RTEMS 6.1
This header file defines the AHBSTAT register block interface. More...
#include <stdint.h>Go to the source code of this file.
| struct | ahbstat |
| This structure defines the AHBSTAT register block memory map. More... | |
| #define | AHBSTAT_AHBS_ME 0x2000U |
| #define | AHBSTAT_AHBS_FW 0x1000U |
| #define | AHBSTAT_AHBS_CF 0x800U |
| #define | AHBSTAT_AHBS_AF 0x400U |
| #define | AHBSTAT_AHBS_CE 0x200U |
| #define | AHBSTAT_AHBS_NE 0x100U |
| #define | AHBSTAT_AHBS_HWRITE 0x80U |
| #define | AHBSTAT_AHBS_HMASTER_SHIFT 3 |
| #define | AHBSTAT_AHBS_HMASTER_MASK 0x78U |
| #define | AHBSTAT_AHBS_HMASTER_GET(_reg) |
| #define | AHBSTAT_AHBS_HMASTER_SET(_reg, _val) |
| #define | AHBSTAT_AHBS_HMASTER(_val) |
| #define | AHBSTAT_AHBS_HSIZE_SHIFT 0 |
| #define | AHBSTAT_AHBS_HSIZE_MASK 0x7U |
| #define | AHBSTAT_AHBS_HSIZE_GET(_reg) |
| #define | AHBSTAT_AHBS_HSIZE_SET(_reg, _val) |
| #define | AHBSTAT_AHBS_HSIZE(_val) |
| #define | AHBSTAT_AHBFAR_HADDR_SHIFT 0 |
| #define | AHBSTAT_AHBFAR_HADDR_MASK 0xffffffffU |
| #define | AHBSTAT_AHBFAR_HADDR_GET(_reg) |
| #define | AHBSTAT_AHBFAR_HADDR_SET(_reg, _val) |
| #define | AHBSTAT_AHBFAR_HADDR(_val) |
Typedefs | |
| typedef struct ahbstat | ahbstat |
| This structure defines the AHBSTAT register block memory map. | |
