RTEMS
6.1
bsps
aarch64
raspberrypi
include
bsp
raspberrypi.h
1
9
10
* Copyright (c) 2022 Mohd Noor Aman
11
* Copyright (c) 2024 Ning Yang
12
13
* The license and distribution terms for this file may be
14
* found in the file LICENSE in this distribution or at
15
16
* http://www.rtems.org/license/LICENSE
17
18
19
20
21
#ifndef LIBBSP_AARCH64_RASPBERRYPI_RASPBERRYPI_4_H
22
#define LIBBSP_AARCH64_RASPBERRYPI_RASPBERRYPI_4_H
23
24
25
#include <bspopts.h>
26
#include <stdint.h>
27
bsp/utility.h
28
29
46
#define BCM2711_REG(x) (*(volatile uint64_t *)(x))
47
#define BCM2711_BIT(n) (1 << (n))
48
#define BCM2835_REG(addr) (*(volatile uint32_t*)(addr))
49
58
#define RPI_PERIPHERAL_BASE 0xFE000000
59
#define BASE_OFFSET 0xFE000000
60
#define RPI_PERIPHERAL_SIZE 0x01800000
61
67
#define BUS_TO_PHY(x) ((x) - BASE_OFFSET)
68
77
#define BCM2711_CLOCK_FREQ 250000000
78
79
#define BCM2711_TIMER_BASE (RPI_PERIPHERAL_BASE + 0xB400)
80
81
#define BCM2711_TIMER_LOD (BCM2711_TIMER_BASE + 0x00)
82
#define BCM2711_TIMER_VAL (BCM2711_TIMER_BASE + 0x04)
83
#define BCM2711_TIMER_CTL (BCM2711_TIMER_BASE + 0x08)
84
#define BCM2711_TIMER_CLI (BCM2711_TIMER_BASE + 0x0C)
85
#define BCM2711_TIMER_RIS (BCM2711_TIMER_BASE + 0x10)
86
#define BCM2711_TIMER_MIS (BCM2711_TIMER_BASE + 0x14)
87
#define BCM2711_TIMER_RLD (BCM2711_TIMER_BASE + 0x18)
88
#define BCM2711_TIMER_DIV (BCM2711_TIMER_BASE + 0x1C)
89
#define BCM2711_TIMER_CNT (BCM2711_TIMER_BASE + 0x20)
90
91
#define BCM2711_TIMER_PRESCALE 0xF9
92
101
#define BCM2711_PM_PASSWD_MAGIC 0x5a000000
102
103
#define BCM2711_PM_BASE (RPI_PERIPHERAL_BASE + 0x100000)
104
105
#define BCM2711_PM_GNRIC (BCM2711_PM_BASE + 0x00)
106
#define BCM2711_PM_GNRIC_POWUP 0x00000001
107
#define BCM2711_PM_GNRIC_POWOK 0x00000002
108
#define BCM2711_PM_GNRIC_ISPOW 0x00000004
109
#define BCM2711_PM_GNRIC_MEMREP 0x00000008
110
#define BCM2711_PM_GNRIC_MRDONE 0x00000010
111
#define BCM2711_PM_GNRIC_ISFUNC 0x00000020
112
#define BCM2711_PM_GNRIC_RSTN 0x00000fc0
113
#define BCM2711_PM_GNRIC_ENAB 0x00001000
114
#define BCM2711_PM_GNRIC_CFG 0x007f0000
115
116
#define BCM2711_PM_AUDIO (BCM2711_PM_BASE + 0x04)
117
#define BCM2711_PM_AUDIO_APSM 0x000fffff
118
#define BCM2711_PM_AUDIO_CTRLEN 0x00100000
119
#define BCM2711_PM_AUDIO_RSTN 0x00200000
120
121
#define BCM2711_PM_STATUS (BCM2711_PM_BASE + 0x18)
122
123
#define BCM2711_PM_RSTC (BCM2711_PM_BASE + 0x1c)
124
#define BCM2711_PM_RSTC_DRCFG 0x00000003
125
#define BCM2711_PM_RSTC_WRCFG 0x00000030
126
#define BCM2711_PM_RSTC_WRCFG_FULL 0x00000020
127
#define BCM2711_PM_RSTC_WRCFG_CLR 0xffffffcf
128
#define BCM2711_PM_RSTC_SRCFG 0x00000300
129
#define BCM2711_PM_RSTC_QRCFG 0x00003000
130
#define BCM2711_PM_RSTC_FRCFG 0x00030000
131
#define BCM2711_PM_RSTC_HRCFG 0x00300000
132
#define BCM2711_PM_RSTC_RESET 0x00000102
133
134
#define BCM2711_PM_RSTS (BCM2711_PM_BASE + 0x20)
135
#define BCM2711_PM_RSTS_HADDRQ 0x00000001
136
#define BCM2711_PM_RSTS_HADDRF 0x00000002
137
#define BCM2711_PM_RSTS_HADDRH 0x00000004
138
#define BCM2711_PM_RSTS_HADWRQ 0x00000010
139
#define BCM2711_PM_RSTS_HADWRF 0x0000002
140
#define BCM2711_PM_RSTS_HADWRH 0x00000040
