RTEMS 6.1
Functions that manage interrupts and exceptions via the NVIC. More...
 FPU Functions
 Function that provides FPU type.
__STATIC_INLINE void __NVIC_SetPriorityGrouping (uint32_t PriorityGroup)
 Set Priority Grouping.
__STATIC_INLINE uint32_t __NVIC_GetPriorityGrouping (void)
 Get Priority Grouping.
__STATIC_INLINE void __NVIC_EnableIRQ (IRQn_Type IRQn)
 Enable Interrupt.
__STATIC_INLINE uint32_t __NVIC_GetEnableIRQ (IRQn_Type IRQn)
 Get Interrupt Enable status.
__STATIC_INLINE void __NVIC_DisableIRQ (IRQn_Type IRQn)
 Disable Interrupt.
__STATIC_INLINE uint32_t __NVIC_GetPendingIRQ (IRQn_Type IRQn)
 Get Pending Interrupt.
__STATIC_INLINE void __NVIC_SetPendingIRQ (IRQn_Type IRQn)
 Set Pending Interrupt.
__STATIC_INLINE void __NVIC_ClearPendingIRQ (IRQn_Type IRQn)
 Clear Pending Interrupt.
__STATIC_INLINE uint32_t __NVIC_GetActive (IRQn_Type IRQn)
 Get Active Interrupt.
__STATIC_INLINE void __NVIC_SetPriority (IRQn_Type IRQn, uint32_t priority)
 Set Interrupt Priority.
__STATIC_INLINE uint32_t __NVIC_GetPriority (IRQn_Type IRQn)
 Get Interrupt Priority.
__STATIC_INLINE uint32_t NVIC_EncodePriority (uint32_t PriorityGroup, uint32_t PreemptPriority, uint32_t SubPriority)
 Encode Priority.
__STATIC_INLINE void NVIC_DecodePriority (uint32_t Priority, uint32_t PriorityGroup, uint32_t *const pPreemptPriority, uint32_t *const pSubPriority)
 Decode Priority.
__STATIC_INLINE void __NVIC_SetVector (IRQn_Type IRQn, uint32_t vector)
 Set Interrupt Vector.
__STATIC_INLINE uint32_t __NVIC_GetVector (IRQn_Type IRQn)
 Get Interrupt Vector.
__NO_RETURN __STATIC_INLINE void __NVIC_SystemReset (void)
 System Reset.
__STATIC_INLINE uint32_t SCB_GetFPUType (void)
 get FPU type
__STATIC_INLINE uint32_t ITM_SendChar (uint32_t ch)
 ITM Send Character.
__STATIC_INLINE int32_t ITM_ReceiveChar (void)
 ITM Receive Character.
__STATIC_INLINE int32_t ITM_CheckChar (void)
 ITM Check Character.
#define NVIC_SetPriorityGrouping   __NVIC_SetPriorityGrouping
#define NVIC_GetPriorityGrouping   __NVIC_GetPriorityGrouping
#define NVIC_EnableIRQ   __NVIC_EnableIRQ
#define NVIC_GetEnableIRQ   __NVIC_GetEnableIRQ
#define NVIC_DisableIRQ   __NVIC_DisableIRQ
#define NVIC_GetPendingIRQ   __NVIC_GetPendingIRQ
#define NVIC_SetPendingIRQ   __NVIC_SetPendingIRQ
#define NVIC_ClearPendingIRQ   __NVIC_ClearPendingIRQ
#define NVIC_GetActive   __NVIC_GetActive
#define NVIC_SetPriority   __NVIC_SetPriority
#define NVIC_GetPriority   __NVIC_GetPriority
#define NVIC_SystemReset   __NVIC_SystemReset
#define NVIC_SetVector   __NVIC_SetVector
#define NVIC_GetVector   __NVIC_GetVector
#define NVIC_USER_IRQ_OFFSET   16
#define EXC_RETURN_HANDLER   (0xFFFFFFF1UL) /* return to Handler mode, uses MSP after return */
#define EXC_RETURN_THREAD_MSP   (0xFFFFFFF9UL) /* return to Thread mode, uses MSP after return */
#define EXC_RETURN_THREAD_PSP   (0xFFFFFFFDUL) /* return to Thread mode, uses PSP after return */
#define EXC_RETURN_HANDLER_FPU   (0xFFFFFFE1UL) /* return to Handler mode, uses MSP after return, restore floating-point state */
#define EXC_RETURN_THREAD_MSP_FPU   (0xFFFFFFE9UL) /* return to Thread mode, uses MSP after return, restore floating-point state */
#define EXC_RETURN_THREAD_PSP_FPU   (0xFFFFFFEDUL) /* return to Thread mode, uses PSP after return, restore floating-point state */
◆ __NVIC_ClearPendingIRQ()
__STATIC_INLINE void __NVIC_ClearPendingIRQ ( IRQn_Type  IRQn)
Clears the pending bit of a device specific interrupt in the NVIC pending register.
