]
#define ADC_ETC_CTRL_SOFTRST (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_CTRL_SOFTRST_SHIFT)) & ADC_ETC_CTRL_SOFTRST_MASK)
SOFTRST 0b0..ADC_ETC works normally. 0b1..All registers inside ADC_ETC will be reset to the default value.
◆ ADC_ETC_CTRL_SOFTRST [2/3]
◆ ADC_ETC_CTRL_SOFTRST [3/3]
◆ ADC_ETC_CTRL_TRIG_ENABLE [1/3]
#define ADC_ETC_CTRL_TRIG_ENABLE (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_CTRL_TRIG_ENABLE_SHIFT)) & ADC_ETC_CTRL_TRIG_ENABLE_MASK)
TRIG_ENABLE 0b00000000..disable all 8 external XBAR triggers. 0b00000001..enable external XBAR trigger0. 0b00000010..enable external XBAR trigger1. 0b00000011..enable external XBAR trigger0 and trigger1. 0b11111111..enable all 8 external XBAR triggers.
◆ ADC_ETC_CTRL_TRIG_ENABLE [2/3]
◆ ADC_ETC_CTRL_TRIG_ENABLE [3/3]
◆ ADC_ETC_CTRL_TSC_BYPASS
#define ADC_ETC_CTRL_TSC_BYPASS (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_CTRL_TSC_BYPASS_SHIFT)) & ADC_ETC_CTRL_TSC_BYPASS_MASK)
TSC_BYPASS 0b0..TSC not bypassed. 0b1..TSC is bypassed to ADC2, that means TSC will control ADC2 directly.
◆ ADC_ETC_DMA_CTRL_TRIG0_ENABLE [1/3]
#define ADC_ETC_DMA_CTRL_TRIG0_ENABLE (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DMA_CTRL_TRIG0_ENABLE_SHIFT)) & ADC_ETC_DMA_CTRL_TRIG0_ENABLE_MASK)
TRIG0_ENABLE 0b0..TRIG0 DMA request disabled. 0b1..TRIG0 DMA request enabled.
◆ ADC_ETC_DMA_CTRL_TRIG0_ENABLE [2/3]
◆ ADC_ETC_DMA_CTRL_TRIG0_ENABLE [3/3]
◆ ADC_ETC_DMA_CTRL_TRIG0_REQ [1/3]
#define ADC_ETC_DMA_CTRL_TRIG0_REQ (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DMA_CTRL_TRIG0_REQ_SHIFT)) & ADC_ETC_DMA_CTRL_TRIG0_REQ_MASK)
TRIG0_REQ 0b0..TRIG0_REQ not detected. 0b1..TRIG0_REQ detected.
◆ ADC_ETC_DMA_CTRL_TRIG0_REQ [2/3]
◆ ADC_ETC_DMA_CTRL_TRIG0_REQ [3/3]
◆ ADC_ETC_DMA_CTRL_TRIG1_ENABLE [1/3]
#define ADC_ETC_DMA_CTRL_TRIG1_ENABLE (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DMA_CTRL_TRIG1_ENABLE_SHIFT)) & ADC_ETC_DMA_CTRL_TRIG1_ENABLE_MASK)
TRIG1_ENABLE 0b0..TRIG1 DMA request disabled. 0b1..TRIG1 DMA request enabled.
◆ ADC_ETC_DMA_CTRL_TRIG1_ENABLE [2/3]
◆ ADC_ETC_DMA_CTRL_TRIG1_ENABLE [3/3]
◆ ADC_ETC_DMA_CTRL_TRIG1_REQ [1/3]
#define ADC_ETC_DMA_CTRL_TRIG1_REQ (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DMA_CTRL_TRIG1_REQ_SHIFT)) & ADC_ETC_DMA_CTRL_TRIG1_REQ_MASK)
TRIG1_REQ 0b0..TRIG1_REQ not detected. 0b1..TRIG1_REQ detected.
◆ ADC_ETC_DMA_CTRL_TRIG1_REQ [2/3]
◆ ADC_ETC_DMA_CTRL_TRIG1_REQ [3/3]
◆ ADC_ETC_DMA_CTRL_TRIG2_ENABLE [1/3]
#define ADC_ETC_DMA_CTRL_TRIG2_ENABLE (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DMA_CTRL_TRIG2_ENABLE_SHIFT)) & ADC_ETC_DMA_CTRL_TRIG2_ENABLE_MASK)
TRIG2_ENABLE 0b0..TRIG2 DMA request disabled. 0b1..TRIG2 DMA request enabled.
◆ ADC_ETC_DMA_CTRL_TRIG2_ENABLE [2/3]
◆ ADC_ETC_DMA_CTRL_TRIG2_ENABLE [3/3]
◆ ADC_ETC_DMA_CTRL_TRIG2_REQ [1/3]
#define ADC_ETC_DMA_CTRL_TRIG2_REQ (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DMA_CTRL_TRIG2_REQ_SHIFT)) & ADC_ETC_DMA_CTRL_TRIG2_REQ_MASK)
TRIG2_REQ 0b0..TRIG2_REQ not detected. 0b1..TRIG2_REQ detected.
◆ ADC_ETC_DMA_CTRL_TRIG2_REQ [2/3]
◆ ADC_ETC_DMA_CTRL_TRIG2_REQ [3/3]
◆ ADC_ETC_DMA_CTRL_TRIG3_ENABLE [1/3]
#define ADC_ETC_DMA_CTRL_TRIG3_ENABLE (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DMA_CTRL_TRIG3_ENABLE_SHIFT)) & ADC_ETC_DMA_CTRL_TRIG3_ENABLE_MASK)
TRIG3_ENABLE 0b0..TRIG3 DMA request disabled. 0b1..TRIG3 DMA request enabled.
◆ ADC_ETC_DMA_CTRL_TRIG3_ENABLE [2/3]
◆ ADC_ETC_DMA_CTRL_TRIG3_ENABLE [3/3]
◆ ADC_ETC_DMA_CTRL_TRIG3_REQ [1/3]
#define ADC_ETC_DMA_CTRL_TRIG3_REQ (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DMA_CTRL_TRIG3_REQ_SHIFT)) & ADC_ETC_DMA_CTRL_TRIG3_REQ_MASK)
TRIG3_REQ 0b0..TRIG3_REQ not detected. 0b1..TRIG3_REQ detected.
◆ ADC_ETC_DMA_CTRL_TRIG3_REQ [2/3]
◆ ADC_ETC_DMA_CTRL_TRIG3_REQ [3/3]
◆ ADC_ETC_DMA_CTRL_TRIG4_ENABLE [1/3]
#define ADC_ETC_DMA_CTRL_TRIG4_ENABLE (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DMA_CTRL_TRIG4_ENABLE_SHIFT)) & ADC_ETC_DMA_CTRL_TRIG4_ENABLE_MASK)
TRIG4_ENABLE 0b0..TRIG4 DMA request disabled. 0b1..TRIG4 DMA request enabled.
◆ ADC_ETC_DMA_CTRL_TRIG4_ENABLE [2/3]
◆ ADC_ETC_DMA_CTRL_TRIG4_ENABLE [3/3]
◆ ADC_ETC_DMA_CTRL_TRIG4_REQ [1/3]
#define ADC_ETC_DMA_CTRL_TRIG4_REQ (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DMA_CTRL_TRIG4_REQ_SHIFT)) & ADC_ETC_DMA_CTRL_TRIG4_REQ_MASK)
TRIG4_REQ 0b0..TRIG4_REQ not detected. 0b1..TRIG4_REQ detected.
◆ ADC_ETC_DMA_CTRL_TRIG4_REQ [2/3]
◆ ADC_ETC_DMA_CTRL_TRIG4_REQ [3/3]
◆ ADC_ETC_DMA_CTRL_TRIG5_ENABLE [1/3]
#define ADC_ETC_DMA_CTRL_TRIG5_ENABLE (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DMA_CTRL_TRIG5_ENABLE_SHIFT)) & ADC_ETC_DMA_CTRL_TRIG5_ENABLE_MASK)
TRIG5_ENABLE 0b0..TRIG5 DMA request disabled. 0b1..TRIG5 DMA request enabled.
◆ ADC_ETC_DMA_CTRL_TRIG5_ENABLE [2/3]
◆ ADC_ETC_DMA_CTRL_TRIG5_ENABLE [3/3]
◆ ADC_ETC_DMA_CTRL_TRIG5_REQ [1/3]
#define ADC_ETC_DMA_CTRL_TRIG5_REQ (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DMA_CTRL_TRIG5_REQ_SHIFT)) & ADC_ETC_DMA_CTRL_TRIG5_REQ_MASK)
TRIG5_REQ 0b0..TRIG5_REQ not detected. 0b1..TRIG5_REQ detected.
◆ ADC_ETC_DMA_CTRL_TRIG5_REQ [2/3]
◆ ADC_ETC_DMA_CTRL_TRIG5_REQ [3/3]
◆ ADC_ETC_DMA_CTRL_TRIG6_ENABLE [1/3]
#define ADC_ETC_DMA_CTRL_TRIG6_ENABLE (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DMA_CTRL_TRIG6_ENABLE_SHIFT)) & ADC_ETC_DMA_CTRL_TRIG6_ENABLE_MASK)
TRIG6_ENABLE 0b0..TRIG6 DMA request disabled. 0b1..TRIG6 DMA request enabled.
