RTEMS 6.1
watchdog.h
2
11/*
12 * Copyright (C) 2024 Ning Yang
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_AARCH64_RASPBERRYPI_BSP_RPI_WATCHDOG_H
37#define LIBBSP_AARCH64_RASPBERRYPI_BSP_RPI_WATCHDOG_H
38
39#ifdef __cplusplus
40extern "C" {
41#endif
42
64
73void raspberrypi_watchdog_start(uint32_t timeout_ms);
74
79
84
92
93#ifdef __cplusplus
94}
95#endif
96
97#endif
void raspberrypi_watchdog_init(void)
Initialize BSP watchdog routines.
Definition: watchdog.c:44
void raspberrypi_watchdog_reload(void)
Reload watchdog.
Definition: watchdog.c:65
uint32_t raspberrypi_watchdog_get_remaining_time(void)
Get the remaining time of the watchdog. The return value is still valid when the watchdog has been st...
Definition: watchdog.c:70
void raspberrypi_watchdog_stop(void)
Turn off the watchdog.
Definition: watchdog.c:60
Turn on the watchdog / begin the counter at the desired value.
Definition: watchdog.c:49