Parameters
[in]IRQnDevice specific interrupt number.
Note
IRQn must not be negative.
◆ __NVIC_DisableIRQ()
__STATIC_INLINE void __NVIC_DisableIRQ ( IRQn_Type  IRQn)
Disable Interrupt.
Disables a device specific interrupt in the NVIC interrupt controller.
Parameters
Note
◆ __NVIC_EnableIRQ()
__STATIC_INLINE void __NVIC_EnableIRQ ( IRQn_Type  IRQn)
Enable Interrupt.
Enables a device specific interrupt in the NVIC interrupt controller.
Parameters
Note
◆ __NVIC_GetActive()
__STATIC_INLINE uint32_t __NVIC_GetActive ( IRQn_Type  IRQn)
Reads the active register in the NVIC and returns the active bit for the device specific interrupt.
Parameters
Returns
0 Interrupt status is not active.
1 Interrupt status is active.
Note
◆ __NVIC_GetEnableIRQ()
__STATIC_INLINE uint32_t __NVIC_GetEnableIRQ ( IRQn_Type  IRQn)
Returns a device specific interrupt enable status from the NVIC interrupt controller.
Parameters
Returns
0 Interrupt is not enabled.
1 Interrupt is enabled.
Note
◆ __NVIC_GetPendingIRQ()
__STATIC_INLINE uint32_t __NVIC_GetPendingIRQ ( IRQn_Type  IRQn)
Reads the NVIC pending register and returns the pending bit for the specified device specific interrupt.
Parameters
Returns
0 Interrupt status is not pending.
1 Interrupt status is pending.
Note
◆ __NVIC_GetPriority()
__STATIC_INLINE uint32_t __NVIC_GetPriority ( IRQn_Type  IRQn)
Reads the priority of a device specific interrupt or a processor exception. The interrupt number can be positive to specify a device specific interrupt, or negative to specify a processor exception.
Parameters
[in]IRQnInterrupt number.
Returns
Interrupt Priority. Value is aligned automatically to the implemented priority bits of the microcontroller.
◆ __NVIC_GetPriorityGrouping()
__STATIC_INLINE uint32_t __NVIC_GetPriorityGrouping ( void  )
Reads the priority grouping field from the NVIC Interrupt Controller.
Returns
Priority grouping field (SCB->AIRCR [10:8] PRIGROUP field).
◆ __NVIC_GetVector()
__STATIC_INLINE uint32_t __NVIC_GetVector ( IRQn_Type  IRQn)
Reads an interrupt vector from interrupt vector table. The interrupt number can be positive to specify a device specific interrupt, or negative to specify a processor exception.
Parameters
Returns
Address of interrupt handler function
◆ __NVIC_SetPendingIRQ()
__STATIC_INLINE void __NVIC_SetPendingIRQ ( IRQn_Type  IRQn)
Sets the pending bit of a device specific interrupt in the NVIC pending register.
