RTEMS 6.1
Register definitions. More...
Register Macros | |
| #define | BCM2711_REG(x) (*(volatile uint64_t *)(x)) |
| #define | BCM2711_BIT(n) (1 << (n)) |
| #define | BCM2835_REG(addr) (*(volatile uint32_t*)(addr)) |
Peripheral Base Register Address | |
| #define | RPI_PERIPHERAL_BASE 0xFE000000 |
| #define | BASE_OFFSET 0xFE000000 |
| #define | RPI_PERIPHERAL_SIZE 0x01800000 |
Bus to Physical address translation | |
Macro. | |
| #define | BUS_TO_PHY(x) ((x) - BASE_OFFSET) |
Internal ARM Timer Registers | |
| #define | BCM2711_CLOCK_FREQ 250000000 |
| #define | BCM2711_TIMER_BASE (RPI_PERIPHERAL_BASE + 0xB400) |
| #define | BCM2711_TIMER_LOD (BCM2711_TIMER_BASE + 0x00) |
| #define | BCM2711_TIMER_VAL (BCM2711_TIMER_BASE + 0x04) |
| #define | BCM2711_TIMER_CTL (BCM2711_TIMER_BASE + 0x08) |
| #define | BCM2711_TIMER_CLI (BCM2711_TIMER_BASE + 0x0C) |
| #define | BCM2711_TIMER_RIS (BCM2711_TIMER_BASE + 0x10) |
| #define | BCM2711_TIMER_MIS (BCM2711_TIMER_BASE + 0x14) |
| #define | BCM2711_TIMER_RLD (BCM2711_TIMER_BASE + 0x18) |
| #define | BCM2711_TIMER_DIV (BCM2711_TIMER_BASE + 0x1C) |
| #define | BCM2711_TIMER_CNT (BCM2711_TIMER_BASE + 0x20) |
| #define | BCM2711_TIMER_PRESCALE 0xF9 |
Power Management and Watchdog Registers | |
| #define | BCM2711_PM_PASSWD_MAGIC 0x5a000000 |
| #define | BCM2711_PM_BASE (RPI_PERIPHERAL_BASE + 0x100000) |
| #define | BCM2711_PM_GNRIC (BCM2711_PM_BASE + 0x00) |
| #define | BCM2711_PM_GNRIC_POWUP 0x00000001 |
| #define | BCM2711_PM_GNRIC_POWOK 0x00000002 |
| #define | BCM2711_PM_GNRIC_ISPOW 0x00000004 |
| #define | BCM2711_PM_GNRIC_MEMREP 0x00000008 |
| #define | BCM2711_PM_GNRIC_MRDONE 0x00000010 |
| #define | BCM2711_PM_GNRIC_ISFUNC 0x00000020 |
| #define | BCM2711_PM_GNRIC_RSTN 0x00000fc0 |
| #define | BCM2711_PM_GNRIC_ENAB 0x00001000 |
| #define | BCM2711_PM_GNRIC_CFG 0x007f0000 |
| #define | BCM2711_PM_AUDIO (BCM2711_PM_BASE + 0x04) |
| #define | BCM2711_PM_AUDIO_APSM 0x000fffff |
| #define | BCM2711_PM_AUDIO_CTRLEN 0x00100000 |
| #define | BCM2711_PM_AUDIO_RSTN 0x00200000 |
| #define | BCM2711_PM_STATUS (BCM2711_PM_BASE + 0x18) |
| #define | BCM2711_PM_RSTC (BCM2711_PM_BASE + 0x1c) |
| #define | BCM2711_PM_RSTC_DRCFG 0x00000003 |
| #define | BCM2711_PM_RSTC_WRCFG 0x00000030 |
| #define | BCM2711_PM_RSTC_WRCFG_FULL 0x00000020 |
| #define | BCM2711_PM_RSTC_WRCFG_CLR 0xffffffcf |
| #define | BCM2711_PM_RSTC_SRCFG 0x00000300 |
| #define | BCM2711_PM_RSTC_QRCFG 0x00003000 |
| #define | BCM2711_PM_RSTC_FRCFG 0x00030000 |
| #define | BCM2711_PM_RSTC_HRCFG 0x00300000 |
| #define | BCM2711_PM_RSTC_RESET 0x00000102 |
| #define | BCM2711_PM_RSTS (BCM2711_PM_BASE + 0x20) |
| #define | BCM2711_PM_RSTS_HADDRQ 0x00000001 |
| #define | BCM2711_PM_RSTS_HADDRF 0x00000002 |