◆ ADC_ETC_DMA_CTRL_TRIG6_ENABLE [2/3]
◆ ADC_ETC_DMA_CTRL_TRIG6_ENABLE [3/3]
◆ ADC_ETC_DMA_CTRL_TRIG6_REQ [1/3]
#define ADC_ETC_DMA_CTRL_TRIG6_REQ (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DMA_CTRL_TRIG6_REQ_SHIFT)) & ADC_ETC_DMA_CTRL_TRIG6_REQ_MASK)
TRIG6_REQ 0b0..TRIG6_REQ not detected. 0b1..TRIG6_REQ detected.
◆ ADC_ETC_DMA_CTRL_TRIG6_REQ [2/3]
◆ ADC_ETC_DMA_CTRL_TRIG6_REQ [3/3]
◆ ADC_ETC_DMA_CTRL_TRIG7_ENABLE [1/3]
#define ADC_ETC_DMA_CTRL_TRIG7_ENABLE (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DMA_CTRL_TRIG7_ENABLE_SHIFT)) & ADC_ETC_DMA_CTRL_TRIG7_ENABLE_MASK)
TRIG7_ENABLE 0b0..TRIG7 DMA request disabled. 0b1..TRIG7 DMA request enabled.
◆ ADC_ETC_DMA_CTRL_TRIG7_ENABLE [2/3]
◆ ADC_ETC_DMA_CTRL_TRIG7_ENABLE [3/3]
◆ ADC_ETC_DMA_CTRL_TRIG7_REQ [1/3]
#define ADC_ETC_DMA_CTRL_TRIG7_REQ (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DMA_CTRL_TRIG7_REQ_SHIFT)) & ADC_ETC_DMA_CTRL_TRIG7_REQ_MASK)
TRIG7_REQ 0b0..TRIG7_REQ not detected. 0b1..TRIG7_REQ detected.
◆ ADC_ETC_DMA_CTRL_TRIG7_REQ [2/3]
◆ ADC_ETC_DMA_CTRL_TRIG7_REQ [3/3]
◆ ADC_ETC_DONE0_1_IRQ_TRIG0_DONE0 [1/3]
#define ADC_ETC_DONE0_1_IRQ_TRIG0_DONE0 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE0_1_IRQ_TRIG0_DONE0_SHIFT)) & ADC_ETC_DONE0_1_IRQ_TRIG0_DONE0_MASK)
TRIG0_DONE0 0b0..No TRIG0_DONE0 interrupt detected 0b1..TRIG0_DONE0 interrupt detected
◆ ADC_ETC_DONE0_1_IRQ_TRIG0_DONE0 [2/3]
◆ ADC_ETC_DONE0_1_IRQ_TRIG0_DONE0 [3/3]
◆ ADC_ETC_DONE0_1_IRQ_TRIG0_DONE1 [1/3]
#define ADC_ETC_DONE0_1_IRQ_TRIG0_DONE1 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE0_1_IRQ_TRIG0_DONE1_SHIFT)) & ADC_ETC_DONE0_1_IRQ_TRIG0_DONE1_MASK)
TRIG0_DONE1 0b0..No TRIG0_DONE1 interrupt detected 0b1..TRIG0_DONE1 interrupt detected
◆ ADC_ETC_DONE0_1_IRQ_TRIG0_DONE1 [2/3]
◆ ADC_ETC_DONE0_1_IRQ_TRIG0_DONE1 [3/3]
◆ ADC_ETC_DONE0_1_IRQ_TRIG1_DONE0 [1/3]
#define ADC_ETC_DONE0_1_IRQ_TRIG1_DONE0 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE0_1_IRQ_TRIG1_DONE0_SHIFT)) & ADC_ETC_DONE0_1_IRQ_TRIG1_DONE0_MASK)
TRIG1_DONE0 0b0..No TRIG1_DONE0 interrupt detected 0b1..TRIG1_DONE0 interrupt detected
◆ ADC_ETC_DONE0_1_IRQ_TRIG1_DONE0 [2/3]
◆ ADC_ETC_DONE0_1_IRQ_TRIG1_DONE0 [3/3]
◆ ADC_ETC_DONE0_1_IRQ_TRIG1_DONE1 [1/3]
#define ADC_ETC_DONE0_1_IRQ_TRIG1_DONE1 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE0_1_IRQ_TRIG1_DONE1_SHIFT)) & ADC_ETC_DONE0_1_IRQ_TRIG1_DONE1_MASK)
TRIG1_DONE1 0b0..No TRIG1_DONE1 interrupt detected 0b1..TRIG1_DONE1 interrupt detected
◆ ADC_ETC_DONE0_1_IRQ_TRIG1_DONE1 [2/3]
◆ ADC_ETC_DONE0_1_IRQ_TRIG1_DONE1 [3/3]
◆ ADC_ETC_DONE0_1_IRQ_TRIG2_DONE0 [1/3]
#define ADC_ETC_DONE0_1_IRQ_TRIG2_DONE0 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE0_1_IRQ_TRIG2_DONE0_SHIFT)) & ADC_ETC_DONE0_1_IRQ_TRIG2_DONE0_MASK)
TRIG2_DONE0 0b0..No TRIG2_DONE0 interrupt detected 0b1..TRIG2_DONE0 interrupt detected
◆ ADC_ETC_DONE0_1_IRQ_TRIG2_DONE0 [2/3]
◆ ADC_ETC_DONE0_1_IRQ_TRIG2_DONE0 [3/3]
◆ ADC_ETC_DONE0_1_IRQ_TRIG2_DONE1 [1/3]
#define ADC_ETC_DONE0_1_IRQ_TRIG2_DONE1 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE0_1_IRQ_TRIG2_DONE1_SHIFT)) & ADC_ETC_DONE0_1_IRQ_TRIG2_DONE1_MASK)
TRIG2_DONE1 0b0..No TRIG2_DONE1 interrupt detected 0b1..TRIG2_DONE1 interrupt detected
◆ ADC_ETC_DONE0_1_IRQ_TRIG2_DONE1 [2/3]
◆ ADC_ETC_DONE0_1_IRQ_TRIG2_DONE1 [3/3]
◆ ADC_ETC_DONE0_1_IRQ_TRIG3_DONE0 [1/3]
#define ADC_ETC_DONE0_1_IRQ_TRIG3_DONE0 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE0_1_IRQ_TRIG3_DONE0_SHIFT)) & ADC_ETC_DONE0_1_IRQ_TRIG3_DONE0_MASK)
TRIG3_DONE0 0b0..No TRIG3_DONE0 interrupt detected 0b1..TRIG3_DONE0 interrupt detected
◆ ADC_ETC_DONE0_1_IRQ_TRIG3_DONE0 [2/3]
◆ ADC_ETC_DONE0_1_IRQ_TRIG3_DONE0 [3/3]
◆ ADC_ETC_DONE0_1_IRQ_TRIG3_DONE1 [1/3]
#define ADC_ETC_DONE0_1_IRQ_TRIG3_DONE1 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE0_1_IRQ_TRIG3_DONE1_SHIFT)) & ADC_ETC_DONE0_1_IRQ_TRIG3_DONE1_MASK)
TRIG3_DONE1 0b0..No TRIG3_DONE1 interrupt detected 0b1..TRIG3_DONE1 interrupt detected
◆ ADC_ETC_DONE0_1_IRQ_TRIG3_DONE1 [2/3]
◆ ADC_ETC_DONE0_1_IRQ_TRIG3_DONE1 [3/3]
◆ ADC_ETC_DONE0_1_IRQ_TRIG4_DONE0 [1/3]
#define ADC_ETC_DONE0_1_IRQ_TRIG4_DONE0 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE0_1_IRQ_TRIG4_DONE0_SHIFT)) & ADC_ETC_DONE0_1_IRQ_TRIG4_DONE0_MASK)
TRIG4_DONE0 0b0..No TRIG4_DONE0 interrupt detected 0b1..TRIG4_DONE0 interrupt detected
◆ ADC_ETC_DONE0_1_IRQ_TRIG4_DONE0 [2/3]
◆ ADC_ETC_DONE0_1_IRQ_TRIG4_DONE0 [3/3]
◆ ADC_ETC_DONE0_1_IRQ_TRIG4_DONE1 [1/3]
#define ADC_ETC_DONE0_1_IRQ_TRIG4_DONE1 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE0_1_IRQ_TRIG4_DONE1_SHIFT)) & ADC_ETC_DONE0_1_IRQ_TRIG4_DONE1_MASK)
TRIG4_DONE1 0b0..No TRIG4_DONE1 interrupt detected 0b1..TRIG4_DONE1 interrupt detected
◆ ADC_ETC_DONE0_1_IRQ_TRIG4_DONE1 [2/3]
◆ ADC_ETC_DONE0_1_IRQ_TRIG4_DONE1 [3/3]
◆ ADC_ETC_DONE0_1_IRQ_TRIG5_DONE0 [1/3]
#define ADC_ETC_DONE0_1_IRQ_TRIG5_DONE0 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE0_1_IRQ_TRIG5_DONE0_SHIFT)) & ADC_ETC_DONE0_1_IRQ_TRIG5_DONE0_MASK)
TRIG5_DONE0 0b0..No TRIG5_DONE0 interrupt detected 0b1..TRIG5_DONE0 interrupt detected
◆ ADC_ETC_DONE0_1_IRQ_TRIG5_DONE0 [2/3]
◆ ADC_ETC_DONE0_1_IRQ_TRIG5_DONE0 [3/3]
◆ ADC_ETC_DONE0_1_IRQ_TRIG5_DONE1 [1/3]
#define ADC_ETC_DONE0_1_IRQ_TRIG5_DONE1 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE0_1_IRQ_TRIG5_DONE1_SHIFT)) & ADC_ETC_DONE0_1_IRQ_TRIG5_DONE1_MASK)
TRIG5_DONE1 0b0..No TRIG5_DONE1 interrupt detected 0b1..TRIG5_DONE1 interrupt detected
◆ ADC_ETC_DONE0_1_IRQ_TRIG5_DONE1 [2/3]
◆ ADC_ETC_DONE0_1_IRQ_TRIG5_DONE1 [3/3]
◆ ADC_ETC_DONE0_1_IRQ_TRIG6_DONE0 [1/3]
#define ADC_ETC_DONE0_1_IRQ_TRIG6_DONE0 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE0_1_IRQ_TRIG6_DONE0_SHIFT)) & ADC_ETC_DONE0_1_IRQ_TRIG6_DONE0_MASK)
TRIG6_DONE0 0b0..No TRIG6_DONE0 interrupt detected 0b1..TRIG6_DONE0 interrupt detected
◆ ADC_ETC_DONE0_1_IRQ_TRIG6_DONE0 [2/3]
◆ ADC_ETC_DONE0_1_IRQ_TRIG6_DONE0 [3/3]
◆ ADC_ETC_DONE0_1_IRQ_TRIG6_DONE1 [1/3]
#define ADC_ETC_DONE0_1_IRQ_TRIG6_DONE1 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE0_1_IRQ_TRIG6_DONE1_SHIFT)) & ADC_ETC_DONE0_1_IRQ_TRIG6_DONE1_MASK)
TRIG6_DONE1 0b0..No TRIG6_DONE1 interrupt detected 0b1..TRIG6_DONE1 interrupt detected
◆ ADC_ETC_DONE0_1_IRQ_TRIG6_DONE1 [2/3]
◆ ADC_ETC_DONE0_1_IRQ_TRIG6_DONE1 [3/3]
◆ ADC_ETC_DONE0_1_IRQ_TRIG7_DONE0 [1/3]
#define ADC_ETC_DONE0_1_IRQ_TRIG7_DONE0 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE0_1_IRQ_TRIG7_DONE0_SHIFT)) & ADC_ETC_DONE0_1_IRQ_TRIG7_DONE0_MASK)
TRIG7_DONE0 0b0..No TRIG7_DONE0 interrupt detected 0b1..TRIG7_DONE0 interrupt detected
◆ ADC_ETC_DONE0_1_IRQ_TRIG7_DONE0 [2/3]
◆ ADC_ETC_DONE0_1_IRQ_TRIG7_DONE0 [3/3]
◆ ADC_ETC_DONE0_1_IRQ_TRIG7_DONE1 [1/3]
#define ADC_ETC_DONE0_1_IRQ_TRIG7_DONE1 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE0_1_IRQ_TRIG7_DONE1_SHIFT)) & ADC_ETC_DONE0_1_IRQ_TRIG7_DONE1_MASK)
TRIG7_DONE1 0b0..No TRIG7_DONE1 interrupt detected 0b1..TRIG7_DONE1 interrupt detected
◆ ADC_ETC_DONE0_1_IRQ_TRIG7_DONE1 [2/3]
◆ ADC_ETC_DONE0_1_IRQ_TRIG7_DONE1 [3/3]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG0_DONE2 [1/3]
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG0_DONE2 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG0_DONE2_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG0_DONE2_MASK)
TRIG0_DONE2 0b0..No TRIG0_DONE2 interrupt detected 0b1..TRIG0_DONE2 interrupt detected
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG0_DONE2 [2/3]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG0_DONE2 [3/3]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG0_DONE3 [1/2]
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG0_DONE3 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG0_DONE3_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG0_DONE3_MASK)
TRIG0_DONE3 0b0..No TRIG0_DONE3 interrupt detected 0b1..TRIG0_DONE3 interrupt detected
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG0_DONE3 [2/2]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG0_ERR [1/3]
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG0_ERR (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG0_ERR_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG0_ERR_MASK)
TRIG0_ERR 0b0..No TRIG0_ERR interrupt detected 0b1..TRIG0_ERR interrupt detected
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG0_ERR [2/3]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG0_ERR [3/3]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG1_DONE2 [1/3]
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG1_DONE2 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG1_DONE2_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG1_DONE2_MASK)
TRIG1_DONE2 0b0..No TRIG1_DONE2 interrupt detected 0b1..TRIG1_DONE2 interrupt detected
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG1_DONE2 [2/3]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG1_DONE2 [3/3]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG1_DONE3 [1/2]
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG1_DONE3 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG1_DONE3_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG1_DONE3_MASK)
TRIG1_DONE3 0b0..No TRIG1_DONE3 interrupt detected 0b1..TRIG1_DONE3 interrupt detected
