RTEMS
6.1
bsps
x86_64
amd64
include
pic.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
* Copyright (c) 2018 Amaan Cheval <amaan.cheval@gmail.com>
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
24
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
27
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
28
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
29
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
30
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
31
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
32
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
33
* SUCH DAMAGE.
34
35
36
#ifndef _AMD64_PIC_H
37
#define _AMD64_PIC_H
38
39
#ifdef __cplusplus
40
extern
"C"
41
#endif
42
43
#define PIC1 0x20
/* IO base address for master PIC */
44
#define PIC2 0xA0
/* IO base address for slave PIC */
45
#define PIC1_COMMAND PIC1
46
#define PIC1_DATA (PIC1+1)
47
#define PIC2_COMMAND PIC2
48
#define PIC2_DATA (PIC2+1)
49
50
/* reinitialize the PIC controllers, giving them specified vector offsets
51
rather than 8h and 70h, as configured by default */
52
53
#define PIC_ICW1_ICW4 0x01
/* ICW4 (not) needed */
54
#define PIC_ICW1_SINGLE 0x02
/* Single (cascade) mode */
55
#define PIC_ICW1_INTERVAL4 0x04
/* Call address interval 4 (8) */
56
#define PIC_ICW1_LEVEL 0x08
/* Level triggered (edge) mode */
57
#define PIC_ICW1_INIT 0x10
/* Initialization - required! */
58
59
#define PIC_ICW4_8086 0x01
/* 8086/88 (MCS-80/85) mode */
60
#define PIC_ICW4_AUTO 0x02
/* Auto (normal) EOI */
61
#define PIC_ICW4_BUF_SLAVE 0x08
/* Buffered mode/slave */
62
#define PIC_ICW4_BUF_MASTER 0x0C
/* Buffered mode/master */
63
#define PIC_ICW4_SFNM 0x10
/* Special fully nested (not) */
64
65
/* This remaps IRQ0 to vector number 0x20 and so on (i.e. IDT[32]) */
66
#define PIC1_REMAP_DEST 0x20
67
#define PIC2_REMAP_DEST 0x28
68
69
/* Remap PIC1's interrupts to offset1 and PIC2's to offset2 */
70
void
pic_remap(uint8_t offset1, uint8_t offset2);
71
78
void
pic_disable
void
79
80
#ifdef __cplusplus
81
82
#endif
83
84
#endif
/* _AMD64_PIC_H */
pic_disable
void pic_disable(void)
Definition:
pic.c:80