| #define | BCM2711_PM_RSTS_HADDRH 0x00000004 |
| #define | BCM2711_PM_RSTS_HADWRQ 0x00000010 |
| #define | BCM2711_PM_RSTS_HADWRF 0x0000002 |
| #define | BCM2711_PM_RSTS_HADWRH 0x00000040 |
| #define | BCM2711_PM_RSTS_HADSRQ 0x00000100 |
| #define | BCM2711_PM_RSTS_HADSRF 0x00000200 |
| #define | BCM2711_PM_RSTS_HADSRH 0x00000400 |
| #define | BCM2711_PM_RSTS_HADPOR 0x00001000 |
| #define | BCM2711_PM_WDOG (BCM2711_PM_BASE + 0x24) |
| #define | BCM2711_PM_WDOG_MASK 0x000fffff |
AUX Registers | |
| #define | BCM2711_AUX_BASE (RPI_PERIPHERAL_BASE + 0x215000) |
| #define | AUX_ENABLES (BCM2711_AUX_BASE + 0x04) |
| #define | AUX_MU_IO_REG (BCM2711_AUX_BASE + 0x40) |
| #define | AUX_MU_IER_REG (BCM2711_AUX_BASE + 0x44) |
| #define | AUX_MU_IIR_REG (BCM2711_AUX_BASE + 0x48) |
| #define | AUX_MU_LCR_REG (BCM2711_AUX_BASE + 0x4C) |
| #define | AUX_MU_MCR_REG (BCM2711_AUX_BASE + 0x50) |
| #define | AUX_MU_LSR_REG (BCM2711_AUX_BASE + 0x54) |
| #define | AUX_MU_MSR_REG (BCM2711_AUX_BASE + 0x58) |
| #define | AUX_MU_SCRATCH (BCM2711_AUX_BASE + 0x5C) |
| #define | AUX_MU_CNTL_REG (BCM2711_AUX_BASE + 0x60) |
| #define | AUX_MU_STAT_REG (BCM2711_AUX_BASE + 0x64) |
| #define | AUX_MU_BAUD_REG (BCM2711_AUX_BASE + 0x68) |
PL011 UARTs | |
| #define | BCM2711_PL011_BASE (RPI_PERIPHERAL_BASE + 0x201000) |
| #define | BCM2711_PL011_SIZE 0xc00 |
| #define | BCM2711_PL011_DEVICE_SIZE 0x200 |
| #define | BCM2711_UART0_BASE (BCM2711_PL011_BASE + 0x000) |
| #define | BCM2711_UART0_SIZE BCM2711_PL011_DEVICE_SIZE |
| #define | BCM2711_UART2_BASE (BCM2711_PL011_BASE + 0x400) |
| #define | BCM2711_UART2_SIZE BCM2711_PL011_DEVICE_SIZE |
| #define | BCM2711_UART3_BASE (BCM2711_PL011_BASE + 0x600) |
| #define | BCM2711_UART3_SIZE BCM2711_PL011_DEVICE_SIZE |
| #define | BCM2711_UART4_BASE (BCM2711_PL011_BASE + 0x800) |
| #define | BCM2711_UART4_SIZE BCM2711_PL011_DEVICE_SIZE |
| #define | BCM2711_UART5_BASE (BCM2711_PL011_BASE + 0xa00) |
| #define | BCM2711_UART5_SIZE BCM2711_PL011_DEVICE_SIZE |
GPU Timer Registers | |
| #define | BCM2711_GPU_TIMER_BASE (RPI_PERIPHERAL_BASE + 0x3000) |
| #define | BCM2711_GPU_TIMER_CS (BCM2711_GPU_TIMER_BASE + 0x00) |
| #define | BCM2711_GPU_TIMER_CS_M0 0x00000001 |
| #define | BCM2711_GPU_TIMER_CS_M1 0x00000002 |
| #define | BCM2711_GPU_TIMER_CS_M2 0x00000004 |
| #define | BCM2711_GPU_TIMER_CS_M3 0x00000008 |
| #define | BCM2711_GPU_TIMER_CLO (BCM2711_GPU_TIMER_BASE + 0x04) |
| #define | BCM2711_GPU_TIMER_CHI (BCM2711_GPU_TIMER_BASE + 0x08) |
| #define | BCM2711_GPU_TIMER_C0 (BCM2711_GPU_TIMER_BASE + 0x0C) |
| #define | BCM2711_GPU_TIMER_C1 (BCM2711_GPU_TIMER_BASE + 0x10) |
| #define | BCM2711_GPU_TIMER_C2 (BCM2711_GPU_TIMER_BASE + 0x14) |
