RTEMS 6.1
acpi_operand_object Union Reference
ACPI_OBJECT_COMMON Common
ACPI_OBJECT_INTEGER Integer
ACPI_OBJECT_STRING String
ACPI_OBJECT_BUFFER Buffer
ACPI_OBJECT_PACKAGE Package
ACPI_OBJECT_EVENT Event
ACPI_OBJECT_METHOD Method
ACPI_OBJECT_MUTEX Mutex
ACPI_OBJECT_REGION Region
ACPI_OBJECT_NOTIFY_COMMON CommonNotify
ACPI_OBJECT_DEVICE Device
ACPI_OBJECT_POWER_RESOURCE PowerResource
ACPI_OBJECT_PROCESSOR Processor
ACPI_OBJECT_THERMAL_ZONE ThermalZone
ACPI_OBJECT_FIELD_COMMON CommonField
ACPI_OBJECT_REGION_FIELD Field
ACPI_OBJECT_BUFFER_FIELD BufferField
ACPI_OBJECT_BANK_FIELD BankField
ACPI_OBJECT_INDEX_FIELD IndexField
ACPI_OBJECT_NOTIFY_HANDLER Notify
ACPI_OBJECT_ADDR_HANDLER AddressSpace
ACPI_OBJECT_REFERENCE Reference
ACPI_OBJECT_EXTRA Extra
ACPI_OBJECT_DATA Data
ACPI_OBJECT_CACHE_LIST Cache
ACPI_NAMESPACE_NODE Node
The documentation for this union was generated from the following file:
