RTEMS 6.1
Data Structures | Macros
core_cm7.h File Reference
CMSIS Cortex-M7 Core Peripheral Access Layer Header File. More...
#include <stdint.h>
#include "cmsis_version.h"
#include "cmsis_compiler.h"
union  APSR_Type
 Union type to access the Application Program Status Register (APSR). More...
union  IPSR_Type
 Union type to access the Interrupt Program Status Register (IPSR). More...
union  xPSR_Type
 Union type to access the Special-Purpose Program Status Registers (xPSR). More...
union  CONTROL_Type
 Union type to access the Control Registers (CONTROL). More...
struct  NVIC_Type
 Structure type to access the Nested Vectored Interrupt Controller (NVIC). More...
struct  SCB_Type
 Structure type to access the System Control Block (SCB). More...
struct  SCnSCB_Type
 Structure type to access the System Control and ID Register not in the SCB. More...
struct  SysTick_Type
 Structure type to access the System Timer (SysTick). More...
struct  ITM_Type
 Structure type to access the Instrumentation Trace Macrocell Register (ITM). More...
struct  DWT_Type
 Structure type to access the Data Watchpoint and Trace Register (DWT). More...
struct  TPI_Type
 Structure type to access the Trace Port Interface Register (TPI). More...
struct  FPU_Type
 Structure type to access the Floating Point Unit (FPU). More...
struct  CoreDebug_Type
 Structure type to access the Core Debug Register (CoreDebug). More...
__STATIC_INLINE void __NVIC_SetPriorityGrouping (uint32_t PriorityGroup)
 Set Priority Grouping.
__STATIC_INLINE uint32_t __NVIC_GetPriorityGrouping (void)
 Get Priority Grouping.
__STATIC_INLINE void __NVIC_EnableIRQ (IRQn_Type IRQn)
 Enable Interrupt.
__STATIC_INLINE uint32_t __NVIC_GetEnableIRQ (IRQn_Type IRQn)
 Get Interrupt Enable status.
__STATIC_INLINE void __NVIC_DisableIRQ (IRQn_Type IRQn)
 Disable Interrupt.
__STATIC_INLINE uint32_t __NVIC_GetPendingIRQ (IRQn_Type IRQn)
 Get Pending Interrupt.
__STATIC_INLINE void __NVIC_SetPendingIRQ (IRQn_Type IRQn)
 Set Pending Interrupt.
__STATIC_INLINE void __NVIC_ClearPendingIRQ (IRQn_Type IRQn)
 Clear Pending Interrupt.
__STATIC_INLINE uint32_t __NVIC_GetActive (IRQn_Type IRQn)
 Get Active Interrupt.
__STATIC_INLINE void __NVIC_SetPriority (IRQn_Type IRQn, uint32_t priority)
 Set Interrupt Priority.
__STATIC_INLINE uint32_t __NVIC_GetPriority (IRQn_Type IRQn)
 Get Interrupt Priority.
__STATIC_INLINE uint32_t NVIC_EncodePriority (uint32_t PriorityGroup, uint32_t PreemptPriority, uint32_t SubPriority)
 Encode Priority.
__STATIC_INLINE void NVIC_DecodePriority (uint32_t Priority, uint32_t PriorityGroup, uint32_t *const pPreemptPriority, uint32_t *const pSubPriority)
 Decode Priority.
__STATIC_INLINE void __NVIC_SetVector (IRQn_Type IRQn, uint32_t vector)
 Set Interrupt Vector.
__STATIC_INLINE uint32_t __NVIC_GetVector (IRQn_Type IRQn)
 Get Interrupt Vector.
__NO_RETURN __STATIC_INLINE void __NVIC_SystemReset (void)
 System Reset.
__STATIC_INLINE uint32_t SCB_GetFPUType (void)
 get FPU type
__STATIC_INLINE uint32_t ITM_SendChar (uint32_t ch)
 ITM Send Character.
__STATIC_INLINE int32_t ITM_ReceiveChar (void)
 ITM Receive Character.
__STATIC_INLINE int32_t ITM_CheckChar (void)
 ITM Check Character.
#define __CM7_CMSIS_VERSION_MAIN   (__CM_CMSIS_VERSION_MAIN)
#define __CM7_CMSIS_VERSION_SUB   ( __CM_CMSIS_VERSION_SUB)
#define __CORTEX_M   (7U)
#define __CORE_CM7_H_DEPENDANT
#define __I   volatile const
#define __O   volatile
#define __IO   volatile
#define __IM   volatile const /*! Defines 'read only' structure member permissions */
#define __OM   volatile /*! Defines 'write only' structure member permissions */
#define __IOM   volatile /*! Defines 'read / write' structure member permissions */
#define APSR_N_Pos   31U
#define APSR_N_Msk   (1UL << APSR_N_Pos)
#define APSR_Z_Pos   30U
#define APSR_Z_Msk   (1UL << APSR_Z_Pos)
#define APSR_C_Pos   29U
#define APSR_C_Msk   (1UL << APSR_C_Pos)
#define APSR_V_Pos   28U
#define APSR_V_Msk   (1UL << APSR_V_Pos)
#define APSR_Q_Pos   27U
#define APSR_Q_Msk   (1UL << APSR_Q_Pos)
#define APSR_GE_Pos   16U
#define APSR_GE_Msk   (0xFUL << APSR_GE_Pos)
#define IPSR_ISR_Pos   0U
#define IPSR_ISR_Msk   (0x1FFUL /*<< IPSR_ISR_Pos*/)
#define xPSR_N_Pos   31U
#define xPSR_N_Msk   (1UL << xPSR_N_Pos)
#define xPSR_Z_Pos   30U
#define xPSR_Z_Msk   (1UL << xPSR_Z_Pos)
#define xPSR_C_Pos   29U
#define xPSR_C_Msk   (1UL << xPSR_C_Pos)
#define xPSR_V_Pos   28U
#define xPSR_V_Msk   (1UL << xPSR_V_Pos)
#define xPSR_Q_Pos   27U
#define xPSR_Q_Msk   (1UL << xPSR_Q_Pos)
#define xPSR_ICI_IT_2_Pos   25U
#define xPSR_ICI_IT_2_Msk   (3UL << xPSR_ICI_IT_2_Pos)
#define xPSR_T_Pos   24U
#define xPSR_T_Msk   (1UL << xPSR_T_Pos)
#define xPSR_GE_Pos   16U
#define xPSR_GE_Msk   (0xFUL << xPSR_GE_Pos)
#define xPSR_ICI_IT_1_Pos   10U
#define xPSR_ICI_IT_1_Msk   (0x3FUL << xPSR_ICI_IT_1_Pos)
#define xPSR_ISR_Pos   0U