| #define | BCM2711_GPU_TIMER_C3 (BCM2711_GPU_TIMER_BASE + 0x18) |
| #define | BCM2835_GPU_TIMER_CS_M3 BCM2711_GPU_TIMER_CS_M3 |
| #define | BCM2835_GPU_TIMER_C3 BCM2711_GPU_TIMER_C3 |
| #define | BCM2835_GPU_TIMER_CLO BCM2711_GPU_TIMER_CLO |
| #define | BCM2835_GPU_TIMER_CS BCM2711_GPU_TIMER_CS |
GPIO Registers | |
| #define | BCM2711_GPIO_BASE (RPI_PERIPHERAL_BASE + 0x200000) |
| #define | BCM2711_GPIO_SIZE 0xf4 |
| #define | BCM2711_GPIO_PIN_COUNT 58 |
EMMC Registers | |
| #define | BCM2711_EMMC_BASE (RPI_PERIPHERAL_BASE + 0x300000) |
SPI Registers | |
| #define | BCM2711_SPI0_BASE (RPI_PERIPHERAL_BASE + 0x204000) |
| #define | BCM2711_SPI3_BASE (RPI_PERIPHERAL_BASE + 0x204600) |
| #define | BCM2711_SPI4_BASE (RPI_PERIPHERAL_BASE + 0x204800) |
| #define | BCM2711_SPI5_BASE (RPI_PERIPHERAL_BASE + 0x204A00) |
| #define | BCM2711_SPI6_BASE (RPI_PERIPHERAL_BASE + 0x204C00) |
Mailbox Registers | |
| #define | BCM2711_MBOX_BASE (RPI_PERIPHERAL_BASE+0xB880) |
| #define | BCM2711_MBOX_READ (BCM2711_MBOX_BASE+0x00) |
| #define | BCM2711_MBOX_PEEK (BCM2711_MBOX_BASE+0x10) |
| #define | BCM2711_MBOX_SENDER (BCM2711_MBOX_BASE+0x14) |
| #define | BCM2711_MBOX_STATUS (BCM2711_MBOX_BASE+0x18) |
| #define | BCM2711_MBOX_WRITE (BCM2711_MBOX_BASE+0x20) |
| #define | BCM2711_MBOX_CONFIG (BCM2711_MBOX_BASE+0x1C) |
| #define | BCM2711_MBOX_RESPONSE 0x80000000 |
| #define | BCM2711_MBOX_FULL 0x80000000 |
| #define | BCM2711_MBOX_EMPTY 0x40000000 |
Mailbox Channels | |
| #define | BCM2711_MBOX_CHANNEL_PM 0 |
| #define | BCM2711_MBOX_CHANNEL_FB 1 |
| #define | BCM2711_MBOX_CHANNEL_VUART 2 |
| #define | BCM2711_MBOX_CHANNEL_VCHIQ 3 |
| #define | BCM2711_MBOX_CHANNEL_LED 4 |
| #define | BCM2711_MBOX_CHANNEL_BUTTON 5 |
| #define | BCM2711_MBOX_CHANNEL_TOUCHS 6 |
| #define | BCM2711_MBOX_CHANNEL_COUNT 7 |
| #define | BCM2711_MBOX_CHANNEL_PROP_AVC 8 |
| #define | BCM2711_MBOX_CHANNEL_PROP_VCA 9 |
Raspberry Pi 2 Interrupt Register Defines | |
| #define | BCM2711_CORE0_TIMER_IRQ_CTRL_BASE 0xFF800040 |
| #define | BCM2711_CORE1_TIMER_IRQ_CTRL_BASE 0xFF800044 |
| #define | BCM2711_CORE2_TIMER_IRQ_CTRL_BASE 0xFF800048 |
| #define | BCM2711_CORE3_TIMER_IRQ_CTRL_BASE 0xFF80004C |
| #define | BCM2711_CORE_TIMER_IRQ_CTRL(cpuidx) (BCM2711_CORE0_TIMER_IRQ_CTRL_BASE + 0x4 * (cpuidx)) |
Raspberry Pi 4 ARM_LOCAL registers | |
| #define | BCM2711_LOCAL_REGS_BASE 0x4C0000000 |
| #define | BCM2711_LOCAL_REGS_SIZE 0x100 |
| #define | BCM2711_LOCAL_ARM_CONTROL (BCM2711_LOCAL_REGS_BASE + 0x00) |
| #define | BCM2711_LOCAL_CORE_IRQ_CONTROL (BCM2711_LOCAL_REGS_BASE + 0x0c) |
| #define | BCM2711_LOCAL_PMU_CONTROL_SET (BCM2711_LOCAL_REGS_BASE + 0x10) |
| #define | BCM2711_LOCAL_PMU_CONTROL_CLR (BCM2711_LOCAL_REGS_BASE + 0x14) |
