RTEMS 5.2
rtems-rfs-inode.h
1
13/*
14 * COPYRIGHT (c) 2010 Chris Johns <chrisj@rtems.org>
15 *
16 * The license and distribution terms for this file may be
17 * found in the file LICENSE in this distribution or at
18 * http://www.rtems.org/license/LICENSE.
19 */
20
21
22#if !defined (_RTEMS_RFS_INODE_H_)
23#define _RTEMS_RFS_INODE_H_
24
25#include <sys/stat.h>
26
29
33#define RTEMS_RFS_S_ISUID S_ISUID
34#define RTEMS_RFS_S_ISGID S_ISGID
35#define RTEMS_RFS_S_ISVTX S_ISVTX
36#define RTEMS_RFS_S_IREAD S_IREAD
37#define RTEMS_RFS_S_IWRITE S_IWRITE
38#define RTEMS_RFS_S_IEXEC S_IEXEC
39#define RTEMS_RFS_S_ENFMT S_ENFMT
40#define RTEMS_RFS_S_IFMT S_IFMT
41#define RTEMS_RFS_S_IFDIR S_IFDIR
42#define RTEMS_RFS_S_IFCHR S_IFCHR
43#define RTEMS_RFS_S_IFBLK S_IFBLK
44#define RTEMS_RFS_S_IFREG S_IFREG
45#define RTEMS_RFS_S_IFLNK S_IFLNK
46#define RTEMS_RFS_S_IFSOCK S_IFSOCK
47#define RTEMS_RFS_S_IFIFO S_IFIFO
48#define RTEMS_RFS_S_IRWXU S_IRWXU
49#define RTEMS_RFS_S_IRUSR S_IRUSR
50#define RTEMS_RFS_S_IWUSR S_IWUSR
51#define RTEMS_RFS_S_IXUSR S_IXUSR
52#define RTEMS_RFS_S_IRWXG S_IRWXG
53#define RTEMS_RFS_S_IRGRP S_IRGRP
54#define RTEMS_RFS_S_IWGRP S_IWGRP
55#define RTEMS_RFS_S_IXGRP S_IXGRP
56#define RTEMS_RFS_S_IRWXO S_IRWXO
57#define RTEMS_RFS_S_IROTH S_IROTH
58#define RTEMS_RFS_S_IWOTH S_IWOTH
59#define RTEMS_RFS_S_IXOTH S_IXOTH
61#define RTEMS_RFS_S_ISBLK(m) S_ISBLK(m)
62#define RTEMS_RFS_S_ISCHR(m) S_ISCHR(m)
63#define RTEMS_RFS_S_ISDIR(m) S_ISDIR(m)
64#define RTEMS_RFS_S_ISFIFO(m) S_ISFIFO(m)
65#define RTEMS_RFS_S_ISREG(m) S_ISREG(m)
66#define RTEMS_RFS_S_ISLNK(m) S_ISLNK(m)
67#define RTEMS_RFS_S_ISSOCK(m) S_ISSOCK(m)
68
72#define RTEMS_RFS_S_SYMLINK \
73 RTEMS_RFS_S_IFLNK | RTEMS_RFS_S_IRWXU | RTEMS_RFS_S_IRWXG | RTEMS_RFS_S_IRWXO
74
78typedef uint32_t rtems_rfs_ino;
79
83typedef uint32_t rtems_rfs_time;
84
89typedef uint32_t rtems_rfs_inode_block;
90
94#define RTEMS_RFS_INODE_DATA_NAME_SIZE \
95 (RTEMS_RFS_INODE_BLOCKS * sizeof (rtems_rfs_inode_block))
96
100typedef struct _rtems_rfs_inode
101{
105 uint16_t links;
106
110 uint16_t mode;
111
115 uint32_t owner;
116
120 uint16_t flags;
121
125 uint16_t block_offset;
126
130 uint32_t block_count;
131
136
141
146
154 union
155 {
157 uint8_t name[RTEMS_RFS_INODE_DATA_NAME_SIZE];
159
165
170
172
176#define RTEMS_RFS_INODE_SIZE (sizeof (rtems_rfs_inode))
177
182{
187
192
197
202
207
212
216 int loads;
217
219
223#define rtems_rfs_inode_is_loaded(_h) ((_h)->node)
224
228#define rtems_rfs_inode_ino(_h) ((_h)->ino)
229
237static inline uint16_t
238rtems_rfs_inode_get_links (rtems_rfs_inode_handle* handle)
239{
240 uint16_t links;
241 links = rtems_rfs_read_u16 (&handle->node->links);
242 if (links == 0xffff)
243 links = 0;
244 return links;
245}
246
253static inline void
254rtems_rfs_inode_set_links (rtems_rfs_inode_handle* handle, uint16_t links)
255{
256 rtems_rfs_write_u16 (&handle->node->links, links);
258}
259
267static inline uint16_t
268rtems_rfs_inode_get_flags (rtems_rfs_inode_handle* handle)
269{
270 return rtems_rfs_read_u16 (&handle->node->flags);
271}
272
279static inline void
280rtems_rfs_inode_set_flags (rtems_rfs_inode_handle* handle, uint16_t flags)
281{
282 rtems_rfs_write_u16 (&handle->node->flags, flags);
284}
285
293static inline uint16_t
294rtems_rfs_inode_get_mode (rtems_rfs_inode_handle* handle)
295{
296 return rtems_rfs_read_u16 (&handle->node->mode);
297}
298
305static inline void
306rtems_rfs_inode_set_mode (rtems_rfs_inode_handle* handle, uint16_t mode)
307{
308 rtems_rfs_write_u16 (&handle->node->mode, mode);
310}
311
319static inline uint16_t
320rtems_rfs_inode_get_uid (rtems_rfs_inode_handle* handle)