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG1_DONE3 [2/2]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG1_ERR [1/3]
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG1_ERR (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG1_ERR_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG1_ERR_MASK)
TRIG1_ERR 0b0..No TRIG1_ERR interrupt detected 0b1..TRIG1_ERR interrupt detected
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG1_ERR [2/3]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG1_ERR [3/3]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG2_DONE2 [1/3]
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG2_DONE2 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG2_DONE2_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG2_DONE2_MASK)
TRIG2_DONE2 0b0..No TRIG2_DONE2 interrupt detected 0b1..TRIG2_DONE2 interrupt detected
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG2_DONE2 [2/3]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG2_DONE2 [3/3]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG2_DONE3 [1/2]
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG2_DONE3 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG2_DONE3_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG2_DONE3_MASK)
TRIG2_DONE3 0b0..No TRIG2_DONE3 interrupt detected 0b1..TRIG2_DONE3 interrupt detected
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG2_DONE3 [2/2]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG2_ERR [1/3]
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG2_ERR (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG2_ERR_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG2_ERR_MASK)
TRIG2_ERR 0b0..No TRIG2_ERR interrupt detected 0b1..TRIG2_ERR interrupt detected
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG2_ERR [2/3]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG2_ERR [3/3]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG3_DONE2 [1/3]
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG3_DONE2 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG3_DONE2_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG3_DONE2_MASK)
TRIG3_DONE2 0b0..No TRIG3_DONE2 interrupt detected 0b1..TRIG3_DONE2 interrupt detected
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG3_DONE2 [2/3]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG3_DONE2 [3/3]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG3_DONE3 [1/2]
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG3_DONE3 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG3_DONE3_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG3_DONE3_MASK)
TRIG3_DONE3 0b0..No TRIG3_DONE3 interrupt detected 0b1..TRIG3_DONE3 interrupt detected
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG3_DONE3 [2/2]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG3_ERR [1/3]
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG3_ERR (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG3_ERR_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG3_ERR_MASK)
TRIG3_ERR 0b0..No TRIG3_ERR interrupt detected 0b1..TRIG3_ERR interrupt detected
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG3_ERR [2/3]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG3_ERR [3/3]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG4_DONE2 [1/3]
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG4_DONE2 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG4_DONE2_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG4_DONE2_MASK)
TRIG4_DONE2 0b0..No TRIG4_DONE2 interrupt detected 0b1..TRIG4_DONE2 interrupt detected
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG4_DONE2 [2/3]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG4_DONE2 [3/3]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG4_DONE3 [1/2]
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG4_DONE3 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG4_DONE3_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG4_DONE3_MASK)
TRIG4_DONE3 0b0..No TRIG4_DONE3 interrupt detected 0b1..TRIG4_DONE3 interrupt detected
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG4_DONE3 [2/2]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG4_ERR [1/3]
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG4_ERR (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG4_ERR_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG4_ERR_MASK)
TRIG4_ERR 0b0..No TRIG4_ERR interrupt detected 0b1..TRIG4_ERR interrupt detected
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG4_ERR [2/3]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG4_ERR [3/3]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG5_DONE2 [1/3]
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG5_DONE2 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG5_DONE2_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG5_DONE2_MASK)
TRIG5_DONE2 0b0..No TRIG5_DONE2 interrupt detected 0b1..TRIG5_DONE2 interrupt detected
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG5_DONE2 [2/3]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG5_DONE2 [3/3]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG5_DONE3 [1/2]
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG5_DONE3 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG5_DONE3_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG5_DONE3_MASK)
TRIG5_DONE3 0b0..No TRIG5_DONE3 interrupt detected 0b1..TRIG5_DONE3 interrupt detected
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG5_DONE3 [2/2]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG5_ERR [1/3]
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG5_ERR (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG5_ERR_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG5_ERR_MASK)
TRIG5_ERR 0b0..No TRIG5_ERR interrupt detected 0b1..TRIG5_ERR interrupt detected
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG5_ERR [2/3]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG5_ERR [3/3]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG6_DONE2 [1/3]
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG6_DONE2 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG6_DONE2_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG6_DONE2_MASK)
TRIG6_DONE2 0b0..No TRIG6_DONE2 interrupt detected 0b1..TRIG6_DONE2 interrupt detected
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG6_DONE2 [2/3]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG6_DONE2 [3/3]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG6_DONE3 [1/2]
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG6_DONE3 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG6_DONE3_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG6_DONE3_MASK)
TRIG6_DONE3 0b0..No TRIG6_DONE3 interrupt detected 0b1..TRIG6_DONE3 interrupt detected
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG6_DONE3 [2/2]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG6_ERR [1/3]
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG6_ERR (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG6_ERR_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG6_ERR_MASK)
TRIG6_ERR 0b0..No TRIG6_ERR interrupt detected 0b1..TRIG6_ERR interrupt detected
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG6_ERR [2/3]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG6_ERR [3/3]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG7_DONE2 [1/3]
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG7_DONE2 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG7_DONE2_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG7_DONE2_MASK)
TRIG7_DONE2 0b0..No TRIG7_DONE2 interrupt detected 0b1..TRIG7_DONE2 interrupt detected
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG7_DONE2 [2/3]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG7_DONE2 [3/3]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG7_DONE3 [1/2]
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG7_DONE3 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG7_DONE3_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG7_DONE3_MASK)
TRIG7_DONE3 0b0..No TRIG7_DONE3 interrupt detected 0b1..TRIG7_DONE3 interrupt detected
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG7_DONE3 [2/2]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG7_ERR [1/3]
#define ADC_ETC_DONE2_3_ERR_IRQ_TRIG7_ERR (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_DONE2_3_ERR_IRQ_TRIG7_ERR_SHIFT)) & ADC_ETC_DONE2_3_ERR_IRQ_TRIG7_ERR_MASK)
TRIG7_ERR 0b0..No TRIG7_ERR interrupt detected 0b1..TRIG7_ERR interrupt detected
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG7_ERR [2/3]
◆ ADC_ETC_DONE2_3_ERR_IRQ_TRIG7_ERR [3/3]
◆ ADC_ETC_TRIGn_CHAIN_1_0_B2B0 [1/3]
#define ADC_ETC_TRIGn_CHAIN_1_0_B2B0 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_1_0_B2B0_SHIFT)) & ADC_ETC_TRIGn_CHAIN_1_0_B2B0_MASK)
B2B0 0b0..Disable B2B. Wait until delay value defined by TRIG0_COUNTER[SAMPLE_INTERVAL] is reached 0b1..Enable B2B. When Segment 0 finished (ADC COCO) then automatically trigger next ADC conversion, no need to wait until interval delay reached.
