RTEMS 5.2
#include <rtems-rfs-inode.h>
Data Fields | |
| rtems_chain_node | link |
| rtems_rfs_ino | ino |
| rtems_rfs_inode * | node |
| rtems_rfs_buffer_handle | buffer |
| rtems_rfs_buffer_block | block |
| int | offset |
| int | loads |
RFS Inode Handle.
| rtems_rfs_buffer_block _rtems_rfs_inode_handle::block |
The block number that holds the inode.
| rtems_rfs_buffer_handle _rtems_rfs_inode_handle::buffer |
The buffer that contains this inode.
| rtems_rfs_ino _rtems_rfs_inode_handle::ino |
The ino for this handle.
| rtems_chain_node _rtems_rfs_inode_handle::link |
Handles can be linked as a list for easy processing.
| int _rtems_rfs_inode_handle::loads |
Number of load requests.
| rtems_rfs_inode* _rtems_rfs_inode_handle::node |
The pointer to the inode.
| int _rtems_rfs_inode_handle::offset |
The offset into the block for the inode.