#define xPSR_ISR_Msk   (0x1FFUL /*<< xPSR_ISR_Pos*/)
#define CONTROL_FPCA_Pos   2U
#define CONTROL_FPCA_Msk   (1UL << CONTROL_FPCA_Pos)
#define CONTROL_SPSEL_Pos   1U
#define CONTROL_SPSEL_Msk   (1UL << CONTROL_SPSEL_Pos)
#define CONTROL_nPRIV_Pos   0U
#define CONTROL_nPRIV_Msk   (1UL /*<< CONTROL_nPRIV_Pos*/)
#define NVIC_STIR_INTID_Pos   0U
#define NVIC_STIR_INTID_Msk   (0x1FFUL /*<< NVIC_STIR_INTID_Pos*/)
#define SCB_CPUID_IMPLEMENTER_Pos   24U
#define SCB_CPUID_IMPLEMENTER_Msk   (0xFFUL << SCB_CPUID_IMPLEMENTER_Pos)
#define SCB_CPUID_VARIANT_Pos   20U
#define SCB_CPUID_VARIANT_Msk   (0xFUL << SCB_CPUID_VARIANT_Pos)
#define SCB_CPUID_ARCHITECTURE_Pos   16U
#define SCB_CPUID_ARCHITECTURE_Msk   (0xFUL << SCB_CPUID_ARCHITECTURE_Pos)
#define SCB_CPUID_PARTNO_Pos   4U
#define SCB_CPUID_PARTNO_Msk   (0xFFFUL << SCB_CPUID_PARTNO_Pos)
#define SCB_CPUID_REVISION_Pos   0U
#define SCB_CPUID_REVISION_Msk   (0xFUL /*<< SCB_CPUID_REVISION_Pos*/)
#define SCB_ICSR_NMIPENDSET_Pos   31U
#define SCB_ICSR_NMIPENDSET_Msk   (1UL << SCB_ICSR_NMIPENDSET_Pos)
#define SCB_ICSR_PENDSVSET_Pos   28U
#define SCB_ICSR_PENDSVSET_Msk   (1UL << SCB_ICSR_PENDSVSET_Pos)
#define SCB_ICSR_PENDSVCLR_Pos   27U
#define SCB_ICSR_PENDSVCLR_Msk   (1UL << SCB_ICSR_PENDSVCLR_Pos)
#define SCB_ICSR_PENDSTSET_Pos   26U
#define SCB_ICSR_PENDSTSET_Msk   (1UL << SCB_ICSR_PENDSTSET_Pos)
#define SCB_ICSR_PENDSTCLR_Pos   25U
#define SCB_ICSR_PENDSTCLR_Msk   (1UL << SCB_ICSR_PENDSTCLR_Pos)
#define SCB_ICSR_ISRPREEMPT_Pos   23U
#define SCB_ICSR_ISRPREEMPT_Msk   (1UL << SCB_ICSR_ISRPREEMPT_Pos)
#define SCB_ICSR_ISRPENDING_Pos   22U
#define SCB_ICSR_ISRPENDING_Msk   (1UL << SCB_ICSR_ISRPENDING_Pos)
#define SCB_ICSR_VECTPENDING_Pos   12U
#define SCB_ICSR_VECTPENDING_Msk   (0x1FFUL << SCB_ICSR_VECTPENDING_Pos)
#define SCB_ICSR_RETTOBASE_Pos   11U
#define SCB_ICSR_RETTOBASE_Msk   (1UL << SCB_ICSR_RETTOBASE_Pos)
#define SCB_ICSR_VECTACTIVE_Pos   0U
#define SCB_ICSR_VECTACTIVE_Msk   (0x1FFUL /*<< SCB_ICSR_VECTACTIVE_Pos*/)
#define SCB_VTOR_TBLOFF_Pos   7U
#define SCB_VTOR_TBLOFF_Msk   (0x1FFFFFFUL << SCB_VTOR_TBLOFF_Pos)
#define SCB_AIRCR_VECTKEY_Pos   16U
#define SCB_AIRCR_VECTKEY_Msk   (0xFFFFUL << SCB_AIRCR_VECTKEY_Pos)
#define SCB_AIRCR_VECTKEYSTAT_Pos   16U
#define SCB_AIRCR_VECTKEYSTAT_Msk   (0xFFFFUL << SCB_AIRCR_VECTKEYSTAT_Pos)
#define SCB_AIRCR_ENDIANESS_Pos   15U
#define SCB_AIRCR_ENDIANESS_Msk   (1UL << SCB_AIRCR_ENDIANESS_Pos)
#define SCB_AIRCR_PRIGROUP_Pos   8U
#define SCB_AIRCR_PRIGROUP_Msk   (7UL << SCB_AIRCR_PRIGROUP_Pos)
#define SCB_AIRCR_SYSRESETREQ_Pos   2U
#define SCB_AIRCR_SYSRESETREQ_Msk   (1UL << SCB_AIRCR_SYSRESETREQ_Pos)
#define SCB_AIRCR_VECTCLRACTIVE_Pos   1U
#define SCB_AIRCR_VECTCLRACTIVE_Msk   (1UL << SCB_AIRCR_VECTCLRACTIVE_Pos)
#define SCB_AIRCR_VECTRESET_Pos   0U
#define SCB_AIRCR_VECTRESET_Msk   (1UL /*<< SCB_AIRCR_VECTRESET_Pos*/)
#define SCB_SCR_SEVONPEND_Pos   4U
#define SCB_SCR_SEVONPEND_Msk   (1UL << SCB_SCR_SEVONPEND_Pos)
#define SCB_SCR_SLEEPDEEP_Pos   2U
#define SCB_SCR_SLEEPDEEP_Msk   (1UL << SCB_SCR_SLEEPDEEP_Pos)
#define SCB_SCR_SLEEPONEXIT_Pos   1U
#define SCB_SCR_SLEEPONEXIT_Msk   (1UL << SCB_SCR_SLEEPONEXIT_Pos)
#define SCB_CCR_BP_Pos   18U
#define SCB_CCR_BP_Msk   (1UL << SCB_CCR_BP_Pos)
#define SCB_CCR_IC_Pos   17U
#define SCB_CCR_IC_Msk   (1UL << SCB_CCR_IC_Pos)
#define SCB_CCR_DC_Pos   16U
#define SCB_CCR_DC_Msk   (1UL << SCB_CCR_DC_Pos)
#define SCB_CCR_STKALIGN_Pos   9U
#define SCB_CCR_STKALIGN_Msk   (1UL << SCB_CCR_STKALIGN_Pos)
#define SCB_CCR_BFHFNMIGN_Pos   8U
#define SCB_CCR_BFHFNMIGN_Msk   (1UL << SCB_CCR_BFHFNMIGN_Pos)
#define SCB_CCR_DIV_0_TRP_Pos   4U
#define SCB_CCR_DIV_0_TRP_Msk   (1UL << SCB_CCR_DIV_0_TRP_Pos)
#define SCB_CCR_UNALIGN_TRP_Pos   3U
#define SCB_CCR_UNALIGN_TRP_Msk   (1UL << SCB_CCR_UNALIGN_TRP_Pos)
#define SCB_CCR_USERSETMPEND_Pos   1U
#define SCB_CCR_USERSETMPEND_Msk   (1UL << SCB_CCR_USERSETMPEND_Pos)
#define SCB_CCR_NONBASETHRDENA_Pos   0U
#define SCB_CCR_NONBASETHRDENA_Msk   (1UL /*<< SCB_CCR_NONBASETHRDENA_Pos*/)
#define SCB_SHCSR_USGFAULTENA_Pos   18U
#define SCB_SHCSR_USGFAULTENA_Msk   (1UL << SCB_SHCSR_USGFAULTENA_Pos)
#define SCB_SHCSR_BUSFAULTENA_Pos   17U
#define SCB_SHCSR_BUSFAULTENA_Msk   (1UL << SCB_SHCSR_BUSFAULTENA_Pos)
#define SCB_SHCSR_MEMFAULTENA_Pos   16U
#define SCB_SHCSR_MEMFAULTENA_Msk   (1UL << SCB_SHCSR_MEMFAULTENA_Pos)
#define SCB_SHCSR_SVCALLPENDED_Pos   15U
#define SCB_SHCSR_SVCALLPENDED_Msk   (1UL << SCB_SHCSR_SVCALLPENDED_Pos)
#define SCB_SHCSR_BUSFAULTPENDED_Pos   14U
#define SCB_SHCSR_BUSFAULTPENDED_Msk   (1UL << SCB_SHCSR_BUSFAULTPENDED_Pos)
#define SCB_SHCSR_MEMFAULTPENDED_Pos   13U
#define SCB_SHCSR_MEMFAULTPENDED_Msk   (1UL << SCB_SHCSR_MEMFAULTPENDED_Pos)
#define SCB_SHCSR_USGFAULTPENDED_Pos   12U
#define SCB_SHCSR_USGFAULTPENDED_Msk   (1UL << SCB_SHCSR_USGFAULTPENDED_Pos)
#define SCB_SHCSR_SYSTICKACT_Pos   11U
#define SCB_SHCSR_SYSTICKACT_Msk   (1UL << SCB_SHCSR_SYSTICKACT_Pos)