141
#define BCM2711_PM_RSTS_HADSRQ 0x00000100
142
#define BCM2711_PM_RSTS_HADSRF 0x00000200
143
#define BCM2711_PM_RSTS_HADSRH 0x00000400
144
#define BCM2711_PM_RSTS_HADPOR 0x00001000
145
146
#define BCM2711_PM_WDOG (BCM2711_PM_BASE + 0x24)
147
#define BCM2711_PM_WDOG_MASK 0x000fffff
148
160
#define BCM2711_AUX_BASE (RPI_PERIPHERAL_BASE + 0x215000)
161
162
#define AUX_ENABLES (BCM2711_AUX_BASE + 0x04)
163
#define AUX_MU_IO_REG (BCM2711_AUX_BASE + 0x40)
164
#define AUX_MU_IER_REG (BCM2711_AUX_BASE + 0x44)
165
#define AUX_MU_IIR_REG (BCM2711_AUX_BASE + 0x48)
166
#define AUX_MU_LCR_REG (BCM2711_AUX_BASE + 0x4C)
167
#define AUX_MU_MCR_REG (BCM2711_AUX_BASE + 0x50)
168
#define AUX_MU_LSR_REG (BCM2711_AUX_BASE + 0x54)
169
#define AUX_MU_MSR_REG (BCM2711_AUX_BASE + 0x58)
170
#define AUX_MU_SCRATCH (BCM2711_AUX_BASE + 0x5C)
171
#define AUX_MU_CNTL_REG (BCM2711_AUX_BASE + 0x60)
172
#define AUX_MU_STAT_REG (BCM2711_AUX_BASE + 0x64)
173
#define AUX_MU_BAUD_REG (BCM2711_AUX_BASE + 0x68)
174
182
#define BCM2711_PL011_BASE (RPI_PERIPHERAL_BASE + 0x201000)
183
#define BCM2711_PL011_SIZE 0xc00
184
#define BCM2711_PL011_DEVICE_SIZE 0x200
185
186
#define BCM2711_UART0_BASE (BCM2711_PL011_BASE + 0x000)
187
#define BCM2711_UART0_SIZE BCM2711_PL011_DEVICE_SIZE
188
#define BCM2711_UART2_BASE (BCM2711_PL011_BASE + 0x400)
189
#define BCM2711_UART2_SIZE BCM2711_PL011_DEVICE_SIZE
190
#define BCM2711_UART3_BASE (BCM2711_PL011_BASE + 0x600)
191
#define BCM2711_UART3_SIZE BCM2711_PL011_DEVICE_SIZE
192
#define BCM2711_UART4_BASE (BCM2711_PL011_BASE + 0x800)
193
#define BCM2711_UART4_SIZE BCM2711_PL011_DEVICE_SIZE
194
#define BCM2711_UART5_BASE (BCM2711_PL011_BASE + 0xa00)
195
#define BCM2711_UART5_SIZE BCM2711_PL011_DEVICE_SIZE
209
#define BCM2711_GPU_TIMER_BASE (RPI_PERIPHERAL_BASE + 0x3000)
210
211
#define BCM2711_GPU_TIMER_CS (BCM2711_GPU_TIMER_BASE + 0x00)
212
#define BCM2711_GPU_TIMER_CS_M0 0x00000001
213
#define BCM2711_GPU_TIMER_CS_M1 0x00000002
214
#define BCM2711_GPU_TIMER_CS_M2 0x00000004
215
#define BCM2711_GPU_TIMER_CS_M3 0x00000008
216
#define BCM2711_GPU_TIMER_CLO (BCM2711_GPU_TIMER_BASE + 0x04)
217
#define BCM2711_GPU_TIMER_CHI (BCM2711_GPU_TIMER_BASE + 0x08)
218
#define BCM2711_GPU_TIMER_C0 (BCM2711_GPU_TIMER_BASE + 0x0C)
219
#define BCM2711_GPU_TIMER_C1 (BCM2711_GPU_TIMER_BASE + 0x10)
220
#define BCM2711_GPU_TIMER_C2 (BCM2711_GPU_TIMER_BASE + 0x14)
221
#define BCM2711_GPU_TIMER_C3 (BCM2711_GPU_TIMER_BASE + 0x18)
222
226
#define BCM2835_GPU_TIMER_CS_M3 BCM2711_GPU_TIMER_CS_M3
227
#define BCM2835_GPU_TIMER_C3 BCM2711_GPU_TIMER_C3
228
#define BCM2835_GPU_TIMER_CLO BCM2711_GPU_TIMER_CLO
229
#define BCM2835_GPU_TIMER_CS BCM2711_GPU_TIMER_CS
238
#define BCM2711_GPIO_BASE (RPI_PERIPHERAL_BASE + 0x200000)
239
#define BCM2711_GPIO_SIZE 0xf4
240
241
#define BCM2711_GPIO_PIN_COUNT 58
242
256
#define BCM2711_EMMC_BASE (RPI_PERIPHERAL_BASE + 0x300000)
257
266
#define BCM2711_SPI0_BASE (RPI_PERIPHERAL_BASE + 0x204000)
267
#define BCM2711_SPI3_BASE (RPI_PERIPHERAL_BASE + 0x204600)
268
#define BCM2711_SPI4_BASE (RPI_PERIPHERAL_BASE + 0x204800)
269
