RTEMS 6.1
Raspberry Pi 4B specific GPIO definitions. More...
Enumerations | |
| enum | raspberrypi_gpio_function { GPIO_INPUT , GPIO_OUTPUT , GPIO_AF5 , GPIO_AF4 , GPIO_AF0 , GPIO_AF1 , GPIO_AF2 , GPIO_AF3 } |
| Raspberry Pi GPIO functions. | |
| enum | raspberrypi_gpio_pull { GPIO_PULL_NONE , GPIO_PULL_UP , GPIO_PULL_DOWN } |
| rtems_status_code | raspberrypi_gpio_set_function (const unsigned int pin, const raspberrypi_gpio_function value) |
| Set the operation of the general-purpose I/O pins. Each of the 58 GPIO pins has at least two alternative functions as defined. | |
| rtems_status_code | raspberrypi_gpio_set_pin (const unsigned int pin) |
| Set a GPIO pin. | |
| rtems_status_code | raspberrypi_gpio_clear_pin (const unsigned int pin) |
| Clear a GPIO pin. | |
| rtems_status_code | raspberrypi_gpio_set_pull (const unsigned int pin, const raspberrypi_gpio_pull value) |
| Control the actuation of the internal pull-up/down resistors. | |
| rtems_status_code raspberrypi_gpio_clear_pin | ( | const unsigned int | pin | ) |
Clear a GPIO pin.
| pin | The GPIO pin. |
| RTEMS_SUCCESSFUL | GPIO pin clear successfully. |
| RTEMS_INVALID_NUMBER | This status code indicates that a specified number was invalid. |
| rtems_status_code raspberrypi_gpio_set_function | ( | const unsigned int | pin, |
| const raspberrypi_gpio_function | value | ||
| value | The optional functions are GPIO_INPUT, GPIO_OUTPUT, GPIO_AF5, GPIO_AF4, GPIO_AF0, GPIO_AF1, GPIO_AF2, GPIO_AF3. |
| RTEMS_SUCCESSFUL | GPIO function successfully configured. |
| rtems_status_code raspberrypi_gpio_set_pin | ( | const unsigned int | pin | ) |
Set a GPIO pin.
| RTEMS_SUCCESSFUL | GPIO pin set successfully. |
| rtems_status_code raspberrypi_gpio_set_pull | ( | const unsigned int | pin, |
| const raspberrypi_gpio_pull | value | ||
| value | The optional value are GPIO_PULL_NONE, GPIO_PULL_UP, GPIO_PULL_DOWN. |
| RTEMS_SUCCESSFUL | GPIO pull set successfully. |