#define SCB_SHCSR_PENDSVACT_Pos   10U
#define SCB_SHCSR_PENDSVACT_Msk   (1UL << SCB_SHCSR_PENDSVACT_Pos)
#define SCB_SHCSR_MONITORACT_Pos   8U
#define SCB_SHCSR_MONITORACT_Msk   (1UL << SCB_SHCSR_MONITORACT_Pos)
#define SCB_SHCSR_SVCALLACT_Pos   7U
#define SCB_SHCSR_SVCALLACT_Msk   (1UL << SCB_SHCSR_SVCALLACT_Pos)
#define SCB_SHCSR_USGFAULTACT_Pos   3U
#define SCB_SHCSR_USGFAULTACT_Msk   (1UL << SCB_SHCSR_USGFAULTACT_Pos)
#define SCB_SHCSR_BUSFAULTACT_Pos   1U
#define SCB_SHCSR_BUSFAULTACT_Msk   (1UL << SCB_SHCSR_BUSFAULTACT_Pos)
#define SCB_SHCSR_MEMFAULTACT_Pos   0U
#define SCB_SHCSR_MEMFAULTACT_Msk   (1UL /*<< SCB_SHCSR_MEMFAULTACT_Pos*/)
#define SCB_CFSR_USGFAULTSR_Pos   16U
#define SCB_CFSR_USGFAULTSR_Msk   (0xFFFFUL << SCB_CFSR_USGFAULTSR_Pos)
#define SCB_CFSR_BUSFAULTSR_Pos   8U
#define SCB_CFSR_BUSFAULTSR_Msk   (0xFFUL << SCB_CFSR_BUSFAULTSR_Pos)
#define SCB_CFSR_MEMFAULTSR_Pos   0U
#define SCB_CFSR_MEMFAULTSR_Msk   (0xFFUL /*<< SCB_CFSR_MEMFAULTSR_Pos*/)
#define SCB_CFSR_MMARVALID_Pos   (SCB_CFSR_MEMFAULTSR_Pos + 7U)
#define SCB_CFSR_MMARVALID_Msk   (1UL << SCB_CFSR_MMARVALID_Pos)
#define SCB_CFSR_MLSPERR_Pos   (SCB_CFSR_MEMFAULTSR_Pos + 5U)
#define SCB_CFSR_MLSPERR_Msk   (1UL << SCB_CFSR_MLSPERR_Pos)
#define SCB_CFSR_MSTKERR_Pos   (SCB_CFSR_MEMFAULTSR_Pos + 4U)
#define SCB_CFSR_MSTKERR_Msk   (1UL << SCB_CFSR_MSTKERR_Pos)
#define SCB_CFSR_MUNSTKERR_Pos   (SCB_CFSR_MEMFAULTSR_Pos + 3U)
#define SCB_CFSR_MUNSTKERR_Msk   (1UL << SCB_CFSR_MUNSTKERR_Pos)
#define SCB_CFSR_DACCVIOL_Pos   (SCB_CFSR_MEMFAULTSR_Pos + 1U)
#define SCB_CFSR_DACCVIOL_Msk   (1UL << SCB_CFSR_DACCVIOL_Pos)
#define SCB_CFSR_IACCVIOL_Pos   (SCB_CFSR_MEMFAULTSR_Pos + 0U)
#define SCB_CFSR_IACCVIOL_Msk   (1UL /*<< SCB_CFSR_IACCVIOL_Pos*/)
#define SCB_CFSR_BFARVALID_Pos   (SCB_CFSR_BUSFAULTSR_Pos + 7U)
#define SCB_CFSR_BFARVALID_Msk   (1UL << SCB_CFSR_BFARVALID_Pos)
#define SCB_CFSR_LSPERR_Pos   (SCB_CFSR_BUSFAULTSR_Pos + 5U)
#define SCB_CFSR_LSPERR_Msk   (1UL << SCB_CFSR_LSPERR_Pos)
#define SCB_CFSR_STKERR_Pos   (SCB_CFSR_BUSFAULTSR_Pos + 4U)
#define SCB_CFSR_STKERR_Msk   (1UL << SCB_CFSR_STKERR_Pos)
#define SCB_CFSR_UNSTKERR_Pos   (SCB_CFSR_BUSFAULTSR_Pos + 3U)
#define SCB_CFSR_UNSTKERR_Msk   (1UL << SCB_CFSR_UNSTKERR_Pos)
#define SCB_CFSR_IMPRECISERR_Pos   (SCB_CFSR_BUSFAULTSR_Pos + 2U)
#define SCB_CFSR_IMPRECISERR_Msk   (1UL << SCB_CFSR_IMPRECISERR_Pos)
#define SCB_CFSR_PRECISERR_Pos   (SCB_CFSR_BUSFAULTSR_Pos + 1U)
#define SCB_CFSR_PRECISERR_Msk   (1UL << SCB_CFSR_PRECISERR_Pos)
#define SCB_CFSR_IBUSERR_Pos   (SCB_CFSR_BUSFAULTSR_Pos + 0U)
#define SCB_CFSR_IBUSERR_Msk   (1UL << SCB_CFSR_IBUSERR_Pos)
#define SCB_CFSR_DIVBYZERO_Pos   (SCB_CFSR_USGFAULTSR_Pos + 9U)
#define SCB_CFSR_DIVBYZERO_Msk   (1UL << SCB_CFSR_DIVBYZERO_Pos)
#define SCB_CFSR_UNALIGNED_Pos   (SCB_CFSR_USGFAULTSR_Pos + 8U)
#define SCB_CFSR_UNALIGNED_Msk   (1UL << SCB_CFSR_UNALIGNED_Pos)
#define SCB_CFSR_NOCP_Pos   (SCB_CFSR_USGFAULTSR_Pos + 3U)
#define SCB_CFSR_NOCP_Msk   (1UL << SCB_CFSR_NOCP_Pos)
#define SCB_CFSR_INVPC_Pos   (SCB_CFSR_USGFAULTSR_Pos + 2U)
#define SCB_CFSR_INVPC_Msk   (1UL << SCB_CFSR_INVPC_Pos)
#define SCB_CFSR_INVSTATE_Pos   (SCB_CFSR_USGFAULTSR_Pos + 1U)
#define SCB_CFSR_INVSTATE_Msk   (1UL << SCB_CFSR_INVSTATE_Pos)
#define SCB_CFSR_UNDEFINSTR_Pos   (SCB_CFSR_USGFAULTSR_Pos + 0U)
#define SCB_CFSR_UNDEFINSTR_Msk   (1UL << SCB_CFSR_UNDEFINSTR_Pos)
#define SCB_HFSR_DEBUGEVT_Pos   31U
#define SCB_HFSR_DEBUGEVT_Msk   (1UL << SCB_HFSR_DEBUGEVT_Pos)
#define SCB_HFSR_FORCED_Pos   30U
#define SCB_HFSR_FORCED_Msk   (1UL << SCB_HFSR_FORCED_Pos)
#define SCB_HFSR_VECTTBL_Pos   1U
#define SCB_HFSR_VECTTBL_Msk   (1UL << SCB_HFSR_VECTTBL_Pos)
#define SCB_DFSR_EXTERNAL_Pos   4U
#define SCB_DFSR_EXTERNAL_Msk   (1UL << SCB_DFSR_EXTERNAL_Pos)
#define SCB_DFSR_VCATCH_Pos   3U
#define SCB_DFSR_VCATCH_Msk   (1UL << SCB_DFSR_VCATCH_Pos)
#define SCB_DFSR_DWTTRAP_Pos   2U
#define SCB_DFSR_DWTTRAP_Msk   (1UL << SCB_DFSR_DWTTRAP_Pos)
#define SCB_DFSR_BKPT_Pos   1U
#define SCB_DFSR_BKPT_Msk   (1UL << SCB_DFSR_BKPT_Pos)
#define SCB_DFSR_HALTED_Pos   0U
#define SCB_DFSR_HALTED_Msk   (1UL /*<< SCB_DFSR_HALTED_Pos*/)
#define SCB_CLIDR_LOUU_Pos   27U
#define SCB_CLIDR_LOUU_Msk   (7UL << SCB_CLIDR_LOUU_Pos)
#define SCB_CLIDR_LOC_Pos   24U
#define SCB_CLIDR_LOC_Msk   (7UL << SCB_CLIDR_LOC_Pos)
#define SCB_CTR_FORMAT_Pos   29U
#define SCB_CTR_FORMAT_Msk   (7UL << SCB_CTR_FORMAT_Pos)
#define SCB_CTR_CWG_Pos   24U
#define SCB_CTR_CWG_Msk   (0xFUL << SCB_CTR_CWG_Pos)
#define SCB_CTR_ERG_Pos   20U
#define SCB_CTR_ERG_Msk   (0xFUL << SCB_CTR_ERG_Pos)
#define SCB_CTR_DMINLINE_Pos   16U
#define SCB_CTR_DMINLINE_Msk   (0xFUL << SCB_CTR_DMINLINE_Pos)
#define SCB_CTR_IMINLINE_Pos   0U
#define SCB_CTR_IMINLINE_Msk   (0xFUL /*<< SCB_CTR_IMINLINE_Pos*/)
#define SCB_CCSIDR_WT_Pos   31U
#define SCB_CCSIDR_WT_Msk   (1UL << SCB_CCSIDR_WT_Pos)
