RTEMS 6.1
acevents.h
1/******************************************************************************
2 *
3 * Name: acevents.h - Event subcomponent prototypes and defines
4 *
5 *****************************************************************************/
6
7/******************************************************************************
8 *
9 * 1. Copyright Notice
10 *
11 * Some or all of this work - Copyright (c) 1999 - 2024, Intel Corp.
12 * All rights reserved.
13 *
14 * 2. License
15 *
16 * 2.1. This is your license from Intel Corp. under its intellectual property
17 * rights. You may have additional license terms from the party that provided
18 * you this software, covering your right to use that party's intellectual
19 * property rights.
20 *
21 * 2.2. Intel grants, free of charge, to any person ("Licensee") obtaining a
22 * copy of the source code appearing in this file ("Covered Code") an
23 * irrevocable, perpetual, worldwide license under Intel's copyrights in the
24 * base code distributed originally by Intel ("Original Intel Code") to copy,
25 * make derivatives, distribute, use and display any portion of the Covered
26 * Code in any form, with the right to sublicense such rights; and
27 *
28 * 2.3. Intel grants Licensee a non-exclusive and non-transferable patent
29 * license (with the right to sublicense), under only those claims of Intel
30 * patents that are infringed by the Original Intel Code, to make, use, sell,
31 * offer to sell, and import the Covered Code and derivative works thereof
32 * solely to the minimum extent necessary to exercise the above copyright
33 * license, and in no event shall the patent license extend to any additions
34 * to or modifications of the Original Intel Code. No other license or right
35 * is granted directly or by implication, estoppel or otherwise;
36 *
37 * The above copyright and patent license is granted only if the following
38 * conditions are met:
39 *
40 * 3. Conditions
41 *
42 * 3.1. Redistribution of Source with Rights to Further Distribute Source.
43 * Redistribution of source code of any substantial portion of the Covered
44 * Code or modification with rights to further distribute source must include
45 * the above Copyright Notice, the above License, this list of Conditions,
46 * and the following Disclaimer and Export Compliance provision. In addition,
47 * Licensee must cause all Covered Code to which Licensee contributes to
48 * contain a file documenting the changes Licensee made to create that Covered
49 * Code and the date of any change. Licensee must include in that file the
50 * documentation of any changes made by any predecessor Licensee. Licensee
51 * must include a prominent statement that the modification is derived,
52 * directly or indirectly, from Original Intel Code.
53 *
54 * 3.2. Redistribution of Source with no Rights to Further Distribute Source.
55 * Redistribution of source code of any substantial portion of the Covered
56 * Code or modification without rights to further distribute source must
57 * include the following Disclaimer and Export Compliance provision in the
58 * documentation and/or other materials provided with distribution. In
59 * addition, Licensee may not authorize further sublicense of source of any
60 * portion of the Covered Code, and must include terms to the effect that the
61 * license from Licensee to its licensee is limited to the intellectual
62 * property embodied in the software Licensee provides to its licensee, and
63 * not to intellectual property embodied in modifications its licensee may
64 * make.
65 *
66 * 3.3. Redistribution of Executable. Redistribution in executable form of any
67 * substantial portion of the Covered Code or modification must reproduce the
68 * above Copyright Notice, and the following Disclaimer and Export Compliance
69 * provision in the documentation and/or other materials provided with the
70 * distribution.
71 *
72 * 3.4. Intel retains all right, title, and interest in and to the Original
73 * Intel Code.
74 *
75 * 3.5. Neither the name Intel nor any other trademark owned or controlled by
76 * Intel shall be used in advertising or otherwise to promote the sale, use or
77 * other dealings in products derived from or relating to the Covered Code
78 * without prior written authorization from Intel.
79 *
80 * 4. Disclaimer and Export Compliance
81 *
82 * 4.1. INTEL MAKES NO WARRANTY OF ANY KIND REGARDING ANY SOFTWARE PROVIDED
83 * HERE. ANY SOFTWARE ORIGINATING FROM INTEL OR DERIVED FROM INTEL SOFTWARE
84 * IS PROVIDED "AS IS," AND INTEL WILL NOT PROVIDE ANY SUPPORT, ASSISTANCE,
85 * INSTALLATION, TRAINING OR OTHER SERVICES. INTEL WILL NOT PROVIDE ANY
86 * UPDATES, ENHANCEMENTS OR EXTENSIONS. INTEL SPECIFICALLY DISCLAIMS ANY
87 * IMPLIED WARRANTIES OF MERCHANTABILITY, NONINFRINGEMENT AND FITNESS FOR A
88 * PARTICULAR PURPOSE.
