RTEMS 6.1
start Directory Reference
file  bootcard.c
file  bspfatal-default.c
 This source file contains the implementation of bsp_fatal_extension().
file  bspgetworkarea-default.c
 This source file contains the default implementation of _Memory_Get().
file  bspsmp-arm-psci.c
 PSCI-based BSP CPU start.
file  gettargethash-default.c
 This source file contains the default implementation of rtems_get_target_hash().
file  mallocinitmulti.c
 This source file contains the _Workspace_Malloc_initialize_separate() implementation which supports more than one memory area.
file  mallocinitone.c
 This source file contains the _Workspace_Malloc_initialize_separate() implementation which supports exactly one memory area.
file  stackalloc.c
 Stack initialization, allocation and free functions.
file  wkspaceinitmulti.c
 This source file contains the _Workspace_Handler_initialization() implementation which supports more than one memory area.
file  wkspaceinitone.c
 This source file contains the _Workspace_Handler_initialization() implementation which supports exactly one memory area.