#define SCB_CCSIDR_WB_Pos   30U
#define SCB_CCSIDR_WB_Msk   (1UL << SCB_CCSIDR_WB_Pos)
#define SCB_CCSIDR_RA_Pos   29U
#define SCB_CCSIDR_RA_Msk   (1UL << SCB_CCSIDR_RA_Pos)
#define SCB_CCSIDR_WA_Pos   28U
#define SCB_CCSIDR_WA_Msk   (1UL << SCB_CCSIDR_WA_Pos)
#define SCB_CCSIDR_NUMSETS_Pos   13U
#define SCB_CCSIDR_NUMSETS_Msk   (0x7FFFUL << SCB_CCSIDR_NUMSETS_Pos)
#define SCB_CCSIDR_ASSOCIATIVITY_Pos   3U
#define SCB_CCSIDR_ASSOCIATIVITY_Msk   (0x3FFUL << SCB_CCSIDR_ASSOCIATIVITY_Pos)
#define SCB_CCSIDR_LINESIZE_Pos   0U
#define SCB_CCSIDR_LINESIZE_Msk   (7UL /*<< SCB_CCSIDR_LINESIZE_Pos*/)
#define SCB_CSSELR_LEVEL_Pos   1U
#define SCB_CSSELR_LEVEL_Msk   (7UL << SCB_CSSELR_LEVEL_Pos)
#define SCB_CSSELR_IND_Pos   0U
#define SCB_CSSELR_IND_Msk   (1UL /*<< SCB_CSSELR_IND_Pos*/)
#define SCB_STIR_INTID_Pos   0U
#define SCB_STIR_INTID_Msk   (0x1FFUL /*<< SCB_STIR_INTID_Pos*/)
#define SCB_DCISW_WAY_Pos   30U
#define SCB_DCISW_WAY_Msk   (3UL << SCB_DCISW_WAY_Pos)
#define SCB_DCISW_SET_Pos   5U
#define SCB_DCISW_SET_Msk   (0x1FFUL << SCB_DCISW_SET_Pos)
#define SCB_DCCSW_WAY_Pos   30U
#define SCB_DCCSW_WAY_Msk   (3UL << SCB_DCCSW_WAY_Pos)
#define SCB_DCCSW_SET_Pos   5U
#define SCB_DCCSW_SET_Msk   (0x1FFUL << SCB_DCCSW_SET_Pos)
#define SCB_DCCISW_WAY_Pos   30U
#define SCB_DCCISW_WAY_Msk   (3UL << SCB_DCCISW_WAY_Pos)
#define SCB_DCCISW_SET_Pos   5U
#define SCB_DCCISW_SET_Msk   (0x1FFUL << SCB_DCCISW_SET_Pos)
#define SCB_ITCMCR_SZ_Pos   3U
#define SCB_ITCMCR_SZ_Msk   (0xFUL << SCB_ITCMCR_SZ_Pos)
#define SCB_ITCMCR_RETEN_Pos   2U
#define SCB_ITCMCR_RETEN_Msk   (1UL << SCB_ITCMCR_RETEN_Pos)
#define SCB_ITCMCR_RMW_Pos   1U
#define SCB_ITCMCR_RMW_Msk   (1UL << SCB_ITCMCR_RMW_Pos)
#define SCB_ITCMCR_EN_Pos   0U
#define SCB_ITCMCR_EN_Msk   (1UL /*<< SCB_ITCMCR_EN_Pos*/)
#define SCB_DTCMCR_SZ_Pos   3U
#define SCB_DTCMCR_SZ_Msk   (0xFUL << SCB_DTCMCR_SZ_Pos)
#define SCB_DTCMCR_RETEN_Pos   2U
#define SCB_DTCMCR_RETEN_Msk   (1UL << SCB_DTCMCR_RETEN_Pos)
#define SCB_DTCMCR_RMW_Pos   1U
#define SCB_DTCMCR_RMW_Msk   (1UL << SCB_DTCMCR_RMW_Pos)
#define SCB_DTCMCR_EN_Pos   0U
#define SCB_DTCMCR_EN_Msk   (1UL /*<< SCB_DTCMCR_EN_Pos*/)
#define SCB_AHBPCR_SZ_Pos   1U
#define SCB_AHBPCR_SZ_Msk   (7UL << SCB_AHBPCR_SZ_Pos)
#define SCB_AHBPCR_EN_Pos   0U
#define SCB_AHBPCR_EN_Msk   (1UL /*<< SCB_AHBPCR_EN_Pos*/)
#define SCB_CACR_FORCEWT_Pos   2U
#define SCB_CACR_FORCEWT_Msk   (1UL << SCB_CACR_FORCEWT_Pos)
#define SCB_CACR_ECCEN_Pos   1U
#define SCB_CACR_ECCEN_Msk   (1UL << SCB_CACR_ECCEN_Pos)
#define SCB_CACR_ECCDIS_Pos   1U
#define SCB_CACR_ECCDIS_Msk   (1UL << SCB_CACR_ECCDIS_Pos)
#define SCB_CACR_SIWT_Pos   0U
#define SCB_CACR_SIWT_Msk   (1UL /*<< SCB_CACR_SIWT_Pos*/)
#define SCB_AHBSCR_INITCOUNT_Pos   11U
#define SCB_AHBSCR_INITCOUNT_Msk   (0x1FUL << SCB_AHBSCR_INITCOUNT_Pos)
#define SCB_AHBSCR_TPRI_Pos   2U
#define SCB_AHBSCR_TPRI_Msk   (0x1FFUL << SCB_AHBSCR_TPRI_Pos)
#define SCB_AHBSCR_CTL_Pos   0U
#define SCB_AHBSCR_CTL_Msk   (3UL /*<< SCB_AHBSCR_CTL_Pos*/)
#define SCB_ABFSR_AXIMTYPE_Pos   8U
#define SCB_ABFSR_AXIMTYPE_Msk   (3UL << SCB_ABFSR_AXIMTYPE_Pos)
#define SCB_ABFSR_EPPB_Pos   4U
#define SCB_ABFSR_EPPB_Msk   (1UL << SCB_ABFSR_EPPB_Pos)
#define SCB_ABFSR_AXIM_Pos   3U
#define SCB_ABFSR_AXIM_Msk   (1UL << SCB_ABFSR_AXIM_Pos)
#define SCB_ABFSR_AHBP_Pos   2U
#define SCB_ABFSR_AHBP_Msk   (1UL << SCB_ABFSR_AHBP_Pos)
#define SCB_ABFSR_DTCM_Pos   1U
#define SCB_ABFSR_DTCM_Msk   (1UL << SCB_ABFSR_DTCM_Pos)
#define SCB_ABFSR_ITCM_Pos   0U
#define SCB_ABFSR_ITCM_Msk   (1UL /*<< SCB_ABFSR_ITCM_Pos*/)
#define SCnSCB_ICTR_INTLINESNUM_Pos   0U
#define SCnSCB_ICTR_INTLINESNUM_Msk   (0xFUL /*<< SCnSCB_ICTR_INTLINESNUM_Pos*/)
#define SCnSCB_ACTLR_DISDYNADD_Pos   26U
#define SCnSCB_ACTLR_DISDYNADD_Msk   (1UL << SCnSCB_ACTLR_DISDYNADD_Pos)
#define SCnSCB_ACTLR_DISISSCH1_Pos   21U
#define SCnSCB_ACTLR_DISISSCH1_Msk   (0x1FUL << SCnSCB_ACTLR_DISISSCH1_Pos)
#define SCnSCB_ACTLR_DISDI_Pos   16U
#define SCnSCB_ACTLR_DISDI_Msk   (0x1FUL << SCnSCB_ACTLR_DISDI_Pos)
#define SCnSCB_ACTLR_DISCRITAXIRUR_Pos   15U
#define SCnSCB_ACTLR_DISCRITAXIRUR_Msk   (1UL << SCnSCB_ACTLR_DISCRITAXIRUR_Pos)
#define SCnSCB_ACTLR_DISBTACALLOC_Pos   14U
#define SCnSCB_ACTLR_DISBTACALLOC_Msk   (1UL << SCnSCB_ACTLR_DISBTACALLOC_Pos)
#define SCnSCB_ACTLR_DISBTACREAD_Pos   13U
#define SCnSCB_ACTLR_DISBTACREAD_Msk   (1UL << SCnSCB_ACTLR_DISBTACREAD_Pos)
#define SCnSCB_ACTLR_DISITMATBFLUSH_Pos   12U
#define SCnSCB_ACTLR_DISITMATBFLUSH_Msk   (1UL << SCnSCB_ACTLR_DISITMATBFLUSH_Pos)
#define SCnSCB_ACTLR_DISRAMODE_Pos   11U
#define SCnSCB_ACTLR_DISRAMODE_Msk   (1UL << SCnSCB_ACTLR_DISRAMODE_Pos)
#define SCnSCB_ACTLR_FPEXCODIS_Pos   10U
#define SCnSCB_ACTLR_FPEXCODIS_Msk   (1UL << SCnSCB_ACTLR_FPEXCODIS_Pos)
#define SCnSCB_ACTLR_DISFOLD_Pos   2U
#define SCnSCB_ACTLR_DISFOLD_Msk   (1UL << SCnSCB_ACTLR_DISFOLD_Pos)
#define SCnSCB_ACTLR_DISMCYCINT_Pos   0U