#define BCM2711_SPI5_BASE (RPI_PERIPHERAL_BASE + 0x204A00)
270
#define BCM2711_SPI6_BASE (RPI_PERIPHERAL_BASE + 0x204C00)
271
280
#define BCM2711_MBOX_BASE (RPI_PERIPHERAL_BASE+0xB880)
281
282
#define BCM2711_MBOX_READ (BCM2711_MBOX_BASE+0x00)
283
#define BCM2711_MBOX_PEEK (BCM2711_MBOX_BASE+0x10)
284
#define BCM2711_MBOX_SENDER (BCM2711_MBOX_BASE+0x14)
285
#define BCM2711_MBOX_STATUS (BCM2711_MBOX_BASE+0x18)
286
#define BCM2711_MBOX_WRITE (BCM2711_MBOX_BASE+0x20)
287
#define BCM2711_MBOX_CONFIG (BCM2711_MBOX_BASE+0x1C)
288
289
#define BCM2711_MBOX_RESPONSE 0x80000000
290
#define BCM2711_MBOX_FULL 0x80000000
291
#define BCM2711_MBOX_EMPTY 0x40000000
292
301
/* Power Manager channel */
302
#define BCM2711_MBOX_CHANNEL_PM 0
303
/* Framebuffer channel */
304
#define BCM2711_MBOX_CHANNEL_FB 1
305
/* Virtual UART channel */
306
#define BCM2711_MBOX_CHANNEL_VUART 2
307
/* VCHIQ channel */
308
#define BCM2711_MBOX_CHANNEL_VCHIQ 3
309
/* LEDs channel */
310
#define BCM2711_MBOX_CHANNEL_LED 4
311
/* Button channel */
312
#define BCM2711_MBOX_CHANNEL_BUTTON 5
313
/* Touch screen channel */
314
#define BCM2711_MBOX_CHANNEL_TOUCHS 6
315
316
#define BCM2711_MBOX_CHANNEL_COUNT 7
317
/* Property tags (ARM <-> VC) channel */
318
#define BCM2711_MBOX_CHANNEL_PROP_AVC 8
319
/* Property tags (VC <-> ARM) channel */
320
#define BCM2711_MBOX_CHANNEL_PROP_VCA 9
321
332
/* Timers interrupt control registers */
333
#define BCM2711_CORE0_TIMER_IRQ_CTRL_BASE 0xFF800040
334
#define BCM2711_CORE1_TIMER_IRQ_CTRL_BASE 0xFF800044
335
#define BCM2711_CORE2_TIMER_IRQ_CTRL_BASE 0xFF800048
336
#define BCM2711_CORE3_TIMER_IRQ_CTRL_BASE 0xFF80004C
337
338
#define BCM2711_CORE_TIMER_IRQ_CTRL(cpuidx) \
339
(BCM2711_CORE0_TIMER_IRQ_CTRL_BASE + 0x4 * (cpuidx))
340
341
348
#define BCM2711_LOCAL_REGS_BASE 0x4C0000000
349
#define BCM2711_LOCAL_REGS_SIZE 0x100
350
351
#define BCM2711_LOCAL_ARM_CONTROL (BCM2711_LOCAL_REGS_BASE + 0x00)
352
#define BCM2711_LOCAL_CORE_IRQ_CONTROL (BCM2711_LOCAL_REGS_BASE + 0x0c)
353
#define BCM2711_LOCAL_PMU_CONTROL_SET (BCM2711_LOCAL_REGS_BASE + 0x10)
354
#define BCM2711_LOCAL_PMU_CONTROL_CLR (BCM2711_LOCAL_REGS_BASE + 0x14)
355
#define BCM2711_LOCAL_PERI_IRQ_ROUTE0 (BCM2711_LOCAL_REGS_BASE + 0x24)
356
#define BCM2711_LOCAL_AXI_QUIET_TIME (BCM2711_LOCAL_REGS_BASE + 0x30)
357
#define BCM2711_LOCAL_LOCAL_TIMER_CONTROL (BCM2711_LOCAL_REGS_BASE + 0x34)
358
#define BCM2711_LOCAL_LOCAL_TIMER_IRQ (BCM2711_LOCAL_REGS_BASE + 0x38)
359
360
#define BCM2711_LOCAL_TIMER_CNTRL0 (BCM2711_LOCAL_REGS_BASE + 0x40)
361
#define BCM2711_LOCAL_TIMER_CNTRL1 (BCM2711_LOCAL_REGS_BASE + 0x44)
362
#define BCM2711_LOCAL_TIMER_CNTRL2 (BCM2711_LOCAL_REGS_BASE + 0x48)
363
#define BCM2711_LOCAL_TIMER_CNTRL3 (BCM2711_LOCAL_REGS_BASE + 0x4c)
364
365
#define BCM2711_LOCAL_MAILBOX_CNTRL0 (BCM2711_LOCAL_REGS_BASE + 0x50)
366
#define BCM2711_LOCAL_MAILBOX_CNTRL1 (BCM2711_LOCAL_REGS_BASE + 0x54)
367
#define BCM2711_LOCAL_MAILBOX_CNTRL2 (BCM2711_LOCAL_REGS_BASE + 0x58)
368
#define BCM2711_LOCAL_MAILBOX_CNTRL3 (BCM2711_LOCAL_REGS_BASE + 0x5c)
369
370
#define BCM2711_LOCAL_IRQ_SOURCE0 (BCM2711_LOCAL_REGS_BASE + 0x60)
371