89 *
90 * 4.2. IN NO EVENT SHALL INTEL HAVE ANY LIABILITY TO LICENSEE, ITS LICENSEES
91 * OR ANY OTHER THIRD PARTY, FOR ANY LOST PROFITS, LOST DATA, LOSS OF USE OR
92 * COSTS OF PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES, OR FOR ANY INDIRECT,
93 * SPECIAL OR CONSEQUENTIAL DAMAGES ARISING OUT OF THIS AGREEMENT, UNDER ANY
94 * CAUSE OF ACTION OR THEORY OF LIABILITY, AND IRRESPECTIVE OF WHETHER INTEL
95 * HAS ADVANCE NOTICE OF THE POSSIBILITY OF SUCH DAMAGES. THESE LIMITATIONS
96 * SHALL APPLY NOTWITHSTANDING THE FAILURE OF THE ESSENTIAL PURPOSE OF ANY
97 * LIMITED REMEDY.
98 *
99 * 4.3. Licensee shall not export, either directly or indirectly, any of this
100 * software or system incorporating such software without first obtaining any
101 * required license or other approval from the U. S. Department of Commerce or
102 * any other agency or department of the United States Government. In the
103 * event Licensee exports any such software from the United States or
104 * re-exports any such software from a foreign destination, Licensee shall
105 * ensure that the distribution and export/re-export of the software is in
106 * compliance with all laws, regulations, orders, or other restrictions of the
107 * U.S. Export Administration Regulations. Licensee agrees that neither it nor
108 * any of its subsidiaries will export/re-export any technical data, process,
109 * software, or service, directly or indirectly, to any country for which the
110 * United States government or any agency thereof requires an export license,
111 * other governmental approval, or letter of assurance, without first obtaining
112 * such license, approval or letter.
113 *
114 *****************************************************************************
115 *
116 * Alternatively, you may choose to be licensed under the terms of the
117 * following license:
118 *
119 * Redistribution and use in source and binary forms, with or without
120 * modification, are permitted provided that the following conditions
121 * are met:
122 * 1. Redistributions of source code must retain the above copyright
123 * notice, this list of conditions, and the following disclaimer,
124 * without modification.
125 * 2. Redistributions in binary form must reproduce at minimum a disclaimer
126 * substantially similar to the "NO WARRANTY" disclaimer below
127 * ("Disclaimer") and any redistribution must be conditioned upon
128 * including a substantially similar Disclaimer requirement for further
129 * binary redistribution.
130 * 3. Neither the names of the above-listed copyright holders nor the names
131 * of any contributors may be used to endorse or promote products derived
132 * from this software without specific prior written permission.
133 *
134 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
135 * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
136 * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
137 * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
138 * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
139 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
140 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
141 * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
142 * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
143 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
144 * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
145 *
146 * Alternatively, you may choose to be licensed under the terms of the
147 * GNU General Public License ("GPL") version 2 as published by the Free
148 * Software Foundation.
149 *
150 *****************************************************************************/
