RTEMS 6.1
rtems_capture_buffer Struct Reference
#include <capture_buffer.h>
uint8_t * buffer
size_t size
size_t count
size_t head
size_t tail
size_t end
size_t max_rec
Capture buffer. There is one per CPU.
Field Documentation
◆ buffer
uint8_t* rtems_capture_buffer::buffer
The per cpu buffer.
◆ count
size_t rtems_capture_buffer::count
The number of used bytes in the buffer.
◆ end
size_t rtems_capture_buffer::end
Buffer current end, it may move in.
◆ head
size_t rtems_capture_buffer::head
First record.
◆ max_rec
size_t rtems_capture_buffer::max_rec
The largest record in the buffer.
◆ size
size_t rtems_capture_buffer::size
The size of the buffer in bytes.
◆ tail
size_t rtems_capture_buffer::tail
Head == Tail for empty.