#define BCM2711_LOCAL_IRQ_SOURCE1 (BCM2711_LOCAL_REGS_BASE + 0x64)
372
#define BCM2711_LOCAL_IRQ_SOURCE2 (BCM2711_LOCAL_REGS_BASE + 0x68)
373
#define BCM2711_LOCAL_IRQ_SOURCE3 (BCM2711_LOCAL_REGS_BASE + 0x6c)
374
375
#define BCM2711_LOCAL_FIQ_SOURCE0 (BCM2711_LOCAL_REGS_BASE + 0x70)
376
#define BCM2711_LOCAL_FIQ_SOURCE1 (BCM2711_LOCAL_REGS_BASE + 0x74)
377
#define BCM2711_LOCAL_FIQ_SOURCE2 (BCM2711_LOCAL_REGS_BASE + 0x78)
378
#define BCM2711_LOCAL_FIQ_SOURCE3 (BCM2711_LOCAL_REGS_BASE + 0x7c)
379
388
#define BCM2711_MAILBOX_00_WRITE_SET_BASE 0x4C000080
389
#define BCM2711_MAILBOX_01_WRITE_SET_BASE 0x4C000084
390
#define BCM2711_MAILBOX_02_WRITE_SET_BASE 0x4C000088
391
#define BCM2711_MAILBOX_03_WRITE_SET_BASE 0x4C00008C
392
#define BCM2711_MAILBOX_04_WRITE_SET_BASE 0x4C000090
393
#define BCM2711_MAILBOX_05_WRITE_SET_BASE 0x4C000094
394
#define BCM2711_MAILBOX_06_WRITE_SET_BASE 0x4C000098
395
#define BCM2711_MAILBOX_07_WRITE_SET_BASE 0x4C00009C
396
#define BCM2711_MAILBOX_08_WRITE_SET_BASE 0x4C0000A0
397
#define BCM2711_MAILBOX_09_WRITE_SET_BASE 0x4C0000A4
398
#define BCM2711_MAILBOX_10_WRITE_SET_BASE 0x4C0000A8
399
#define BCM2711_MAILBOX_11_WRITE_SET_BASE 0x4C0000AC
400
#define BCM2711_MAILBOX_12_WRITE_SET_BASE 0x4C0000B0
401
#define BCM2711_MAILBOX_13_WRITE_SET_BASE 0x4C0000B4
402
#define BCM2711_MAILBOX_14_WRITE_SET_BASE 0x4C0000B8
403
#define BCM2711_MAILBOX_15_WRITE_SET_BASE 0x4C0000BC
404
405
#define BCM2711_MAILBOX_00_READ_CLEAR_BASE 0x4C0000C0
406
#define BCM2711_MAILBOX_01_READ_CLEAR_BASE 0x4C0000C4
407
#define BCM2711_MAILBOX_02_READ_CLEAR_BASE 0x4C0000C8
408
#define BCM2711_MAILBOX_03_READ_CLEAR_BASE 0x4C0000CC
409
#define BCM2711_MAILBOX_04_READ_CLEAR_BASE 0x4C0000D0
410
#define BCM2711_MAILBOX_05_READ_CLEAR_BASE 0x4C0000D4
411
#define BCM2711_MAILBOX_06_READ_CLEAR_BASE 0x4C0000D8
412
#define BCM2711_MAILBOX_07_READ_CLEAR_BASE 0x4C0000DC
413
#define BCM2711_MAILBOX_08_READ_CLEAR_BASE 0x4C0000E0
414
#define BCM2711_MAILBOX_09_READ_CLEAR_BASE 0x4C0000E4
415
#define BCM2711_MAILBOX_10_READ_CLEAR_BASE 0x4C0000E8
416
#define BCM2711_MAILBOX_11_READ_CLEAR_BASE 0x4C0000EC
417
#define BCM2711_MAILBOX_12_READ_CLEAR_BASE 0x4C0000F0
418
#define BCM2711_MAILBOX_13_READ_CLEAR_BASE 0x4C0000F4
419
#define BCM2711_MAILBOX_14_READ_CLEAR_BASE 0x4C0000F8
420
#define BCM2711_MAILBOX_15_READ_CLEAR_BASE 0x4C0000FC
421
422
429
#define BCM2711_ARMC_REGS_BASE (RPI_PERIPHERAL_BASE + 0xB200)
430
#define BCM2711_ARMC_REGS_SIZE 0x200
431
432
#define BCM2711_ARMC_IRQ0_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x00)
433
#define BCM2711_ARMC_IRQ0_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x04)
434
#define BCM2711_ARMC_IRQ0_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x08)
435
#define BCM2711_ARMC_IRQ0_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0x10)
436
#define BCM2711_ARMC_IRQ0_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0x14)
437
#define BCM2711_ARMC_IRQ0_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0x18)
438
#define BCM2711_ARMC_IRQ0_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x20)
439
#define BCM2711_ARMC_IRQ0_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x24)
440
#define BCM2711_ARMC_IRQ0_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x28)
441
442
#define BCM2711_ARMC_IRQ_STATUS0 (BCM2711_ARMC_REGS_BASE + 0x30)
443
#define BCM2711_ARMC_IRQ_STATUS1 (BCM2711_ARMC_REGS_BASE + 0x34)
444
#define BCM2711_ARMC_IRQ_STATUS2 (BCM2711_ARMC_REGS_BASE + 0x38)
445
446
#define BCM2711_ARMC_IRQ1_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x40)
447
#define BCM2711_ARMC_IRQ1_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x44)
448
#define BCM2711_ARMC_IRQ1_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x48)
449
#define BCM2711_ARMC_IRQ1_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0x50)
450
#define BCM2711_ARMC_IRQ1_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0x54)
451
#define BCM2711_ARMC_IRQ1_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0x58)
452
#define BCM2711_ARMC_IRQ1_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x60)
453
#define BCM2711_ARMC_IRQ1_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x64)
454
#define BCM2711_ARMC_IRQ1_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x68)
455
456
#define BCM2711_ARMC_IRQ2_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x80)
457
#define BCM2711_ARMC_IRQ2_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x84)
458
#define BCM2711_ARMC_IRQ2_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x88)
459
#define BCM2711_ARMC_IRQ2_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0x90)
460
#define BCM2711_ARMC_IRQ2_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0x94)
461
#define BCM2711_ARMC_IRQ2_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0x98)
462
#define BCM2711_ARMC_IRQ2_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0xA0)
463
#define BCM2711_ARMC_IRQ2_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0xA4)
464
#define BCM2711_ARMC_IRQ2_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0xA8)
465
466
#define BCM2711_ARMC_IRQ3_PENDING0 (BCM2711_ARMC_REGS_BASE + 0xC0)
467
#define BCM2711_ARMC_IRQ3_PENDING1 (BCM2711_ARMC_REGS_BASE + 0xC4)
468
#define BCM2711_ARMC_IRQ3_PENDING2 (BCM2711_ARMC_REGS_BASE + 0xC8)
469
#define BCM2711_ARMC_IRQ3_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0xD0)
470
#define BCM2711_ARMC_IRQ3_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0xD4)
471
#define BCM2711_ARMC_IRQ3_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0xD8)
472
#define BCM2711_ARMC_IRQ3_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0xE0)
473
#define BCM2711_ARMC_IRQ3_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0xE4)
474
#define BCM2711_ARMC_IRQ3_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0xE8)
475
476
477
478
#define BCM2711_ARMC_FIQ0_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x100)
479
#define BCM2711_ARMC_FIQ0_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x104)
480
#define BCM2711_ARMC_FIQ0_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x108)
481
#define BCM2711_ARMC_FIQ0_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0x110)
482
