#define | RTEMS_CAPTURE_RECORD_EVENTS (0) |
#define | capture_per_cpu_get(_cpu) ( &capture_per_cpu[ _cpu ] ) |
#define | capture_records_on_cpu(_cpu) capture_per_cpu[ _cpu ].records |
#define | capture_count_on_cpu(_cpu) capture_per_cpu[ _cpu ].count |
#define | capture_flags_on_cpu(_cpu) capture_per_cpu[ _cpu ].flags |
#define | capture_reader_on_cpu(_cpu) capture_per_cpu[ _cpu ].reader |
#define | capture_lock_on_cpu(_cpu) capture_per_cpu[ _cpu ].lock |
#define | capture_flags_global capture_global.flags |
#define | capture_controls capture_global.controls |
#define | capture_extension_index capture_global.extension_index |
#define | capture_timestamp capture_global.timestamp |
#define | capture_ceiling capture_global.ceiling |
#define | capture_floor capture_global.floor |
#define | capture_lock_global capture_global.lock |
| void | rtems_capture_set_extension_index (int index) |
| | Capture set extension index.
| int | rtems_capture_get_extension_index (void) |
| | Capture get extension index.
| uint32_t | rtems_capture_get_flags (void) |
| | Capture get flags.
| void | rtems_capture_set_flags (uint32_t mask) |
| | Capture set flags.
| void | rtems_capture_get_time (rtems_capture_time *time) |
| | Capture returns the current time.
| void | rtems_capture_record_lock (rtems_capture_record_lock_context *context) |
| | Capture record lock.
| void | rtems_capture_record_unlock (rtems_capture_record_lock_context *context) |
| | Capture record unlock.
| void * | rtems_capture_record_open (rtems_tcb *tcb, uint32_t events, size_t size, rtems_capture_record_lock_context *context) |
| | Capture record open.
| void | rtems_capture_record_close (rtems_capture_record_lock_context *context) |
| | Capture record close.
| void | rtems_capture_initialize_task (rtems_tcb *tcb) |
| | Capture initialize task.
| void | rtems_capture_record_task (rtems_tcb *tcb) |
| | Capture record task.
| bool | rtems_capture_filter (rtems_tcb *tcb, uint32_t events) |
| | Capture filter.
| bool | rtems_capture_trigger_fired (rtems_tcb *ft, rtems_tcb *tt, uint32_t events) |
| | Capture check trigger.
| rtems_status_code | rtems_capture_open (uint32_t size, rtems_capture_timestamp timestamp RTEMS_UNUSED) |
| | Capture open.
| rtems_status_code | rtems_capture_close (void) |
| | Capture close.
| rtems_status_code | rtems_capture_set_control (bool enable) |
| | Capture control trace enable/disable.
| rtems_status_code | rtems_capture_set_monitor (bool enable) |
| | Capture monitor enable/disable.
rtems_status_code | rtems_capture_flush (bool prime) |
| rtems_status_code | rtems_capture_watch_add (rtems_name name, rtems_id id) |
| | Capture add watch.
| rtems_status_code | rtems_capture_watch_del (rtems_name name, rtems_id id) |
| | Capture delete watch.
| rtems_status_code | rtems_capture_watch_ctrl (rtems_name name, rtems_id id, bool enable) |
| | Capture enable/disable watch.
| rtems_status_code | rtems_capture_watch_global (bool enable) |
| | Capture enable/disable global watch.
| bool | rtems_capture_watch_global_on (void) |
| | Get global watch state.
| rtems_status_code | rtems_capture_watch_ceiling (rtems_task_priority ceiling) |
| | Set watch ceiling.
| rtems_task_priority | rtems_capture_watch_get_ceiling (void) |
| | Get watch ceiling.
| rtems_status_code | rtems_capture_watch_floor (rtems_task_priority floor) |
| | Capture set watch floor.
| rtems_task_priority | rtems_capture_watch_get_floor (void) |
| rtems_status_code | rtems_capture_set_trigger (rtems_name from_name, rtems_id from_id, rtems_name to_name, rtems_id to_id, rtems_capture_trigger_mode mode, rtems_capture_trigger trigger) |
| | Capture set trigger.
| rtems_status_code | rtems_capture_clear_trigger (rtems_name from_name, rtems_id from_id, rtems_name to_name, rtems_id to_id, rtems_capture_trigger_mode mode, rtems_capture_trigger trigger) |
| | Capture clear trigger.
| rtems_status_code | rtems_capture_read (uint32_t cpu, size_t *read, const void **recs) |
| | Capture read records from capture buffer.
| rtems_status_code | rtems_capture_release (uint32_t cpu, uint32_t count) |
| | Capture release records.
| const char * | rtems_capture_event_text (int event) |
| | Capture get event text.
| rtems_capture_control * | rtems_capture_get_control_list (void) |
| | Capture get control list.
RTEMS Performance Monitoring and Measurement Framework.
This is the Capture Engine component.