| #define | BCM2711_LOCAL_PERI_IRQ_ROUTE0 (BCM2711_LOCAL_REGS_BASE + 0x24) |
| #define | BCM2711_LOCAL_AXI_QUIET_TIME (BCM2711_LOCAL_REGS_BASE + 0x30) |
| #define | BCM2711_LOCAL_LOCAL_TIMER_CONTROL (BCM2711_LOCAL_REGS_BASE + 0x34) |
| #define | BCM2711_LOCAL_LOCAL_TIMER_IRQ (BCM2711_LOCAL_REGS_BASE + 0x38) |
| #define | BCM2711_LOCAL_TIMER_CNTRL0 (BCM2711_LOCAL_REGS_BASE + 0x40) |
| #define | BCM2711_LOCAL_TIMER_CNTRL1 (BCM2711_LOCAL_REGS_BASE + 0x44) |
| #define | BCM2711_LOCAL_TIMER_CNTRL2 (BCM2711_LOCAL_REGS_BASE + 0x48) |
| #define | BCM2711_LOCAL_TIMER_CNTRL3 (BCM2711_LOCAL_REGS_BASE + 0x4c) |
| #define | BCM2711_LOCAL_MAILBOX_CNTRL0 (BCM2711_LOCAL_REGS_BASE + 0x50) |
| #define | BCM2711_LOCAL_MAILBOX_CNTRL1 (BCM2711_LOCAL_REGS_BASE + 0x54) |
| #define | BCM2711_LOCAL_MAILBOX_CNTRL2 (BCM2711_LOCAL_REGS_BASE + 0x58) |
| #define | BCM2711_LOCAL_MAILBOX_CNTRL3 (BCM2711_LOCAL_REGS_BASE + 0x5c) |
| #define | BCM2711_LOCAL_IRQ_SOURCE0 (BCM2711_LOCAL_REGS_BASE + 0x60) |
| #define | BCM2711_LOCAL_IRQ_SOURCE1 (BCM2711_LOCAL_REGS_BASE + 0x64) |
| #define | BCM2711_LOCAL_IRQ_SOURCE2 (BCM2711_LOCAL_REGS_BASE + 0x68) |
| #define | BCM2711_LOCAL_IRQ_SOURCE3 (BCM2711_LOCAL_REGS_BASE + 0x6c) |
| #define | BCM2711_LOCAL_FIQ_SOURCE0 (BCM2711_LOCAL_REGS_BASE + 0x70) |
| #define | BCM2711_LOCAL_FIQ_SOURCE1 (BCM2711_LOCAL_REGS_BASE + 0x74) |
| #define | BCM2711_LOCAL_FIQ_SOURCE2 (BCM2711_LOCAL_REGS_BASE + 0x78) |
| #define | BCM2711_LOCAL_FIQ_SOURCE3 (BCM2711_LOCAL_REGS_BASE + 0x7c) |
Raspberry Pi 4 Mailbox registers | |
| #define | BCM2711_MAILBOX_00_WRITE_SET_BASE 0x4C000080 |
| #define | BCM2711_MAILBOX_01_WRITE_SET_BASE 0x4C000084 |
| #define | BCM2711_MAILBOX_02_WRITE_SET_BASE 0x4C000088 |
| #define | BCM2711_MAILBOX_03_WRITE_SET_BASE 0x4C00008C |
| #define | BCM2711_MAILBOX_04_WRITE_SET_BASE 0x4C000090 |
| #define | BCM2711_MAILBOX_05_WRITE_SET_BASE 0x4C000094 |
| #define | BCM2711_MAILBOX_06_WRITE_SET_BASE 0x4C000098 |
| #define | BCM2711_MAILBOX_07_WRITE_SET_BASE 0x4C00009C |
| #define | BCM2711_MAILBOX_08_WRITE_SET_BASE 0x4C0000A0 |
| #define | BCM2711_MAILBOX_09_WRITE_SET_BASE 0x4C0000A4 |
| #define | BCM2711_MAILBOX_10_WRITE_SET_BASE 0x4C0000A8 |
| #define | BCM2711_MAILBOX_11_WRITE_SET_BASE 0x4C0000AC |
| #define | BCM2711_MAILBOX_12_WRITE_SET_BASE 0x4C0000B0 |
| #define | BCM2711_MAILBOX_13_WRITE_SET_BASE 0x4C0000B4 |
| #define | BCM2711_MAILBOX_14_WRITE_SET_BASE 0x4C0000B8 |
| #define | BCM2711_MAILBOX_15_WRITE_SET_BASE 0x4C0000BC |
| #define | BCM2711_MAILBOX_00_READ_CLEAR_BASE 0x4C0000C0 |
| #define | BCM2711_MAILBOX_01_READ_CLEAR_BASE 0x4C0000C4 |
| #define | BCM2711_MAILBOX_02_READ_CLEAR_BASE 0x4C0000C8 |
| #define | BCM2711_MAILBOX_03_READ_CLEAR_BASE 0x4C0000CC |
