RTEMS 6.1
console-config.c File Reference
Console Configuration. More...
#include <rtems/bspIo.h>
#include <rtems/console.h>
#include <rtems/sysinit.h>
#include <libchip/serial.h>
#include <libfdt.h>
#include <libchip/ns16550.h>
#include <dev/serial/arm-pl011.h>
#include <bspopts.h>
#include <bsp/usart.h>
#include <bsp/raspberrypi.h>
#include <bsp/fbcons.h>
#include <bsp.h>
#include <bsp/console-termios.h>
#include <bsp/fdt.h>
#include <bsp/fatal.h>
#include <bsp/gpio.h>
#include <bsp/rpi-gpio.h>
#define PL011   "/dev/ttyAMA0"
#define MINIUART   "/dev/ttyS0"
#define FBCONS   "/dev/fbcons"
void output_char_fb (char c)
rtems_status_code console_initialize (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Console initialization entry point.
 RTEMS_SYSINIT_ITEM (uart_probe, RTEMS_SYSINIT_BSP_START, RTEMS_SYSINIT_ORDER_LAST_BUT_5)
arm_pl011_context pl011_context
ns16550_context mini_uart_context
rpi_fb_context fb_context
BSP_output_char_function_type BSP_output_char = output_char
 This function pointer references the kernel character output implementation.
BSP_polling_getchar_function_type BSP_poll_char = NULL
 This function pointer may reference the kernel character input implementation.
◆ PL011
UART0 - PL011 UART1 - Mini UART
◆ console_initialize()
rtems_status_code console_initialize ( rtems_device_major_number  major,
void *  arg
This method initializes the console device driver.
Parameters
[in]majoris the device driver major number.
[in]minoris the device driver minor number.
[in]argis the parameters to this call.
Return values
RTEMS_SUCCESSFULThe device driver is successfully initialized.
Variable Documentation
◆ pl011_context
Initial value:
.clock = 48000000