◆ ADC_ETC_TRIGn_CHAIN_1_0_B2B0 [2/3]
◆ ADC_ETC_TRIGn_CHAIN_1_0_B2B0 [3/3]
◆ ADC_ETC_TRIGn_CHAIN_1_0_B2B1 [1/3]
#define ADC_ETC_TRIGn_CHAIN_1_0_B2B1 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_1_0_B2B1_SHIFT)) & ADC_ETC_TRIGn_CHAIN_1_0_B2B1_MASK)
B2B1 0b0..Disable B2B. Wait until delay value defined by TRIG1_COUNTER[SAMPLE_INTERVAL] is reached 0b1..Enable B2B. When Segment 0 finished (ADC COCO) then automatically trigger next ADC conversion, no need to wait until interval delay reached.
◆ ADC_ETC_TRIGn_CHAIN_1_0_B2B1 [2/3]
◆ ADC_ETC_TRIGn_CHAIN_1_0_B2B1 [3/3]
◆ ADC_ETC_TRIGn_CHAIN_1_0_CSEL0 [1/3]
#define ADC_ETC_TRIGn_CHAIN_1_0_CSEL0 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_1_0_CSEL0_SHIFT)) & ADC_ETC_TRIGn_CHAIN_1_0_CSEL0_MASK)
CSEL0 0b0000..ADC Channel 0 selected 0b0001..ADC Channel 1 selected. 0b0010..ADC Channel 2 selected. 0b0011..ADC Channel 3 selected. 0b0100..ADC Channel 4 selected. 0b0101..ADC Channel 5 selected. 0b0110..ADC Channel 6 selected. 0b0111..ADC Channel 7 selected. 0b1000..ADC Channel 8 selected. 0b1001..ADC Channel 9 selected. 0b1010..ADC Channel 10 selected. 0b1011..ADC Channel 11 selected. 0b1100..ADC Channel 12 selected. 0b1101..ADC Channel 13 selected. 0b1110..ADC Channel 14 selected. 0b1111..ADC Channel 15 selected.
◆ ADC_ETC_TRIGn_CHAIN_1_0_CSEL0 [2/3]
CSEL0 0b0000..Not a valid selection from the command buffer. Trigger event is ignored. 0b0001..ADC CMD1 selected. 0b0010..ADC CMD2 selected. 0b0011..ADC CMD3 selected. 0b0100..ADC CMD4 selected. 0b0101..ADC CMD5 selected. 0b0110..ADC CMD6 selected. 0b0111..ADC CMD7 selected. 0b1000..ADC CMD8 selected. 0b1001..ADC CMD9 selected. 0b1010..ADC CMD10 selected. 0b1011..ADC CMD11 selected. 0b1100..ADC CMD12 selected. 0b1101..ADC CMD13 selected. 0b1110..ADC CMD14 selected. 0b1111..ADC CMD15 selected.
◆ ADC_ETC_TRIGn_CHAIN_1_0_CSEL0 [3/3]
◆ ADC_ETC_TRIGn_CHAIN_1_0_CSEL1 [1/3]
#define ADC_ETC_TRIGn_CHAIN_1_0_CSEL1 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_1_0_CSEL1_SHIFT)) & ADC_ETC_TRIGn_CHAIN_1_0_CSEL1_MASK)
CSEL1 0b0000..ADC Channel 0 selected 0b0001..ADC Channel 1 selected. 0b0010..ADC Channel 2 selected. 0b0011..ADC Channel 3 selected. 0b0100..ADC Channel 4 selected. 0b0101..ADC Channel 5 selected. 0b0110..ADC Channel 6 selected. 0b0111..ADC Channel 7 selected. 0b1000..ADC Channel 8 selected. 0b1001..ADC Channel 9 selected. 0b1010..ADC Channel 10 selected. 0b1011..ADC Channel 11 selected. 0b1100..ADC Channel 12 selected. 0b1101..ADC Channel 13 selected. 0b1110..ADC Channel 14 selected. 0b1111..ADC Channel 15 selected.
◆ ADC_ETC_TRIGn_CHAIN_1_0_CSEL1 [2/3]
CSEL1 0b0000..Not a valid selection from the command buffer. Trigger event is ignored. 0b0001..ADC CMD1 selected. 0b0010..ADC CMD2 selected. 0b0011..ADC CMD3 selected. 0b0100..ADC CMD4 selected. 0b0101..ADC CMD5 selected. 0b0110..ADC CMD6 selected. 0b0111..ADC CMD7 selected. 0b1000..ADC CMD8 selected. 0b1001..ADC CMD9 selected. 0b1010..ADC CMD10 selected. 0b1011..ADC CMD11 selected. 0b1100..ADC CMD12 selected. 0b1101..ADC CMD13 selected. 0b1110..ADC CMD14 selected. 0b1111..ADC CMD15 selected.
◆ ADC_ETC_TRIGn_CHAIN_1_0_CSEL1 [3/3]
◆ ADC_ETC_TRIGn_CHAIN_1_0_HWTS0 [1/3]
#define ADC_ETC_TRIGn_CHAIN_1_0_HWTS0 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_1_0_HWTS0_SHIFT)) & ADC_ETC_TRIGn_CHAIN_1_0_HWTS0_MASK)
HWTS0 0b00000000..no trigger selected 0b00000001..ADC TRIG0 selected 0b00000010..ADC TRIG1 selected 0b00000100..ADC TRIG2 selected 0b00001000..ADC TRIG3 selected 0b00010000..ADC TRIG4 selected 0b00100000..ADC TRIG5 selected 0b01000000..ADC TRIG6 selected 0b10000000..ADC TRIG7 selected
◆ ADC_ETC_TRIGn_CHAIN_1_0_HWTS0 [2/3]
◆ ADC_ETC_TRIGn_CHAIN_1_0_HWTS0 [3/3]
◆ ADC_ETC_TRIGn_CHAIN_1_0_HWTS1 [1/3]
#define ADC_ETC_TRIGn_CHAIN_1_0_HWTS1 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_1_0_HWTS1_SHIFT)) & ADC_ETC_TRIGn_CHAIN_1_0_HWTS1_MASK)
HWTS1 0b00000000..no trigger selected 0b00000001..ADC TRIG0 selected 0b00000010..ADC TRIG1 selected 0b00000100..ADC TRIG2 selected 0b00001000..ADC TRIG3 selected 0b00010000..ADC TRIG4 selected 0b00100000..ADC TRIG5 selected 0b01000000..ADC TRIG6 selected 0b10000000..ADC TRIG7 selected
◆ ADC_ETC_TRIGn_CHAIN_1_0_HWTS1 [2/3]
◆ ADC_ETC_TRIGn_CHAIN_1_0_HWTS1 [3/3]
◆ ADC_ETC_TRIGn_CHAIN_1_0_IE0 [1/3]
#define ADC_ETC_TRIGn_CHAIN_1_0_IE0 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_1_0_IE0_SHIFT)) & ADC_ETC_TRIGn_CHAIN_1_0_IE0_MASK)
IE0 0b00..No interrupt when finished 0b01..Generate interrupt on Done0 when segment 0 finish. 0b10..Generate interrupt on Done1 when segment 0 finish. 0b11..Generate interrupt on Done2 when segment 0 finish.