| #define | BCM2711_MAILBOX_04_READ_CLEAR_BASE 0x4C0000D0 |
| #define | BCM2711_MAILBOX_05_READ_CLEAR_BASE 0x4C0000D4 |
| #define | BCM2711_MAILBOX_06_READ_CLEAR_BASE 0x4C0000D8 |
| #define | BCM2711_MAILBOX_07_READ_CLEAR_BASE 0x4C0000DC |
| #define | BCM2711_MAILBOX_08_READ_CLEAR_BASE 0x4C0000E0 |
| #define | BCM2711_MAILBOX_09_READ_CLEAR_BASE 0x4C0000E4 |
| #define | BCM2711_MAILBOX_10_READ_CLEAR_BASE 0x4C0000E8 |
| #define | BCM2711_MAILBOX_11_READ_CLEAR_BASE 0x4C0000EC |
| #define | BCM2711_MAILBOX_12_READ_CLEAR_BASE 0x4C0000F0 |
| #define | BCM2711_MAILBOX_13_READ_CLEAR_BASE 0x4C0000F4 |
| #define | BCM2711_MAILBOX_14_READ_CLEAR_BASE 0x4C0000F8 |
| #define | BCM2711_MAILBOX_15_READ_CLEAR_BASE 0x4C0000FC |
Raspberry Pi 4 ARM_C FIQ and IRQ registers | |
| #define | BCM2711_ARMC_REGS_BASE (RPI_PERIPHERAL_BASE + 0xB200) |
| #define | BCM2711_ARMC_REGS_SIZE 0x200 |
| #define | BCM2711_ARMC_IRQ0_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x00) |
| #define | BCM2711_ARMC_IRQ0_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x04) |
| #define | BCM2711_ARMC_IRQ0_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x08) |
| #define | BCM2711_ARMC_IRQ0_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0x10) |
| #define | BCM2711_ARMC_IRQ0_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0x14) |
| #define | BCM2711_ARMC_IRQ0_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0x18) |
| #define | BCM2711_ARMC_IRQ0_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x20) |
| #define | BCM2711_ARMC_IRQ0_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x24) |
| #define | BCM2711_ARMC_IRQ0_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x28) |
| #define | BCM2711_ARMC_IRQ_STATUS0 (BCM2711_ARMC_REGS_BASE + 0x30) |
| #define | BCM2711_ARMC_IRQ_STATUS1 (BCM2711_ARMC_REGS_BASE + 0x34) |
| #define | BCM2711_ARMC_IRQ_STATUS2 (BCM2711_ARMC_REGS_BASE + 0x38) |
| #define | BCM2711_ARMC_IRQ1_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x40) |
| #define | BCM2711_ARMC_IRQ1_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x44) |
| #define | BCM2711_ARMC_IRQ1_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x48) |
| #define | BCM2711_ARMC_IRQ1_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0x50) |
| #define | BCM2711_ARMC_IRQ1_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0x54) |
| #define | BCM2711_ARMC_IRQ1_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0x58) |
| #define | BCM2711_ARMC_IRQ1_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x60) |
| #define | BCM2711_ARMC_IRQ1_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x64) |
| #define | BCM2711_ARMC_IRQ1_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x68) |