151
152#ifndef __ACEVENTS_H__
153#define __ACEVENTS_H__
154
155
156/*
157 * Conditions to trigger post enabling GPE polling:
158 * It is not sufficient to trigger edge-triggered GPE with specific GPE
159 * chips, software need to poll once after enabling.
160 */
161#ifdef ACPI_USE_GPE_POLLING
162#define ACPI_GPE_IS_POLLING_NEEDED(__gpe__) \
163 ((__gpe__)->RuntimeCount == 1 && \
164 (__gpe__)->Flags & ACPI_GPE_INITIALIZED && \
165 ((__gpe__)->Flags & ACPI_GPE_XRUPT_TYPE_MASK) == ACPI_GPE_EDGE_TRIGGERED)
166#else
167#define ACPI_GPE_IS_POLLING_NEEDED(__gpe__) FALSE
168#endif
169
170
171/*
172 * evevent
173 */
174ACPI_STATUS
175AcpiEvInitializeEvents (
176 void);
177
178ACPI_STATUS
179AcpiEvInstallXruptHandlers (
180 void);
181
182UINT32
183AcpiEvFixedEventDetect (
184 void);
185
186
187/*
188 * evmisc
189 */
190BOOLEAN
191AcpiEvIsNotifyObject (
192 ACPI_NAMESPACE_NODE *Node);
193
194UINT32
195AcpiEvGetGpeNumberIndex (
196 UINT32 GpeNumber);
197
198ACPI_STATUS
199AcpiEvQueueNotifyRequest (
201 UINT32 NotifyValue);
202
203
204/*
205 * evglock - Global Lock support
206 */
207ACPI_STATUS
208AcpiEvInitGlobalLockHandler (
209 void);
210
211ACPI_HW_DEPENDENT_RETURN_OK (
212ACPI_STATUS
213AcpiEvAcquireGlobalLock(
214 UINT16 Timeout))
215
216ACPI_HW_DEPENDENT_RETURN_OK (
217ACPI_STATUS
218AcpiEvReleaseGlobalLock(
219 void))
220
221ACPI_STATUS
222AcpiEvRemoveGlobalLockHandler (
223 void);
224
225
226/*
227 * evgpe - Low-level GPE support
228 */
229UINT32
230AcpiEvGpeDetect (
231 ACPI_GPE_XRUPT_INFO *GpeXruptList);
232
233ACPI_STATUS
234AcpiEvUpdateGpeEnableMask (
235 ACPI_GPE_EVENT_INFO *GpeEventInfo);
236
237ACPI_STATUS
238AcpiEvEnableGpe (
239 ACPI_GPE_EVENT_INFO *GpeEventInfo);
240
241ACPI_STATUS
242AcpiEvMaskGpe (
243 ACPI_GPE_EVENT_INFO *GpeEventInfo,
244 BOOLEAN IsMasked);
245
246ACPI_STATUS
247AcpiEvAddGpeReference (
248 ACPI_GPE_EVENT_INFO *GpeEventInfo,
249 BOOLEAN ClearOnEnable);
250
251ACPI_STATUS
252AcpiEvRemoveGpeReference (
253 ACPI_GPE_EVENT_INFO *GpeEventInfo);
254
256AcpiEvGetGpeEventInfo (
257 ACPI_HANDLE GpeDevice,
258 UINT32 GpeNumber);
259
261AcpiEvLowGetGpeInfo (
262 UINT32 GpeNumber,
263 ACPI_GPE_BLOCK_INFO *GpeBlock);
264
265ACPI_STATUS
266AcpiEvFinishGpe (
267 ACPI_GPE_EVENT_INFO *GpeEventInfo);
268
269UINT32
270AcpiEvDetectGpe (
271 ACPI_NAMESPACE_NODE *GpeDevice,
272 ACPI_GPE_EVENT_INFO *GpeEventInfo,
273 UINT32 GpeNumber);
274
275
276/*
277 * evgpeblk - Upper-level GPE block support
278 */
279ACPI_STATUS
280AcpiEvCreateGpeBlock (
281 ACPI_NAMESPACE_NODE *GpeDevice,
282 UINT64 Address,
283 UINT8 SpaceId,
284 UINT32 RegisterCount,
285 UINT16 GpeBlockBaseNumber,
286 UINT32 InterruptNumber,
287 ACPI_GPE_BLOCK_INFO **ReturnGpeBlock);
288
289ACPI_STATUS
290AcpiEvInitializeGpeBlock (
291 ACPI_GPE_XRUPT_INFO *GpeXruptInfo,
292 ACPI_GPE_BLOCK_INFO *GpeBlock,
293 void *Context);
294
295ACPI_HW_DEPENDENT_RETURN_OK (
296ACPI_STATUS
297AcpiEvDeleteGpeBlock (
298 ACPI_GPE_BLOCK_INFO *GpeBlock))
299
300UINT32
301AcpiEvGpeDispatch (
302 ACPI_NAMESPACE_NODE *GpeDevice,
303 ACPI_GPE_EVENT_INFO *GpeEventInfo,
304 UINT32 GpeNumber);
305
306
307/*
308 * evgpeinit - GPE initialization and update
309 */
310ACPI_STATUS
311AcpiEvGpeInitialize (
312 void);
313
314ACPI_HW_DEPENDENT_RETURN_VOID (
315void
316AcpiEvUpdateGpes (
317 ACPI_OWNER_ID TableOwnerId))
318
319ACPI_STATUS
320AcpiEvMatchGpeMethod (
321 ACPI_HANDLE ObjHandle,
322 UINT32 Level,
323 void *Context,
324 void **ReturnValue);
325
326
327/*
328 * evgpeutil - GPE utilities
329 */
330ACPI_STATUS
331AcpiEvWalkGpeList (
332 ACPI_GPE_CALLBACK GpeWalkCallback,
333 void *Context);
334
335ACPI_STATUS