#define BCM2711_ARMC_FIQ0_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0x114)
483
#define BCM2711_ARMC_FIQ0_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0x118)
484
#define BCM2711_ARMC_FIQ0_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x120)
485
#define BCM2711_ARMC_FIQ0_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x124)
486
#define BCM2711_ARMC_FIQ0_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x128)
487
488
#define BCM2711_ARMC_FIQ1_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x140)
489
#define BCM2711_ARMC_FIQ1_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x144)
490
#define BCM2711_ARMC_FIQ1_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x148)
491
#define BCM2711_ARMC_FIQ1_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0x150)
492
#define BCM2711_ARMC_FIQ1_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0x154)
493
#define BCM2711_ARMC_FIQ1_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0x158)
494
#define BCM2711_ARMC_FIQ1_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x160)
495
#define BCM2711_ARMC_FIQ1_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x164)
496
#define BCM2711_ARMC_FIQ1_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x168)
497
498
#define BCM2711_ARMC_FIQ2_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x180)
499
#define BCM2711_ARMC_FIQ2_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x184)
500
#define BCM2711_ARMC_FIQ2_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x188)
501
#define BCM2711_ARMC_FIQ2_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0x190)
502
#define BCM2711_ARMC_FIQ2_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0x194)
503
#define BCM2711_ARMC_FIQ2_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0x198)
504
#define BCM2711_ARMC_FIQ2_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x1A0)
505
#define BCM2711_ARMC_FIQ2_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x1A4)
506
#define BCM2711_ARMC_FIQ2_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x1A8)
507
508
#define BCM2711_ARMC_FIQ3_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x1C0)
509
#define BCM2711_ARMC_FIQ3_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x1C4)
510
#define BCM2711_ARMC_FIQ3_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x1C8)
511
#define BCM2711_ARMC_FIQ3_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0x1D0)
512
#define BCM2711_ARMC_FIQ3_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0x1D4)
513
#define BCM2711_ARMC_FIQ3_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0x1D8)
514
#define BCM2711_ARMC_FIQ3_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x1E0)
515
#define BCM2711_ARMC_FIQ3_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x1E4)
516
#define BCM2711_ARMC_FIQ3_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x1E8)
517
518
#define BCM2711_ARMC_SWIRQ_SET (BCM2711_ARMC_REGS_BASE + 0x1F0)
519
#define BCM2711_ARMC_SWIRQ_CLEAR (BCM2711_ARMC_REGS_BASE + 0x1F4)
520
521
522
523
524
527
#endif
/* LIBBSP_ARM_RASPBERRYPI_RASPBERRYPI_H */
utility.h
This header file provides utility macros for BSPs.
