RTEMS 6.1
ahbstat-regs.h
2
11/*
12 * Copyright (C) 2021 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36/*
37 * This file is part of the RTEMS quality process and was automatically
38 * generated. If you find something that needs to be fixed or
39 * worded better please post a report or patch to an RTEMS mailing list
40 * or raise a bug report:
41 *
42 * https://www.rtems.org/bugs.html
43 *
44 * For information on updating and regenerating please refer to the How-To
45 * section in the Software Requirements Engineering chapter of the
46 * RTEMS Software Engineering manual. The manual is provided as a part of
47 * a release. For development sources please refer to the online
48 * documentation at:
49 *
50 * https://docs.rtems.org
51 */
52
53/* Generated from spec:/dev/grlib/if/ahbstat-header */
54
55#ifndef _GRLIB_AHBSTAT_REGS_H
56#define _GRLIB_AHBSTAT_REGS_H
57
58#include <stdint.h>
59
60#ifdef __cplusplus
61extern "C" {
62#endif
63
64/* Generated from spec:/dev/grlib/if/ahbstat */
65
84#define AHBSTAT_AHBS_ME 0x2000U
85
86#define AHBSTAT_AHBS_FW 0x1000U
87
88#define AHBSTAT_AHBS_CF 0x800U
89
90#define AHBSTAT_AHBS_AF 0x400U
91
92#define AHBSTAT_AHBS_CE 0x200U
93
94#define AHBSTAT_AHBS_NE 0x100U
95
96#define AHBSTAT_AHBS_HWRITE 0x80U
97
98#define AHBSTAT_AHBS_HMASTER_SHIFT 3
99#define AHBSTAT_AHBS_HMASTER_MASK 0x78U
100#define AHBSTAT_AHBS_HMASTER_GET( _reg ) \
101 ( ( ( _reg ) & AHBSTAT_AHBS_HMASTER_MASK ) >> \
102 AHBSTAT_AHBS_HMASTER_SHIFT )
103#define AHBSTAT_AHBS_HMASTER_SET( _reg, _val ) \
104 ( ( ( _reg ) & ~AHBSTAT_AHBS_HMASTER_MASK ) | \
105 ( ( ( _val ) << AHBSTAT_AHBS_HMASTER_SHIFT ) & \
106 AHBSTAT_AHBS_HMASTER_MASK ) )
107#define AHBSTAT_AHBS_HMASTER( _val ) \
108 ( ( ( _val ) << AHBSTAT_AHBS_HMASTER_SHIFT ) & \
109 AHBSTAT_AHBS_HMASTER_MASK )
110
111#define AHBSTAT_AHBS_HSIZE_SHIFT 0
112#define AHBSTAT_AHBS_HSIZE_MASK 0x7U
113#define AHBSTAT_AHBS_HSIZE_GET( _reg ) \
114 ( ( ( _reg ) & AHBSTAT_AHBS_HSIZE_MASK ) >> \
115 AHBSTAT_AHBS_HSIZE_SHIFT )
116#define AHBSTAT_AHBS_HSIZE_SET( _reg, _val ) \
117 ( ( ( _reg ) & ~AHBSTAT_AHBS_HSIZE_MASK ) | \
118 ( ( ( _val ) << AHBSTAT_AHBS_HSIZE_SHIFT ) & \
119 AHBSTAT_AHBS_HSIZE_MASK ) )
120#define AHBSTAT_AHBS_HSIZE( _val ) \
121 ( ( ( _val ) << AHBSTAT_AHBS_HSIZE_SHIFT ) & \
122 AHBSTAT_AHBS_HSIZE_MASK )
123
135#define AHBSTAT_AHBFAR_HADDR_SHIFT 0
136#define AHBSTAT_AHBFAR_HADDR_MASK 0xffffffffU
137#define AHBSTAT_AHBFAR_HADDR_GET( _reg ) \
138 ( ( ( _reg ) & AHBSTAT_AHBFAR_HADDR_MASK ) >> \
139 AHBSTAT_AHBFAR_HADDR_SHIFT )
140#define AHBSTAT_AHBFAR_HADDR_SET( _reg, _val ) \
141 ( ( ( _reg ) & ~AHBSTAT_AHBFAR_HADDR_MASK ) | \
142 ( ( ( _val ) << AHBSTAT_AHBFAR_HADDR_SHIFT ) & \
143 AHBSTAT_AHBFAR_HADDR_MASK ) )
144#define AHBSTAT_AHBFAR_HADDR( _val ) \
145 ( ( ( _val ) << AHBSTAT_AHBFAR_HADDR_SHIFT ) & \
146 AHBSTAT_AHBFAR_HADDR_MASK )
147
153typedef struct ahbstat {
157 uint32_t ahbs;
158
162 uint32_t ahbfar;
164
167#ifdef __cplusplus
168}
169#endif
170
171#endif /* _GRLIB_AHBSTAT_REGS_H */
This structure defines the AHBSTAT register block memory map.
Definition: ahbstat-regs.h:153
uint32_t ahbfar
See AHB Failing address register (AHBFAR).
Definition: ahbstat-regs.h:162
uint32_t ahbs
See AHB Status register (AHBS).
Definition: ahbstat-regs.h:157