336AcpiEvGetGpeDevice (
337 ACPI_GPE_XRUPT_INFO *GpeXruptInfo,
338 ACPI_GPE_BLOCK_INFO *GpeBlock,
339 void *Context);
340
341ACPI_STATUS
342AcpiEvGetGpeXruptBlock (
343 UINT32 InterruptNumber,
344 ACPI_GPE_XRUPT_INFO **GpeXruptBlock);
345
346ACPI_STATUS
347AcpiEvDeleteGpeXrupt (
348 ACPI_GPE_XRUPT_INFO *GpeXrupt);
349
350ACPI_STATUS
351AcpiEvDeleteGpeHandlers (
352 ACPI_GPE_XRUPT_INFO *GpeXruptInfo,
353 ACPI_GPE_BLOCK_INFO *GpeBlock,
354 void *Context);
355
356
357/*
358 * evhandler - Address space handling
359 */
361AcpiEvFindRegionHandler (
362 ACPI_ADR_SPACE_TYPE SpaceId,
363 ACPI_OPERAND_OBJECT *HandlerObj);
364
365BOOLEAN
366AcpiEvHasDefaultHandler (
368 ACPI_ADR_SPACE_TYPE SpaceId);
369
370ACPI_STATUS
371AcpiEvInstallRegionHandlers (
372 void);
373
374ACPI_STATUS
375AcpiEvInstallSpaceHandler (
377 ACPI_ADR_SPACE_TYPE SpaceId,
378 ACPI_ADR_SPACE_HANDLER Handler,
379 ACPI_ADR_SPACE_SETUP Setup,
380 void *Context);
381
382
383/*
384 * evregion - Operation region support
385 */
386ACPI_STATUS
387AcpiEvInitializeOpRegions (
388 void);
389
390ACPI_STATUS
391AcpiEvAddressSpaceDispatch (
392 ACPI_OPERAND_OBJECT *RegionObj,
393 ACPI_OPERAND_OBJECT *FieldObj,
394 UINT32 Function,
395 UINT32 RegionOffset,
396 UINT32 BitWidth,
397 UINT64 *Value);
398
399ACPI_STATUS
400AcpiEvAttachRegion (
401 ACPI_OPERAND_OBJECT *HandlerObj,
402 ACPI_OPERAND_OBJECT *RegionObj,
403 BOOLEAN AcpiNsIsLocked);
404
405void
406AcpiEvDetachRegion (
407 ACPI_OPERAND_OBJECT *RegionObj,
408 BOOLEAN AcpiNsIsLocked);
409
410void
411AcpiEvExecuteRegMethods (
413 ACPI_ADR_SPACE_TYPE SpaceId,
414 UINT32 Function);
415
416ACPI_STATUS
417AcpiEvExecuteRegMethod (
418 ACPI_OPERAND_OBJECT *RegionObj,
419 UINT32 Function);
420
421
422/*
423 * evregini - Region initialization and setup
424 */
425ACPI_STATUS
426AcpiEvSystemMemoryRegionSetup (
427 ACPI_HANDLE Handle,
428 UINT32 Function,
429 void *HandlerContext,
430 void **RegionContext);
431
432ACPI_STATUS
433AcpiEvIoSpaceRegionSetup (
434 ACPI_HANDLE Handle,
435 UINT32 Function,
436 void *HandlerContext,
437 void **RegionContext);
438
439ACPI_STATUS
440AcpiEvPciConfigRegionSetup (
441 ACPI_HANDLE Handle,
442 UINT32 Function,
443 void *HandlerContext,
444 void **RegionContext);
445
446ACPI_STATUS
447AcpiEvCmosRegionSetup (
448 ACPI_HANDLE Handle,
449 UINT32 Function,
450 void *HandlerContext,
451 void **RegionContext);
452
453ACPI_STATUS
454AcpiEvPciBarRegionSetup (
455 ACPI_HANDLE Handle,
456 UINT32 Function,
457 void *HandlerContext,
458 void **RegionContext);
459
460ACPI_STATUS
461AcpiEvDataTableRegionSetup (
462 ACPI_HANDLE Handle,
463 UINT32 Function,
464 void *HandlerContext,
465 void **RegionContext);
466
467ACPI_STATUS
468AcpiEvDefaultRegionSetup (
469 ACPI_HANDLE Handle,
470 UINT32 Function,
471 void *HandlerContext,
472 void **RegionContext);
473
474ACPI_STATUS
475AcpiEvInitializeRegion (
476 ACPI_OPERAND_OBJECT *RegionObj);
477
478BOOLEAN
479AcpiEvIsPciRootBridge (
480 ACPI_NAMESPACE_NODE *Node);
481
482
483/*
484 * evsci - SCI (System Control Interrupt) handling/dispatch
485 */
486UINT32 ACPI_SYSTEM_XFACE
487AcpiEvGpeXruptHandler (
488 void *Context);
489
490UINT32
491AcpiEvSciDispatch (
492 void);
493
494UINT32
495AcpiEvInstallSciHandler (
496 void);
497
498ACPI_STATUS
499AcpiEvRemoveAllSciHandlers (
500 void);
501
502ACPI_HW_DEPENDENT_RETURN_VOID (
503void
504AcpiEvTerminate (
505 void))
506
507#endif /* __ACEVENTS_H__ */
Test context for spec:/rtems/barrier/req/create test case.
Definition: tc-barrier-create.c:144
Definition: aclocal.h:690
Definition: aclocal.h:661
Definition: aclocal.h:709
Definition: aclocal.h:294
Definition: acobject.h:626
