This group contains the Memory Handler implementation.
More...
| const Memory_Information * | _Memory_Get (void) |
| | Return the memory information of this platform.
| void * | _Memory_Allocate (const Memory_Information *information, uintptr_t size, uintptr_t alignment) |
| | Allocate a memory area from the memory information.
| void | _Memory_Fill (const Memory_Information *information, int c) |
| | Fill all free memory areas of the memory information with a constant byte.
void | _Memory_Zero_free_areas (void) |
| | Zeros all free memory areas of the system.
void | _Memory_Dirty_free_areas (void) |
| | Dirty all free memory areas of the system.
| const bool | _Memory_Zero_before_use |
| | Indicates if the memory is zeroed during system initialization.
char | _Memory_Noinit_begin [] |
| | This symbol marks the begin of the non-initialized section used by RTEMS.
char | _Memory_Noinit_end [] |
| | This symbol marks the end of the non-initialized section used by RTEMS.
The Memory Handler provides memory areas supplied by the BSP to higher level memory consumers such as the Workspace Handler and the Malloc Support.
◆ MEMORY_INFORMATION_INITIALIZER
| #define MEMORY_INFORMATION_INITIALIZER |
areas | ) |
{ RTEMS_ARRAY_SIZE( areas ), ( areas ) } |
Statically initialize a memory information.
- Parameters
| areas | The designator of an array of the memory areas. |
◆ MEMORY_INITIALIZER
| #define MEMORY_INITIALIZER |
begin, |
end |
| { ( begin ), ( begin ), ( end ) } |
Statically initialize a memory area.
- Parameters
| begin | The begin of the memory area. |
| end | The end of the memory area. |
◆ _Memory_Allocate()
| void * _Memory_Allocate |
information, |
uintptr_t |
size, |
uintptr_t |
alignment |
It is not possible to free the memory area allocated by this function.
- Parameters
| information | The memory information. |
| size | The size in bytes of the memory area to allocate. |
| alignment | The alignment in bytes of the memory area to allocate. It must be a power of two. |
- Return values
| NULL | No such memory area available. |
| begin | The begin of the allocated memory area. |
◆ _Memory_Fill()
- Parameters
| c | The constant byte to fill the free memory areas. |
◆ _Memory_Get()
This function is provided by the Board Support Package (BSP). Using a function gives the BSPs a bit more freedom with respect to the implementation. Calling this function shall not have side-effects. Initialization steps to set up the memory information shall be done in a system initialization handler (RTEMS_SYSINIT_MEMORY).
- Returns
- The memory information.
◆ _Memory_Zero_before_use
| const bool _Memory_Zero_before_use |
extern |
This value is provided via <rtems/confdefs.h> in case CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY is defined.