#define SCnSCB_ACTLR_DISMCYCINT_Msk   (1UL /*<< SCnSCB_ACTLR_DISMCYCINT_Pos*/)
#define SysTick_CTRL_COUNTFLAG_Pos   16U
#define SysTick_CTRL_COUNTFLAG_Msk   (1UL << SysTick_CTRL_COUNTFLAG_Pos)
#define SysTick_CTRL_CLKSOURCE_Pos   2U
#define SysTick_CTRL_CLKSOURCE_Msk   (1UL << SysTick_CTRL_CLKSOURCE_Pos)
#define SysTick_CTRL_TICKINT_Pos   1U
#define SysTick_CTRL_TICKINT_Msk   (1UL << SysTick_CTRL_TICKINT_Pos)
#define SysTick_CTRL_ENABLE_Pos   0U
#define SysTick_CTRL_ENABLE_Msk   (1UL /*<< SysTick_CTRL_ENABLE_Pos*/)
#define SysTick_LOAD_RELOAD_Pos   0U
#define SysTick_LOAD_RELOAD_Msk   (0xFFFFFFUL /*<< SysTick_LOAD_RELOAD_Pos*/)
#define SysTick_VAL_CURRENT_Pos   0U
#define SysTick_VAL_CURRENT_Msk   (0xFFFFFFUL /*<< SysTick_VAL_CURRENT_Pos*/)
#define SysTick_CALIB_NOREF_Pos   31U
#define SysTick_CALIB_NOREF_Msk   (1UL << SysTick_CALIB_NOREF_Pos)
#define SysTick_CALIB_SKEW_Pos   30U
#define SysTick_CALIB_SKEW_Msk   (1UL << SysTick_CALIB_SKEW_Pos)
#define SysTick_CALIB_TENMS_Pos   0U
#define SysTick_CALIB_TENMS_Msk   (0xFFFFFFUL /*<< SysTick_CALIB_TENMS_Pos*/)
#define ITM_TPR_PRIVMASK_Pos   0U
#define ITM_TPR_PRIVMASK_Msk   (0xFFFFFFFFUL /*<< ITM_TPR_PRIVMASK_Pos*/)
#define ITM_TCR_BUSY_Pos   23U
#define ITM_TCR_BUSY_Msk   (1UL << ITM_TCR_BUSY_Pos)
#define ITM_TCR_TRACEBUSID_Pos   16U
#define ITM_TCR_TRACEBUSID_Msk   (0x7FUL << ITM_TCR_TRACEBUSID_Pos)
#define ITM_TCR_GTSFREQ_Pos   10U
#define ITM_TCR_GTSFREQ_Msk   (3UL << ITM_TCR_GTSFREQ_Pos)
#define ITM_TCR_TSPRESCALE_Pos   8U
#define ITM_TCR_TSPRESCALE_Msk   (3UL << ITM_TCR_TSPRESCALE_Pos)
#define ITM_TCR_SWOENA_Pos   4U
#define ITM_TCR_SWOENA_Msk   (1UL << ITM_TCR_SWOENA_Pos)
#define ITM_TCR_DWTENA_Pos   3U
#define ITM_TCR_DWTENA_Msk   (1UL << ITM_TCR_DWTENA_Pos)
#define ITM_TCR_SYNCENA_Pos   2U
#define ITM_TCR_SYNCENA_Msk   (1UL << ITM_TCR_SYNCENA_Pos)
#define ITM_TCR_TSENA_Pos   1U
#define ITM_TCR_TSENA_Msk   (1UL << ITM_TCR_TSENA_Pos)
#define ITM_TCR_ITMENA_Pos   0U
#define ITM_TCR_ITMENA_Msk   (1UL /*<< ITM_TCR_ITMENA_Pos*/)
#define ITM_LSR_BYTEACC_Pos   2U
#define ITM_LSR_BYTEACC_Msk   (1UL << ITM_LSR_BYTEACC_Pos)
#define ITM_LSR_ACCESS_Pos   1U
#define ITM_LSR_ACCESS_Msk   (1UL << ITM_LSR_ACCESS_Pos)
#define ITM_LSR_PRESENT_Pos   0U
#define ITM_LSR_PRESENT_Msk   (1UL /*<< ITM_LSR_PRESENT_Pos*/)
#define DWT_CTRL_NUMCOMP_Pos   28U
#define DWT_CTRL_NUMCOMP_Msk   (0xFUL << DWT_CTRL_NUMCOMP_Pos)
#define DWT_CTRL_NOTRCPKT_Pos   27U
#define DWT_CTRL_NOTRCPKT_Msk   (0x1UL << DWT_CTRL_NOTRCPKT_Pos)
#define DWT_CTRL_NOEXTTRIG_Pos   26U
#define DWT_CTRL_NOEXTTRIG_Msk   (0x1UL << DWT_CTRL_NOEXTTRIG_Pos)
#define DWT_CTRL_NOCYCCNT_Pos   25U
#define DWT_CTRL_NOCYCCNT_Msk   (0x1UL << DWT_CTRL_NOCYCCNT_Pos)
#define DWT_CTRL_NOPRFCNT_Pos   24U
#define DWT_CTRL_NOPRFCNT_Msk   (0x1UL << DWT_CTRL_NOPRFCNT_Pos)
#define DWT_CTRL_CYCEVTENA_Pos   22U
#define DWT_CTRL_CYCEVTENA_Msk   (0x1UL << DWT_CTRL_CYCEVTENA_Pos)
#define DWT_CTRL_FOLDEVTENA_Pos   21U
#define DWT_CTRL_FOLDEVTENA_Msk   (0x1UL << DWT_CTRL_FOLDEVTENA_Pos)
#define DWT_CTRL_LSUEVTENA_Pos   20U
#define DWT_CTRL_LSUEVTENA_Msk   (0x1UL << DWT_CTRL_LSUEVTENA_Pos)
#define DWT_CTRL_SLEEPEVTENA_Pos   19U
#define DWT_CTRL_SLEEPEVTENA_Msk   (0x1UL << DWT_CTRL_SLEEPEVTENA_Pos)
#define DWT_CTRL_EXCEVTENA_Pos   18U
#define DWT_CTRL_EXCEVTENA_Msk   (0x1UL << DWT_CTRL_EXCEVTENA_Pos)
#define DWT_CTRL_CPIEVTENA_Pos   17U
#define DWT_CTRL_CPIEVTENA_Msk   (0x1UL << DWT_CTRL_CPIEVTENA_Pos)
#define DWT_CTRL_EXCTRCENA_Pos   16U
#define DWT_CTRL_EXCTRCENA_Msk   (0x1UL << DWT_CTRL_EXCTRCENA_Pos)
#define DWT_CTRL_PCSAMPLENA_Pos   12U
#define DWT_CTRL_PCSAMPLENA_Msk   (0x1UL << DWT_CTRL_PCSAMPLENA_Pos)
#define DWT_CTRL_SYNCTAP_Pos   10U
#define DWT_CTRL_SYNCTAP_Msk   (0x3UL << DWT_CTRL_SYNCTAP_Pos)
#define DWT_CTRL_CYCTAP_Pos   9U
#define DWT_CTRL_CYCTAP_Msk   (0x1UL << DWT_CTRL_CYCTAP_Pos)
#define DWT_CTRL_POSTINIT_Pos   5U
#define DWT_CTRL_POSTINIT_Msk   (0xFUL << DWT_CTRL_POSTINIT_Pos)
#define DWT_CTRL_POSTPRESET_Pos   1U
#define DWT_CTRL_POSTPRESET_Msk   (0xFUL << DWT_CTRL_POSTPRESET_Pos)
#define DWT_CTRL_CYCCNTENA_Pos   0U
#define DWT_CTRL_CYCCNTENA_Msk   (0x1UL /*<< DWT_CTRL_CYCCNTENA_Pos*/)
#define DWT_CPICNT_CPICNT_Pos   0U
#define DWT_CPICNT_CPICNT_Msk   (0xFFUL /*<< DWT_CPICNT_CPICNT_Pos*/)
#define DWT_EXCCNT_EXCCNT_Pos   0U
#define DWT_EXCCNT_EXCCNT_Msk   (0xFFUL /*<< DWT_EXCCNT_EXCCNT_Pos*/)
#define DWT_SLEEPCNT_SLEEPCNT_Pos   0U
#define DWT_SLEEPCNT_SLEEPCNT_Msk   (0xFFUL /*<< DWT_SLEEPCNT_SLEEPCNT_Pos*/)
#define DWT_LSUCNT_LSUCNT_Pos   0U
#define DWT_LSUCNT_LSUCNT_Msk   (0xFFUL /*<< DWT_LSUCNT_LSUCNT_Pos*/)
#define DWT_FOLDCNT_FOLDCNT_Pos   0U
#define DWT_FOLDCNT_FOLDCNT_Msk   (0xFFUL /*<< DWT_FOLDCNT_FOLDCNT_Pos*/)
#define DWT_MASK_MASK_Pos   0U
#define DWT_MASK_MASK_Msk   (0x1FUL /*<< DWT_MASK_MASK_Pos*/)
#define DWT_FUNCTION_MATCHED_Pos   24U
#define DWT_FUNCTION_MATCHED_Msk   (0x1UL << DWT_FUNCTION_MATCHED_Pos)