◆ ADC_ETC_TRIGn_CHAIN_1_0_IE0 [2/3]
IE0 0b00..Generate interrupt on Done0 when segment 0 finish. 0b01..Generate interrupt on Done1 when segment 0 finish. 0b10..Generate interrupt on Done2 when segment 0 finish. 0b11..Generate interrupt on Done3 when segment 0 finish.
◆ ADC_ETC_TRIGn_CHAIN_1_0_IE0 [3/3]
◆ ADC_ETC_TRIGn_CHAIN_1_0_IE0_EN [1/2]
#define ADC_ETC_TRIGn_CHAIN_1_0_IE0_EN (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_1_0_IE0_EN_SHIFT)) & ADC_ETC_TRIGn_CHAIN_1_0_IE0_EN_MASK)
IE0_EN 0b0..Interrupt DONE disabled. 0b1..Interrupt DONE enabled. When segment 0 finish, an interrupt will be generated on the specific port configured by the IE0.
◆ ADC_ETC_TRIGn_CHAIN_1_0_IE0_EN [2/2]
◆ ADC_ETC_TRIGn_CHAIN_1_0_IE1 [1/3]
#define ADC_ETC_TRIGn_CHAIN_1_0_IE1 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_1_0_IE1_SHIFT)) & ADC_ETC_TRIGn_CHAIN_1_0_IE1_MASK)
IE1 0b00..No interrupt when finished 0b01..Generate interrupt on Done0 when Segment 1 finish. 0b10..Generate interrupt on Done1 when Segment 1 finish. 0b11..Generate interrupt on Done2 when Segment 1 finish.
◆ ADC_ETC_TRIGn_CHAIN_1_0_IE1 [2/3]
IE1 0b00..Generate interrupt on Done0 when Segment 1 finish. 0b01..Generate interrupt on Done1 when Segment 1 finish. 0b10..Generate interrupt on Done2 when Segment 1 finish. 0b11..Generate interrupt on Done3 when Segment 1 finish.
◆ ADC_ETC_TRIGn_CHAIN_1_0_IE1 [3/3]
◆ ADC_ETC_TRIGn_CHAIN_1_0_IE1_EN [1/2]
#define ADC_ETC_TRIGn_CHAIN_1_0_IE1_EN (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_1_0_IE1_EN_SHIFT)) & ADC_ETC_TRIGn_CHAIN_1_0_IE1_EN_MASK)
IE1_EN 0b0..Interrupt DONE disabled. 0b1..Interrupt DONE enabled. When segment 1 finish, an interrupt will be generated on the specific port configured by the IE1.
◆ ADC_ETC_TRIGn_CHAIN_1_0_IE1_EN [2/2]
◆ ADC_ETC_TRIGn_CHAIN_3_2_B2B2 [1/3]
#define ADC_ETC_TRIGn_CHAIN_3_2_B2B2 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_3_2_B2B2_SHIFT)) & ADC_ETC_TRIGn_CHAIN_3_2_B2B2_MASK)
B2B2 0b0..Disable B2B. Wait until delay value defined by TRIG2_COUNTER[SAMPLE_INTERVAL] is reached 0b1..Enable B2B. When Segment 0 finished (ADC COCO) then automatically trigger next ADC conversion, no need to wait until interval delay reached.
◆ ADC_ETC_TRIGn_CHAIN_3_2_B2B2 [2/3]
◆ ADC_ETC_TRIGn_CHAIN_3_2_B2B2 [3/3]
◆ ADC_ETC_TRIGn_CHAIN_3_2_B2B3 [1/3]
#define ADC_ETC_TRIGn_CHAIN_3_2_B2B3 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_3_2_B2B3_SHIFT)) & ADC_ETC_TRIGn_CHAIN_3_2_B2B3_MASK)
B2B3 0b0..Disable B2B. Wait until delay value defined by TRIG3_COUNTER[SAMPLE_INTERVAL] is reached 0b1..Enable B2B. When Segment 0 finished (ADC COCO) then automatically trigger next ADC conversion, no need to wait until interval delay reached.
◆ ADC_ETC_TRIGn_CHAIN_3_2_B2B3 [2/3]
◆ ADC_ETC_TRIGn_CHAIN_3_2_B2B3 [3/3]
◆ ADC_ETC_TRIGn_CHAIN_3_2_CSEL2 [1/3]
#define ADC_ETC_TRIGn_CHAIN_3_2_CSEL2 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_3_2_CSEL2_SHIFT)) & ADC_ETC_TRIGn_CHAIN_3_2_CSEL2_MASK)
CSEL2 0b0000..ADC Channel 0 selected 0b0001..ADC Channel 1 selected. 0b0010..ADC Channel 2 selected. 0b0011..ADC Channel 3 selected. 0b0100..ADC Channel 4 selected. 0b0101..ADC Channel 5 selected. 0b0110..ADC Channel 6 selected. 0b0111..ADC Channel 7 selected. 0b1000..ADC Channel 8 selected. 0b1001..ADC Channel 9 selected. 0b1010..ADC Channel 10 selected. 0b1011..ADC Channel 11 selected. 0b1100..ADC Channel 12 selected. 0b1101..ADC Channel 13 selected. 0b1110..ADC Channel 14 selected. 0b1111..ADC Channel 15 selected.
◆ ADC_ETC_TRIGn_CHAIN_3_2_CSEL2 [2/3]
CSEL2 0b0000..Not a valid selection from the command buffer. Trigger event is ignored. 0b0001..ADC CMD1 selected. 0b0010..ADC CMD2 selected. 0b0011..ADC CMD3 selected. 0b0100..ADC CMD4 selected. 0b0101..ADC CMD5 selected. 0b0110..ADC CMD6 selected. 0b0111..ADC CMD7 selected. 0b1000..ADC CMD8 selected. 0b1001..ADC CMD9 selected. 0b1010..ADC CMD10 selected. 0b1011..ADC CMD11 selected. 0b1100..ADC CMD12 selected. 0b1101..ADC CMD13 selected. 0b1110..ADC CMD14 selected. 0b1111..ADC CMD15 selected.
◆ ADC_ETC_TRIGn_CHAIN_3_2_CSEL2 [3/3]
◆ ADC_ETC_TRIGn_CHAIN_3_2_CSEL3 [1/3]
#define ADC_ETC_TRIGn_CHAIN_3_2_CSEL3 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_3_2_CSEL3_SHIFT)) & ADC_ETC_TRIGn_CHAIN_3_2_CSEL3_MASK)
CSEL3 0b0000..ADC Channel 0 selected 0b0001..ADC Channel 1 selected. 0b0010..ADC Channel 2 selected. 0b0011..ADC Channel 3 selected. 0b0100..ADC Channel 4 selected. 0b0101..ADC Channel 5 selected. 0b0110..ADC Channel 6 selected. 0b0111..ADC Channel 7 selected. 0b1000..ADC Channel 8 selected. 0b1001..ADC Channel 9 selected. 0b1010..ADC Channel 10 selected. 0b1011..ADC Channel 11 selected. 0b1100..ADC Channel 12 selected. 0b1101..ADC Channel 13 selected. 0b1110..ADC Channel 14 selected. 0b1111..ADC Channel 15 selected.
◆ ADC_ETC_TRIGn_CHAIN_3_2_CSEL3 [2/3]
CSEL3 0b0000..Not a valid selection from the command buffer. Trigger event is ignored. 0b0001..ADC CMD1 selected. 0b0010..ADC CMD2 selected. 0b0011..ADC CMD3 selected. 0b0100..ADC CMD4 selected. 0b0101..ADC CMD5 selected. 0b0110..ADC CMD6 selected. 0b0111..ADC CMD7 selected. 0b1000..ADC CMD8 selected. 0b1001..ADC CMD9 selected. 0b1010..ADC CMD10 selected. 0b1011..ADC CMD11 selected. 0b1100..ADC CMD12 selected. 0b1101..ADC CMD13 selected. 0b1110..ADC CMD14 selected. 0b1111..ADC CMD15 selected.