| #define | BCM2711_ARMC_IRQ2_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x80) |
| #define | BCM2711_ARMC_IRQ2_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x84) |
| #define | BCM2711_ARMC_IRQ2_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x88) |
| #define | BCM2711_ARMC_IRQ2_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0x90) |
| #define | BCM2711_ARMC_IRQ2_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0x94) |
| #define | BCM2711_ARMC_IRQ2_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0x98) |
| #define | BCM2711_ARMC_IRQ2_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0xA0) |
| #define | BCM2711_ARMC_IRQ2_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0xA4) |
| #define | BCM2711_ARMC_IRQ2_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0xA8) |
| #define | BCM2711_ARMC_IRQ3_PENDING0 (BCM2711_ARMC_REGS_BASE + 0xC0) |
| #define | BCM2711_ARMC_IRQ3_PENDING1 (BCM2711_ARMC_REGS_BASE + 0xC4) |
| #define | BCM2711_ARMC_IRQ3_PENDING2 (BCM2711_ARMC_REGS_BASE + 0xC8) |
| #define | BCM2711_ARMC_IRQ3_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0xD0) |
| #define | BCM2711_ARMC_IRQ3_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0xD4) |
| #define | BCM2711_ARMC_IRQ3_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0xD8) |
| #define | BCM2711_ARMC_IRQ3_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0xE0) |
| #define | BCM2711_ARMC_IRQ3_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0xE4) |
| #define | BCM2711_ARMC_IRQ3_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0xE8) |
| #define | BCM2711_ARMC_FIQ0_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x100) |
| #define | BCM2711_ARMC_FIQ0_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x104) |
| #define | BCM2711_ARMC_FIQ0_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x108) |
| #define | BCM2711_ARMC_FIQ0_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0x110) |
| #define | BCM2711_ARMC_FIQ0_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0x114) |
| #define | BCM2711_ARMC_FIQ0_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0x118) |
| #define | BCM2711_ARMC_FIQ0_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x120) |
| #define | BCM2711_ARMC_FIQ0_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x124) |
| #define | BCM2711_ARMC_FIQ0_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x128) |
| #define | BCM2711_ARMC_FIQ1_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x140) |
| #define | BCM2711_ARMC_FIQ1_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x144) |
| #define | BCM2711_ARMC_FIQ1_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x148) |
| #define | BCM2711_ARMC_FIQ1_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0x150) |