#define DWT_FUNCTION_DATAVADDR1_Pos   16U
#define DWT_FUNCTION_DATAVADDR1_Msk   (0xFUL << DWT_FUNCTION_DATAVADDR1_Pos)
#define DWT_FUNCTION_DATAVADDR0_Pos   12U
#define DWT_FUNCTION_DATAVADDR0_Msk   (0xFUL << DWT_FUNCTION_DATAVADDR0_Pos)
#define DWT_FUNCTION_DATAVSIZE_Pos   10U
#define DWT_FUNCTION_DATAVSIZE_Msk   (0x3UL << DWT_FUNCTION_DATAVSIZE_Pos)
#define DWT_FUNCTION_LNK1ENA_Pos   9U
#define DWT_FUNCTION_LNK1ENA_Msk   (0x1UL << DWT_FUNCTION_LNK1ENA_Pos)
#define DWT_FUNCTION_DATAVMATCH_Pos   8U
#define DWT_FUNCTION_DATAVMATCH_Msk   (0x1UL << DWT_FUNCTION_DATAVMATCH_Pos)
#define DWT_FUNCTION_CYCMATCH_Pos   7U
#define DWT_FUNCTION_CYCMATCH_Msk   (0x1UL << DWT_FUNCTION_CYCMATCH_Pos)
#define DWT_FUNCTION_EMITRANGE_Pos   5U
#define DWT_FUNCTION_EMITRANGE_Msk   (0x1UL << DWT_FUNCTION_EMITRANGE_Pos)
#define DWT_FUNCTION_FUNCTION_Pos   0U
#define DWT_FUNCTION_FUNCTION_Msk   (0xFUL /*<< DWT_FUNCTION_FUNCTION_Pos*/)
#define TPI_ACPR_PRESCALER_Pos   0U
#define TPI_ACPR_PRESCALER_Msk   (0x1FFFUL /*<< TPI_ACPR_PRESCALER_Pos*/)
#define TPI_SPPR_TXMODE_Pos   0U
#define TPI_SPPR_TXMODE_Msk   (0x3UL /*<< TPI_SPPR_TXMODE_Pos*/)
#define TPI_FFSR_FtNonStop_Pos   3U
#define TPI_FFSR_FtNonStop_Msk   (0x1UL << TPI_FFSR_FtNonStop_Pos)
#define TPI_FFSR_TCPresent_Pos   2U
#define TPI_FFSR_TCPresent_Msk   (0x1UL << TPI_FFSR_TCPresent_Pos)
#define TPI_FFSR_FtStopped_Pos   1U
#define TPI_FFSR_FtStopped_Msk   (0x1UL << TPI_FFSR_FtStopped_Pos)
#define TPI_FFSR_FlInProg_Pos   0U
#define TPI_FFSR_FlInProg_Msk   (0x1UL /*<< TPI_FFSR_FlInProg_Pos*/)
#define TPI_FFCR_TrigIn_Pos   8U
#define TPI_FFCR_TrigIn_Msk   (0x1UL << TPI_FFCR_TrigIn_Pos)
#define TPI_FFCR_EnFCont_Pos   1U
#define TPI_FFCR_EnFCont_Msk   (0x1UL << TPI_FFCR_EnFCont_Pos)
#define TPI_TRIGGER_TRIGGER_Pos   0U
#define TPI_TRIGGER_TRIGGER_Msk   (0x1UL /*<< TPI_TRIGGER_TRIGGER_Pos*/)
#define TPI_FIFO0_ITM_ATVALID_Pos   29U
#define TPI_FIFO0_ITM_ATVALID_Msk   (0x1UL << TPI_FIFO0_ITM_ATVALID_Pos)
#define TPI_FIFO0_ITM_bytecount_Pos   27U
#define TPI_FIFO0_ITM_bytecount_Msk   (0x3UL << TPI_FIFO0_ITM_bytecount_Pos)
#define TPI_FIFO0_ETM_ATVALID_Pos   26U
#define TPI_FIFO0_ETM_ATVALID_Msk   (0x1UL << TPI_FIFO0_ETM_ATVALID_Pos)
#define TPI_FIFO0_ETM_bytecount_Pos   24U
#define TPI_FIFO0_ETM_bytecount_Msk   (0x3UL << TPI_FIFO0_ETM_bytecount_Pos)
#define TPI_FIFO0_ETM2_Pos   16U
#define TPI_FIFO0_ETM2_Msk   (0xFFUL << TPI_FIFO0_ETM2_Pos)
#define TPI_FIFO0_ETM1_Pos   8U
#define TPI_FIFO0_ETM1_Msk   (0xFFUL << TPI_FIFO0_ETM1_Pos)
#define TPI_FIFO0_ETM0_Pos   0U
#define TPI_FIFO0_ETM0_Msk   (0xFFUL /*<< TPI_FIFO0_ETM0_Pos*/)
#define TPI_ITATBCTR2_ATREADY2_Pos   0U
#define TPI_ITATBCTR2_ATREADY2_Msk   (0x1UL /*<< TPI_ITATBCTR2_ATREADY2_Pos*/)
#define TPI_ITATBCTR2_ATREADY1_Pos   0U
#define TPI_ITATBCTR2_ATREADY1_Msk   (0x1UL /*<< TPI_ITATBCTR2_ATREADY1_Pos*/)
#define TPI_FIFO1_ITM_ATVALID_Pos   29U
#define TPI_FIFO1_ITM_ATVALID_Msk   (0x1UL << TPI_FIFO1_ITM_ATVALID_Pos)
#define TPI_FIFO1_ITM_bytecount_Pos   27U
#define TPI_FIFO1_ITM_bytecount_Msk   (0x3UL << TPI_FIFO1_ITM_bytecount_Pos)
#define TPI_FIFO1_ETM_ATVALID_Pos   26U
#define TPI_FIFO1_ETM_ATVALID_Msk   (0x1UL << TPI_FIFO1_ETM_ATVALID_Pos)
#define TPI_FIFO1_ETM_bytecount_Pos   24U
#define TPI_FIFO1_ETM_bytecount_Msk   (0x3UL << TPI_FIFO1_ETM_bytecount_Pos)
#define TPI_FIFO1_ITM2_Pos   16U
#define TPI_FIFO1_ITM2_Msk   (0xFFUL << TPI_FIFO1_ITM2_Pos)
#define TPI_FIFO1_ITM1_Pos   8U
#define TPI_FIFO1_ITM1_Msk   (0xFFUL << TPI_FIFO1_ITM1_Pos)
#define TPI_FIFO1_ITM0_Pos   0U
#define TPI_FIFO1_ITM0_Msk   (0xFFUL /*<< TPI_FIFO1_ITM0_Pos*/)
#define TPI_ITATBCTR0_ATREADY2_Pos   0U
#define TPI_ITATBCTR0_ATREADY2_Msk   (0x1UL /*<< TPI_ITATBCTR0_ATREADY2_Pos*/)
#define TPI_ITATBCTR0_ATREADY1_Pos   0U
#define TPI_ITATBCTR0_ATREADY1_Msk   (0x1UL /*<< TPI_ITATBCTR0_ATREADY1_Pos*/)
#define TPI_ITCTRL_Mode_Pos   0U
#define TPI_ITCTRL_Mode_Msk   (0x3UL /*<< TPI_ITCTRL_Mode_Pos*/)
#define TPI_DEVID_NRZVALID_Pos   11U
#define TPI_DEVID_NRZVALID_Msk   (0x1UL << TPI_DEVID_NRZVALID_Pos)
#define TPI_DEVID_MANCVALID_Pos   10U
#define TPI_DEVID_MANCVALID_Msk   (0x1UL << TPI_DEVID_MANCVALID_Pos)
#define TPI_DEVID_PTINVALID_Pos   9U
#define TPI_DEVID_PTINVALID_Msk   (0x1UL << TPI_DEVID_PTINVALID_Pos)
#define TPI_DEVID_MinBufSz_Pos   6U
#define TPI_DEVID_MinBufSz_Msk   (0x7UL << TPI_DEVID_MinBufSz_Pos)
#define TPI_DEVID_AsynClkIn_Pos   5U
#define TPI_DEVID_AsynClkIn_Msk   (0x1UL << TPI_DEVID_AsynClkIn_Pos)
#define TPI_DEVID_NrTraceInput_Pos   0U
#define TPI_DEVID_NrTraceInput_Msk   (0x1FUL /*<< TPI_DEVID_NrTraceInput_Pos*/)
#define TPI_DEVTYPE_SubType_Pos   4U
#define TPI_DEVTYPE_SubType_Msk   (0xFUL /*<< TPI_DEVTYPE_SubType_Pos*/)
#define TPI_DEVTYPE_MajorType_Pos   0U
#define TPI_DEVTYPE_MajorType_Msk   (0xFUL << TPI_DEVTYPE_MajorType_Pos)
#define FPU_FPCCR_ASPEN_Pos   31U
#define FPU_FPCCR_ASPEN_Msk   (1UL << FPU_FPCCR_ASPEN_Pos)