◆ ADC_ETC_TRIGn_CHAIN_3_2_CSEL3 [3/3]
◆ ADC_ETC_TRIGn_CHAIN_3_2_HWTS2 [1/3]
#define ADC_ETC_TRIGn_CHAIN_3_2_HWTS2 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_3_2_HWTS2_SHIFT)) & ADC_ETC_TRIGn_CHAIN_3_2_HWTS2_MASK)
HWTS2 0b00000000..no trigger selected 0b00000001..ADC TRIG0 selected 0b00000010..ADC TRIG1 selected 0b00000100..ADC TRIG2 selected 0b00001000..ADC TRIG3 selected 0b00010000..ADC TRIG4 selected 0b00100000..ADC TRIG5 selected 0b01000000..ADC TRIG6 selected 0b10000000..ADC TRIG7 selected
◆ ADC_ETC_TRIGn_CHAIN_3_2_HWTS2 [2/3]
◆ ADC_ETC_TRIGn_CHAIN_3_2_HWTS2 [3/3]
◆ ADC_ETC_TRIGn_CHAIN_3_2_HWTS3 [1/3]
#define ADC_ETC_TRIGn_CHAIN_3_2_HWTS3 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_3_2_HWTS3_SHIFT)) & ADC_ETC_TRIGn_CHAIN_3_2_HWTS3_MASK)
HWTS3 0b00000000..no trigger selected 0b00000001..ADC TRIG0 selected 0b00000010..ADC TRIG1 selected 0b00000100..ADC TRIG2 selected 0b00001000..ADC TRIG3 selected 0b00010000..ADC TRIG4 selected 0b00100000..ADC TRIG5 selected 0b01000000..ADC TRIG6 selected 0b10000000..ADC TRIG7 selected
◆ ADC_ETC_TRIGn_CHAIN_3_2_HWTS3 [2/3]
◆ ADC_ETC_TRIGn_CHAIN_3_2_HWTS3 [3/3]
◆ ADC_ETC_TRIGn_CHAIN_3_2_IE2 [1/3]
#define ADC_ETC_TRIGn_CHAIN_3_2_IE2 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_3_2_IE2_SHIFT)) & ADC_ETC_TRIGn_CHAIN_3_2_IE2_MASK)
IE2 0b00..No interrupt when finished 0b01..Generate interrupt on Done0 when segment 2 finish. 0b10..Generate interrupt on Done1 when segment 2 finish. 0b11..Generate interrupt on Done2 when segment 2 finish.
◆ ADC_ETC_TRIGn_CHAIN_3_2_IE2 [2/3]
IE2 0b00..Generate interrupt on Done0 when segment 2 finish. 0b01..Generate interrupt on Done1 when segment 2 finish. 0b10..Generate interrupt on Done2 when segment 2 finish. 0b11..Generate interrupt on Done3 when segment 2 finish.
◆ ADC_ETC_TRIGn_CHAIN_3_2_IE2 [3/3]
◆ ADC_ETC_TRIGn_CHAIN_3_2_IE2_EN [1/2]
#define ADC_ETC_TRIGn_CHAIN_3_2_IE2_EN (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_3_2_IE2_EN_SHIFT)) & ADC_ETC_TRIGn_CHAIN_3_2_IE2_EN_MASK)
IE2_EN 0b0..Interrupt DONE disabled. 0b1..Interrupt DONE enabled. When segment 2 finish, an interrupt will be generated on the specific port configured by the IE2.
◆ ADC_ETC_TRIGn_CHAIN_3_2_IE2_EN [2/2]
◆ ADC_ETC_TRIGn_CHAIN_3_2_IE3 [1/3]
#define ADC_ETC_TRIGn_CHAIN_3_2_IE3 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_3_2_IE3_SHIFT)) & ADC_ETC_TRIGn_CHAIN_3_2_IE3_MASK)
IE3 0b00..No interrupt when finished 0b01..Generate interrupt on Done0 when segment 3 finish. 0b10..Generate interrupt on Done1 when segment 3 finish. 0b11..Generate interrupt on Done2 when segment 3 finish.
◆ ADC_ETC_TRIGn_CHAIN_3_2_IE3 [2/3]
IE3 0b00..Generate interrupt on Done0 when segment 3 finish. 0b01..Generate interrupt on Done1 when segment 3 finish. 0b10..Generate interrupt on Done2 when segment 3 finish. 0b11..Generate interrupt on Done3 when segment 3 finish.
◆ ADC_ETC_TRIGn_CHAIN_3_2_IE3 [3/3]
◆ ADC_ETC_TRIGn_CHAIN_3_2_IE3_EN [1/2]
#define ADC_ETC_TRIGn_CHAIN_3_2_IE3_EN (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_3_2_IE3_EN_SHIFT)) & ADC_ETC_TRIGn_CHAIN_3_2_IE3_EN_MASK)
IE3_EN 0b0..Interrupt DONE disabled. 0b1..Interrupt DONE enabled. When segment 3 finish, an interrupt will be generated on the specific port configured by the IE3.
◆ ADC_ETC_TRIGn_CHAIN_3_2_IE3_EN [2/2]
◆ ADC_ETC_TRIGn_CHAIN_5_4_B2B4 [1/3]
#define ADC_ETC_TRIGn_CHAIN_5_4_B2B4 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_5_4_B2B4_SHIFT)) & ADC_ETC_TRIGn_CHAIN_5_4_B2B4_MASK)
B2B4 0b0..Disable B2B. Wait until delay value defined by TRIG4_COUNTER[SAMPLE_INTERVAL] is reached 0b1..Enable B2B. When Segment 0 finished (ADC COCO) then automatically trigger next ADC conversion, no need to wait until interval delay reached.
◆ ADC_ETC_TRIGn_CHAIN_5_4_B2B4 [2/3]
◆ ADC_ETC_TRIGn_CHAIN_5_4_B2B4 [3/3]
◆ ADC_ETC_TRIGn_CHAIN_5_4_B2B5 [1/3]
#define ADC_ETC_TRIGn_CHAIN_5_4_B2B5 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_5_4_B2B5_SHIFT)) & ADC_ETC_TRIGn_CHAIN_5_4_B2B5_MASK)
B2B5 0b0..Disable B2B. Wait until delay value defined by TRIG5_COUNTER[SAMPLE_INTERVAL] is reached 0b1..Enable B2B. When Segment 0 finished (ADC COCO) then automatically trigger next ADC conversion, no need to wait until interval delay reached.
◆ ADC_ETC_TRIGn_CHAIN_5_4_B2B5 [2/3]
◆ ADC_ETC_TRIGn_CHAIN_5_4_B2B5 [3/3]
◆ ADC_ETC_TRIGn_CHAIN_5_4_CSEL4 [1/3]
#define ADC_ETC_TRIGn_CHAIN_5_4_CSEL4 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_5_4_CSEL4_SHIFT)) & ADC_ETC_TRIGn_CHAIN_5_4_CSEL4_MASK)
CSEL4 0b0000..ADC Channel 0 selected 0b0001..ADC Channel 1 selected. 0b0010..ADC Channel 2 selected. 0b0011..ADC Channel 3 selected. 0b0100..ADC Channel 4 selected. 0b0101..ADC Channel 5 selected. 0b0110..ADC Channel 6 selected. 0b0111..ADC Channel 7 selected. 0b1000..ADC Channel 8 selected. 0b1001..ADC Channel 9 selected. 0b1010..ADC Channel 10 selected. 0b1011..ADC Channel 11 selected. 0b1100..ADC Channel 12 selected. 0b1101..ADC Channel 13 selected. 0b1110..ADC Channel 14 selected. 0b1111..ADC Channel 15 selected.
◆ ADC_ETC_TRIGn_CHAIN_5_4_CSEL4 [2/3]
CSEL4 0b0000..Not a valid selection from the command buffer. Trigger event is ignored. 0b0001..ADC CMD1 selected. 0b0010..ADC CMD2 selected. 0b0011..ADC CMD3 selected. 0b0100..ADC CMD4 selected. 0b0101..ADC CMD5 selected. 0b0110..ADC CMD6 selected. 0b0111..ADC CMD7 selected. 0b1000..ADC CMD8 selected. 0b1001..ADC CMD9 selected. 0b1010..ADC CMD10 selected. 0b1011..ADC CMD11 selected. 0b1100..ADC CMD12 selected. 0b1101..ADC CMD13 selected. 0b1110..ADC CMD14 selected. 0b1111..ADC CMD15 selected.
◆ ADC_ETC_TRIGn_CHAIN_5_4_CSEL4 [3/3]
◆ ADC_ETC_TRIGn_CHAIN_5_4_CSEL5 [1/3]
#define ADC_ETC_TRIGn_CHAIN_5_4_CSEL5 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_5_4_CSEL5_SHIFT)) & ADC_ETC_TRIGn_CHAIN_5_4_CSEL5_MASK)
CSEL5 0b0000..ADC Channel 0 selected 0b0001..ADC Channel 1 selected. 0b0010..ADC Channel 2 selected. 0b0011..ADC Channel 3 selected. 0b0100..ADC Channel 4 selected. 0b0101..ADC Channel 5 selected. 0b0110..ADC Channel 6 selected. 0b0111..ADC Channel 7 selected. 0b1000..ADC Channel 8 selected. 0b1001..ADC Channel 9 selected. 0b1010..ADC Channel 10 selected. 0b1011..ADC Channel 11 selected. 0b1100..ADC Channel 12 selected. 0b1101..ADC Channel 13 selected. 0b1110..ADC Channel 14 selected. 0b1111..ADC Channel 15 selected.
◆ ADC_ETC_TRIGn_CHAIN_5_4_CSEL5 [2/3]
CSEL5 0b0000..Not a valid selection from the command buffer. Trigger event is ignored. 0b0001..ADC CMD1 selected. 0b0010..ADC CMD2 selected. 0b0011..ADC CMD3 selected. 0b0100..ADC CMD4 selected. 0b0101..ADC CMD5 selected. 0b0110..ADC CMD6 selected. 0b0111..ADC CMD7 selected. 0b1000..ADC CMD8 selected. 0b1001..ADC CMD9 selected. 0b1010..ADC CMD10 selected. 0b1011..ADC CMD11 selected. 0b1100..ADC CMD12 selected. 0b1101..ADC CMD13 selected. 0b1110..ADC CMD14 selected. 0b1111..ADC CMD15 selected.
