RTEMS 6.1
Modules | Files | Data Structures | Typedefs
This group contains the AHBSTAT interfaces. More...
 AHB Failing address register (AHBFAR)
 This group contains register bit definitions.
 AHB Status register (AHBS)
file  ahbstat-regs.h
 This header file defines the AHBSTAT register block interface.
struct  ahbstat
 This structure defines the AHBSTAT register block memory map. More...
typedef struct ahbstat ahbstat