| #define | BCM2711_ARMC_FIQ1_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0x154) |
| #define | BCM2711_ARMC_FIQ1_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0x158) |
| #define | BCM2711_ARMC_FIQ1_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x160) |
| #define | BCM2711_ARMC_FIQ1_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x164) |
| #define | BCM2711_ARMC_FIQ1_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x168) |
| #define | BCM2711_ARMC_FIQ2_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x180) |
| #define | BCM2711_ARMC_FIQ2_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x184) |
| #define | BCM2711_ARMC_FIQ2_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x188) |
| #define | BCM2711_ARMC_FIQ2_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0x190) |
| #define | BCM2711_ARMC_FIQ2_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0x194) |
| #define | BCM2711_ARMC_FIQ2_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0x198) |
| #define | BCM2711_ARMC_FIQ2_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x1A0) |
| #define | BCM2711_ARMC_FIQ2_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x1A4) |
| #define | BCM2711_ARMC_FIQ2_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x1A8) |
| #define | BCM2711_ARMC_FIQ3_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x1C0) |
| #define | BCM2711_ARMC_FIQ3_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x1C4) |
| #define | BCM2711_ARMC_FIQ3_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x1C8) |
| #define | BCM2711_ARMC_FIQ3_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0x1D0) |
| #define | BCM2711_ARMC_FIQ3_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0x1D4) |
| #define | BCM2711_ARMC_FIQ3_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0x1D8) |
| #define | BCM2711_ARMC_FIQ3_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x1E0) |
| #define | BCM2711_ARMC_FIQ3_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x1E4) |
| #define | BCM2711_ARMC_FIQ3_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x1E8) |
| #define | BCM2711_ARMC_SWIRQ_SET (BCM2711_ARMC_REGS_BASE + 0x1F0) |
| #define | BCM2711_ARMC_SWIRQ_CLEAR (BCM2711_ARMC_REGS_BASE + 0x1F4) |
| #define BCM2711_EMMC_BASE (RPI_PERIPHERAL_BASE + 0x300000) |
NOTE: Since the SD controller follows the SDHCI standard, the rtems-libbsd tree already provides the remaining registers.
| #define BCM2711_GPU_TIMER_BASE (RPI_PERIPHERAL_BASE + 0x3000) |
NOTE: The GPU uses Compare registers 0 and 2 for it's own RTOS. 1 and 3 are available for use in RTEMS.
| #define BCM2835_GPU_TIMER_CS_M3 BCM2711_GPU_TIMER_CS_M3 |
NOTE: compatible with the BCM2835 system timer
