RTEMS 6.1
Test context for spec:/rtems/barrier/req/create test case. More...
void * seized_objects
rtems_id worker_id
rtems_id id_value
uint32_t release_done
uint32_t release_expected
rtems_name name
rtems_attribute attribute_set
uint32_t maximum_waiters
rtems_idid
rtems_status_code status
struct {
   size_t   pcs [5]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsBarrierReqCreate_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