◆ ADC_ETC_TRIGn_CHAIN_5_4_CSEL5 [3/3]
◆ ADC_ETC_TRIGn_CHAIN_5_4_HWTS4 [1/3]
#define ADC_ETC_TRIGn_CHAIN_5_4_HWTS4 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_5_4_HWTS4_SHIFT)) & ADC_ETC_TRIGn_CHAIN_5_4_HWTS4_MASK)
HWTS4 0b00000000..no trigger selected 0b00000001..ADC TRIG0 selected 0b00000010..ADC TRIG1 selected 0b00000100..ADC TRIG2 selected 0b00001000..ADC TRIG3 selected 0b00010000..ADC TRIG4 selected 0b00100000..ADC TRIG5 selected 0b01000000..ADC TRIG6 selected 0b10000000..ADC TRIG7 selected
◆ ADC_ETC_TRIGn_CHAIN_5_4_HWTS4 [2/3]
◆ ADC_ETC_TRIGn_CHAIN_5_4_HWTS4 [3/3]
◆ ADC_ETC_TRIGn_CHAIN_5_4_HWTS5 [1/3]
#define ADC_ETC_TRIGn_CHAIN_5_4_HWTS5 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_5_4_HWTS5_SHIFT)) & ADC_ETC_TRIGn_CHAIN_5_4_HWTS5_MASK)
HWTS5 0b00000000..no trigger selected 0b00000001..ADC TRIG0 selected 0b00000010..ADC TRIG1 selected 0b00000100..ADC TRIG2 selected 0b00001000..ADC TRIG3 selected 0b00010000..ADC TRIG4 selected 0b00100000..ADC TRIG5 selected 0b01000000..ADC TRIG6 selected 0b10000000..ADC TRIG7 selected
◆ ADC_ETC_TRIGn_CHAIN_5_4_HWTS5 [2/3]
◆ ADC_ETC_TRIGn_CHAIN_5_4_HWTS5 [3/3]
◆ ADC_ETC_TRIGn_CHAIN_5_4_IE4 [1/3]
#define ADC_ETC_TRIGn_CHAIN_5_4_IE4 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_5_4_IE4_SHIFT)) & ADC_ETC_TRIGn_CHAIN_5_4_IE4_MASK)
IE4 0b00..No interrupt when finished 0b01..Generate interrupt on Done0 when segment 4 finish. 0b10..Generate interrupt on Done1 when segment 4 finish. 0b11..Generate interrupt on Done2 when segment 4 finish.
◆ ADC_ETC_TRIGn_CHAIN_5_4_IE4 [2/3]
IE4 0b00..Generate interrupt on Done0 when segment 4 finish. 0b01..Generate interrupt on Done1 when segment 4 finish. 0b10..Generate interrupt on Done2 when segment 4 finish. 0b11..Generate interrupt on Done3 when segment 4 finish.
◆ ADC_ETC_TRIGn_CHAIN_5_4_IE4 [3/3]
◆ ADC_ETC_TRIGn_CHAIN_5_4_IE4_EN [1/2]
#define ADC_ETC_TRIGn_CHAIN_5_4_IE4_EN (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_5_4_IE4_EN_SHIFT)) & ADC_ETC_TRIGn_CHAIN_5_4_IE4_EN_MASK)
IE4_EN 0b0..Interrupt DONE disabled. 0b1..Interrupt DONE enabled. When segment 4 finish, an interrupt will be generated on the specific port configured by the IE4.
◆ ADC_ETC_TRIGn_CHAIN_5_4_IE4_EN [2/2]
◆ ADC_ETC_TRIGn_CHAIN_5_4_IE5 [1/3]
#define ADC_ETC_TRIGn_CHAIN_5_4_IE5 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_5_4_IE5_SHIFT)) & ADC_ETC_TRIGn_CHAIN_5_4_IE5_MASK)
IE5 0b00..No interrupt when finished 0b01..Generate interrupt on Done0 when segment 5 finish. 0b10..Generate interrupt on Done1 when segment 5 finish. 0b11..Generate interrupt on Done2 when segment 5 finish.
◆ ADC_ETC_TRIGn_CHAIN_5_4_IE5 [2/3]
IE5 0b00..Generate interrupt on Done0 when segment 5 finish. 0b01..Generate interrupt on Done1 when segment 5 finish. 0b10..Generate interrupt on Done2 when segment 5 finish. 0b11..Generate interrupt on Done3 when segment 5 finish.
◆ ADC_ETC_TRIGn_CHAIN_5_4_IE5 [3/3]
◆ ADC_ETC_TRIGn_CHAIN_5_4_IE5_EN [1/2]
#define ADC_ETC_TRIGn_CHAIN_5_4_IE5_EN (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_5_4_IE5_EN_SHIFT)) & ADC_ETC_TRIGn_CHAIN_5_4_IE5_EN_MASK)
IE5_EN 0b0..Interrupt DONE disabled. 0b1..Interrupt DONE enabled. When segment 5 finish, an interrupt will be generated on the specific port configured by the IE5.
◆ ADC_ETC_TRIGn_CHAIN_5_4_IE5_EN [2/2]
◆ ADC_ETC_TRIGn_CHAIN_7_6_B2B6 [1/3]
#define ADC_ETC_TRIGn_CHAIN_7_6_B2B6 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_7_6_B2B6_SHIFT)) & ADC_ETC_TRIGn_CHAIN_7_6_B2B6_MASK)
B2B6 0b0..Disable B2B. Wait until delay value defined by TRIG6_COUNTER[SAMPLE_INTERVAL] is reached 0b1..Enable B2B. When Segment 0 finished (ADC COCO) then automatically trigger next ADC conversion, no need to wait until interval delay reached.
◆ ADC_ETC_TRIGn_CHAIN_7_6_B2B6 [2/3]
◆ ADC_ETC_TRIGn_CHAIN_7_6_B2B6 [3/3]
◆ ADC_ETC_TRIGn_CHAIN_7_6_B2B7 [1/3]
#define ADC_ETC_TRIGn_CHAIN_7_6_B2B7 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_7_6_B2B7_SHIFT)) & ADC_ETC_TRIGn_CHAIN_7_6_B2B7_MASK)
B2B7 0b0..Disable B2B. Wait until delay value defined by TRIG7_COUNTER[SAMPLE_INTERVAL] is reached 0b1..Enable B2B. When Segment 0 finished (ADC COCO) then automatically trigger next ADC conversion, no need to wait until interval delay reached.
◆ ADC_ETC_TRIGn_CHAIN_7_6_B2B7 [2/3]
◆ ADC_ETC_TRIGn_CHAIN_7_6_B2B7 [3/3]
◆ ADC_ETC_TRIGn_CHAIN_7_6_CSEL6 [1/3]
#define ADC_ETC_TRIGn_CHAIN_7_6_CSEL6 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_7_6_CSEL6_SHIFT)) & ADC_ETC_TRIGn_CHAIN_7_6_CSEL6_MASK)
CSEL6 0b0000..ADC Channel 0 selected 0b0001..ADC Channel 1 selected. 0b0010..ADC Channel 2 selected. 0b0011..ADC Channel 3 selected. 0b0100..ADC Channel 4 selected. 0b0101..ADC Channel 5 selected. 0b0110..ADC Channel 6 selected. 0b0111..ADC Channel 7 selected. 0b1000..ADC Channel 8 selected. 0b1001..ADC Channel 9 selected. 0b1010..ADC Channel 10 selected. 0b1011..ADC Channel 11 selected. 0b1100..ADC Channel 12 selected. 0b1101..ADC Channel 13 selected. 0b1110..ADC Channel 14 selected. 0b1111..ADC Channel 15 selected.
◆ ADC_ETC_TRIGn_CHAIN_7_6_CSEL6 [2/3]
CSEL6 0b0000..Not a valid selection from the command buffer. Trigger event is ignored. 0b0001..ADC CMD1 selected. 0b0010..ADC CMD2 selected. 0b0011..ADC CMD3 selected. 0b0100..ADC CMD4 selected. 0b0101..ADC CMD5 selected. 0b0110..ADC CMD6 selected. 0b0111..ADC CMD7 selected. 0b1000..ADC CMD8 selected. 0b1001..ADC CMD9 selected. 0b1010..ADC CMD10 selected. 0b1011..ADC CMD11 selected. 0b1100..ADC CMD12 selected. 0b1101..ADC CMD13 selected. 0b1110..ADC CMD14 selected. 0b1111..ADC CMD15 selected.
◆ ADC_ETC_TRIGn_CHAIN_7_6_CSEL6 [3/3]
◆ ADC_ETC_TRIGn_CHAIN_7_6_CSEL7 [1/3]
#define ADC_ETC_TRIGn_CHAIN_7_6_CSEL7 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_7_6_CSEL7_SHIFT)) & ADC_ETC_TRIGn_CHAIN_7_6_CSEL7_MASK)
CSEL7 0b0000..ADC Channel 0 selected. 0b0001..ADC Channel 1 selected. 0b0010..ADC Channel 2 selected. 0b0011..ADC Channel 3 selected. 0b0100..ADC Channel 4 selected. 0b0101..ADC Channel 5 selected. 0b0110..ADC Channel 6 selected. 0b0111..ADC Channel 7 selected. 0b1000..ADC Channel 8 selected. 0b1001..ADC Channel 9 selected. 0b1010..ADC Channel 10 selected. 0b1011..ADC Channel 11 selected. 0b1100..ADC Channel 12 selected. 0b1101..ADC Channel 13 selected. 0b1110..ADC Channel 14 selected. 0b1111..ADC Channel 15 selected.
