RTEMS 6.1
watchdog.h File Reference
API of the Watchdog driver for the raspberrypi4 bsp in RTEMS. More...
void raspberrypi_watchdog_init (void)
 Initialize BSP watchdog routines.
void raspberrypi_watchdog_start (uint32_t timeout_ms)
 Turn on the watchdog / begin the counter at the desired value.
void raspberrypi_watchdog_stop (void)
 Turn off the watchdog.
void raspberrypi_watchdog_reload (void)
 Reload watchdog.
uint32_t raspberrypi_watchdog_get_remaining_time (void)
 Get the remaining time of the watchdog. The return value is still valid when the watchdog has been stopped.
◆ raspberrypi_watchdog_get_remaining_time()
uint32_t raspberrypi_watchdog_get_remaining_time ( void  )
Return values
Watchdogremaining time in ms.
◆ raspberrypi_watchdog_init()
void raspberrypi_watchdog_init ( void  )
Note
a brief example of expected usage.
void raspberrypi_watchdog_example() { raspberrypi_watchdog_init(); raspberrypi_watchdog_start(15000);
raspberrypi_watchdog_reload(); ... raspberrypi_watchdog_reload();
raspberrypi_watchdog_stop(); }
◆ raspberrypi_watchdog_start()
void raspberrypi_watchdog_start ( uint32_t  timeout_ms)
Parameters
timeoutWatchdog timeout value in ms. The watchdog device has 20 bits of timeout, so it only supports a maximum of 15999 ms for its timeout. This value should be between 0 and 15999.