Parameters
Note
◆ __NVIC_SetPriority()
__STATIC_INLINE void __NVIC_SetPriority ( IRQn_Type  IRQn,
uint32_t  priority
Sets the priority of a device specific interrupt or a processor exception. The interrupt number can be positive to specify a device specific interrupt, or negative to specify a processor exception.
Parameters
[in]priorityPriority to set.
Note
The priority cannot be set for every processor exception.
◆ __NVIC_SetPriorityGrouping()
__STATIC_INLINE void __NVIC_SetPriorityGrouping ( uint32_t  PriorityGroup)
Sets the priority grouping field using the required unlock sequence. The parameter PriorityGroup is assigned to the field SCB->AIRCR [10:8] PRIGROUP field. Only values from 0..7 are used. In case of a conflict between priority grouping and available priority bits (__NVIC_PRIO_BITS), the smallest possible priority group is set.
Parameters
[in]PriorityGroupPriority grouping field.
◆ __NVIC_SetVector()
__STATIC_INLINE void __NVIC_SetVector ( IRQn_Type  IRQn,
uint32_t  vector
Sets an interrupt vector in SRAM based interrupt vector table. The interrupt number can be positive to specify a device specific interrupt, or negative to specify a processor exception. VTOR must been relocated to SRAM before.
Parameters
[in]vectorAddress of interrupt handler function
◆ __NVIC_SystemReset()
__NO_RETURN __STATIC_INLINE void __NVIC_SystemReset ( void  )
System Reset.
Initiates a system reset request to reset the MCU.
◆ ITM_CheckChar()
__STATIC_INLINE int32_t ITM_CheckChar ( void  )
Checks whether a character is pending for reading in the variable ITM_RxBuffer.
Returns
0 No character available.
1 Character available.
◆ ITM_ReceiveChar()
__STATIC_INLINE int32_t ITM_ReceiveChar ( void  )
Inputs a character via the external variable ITM_RxBuffer.
Returns
Received character.
-1 No character pending.
◆ ITM_SendChar()
__STATIC_INLINE uint32_t ITM_SendChar ( uint32_t  ch)
ITM Send Character.
Transmits a character via the ITM channel 0, and
  • Just returns when no debugger is connected that has booked the output.
  • Is blocking when a debugger is connected, but the previous character sent has not been transmitted.
    Parameters
    [in]chCharacter to transmit.
    Returns
◆ NVIC_DecodePriority()
__STATIC_INLINE void NVIC_DecodePriority ( uint32_t  Priority,
Decode Priority.
Decodes an interrupt priority value with a given priority group to preemptive priority value and subpriority value. In case of a conflict between priority grouping and available priority bits (__NVIC_PRIO_BITS) the smallest possible priority group is set.
Parameters
[in]PriorityPriority value, which can be retrieved with the function NVIC_GetPriority().
[in]PriorityGroupUsed priority group.
[out]pPreemptPriorityPreemptive priority value (starting from 0).
[out]pSubPrioritySubpriority value (starting from 0).
◆ NVIC_EncodePriority()
__STATIC_INLINE uint32_t NVIC_EncodePriority ( uint32_t  PriorityGroup,
Encode Priority.
Encodes the priority for an interrupt with the given priority group, preemptive priority value, and subpriority value. In case of a conflict between priority grouping and available priority bits (__NVIC_PRIO_BITS), the smallest possible priority group is set.
Parameters
[in]PreemptPriorityPreemptive priority value (starting from 0).
[in]SubPrioritySubpriority value (starting from 0).
Returns
Encoded priority. Value can be used in the function NVIC_SetPriority().
◆ SCB_GetFPUType()
__STATIC_INLINE uint32_t SCB_GetFPUType ( void  )
get FPU type
returns the FPU type
Returns
  • 0: No FPU
  • 1: Single precision FPU
  • 2: Double + Single precision FPU