◆ ADC_ETC_TRIGn_CHAIN_7_6_CSEL7 [2/3]
CSEL7 0b0000..Not a valid selection from the command buffer. Trigger event is ignored. 0b0001..ADC CMD1 selected. 0b0010..ADC CMD2 selected. 0b0011..ADC CMD3 selected. 0b0100..ADC CMD4 selected. 0b0101..ADC CMD5 selected. 0b0110..ADC CMD6 selected. 0b0111..ADC CMD7 selected. 0b1000..ADC CMD8 selected. 0b1001..ADC CMD9 selected. 0b1010..ADC CMD10 selected. 0b1011..ADC CMD11 selected. 0b1100..ADC CMD12 selected. 0b1101..ADC CMD13 selected. 0b1110..ADC CMD14 selected. 0b1111..ADC CMD15 selected.
◆ ADC_ETC_TRIGn_CHAIN_7_6_CSEL7 [3/3]
◆ ADC_ETC_TRIGn_CHAIN_7_6_HWTS6 [1/3]
#define ADC_ETC_TRIGn_CHAIN_7_6_HWTS6 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_7_6_HWTS6_SHIFT)) & ADC_ETC_TRIGn_CHAIN_7_6_HWTS6_MASK)
HWTS6 0b00000000..no trigger selected 0b00000001..ADC TRIG0 selected 0b00000010..ADC TRIG1 selected 0b00000100..ADC TRIG2 selected 0b00001000..ADC TRIG3 selected 0b00010000..ADC TRIG4 selected 0b00100000..ADC TRIG5 selected 0b01000000..ADC TRIG6 selected 0b10000000..ADC TRIG7 selected
◆ ADC_ETC_TRIGn_CHAIN_7_6_HWTS6 [2/3]
◆ ADC_ETC_TRIGn_CHAIN_7_6_HWTS6 [3/3]
◆ ADC_ETC_TRIGn_CHAIN_7_6_HWTS7 [1/3]
#define ADC_ETC_TRIGn_CHAIN_7_6_HWTS7 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_7_6_HWTS7_SHIFT)) & ADC_ETC_TRIGn_CHAIN_7_6_HWTS7_MASK)
HWTS7 0b00000000..no trigger selected 0b00000001..ADC TRIG0 selected 0b00000010..ADC TRIG1 selected 0b00000100..ADC TRIG2 selected 0b00001000..ADC TRIG3 selected 0b00010000..ADC TRIG4 selected 0b00100000..ADC TRIG5 selected 0b01000000..ADC TRIG6 selected 0b10000000..ADC TRIG7 selected
◆ ADC_ETC_TRIGn_CHAIN_7_6_HWTS7 [2/3]
◆ ADC_ETC_TRIGn_CHAIN_7_6_HWTS7 [3/3]
◆ ADC_ETC_TRIGn_CHAIN_7_6_IE6 [1/3]
#define ADC_ETC_TRIGn_CHAIN_7_6_IE6 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_7_6_IE6_SHIFT)) & ADC_ETC_TRIGn_CHAIN_7_6_IE6_MASK)
IE6 0b00..No interrupt when finished 0b01..Generate interrupt on Done0 when segment 6 finish. 0b10..Generate interrupt on Done1 when segment 6 finish. 0b11..Generate interrupt on Done2 when segment 6 finish.
◆ ADC_ETC_TRIGn_CHAIN_7_6_IE6 [2/3]
IE6 0b00..Generate interrupt on Done0 when segment 6 finish. 0b01..Generate interrupt on Done1 when segment 6 finish. 0b10..Generate interrupt on Done2 when segment 6 finish. 0b11..Generate interrupt on Done3 when segment 6 finish.
◆ ADC_ETC_TRIGn_CHAIN_7_6_IE6 [3/3]
◆ ADC_ETC_TRIGn_CHAIN_7_6_IE6_EN [1/2]
#define ADC_ETC_TRIGn_CHAIN_7_6_IE6_EN (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_7_6_IE6_EN_SHIFT)) & ADC_ETC_TRIGn_CHAIN_7_6_IE6_EN_MASK)
IE6_EN 0b0..Interrupt DONE disabled. 0b1..Interrupt DONE enabled. When segment 6 finish, an interrupt will be generated on the specific port configured by the IE6.
◆ ADC_ETC_TRIGn_CHAIN_7_6_IE6_EN [2/2]
◆ ADC_ETC_TRIGn_CHAIN_7_6_IE7 [1/3]
#define ADC_ETC_TRIGn_CHAIN_7_6_IE7 (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_7_6_IE7_SHIFT)) & ADC_ETC_TRIGn_CHAIN_7_6_IE7_MASK)
IE7 0b00..No interrupt when finished 0b01..Generate interrupt on Done0 when segment 7 finish. 0b10..Generate interrupt on Done1 when segment 7 finish. 0b11..Generate interrupt on Done2 when segment 7 finish.
◆ ADC_ETC_TRIGn_CHAIN_7_6_IE7 [2/3]
IE7 0b00..Generate interrupt on Done0 when segment 7 finish. 0b01..Generate interrupt on Done1 when segment 7 finish. 0b10..Generate interrupt on Done2 when segment 7 finish. 0b11..Generate interrupt on Done3 when segment 7 finish.
◆ ADC_ETC_TRIGn_CHAIN_7_6_IE7 [3/3]
◆ ADC_ETC_TRIGn_CHAIN_7_6_IE7_EN [1/2]
#define ADC_ETC_TRIGn_CHAIN_7_6_IE7_EN (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CHAIN_7_6_IE7_EN_SHIFT)) & ADC_ETC_TRIGn_CHAIN_7_6_IE7_EN_MASK)
IE7_EN 0b0..Interrupt DONE disabled. 0b1..Interrupt DONE enabled. When segment 7 finish, an interrupt will be generated on the specific port configured by the IE7.
◆ ADC_ETC_TRIGn_CHAIN_7_6_IE7_EN [2/2]
◆ ADC_ETC_TRIGn_CTRL_CHAINx_DONE [1/2]
#define ADC_ETC_TRIGn_CTRL_CHAINx_DONE (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CTRL_CHAINx_DONE_SHIFT)) & ADC_ETC_TRIGn_CTRL_CHAINx_DONE_MASK)
CHAINx_DONE 0b00000000..segment x done not detected. 0b00000001..segment x done detected.
◆ ADC_ETC_TRIGn_CTRL_CHAINx_DONE [2/2]
◆ ADC_ETC_TRIGn_CTRL_SW_TRIG [1/3]
#define ADC_ETC_TRIGn_CTRL_SW_TRIG (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CTRL_SW_TRIG_SHIFT)) & ADC_ETC_TRIGn_CTRL_SW_TRIG_MASK)
SW_TRIG 0b0..No software trigger event generated. 0b1..Software trigger event generated.
◆ ADC_ETC_TRIGn_CTRL_SW_TRIG [2/3]
◆ ADC_ETC_TRIGn_CTRL_SW_TRIG [3/3]
◆ ADC_ETC_TRIGn_CTRL_SYNC_MODE [1/3]
#define ADC_ETC_TRIGn_CTRL_SYNC_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CTRL_SYNC_MODE_SHIFT)) & ADC_ETC_TRIGn_CTRL_SYNC_MODE_MASK)
SYNC_MODE 0b0..Synchronization mode disabled, TRIGa and TRIG(a+4) are triggered independently. 0b1..Synchronization mode enabled, TRIGa and TRIG(a+4) are triggered by TRIGa source synchronously.
◆ ADC_ETC_TRIGn_CTRL_SYNC_MODE [2/3]
◆ ADC_ETC_TRIGn_CTRL_SYNC_MODE [3/3]
◆ ADC_ETC_TRIGn_CTRL_TRIG_CHAIN [1/3]
#define ADC_ETC_TRIGn_CTRL_TRIG_CHAIN (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CTRL_TRIG_CHAIN_SHIFT)) & ADC_ETC_TRIGn_CTRL_TRIG_CHAIN_MASK)
TRIG_CHAIN 0b000..Trigger chain length is 1 0b001..Trigger chain length is 2 0b010..Trigger chain length is 3 0b011..Trigger chain length is 4 0b100..Trigger chain length is 5 0b101..Trigger chain length is 6 0b110..Trigger chain length is 7 0b111..Trigger chain length is 8
◆ ADC_ETC_TRIGn_CTRL_TRIG_CHAIN [2/3]
◆ ADC_ETC_TRIGn_CTRL_TRIG_CHAIN [3/3]
◆ ADC_ETC_TRIGn_CTRL_TRIG_MODE [1/3]
#define ADC_ETC_TRIGn_CTRL_TRIG_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << ADC_ETC_TRIGn_CTRL_TRIG_MODE_SHIFT)) & ADC_ETC_TRIGn_CTRL_TRIG_MODE_MASK)
TRIG_MODE 0b0..Hardware trigger. The softerware trigger will be ignored. 0b1..Software trigger. The hardware trigger will be ignored.
◆ ADC_ETC_TRIGn_CTRL_TRIG_MODE [2/3]
◆ ADC_ETC_TRIGn_CTRL_TRIG_MODE [3/3]
