RTEMS 6.1
capture_buffer.h File Reference
Capture buffer. More...
struct  rtems_capture_buffer
typedef struct rtems_capture_buffer rtems_capture_buffer
void * rtems_capture_buffer_allocate (rtems_capture_buffer *buffer, size_t size)
void * rtems_capture_buffer_free (rtems_capture_buffer *buffer, size_t size)
Capture buffer.
This is a set of functions to control a variable length capture record buffer.
Typedef Documentation
◆ rtems_capture_buffer
Capture buffer. There is one per CPU.
