RTEMS 6.1
rpi-gpio.h
2
11/*
12 * Copyright (C) 2023 Utkarsh Verma
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_AARCH64_RASPBERRYPI_BSP_RPI_GPIO_H
37#define LIBBSP_AARCH64_RASPBERRYPI_BSP_RPI_GPIO_H
38
39#include <bspopts.h>
40#include <rtems/rtems/status.h>
41
46typedef enum {
47 GPIO_INPUT,
48 GPIO_OUTPUT,
49 GPIO_AF5,
50 GPIO_AF4,
51 GPIO_AF0,
52 GPIO_AF1,
53 GPIO_AF2,
54 GPIO_AF3,
56
57typedef enum {
58 GPIO_PULL_NONE,
59 GPIO_PULL_UP,
60 GPIO_PULL_DOWN,
61} raspberrypi_gpio_pull;
62
76 const unsigned int pin,
78);
79
89rtems_status_code raspberrypi_gpio_set_pin(const unsigned int pin);
90
100rtems_status_code raspberrypi_gpio_clear_pin(const unsigned int pin);
101
114 const unsigned int pin,
115 const raspberrypi_gpio_pull value
116);
117
118#endif /* LIBBSP_AARCH64_RASPBERRYPI_BSP_RPI_GPIO_H */
rtems_status_code raspberrypi_gpio_set_pull(const unsigned int pin, const raspberrypi_gpio_pull value)
Control the actuation of the internal pull-up/down resistors.
Definition: gpio.c:104
raspberrypi_gpio_function
Raspberry Pi GPIO functions.
Definition: rpi-gpio.h:46
Set a GPIO pin.
Definition: gpio.c:99
rtems_status_code raspberrypi_gpio_set_function(const unsigned int pin, const raspberrypi_gpio_function value)
Set the operation of the general-purpose I/O pins. Each of the 58 GPIO pins has at least two alternat...
Definition: gpio.c:86
Clear a GPIO pin.
Definition: gpio.c:94
rtems_status_code
Definition: status.h:85
This header file provides the status codes of Classic API directives and support functions.