#define FPU_FPCCR_LSPEN_Pos   30U
#define FPU_FPCCR_LSPEN_Msk   (1UL << FPU_FPCCR_LSPEN_Pos)
#define FPU_FPCCR_MONRDY_Pos   8U
#define FPU_FPCCR_MONRDY_Msk   (1UL << FPU_FPCCR_MONRDY_Pos)
#define FPU_FPCCR_BFRDY_Pos   6U
#define FPU_FPCCR_BFRDY_Msk   (1UL << FPU_FPCCR_BFRDY_Pos)
#define FPU_FPCCR_MMRDY_Pos   5U
#define FPU_FPCCR_MMRDY_Msk   (1UL << FPU_FPCCR_MMRDY_Pos)
#define FPU_FPCCR_HFRDY_Pos   4U
#define FPU_FPCCR_HFRDY_Msk   (1UL << FPU_FPCCR_HFRDY_Pos)
#define FPU_FPCCR_THREAD_Pos   3U
#define FPU_FPCCR_THREAD_Msk   (1UL << FPU_FPCCR_THREAD_Pos)
#define FPU_FPCCR_USER_Pos   1U
#define FPU_FPCCR_USER_Msk   (1UL << FPU_FPCCR_USER_Pos)
#define FPU_FPCCR_LSPACT_Pos   0U
#define FPU_FPCCR_LSPACT_Msk   (1UL /*<< FPU_FPCCR_LSPACT_Pos*/)
#define FPU_FPCAR_ADDRESS_Pos   3U
#define FPU_FPCAR_ADDRESS_Msk   (0x1FFFFFFFUL << FPU_FPCAR_ADDRESS_Pos)
#define FPU_FPDSCR_AHP_Pos   26U
#define FPU_FPDSCR_AHP_Msk   (1UL << FPU_FPDSCR_AHP_Pos)
#define FPU_FPDSCR_DN_Pos   25U
#define FPU_FPDSCR_DN_Msk   (1UL << FPU_FPDSCR_DN_Pos)
#define FPU_FPDSCR_FZ_Pos   24U
#define FPU_FPDSCR_FZ_Msk   (1UL << FPU_FPDSCR_FZ_Pos)
#define FPU_FPDSCR_RMode_Pos   22U
#define FPU_FPDSCR_RMode_Msk   (3UL << FPU_FPDSCR_RMode_Pos)
#define FPU_MVFR0_FP_rounding_modes_Pos   28U
#define FPU_MVFR0_FP_rounding_modes_Msk   (0xFUL << FPU_MVFR0_FP_rounding_modes_Pos)
#define FPU_MVFR0_Short_vectors_Pos   24U
#define FPU_MVFR0_Short_vectors_Msk   (0xFUL << FPU_MVFR0_Short_vectors_Pos)
#define FPU_MVFR0_Square_root_Pos   20U
#define FPU_MVFR0_Square_root_Msk   (0xFUL << FPU_MVFR0_Square_root_Pos)
#define FPU_MVFR0_Divide_Pos   16U
#define FPU_MVFR0_Divide_Msk   (0xFUL << FPU_MVFR0_Divide_Pos)
#define FPU_MVFR0_FP_excep_trapping_Pos   12U
#define FPU_MVFR0_FP_excep_trapping_Msk   (0xFUL << FPU_MVFR0_FP_excep_trapping_Pos)
#define FPU_MVFR0_Double_precision_Pos   8U
#define FPU_MVFR0_Double_precision_Msk   (0xFUL << FPU_MVFR0_Double_precision_Pos)
#define FPU_MVFR0_Single_precision_Pos   4U
#define FPU_MVFR0_Single_precision_Msk   (0xFUL << FPU_MVFR0_Single_precision_Pos)
#define FPU_MVFR0_A_SIMD_registers_Pos   0U
#define FPU_MVFR0_A_SIMD_registers_Msk   (0xFUL /*<< FPU_MVFR0_A_SIMD_registers_Pos*/)
#define FPU_MVFR1_FP_fused_MAC_Pos   28U
#define FPU_MVFR1_FP_fused_MAC_Msk   (0xFUL << FPU_MVFR1_FP_fused_MAC_Pos)
#define FPU_MVFR1_FP_HPFP_Pos   24U
#define FPU_MVFR1_FP_HPFP_Msk   (0xFUL << FPU_MVFR1_FP_HPFP_Pos)
#define FPU_MVFR1_D_NaN_mode_Pos   4U
#define FPU_MVFR1_D_NaN_mode_Msk   (0xFUL << FPU_MVFR1_D_NaN_mode_Pos)
#define FPU_MVFR1_FtZ_mode_Pos   0U
#define FPU_MVFR1_FtZ_mode_Msk   (0xFUL /*<< FPU_MVFR1_FtZ_mode_Pos*/)
#define FPU_MVFR2_VFP_Misc_Pos   4U
#define FPU_MVFR2_VFP_Misc_Msk   (0xFUL << FPU_MVFR2_VFP_Misc_Pos)
#define CoreDebug_DHCSR_DBGKEY_Pos   16U
#define CoreDebug_DHCSR_DBGKEY_Msk   (0xFFFFUL << CoreDebug_DHCSR_DBGKEY_Pos)
#define CoreDebug_DHCSR_S_RESET_ST_Pos   25U
#define CoreDebug_DHCSR_S_RESET_ST_Msk   (1UL << CoreDebug_DHCSR_S_RESET_ST_Pos)
#define CoreDebug_DHCSR_S_RETIRE_ST_Pos   24U
#define CoreDebug_DHCSR_S_RETIRE_ST_Msk   (1UL << CoreDebug_DHCSR_S_RETIRE_ST_Pos)
#define CoreDebug_DHCSR_S_LOCKUP_Pos   19U
#define CoreDebug_DHCSR_S_LOCKUP_Msk   (1UL << CoreDebug_DHCSR_S_LOCKUP_Pos)
#define CoreDebug_DHCSR_S_SLEEP_Pos   18U
#define CoreDebug_DHCSR_S_SLEEP_Msk   (1UL << CoreDebug_DHCSR_S_SLEEP_Pos)
#define CoreDebug_DHCSR_S_HALT_Pos   17U
#define CoreDebug_DHCSR_S_HALT_Msk   (1UL << CoreDebug_DHCSR_S_HALT_Pos)
#define CoreDebug_DHCSR_S_REGRDY_Pos   16U
#define CoreDebug_DHCSR_S_REGRDY_Msk   (1UL << CoreDebug_DHCSR_S_REGRDY_Pos)
#define CoreDebug_DHCSR_C_SNAPSTALL_Pos   5U
#define CoreDebug_DHCSR_C_SNAPSTALL_Msk   (1UL << CoreDebug_DHCSR_C_SNAPSTALL_Pos)
#define CoreDebug_DHCSR_C_MASKINTS_Pos   3U
#define CoreDebug_DHCSR_C_MASKINTS_Msk   (1UL << CoreDebug_DHCSR_C_MASKINTS_Pos)
#define CoreDebug_DHCSR_C_STEP_Pos   2U
#define CoreDebug_DHCSR_C_STEP_Msk   (1UL << CoreDebug_DHCSR_C_STEP_Pos)
#define CoreDebug_DHCSR_C_HALT_Pos   1U
#define CoreDebug_DHCSR_C_HALT_Msk   (1UL << CoreDebug_DHCSR_C_HALT_Pos)
#define CoreDebug_DHCSR_C_DEBUGEN_Pos   0U
#define CoreDebug_DHCSR_C_DEBUGEN_Msk   (1UL /*<< CoreDebug_DHCSR_C_DEBUGEN_Pos*/)
#define CoreDebug_DCRSR_REGWnR_Pos   16U
#define CoreDebug_DCRSR_REGWnR_Msk   (1UL << CoreDebug_DCRSR_REGWnR_Pos)
#define CoreDebug_DCRSR_REGSEL_Pos   0U
#define CoreDebug_DCRSR_REGSEL_Msk   (0x1FUL /*<< CoreDebug_DCRSR_REGSEL_Pos*/)
#define CoreDebug_DEMCR_TRCENA_Pos   24U
#define CoreDebug_DEMCR_TRCENA_Msk   (1UL << CoreDebug_DEMCR_TRCENA_Pos)
#define CoreDebug_DEMCR_MON_REQ_Pos   19U
#define CoreDebug_DEMCR_MON_REQ_Msk   (1UL << CoreDebug_DEMCR_MON_REQ_Pos)
#define CoreDebug_DEMCR_MON_STEP_Pos   18U
#define CoreDebug_DEMCR_MON_STEP_Msk   (1UL << CoreDebug_DEMCR_MON_STEP_Pos)
#define CoreDebug_DEMCR_MON_PEND_Pos   17U
