APIC implementation.
More...
#include <acpi/acpi.h>
#include <apic.h>
#include <assert.h>
#include <bsp.h>
#include <pic.h>
#include <rtems/score/idt.h>
void | apic_spurious_handler (void) |
| bool | lapic_initialize (void) |
| | Initializes the Local APIC by hardware and software enabling it.
| uint32_t | lapic_timer_calc_ticks (uint64_t desired_freq_hz) |
| | Calculates the number of Local APIC timer ticks which can be used with lapic_timer_enable to set up a timer of given frequency.
| void | lapic_timer_enable (uint32_t reload_value) |
| | Enables the Local APIC timer.
volatile uint32_t * | amd64_lapic_base |
◆ lapic_initialize()
| bool lapic_initialize |
void |
Initializes the Local APIC by hardware and software enabling it, and sets up the amd64_lapic_base pointer that can be used as a 32-bit addressable array to access Local APIC registers.
- Returns
- true if successful.
◆ lapic_timer_calc_ticks()
| uint32_t lapic_timer_calc_ticks |
uint64_t |
desired_freq_hz | ) |
- Parameters
| desired_freq_hz | The frequency in Hz. |
- Returns
- The number of Local APIC timer ticks.
◆ lapic_timer_enable()
| void lapic_timer_enable |
uint32_t |
reload_value | ) |
- Parameters
| reload_value | Number of ticks per interrupt. |