#define CoreDebug_DEMCR_MON_PEND_Msk   (1UL << CoreDebug_DEMCR_MON_PEND_Pos)
#define CoreDebug_DEMCR_MON_EN_Pos   16U
#define CoreDebug_DEMCR_MON_EN_Msk   (1UL << CoreDebug_DEMCR_MON_EN_Pos)
#define CoreDebug_DEMCR_VC_HARDERR_Pos   10U
#define CoreDebug_DEMCR_VC_HARDERR_Msk   (1UL << CoreDebug_DEMCR_VC_HARDERR_Pos)
#define CoreDebug_DEMCR_VC_INTERR_Pos   9U
#define CoreDebug_DEMCR_VC_INTERR_Msk   (1UL << CoreDebug_DEMCR_VC_INTERR_Pos)
#define CoreDebug_DEMCR_VC_BUSERR_Pos   8U
#define CoreDebug_DEMCR_VC_BUSERR_Msk   (1UL << CoreDebug_DEMCR_VC_BUSERR_Pos)
#define CoreDebug_DEMCR_VC_STATERR_Pos   7U
#define CoreDebug_DEMCR_VC_STATERR_Msk   (1UL << CoreDebug_DEMCR_VC_STATERR_Pos)
#define CoreDebug_DEMCR_VC_CHKERR_Pos   6U
#define CoreDebug_DEMCR_VC_CHKERR_Msk   (1UL << CoreDebug_DEMCR_VC_CHKERR_Pos)
#define CoreDebug_DEMCR_VC_NOCPERR_Pos   5U
#define CoreDebug_DEMCR_VC_NOCPERR_Msk   (1UL << CoreDebug_DEMCR_VC_NOCPERR_Pos)
#define CoreDebug_DEMCR_VC_MMERR_Pos   4U
#define CoreDebug_DEMCR_VC_MMERR_Msk   (1UL << CoreDebug_DEMCR_VC_MMERR_Pos)
#define CoreDebug_DEMCR_VC_CORERESET_Pos   0U
#define CoreDebug_DEMCR_VC_CORERESET_Msk   (1UL /*<< CoreDebug_DEMCR_VC_CORERESET_Pos*/)
#define _VAL2FLD(field, value)   (((uint32_t)(value) << field ## _Pos) & field ## _Msk)
 Mask and shift a bit field value for use in a register bit range.
#define _FLD2VAL(field, value)   (((uint32_t)(value) & field ## _Msk) >> field ## _Pos)
 Mask and shift a register value to extract a bit filed value.
#define SCS_BASE   (0xE000E000UL)
#define ITM_BASE   (0xE0000000UL)
#define DWT_BASE   (0xE0001000UL)
#define TPI_BASE   (0xE0040000UL)
#define CoreDebug_BASE   (0xE000EDF0UL)
#define SysTick_BASE   (SCS_BASE + 0x0010UL)
#define NVIC_BASE   (SCS_BASE + 0x0100UL)
#define SCB_BASE   (SCS_BASE + 0x0D00UL)
#define SCnSCB   ((SCnSCB_Type *) SCS_BASE )
#define SCB   ((SCB_Type *) SCB_BASE )
#define SysTick   ((SysTick_Type *) SysTick_BASE )
#define NVIC   ((NVIC_Type *) NVIC_BASE )
#define ITM   ((ITM_Type *) ITM_BASE )
#define DWT   ((DWT_Type *) DWT_BASE )
#define TPI   ((TPI_Type *) TPI_BASE )
#define CoreDebug   ((CoreDebug_Type *) CoreDebug_BASE)
#define FPU_BASE   (SCS_BASE + 0x0F30UL)
#define FPU   ((FPU_Type *) FPU_BASE )
#define ITM_TCR_TraceBusID_Pos   (ITM_TCR_TRACEBUSID_Pos)
#define ITM_TCR_TraceBusID_Msk   (ITM_TCR_TRACEBUSID_Msk)
#define ITM_TCR_TSPrescale_Pos   (ITM_TCR_TSPRESCALE_Pos)
#define ITM_TCR_TSPrescale_Msk   (ITM_TCR_TSPRESCALE_Msk)
#define ITM_LSR_ByteAcc_Pos   (ITM_LSR_BYTEACC_Pos)
#define ITM_LSR_ByteAcc_Msk   (ITM_LSR_BYTEACC_Msk)
#define ITM_LSR_Access_Pos   (ITM_LSR_ACCESS_Pos)
#define ITM_LSR_Access_Msk   (ITM_LSR_ACCESS_Msk)
#define ITM_LSR_Present_Pos   (ITM_LSR_PRESENT_Pos)
#define ITM_LSR_Present_Msk   (ITM_LSR_PRESENT_Msk)
#define NVIC_SetPriorityGrouping   __NVIC_SetPriorityGrouping
#define NVIC_GetPriorityGrouping   __NVIC_GetPriorityGrouping
#define NVIC_EnableIRQ   __NVIC_EnableIRQ
#define NVIC_GetEnableIRQ   __NVIC_GetEnableIRQ
#define NVIC_DisableIRQ   __NVIC_DisableIRQ
#define NVIC_GetPendingIRQ   __NVIC_GetPendingIRQ
#define NVIC_SetPendingIRQ   __NVIC_SetPendingIRQ
#define NVIC_ClearPendingIRQ   __NVIC_ClearPendingIRQ
#define NVIC_GetActive   __NVIC_GetActive
#define NVIC_SetPriority   __NVIC_SetPriority
#define NVIC_GetPriority   __NVIC_GetPriority
#define NVIC_SystemReset   __NVIC_SystemReset
#define NVIC_SetVector   __NVIC_SetVector
#define NVIC_GetVector   __NVIC_GetVector
#define NVIC_USER_IRQ_OFFSET   16
#define EXC_RETURN_HANDLER   (0xFFFFFFF1UL) /* return to Handler mode, uses MSP after return */
#define EXC_RETURN_THREAD_MSP   (0xFFFFFFF9UL) /* return to Thread mode, uses MSP after return */
#define EXC_RETURN_THREAD_PSP   (0xFFFFFFFDUL) /* return to Thread mode, uses PSP after return */
#define EXC_RETURN_HANDLER_FPU   (0xFFFFFFE1UL) /* return to Handler mode, uses MSP after return, restore floating-point state */
#define EXC_RETURN_THREAD_MSP_FPU   (0xFFFFFFE9UL) /* return to Thread mode, uses MSP after return, restore floating-point state */
#define EXC_RETURN_THREAD_PSP_FPU   (0xFFFFFFEDUL) /* return to Thread mode, uses PSP after return, restore floating-point state */
#define ITM_RXBUFFER_EMPTY   ((int32_t)0x5AA55AA5U)
volatile int32_t ITM_RxBuffer
This header file provides CMSIS interfaces.
Version
V5.2.0
Date
04. April 2023
◆ __CM7_CMSIS_VERSION
Value:
Definition: core_cm7.h:66
Definition: core_cm7.h:67
Deprecated:
CMSIS HAL version number
◆ __CM7_CMSIS_VERSION_MAIN
Deprecated:
[31:16] CMSIS HAL main version
◆ __CM7_CMSIS_VERSION_SUB
Deprecated:
[15:0] CMSIS HAL sub version
◆ __CORE_CM7_H_DEPENDANT
__FPU_USED indicates whether an FPU is used or not. For this, __FPU_PRESENT has to be checked prior to making use of FPU specific registers and functions.
◆ __CORTEX_M
Cortex-M Core
◆ __I
Defines 'read only' permissions
◆ __IO
Defines 'read / write' permissions
◆ __O
Defines 'write only' permissions