321{
322 return rtems_rfs_read_u32 (&handle->node->owner) & 0xffff;
323}
324
332static inline uint16_t
333rtems_rfs_inode_get_gid (rtems_rfs_inode_handle* handle)
334{
335 return (rtems_rfs_read_u32 (&handle->node->owner) >> 16) & 0xffff;
336}
337
345static inline void
346rtems_rfs_inode_set_uid_gid (rtems_rfs_inode_handle* handle,
347 uint16_t uid, uint16_t gid)
348{
349 rtems_rfs_write_u32 (&handle->node->owner, (((uint32_t) gid) << 16) | uid);
351}
352
360static inline uint16_t
361rtems_rfs_inode_get_block_offset (rtems_rfs_inode_handle* handle)
362{
363 return rtems_rfs_read_u16 (&handle->node->block_offset);
364}
365
372static inline void
373rtems_rfs_inode_set_block_offset (rtems_rfs_inode_handle* handle,
374 uint16_t block_offset)
375{
376 rtems_rfs_write_u16 (&handle->node->block_offset, block_offset);
378}
379
387static inline uint32_t
388rtems_rfs_inode_get_block_count (rtems_rfs_inode_handle* handle)
389{
390 return rtems_rfs_read_u32 (&handle->node->block_count);
391}
392
399static inline void
400rtems_rfs_inode_set_block_count (rtems_rfs_inode_handle* handle, uint32_t block_count)
401{
402 rtems_rfs_write_u32 (&handle->node->block_count, block_count);
404}
405
413static inline rtems_rfs_time
414rtems_rfs_inode_get_atime (rtems_rfs_inode_handle* handle)
415{
416 return rtems_rfs_read_u32 (&handle->node->atime);
417}
418
425static inline void
426rtems_rfs_inode_set_atime (rtems_rfs_inode_handle* handle,
427 rtems_rfs_time atime)
428{
429 rtems_rfs_write_u32 (&handle->node->atime, atime);
431}
432
440static inline rtems_rfs_time
441rtems_rfs_inode_get_mtime (rtems_rfs_inode_handle* handle)
442{
443 return rtems_rfs_read_u32 (&handle->node->mtime);
444}
445
452static inline void
453rtems_rfs_inode_set_mtime (rtems_rfs_inode_handle* handle,
454 rtems_rfs_time mtime)
455{
456 rtems_rfs_write_u32 (&handle->node->mtime, mtime);
458}
459
467static inline rtems_rfs_time
468rtems_rfs_inode_get_ctime (rtems_rfs_inode_handle* handle)
469{
470 return rtems_rfs_read_u32 (&handle->node->ctime);
471}
472
479static inline void
480rtems_rfs_inode_set_ctime (rtems_rfs_inode_handle* handle,
481 rtems_rfs_time ctime)
482{
483 rtems_rfs_write_u32 (&handle->node->ctime, ctime);
485}
486
495static inline uint32_t
496rtems_rfs_inode_get_block (rtems_rfs_inode_handle* handle, int block)
497{
498 return rtems_rfs_read_u32 (&handle->node->data.blocks[block]);
499}
500
508static inline void
509rtems_rfs_inode_set_block (rtems_rfs_inode_handle* handle, int block, uint32_t bno)
510{
511 rtems_rfs_write_u32 (&handle->node->data.blocks[block], bno);
513}
514
522static inline uint32_t
523rtems_rfs_inode_get_last_map_block (rtems_rfs_inode_handle* handle)
524{
525 return rtems_rfs_read_u32 (&handle->node->last_map_block);
526}
527
534static inline void
535rtems_rfs_inode_set_last_map_block (rtems_rfs_inode_handle* handle, uint32_t last_map_block)
536{
537 rtems_rfs_write_u32 (&handle->node->last_map_block, last_map_block);
539}
540
549static inline uint32_t
550rtems_rfs_inode_get_last_data_block (rtems_rfs_inode_handle* handle)
551{
552 return rtems_rfs_read_u32 (&handle->node->last_data_block);
553}
554
561static inline void
562rtems_rfs_inode_set_last_data_block (rtems_rfs_inode_handle* handle, uint32_t last_data_block)
563{
564 rtems_rfs_write_u32 (&handle->node->last_data_block, last_data_block);
566}
567
579 rtems_rfs_ino* ino);
580
591 rtems_rfs_ino ino);
592
607 rtems_rfs_ino ino,
609 bool load);
610
621 rtems_rfs_inode_handle* handle);
622
633 rtems_rfs_inode_handle* handle);
634
647 bool update_ctime);
648
660 rtems_rfs_ino parent,
661 const char* name,
662 size_t length,
663 uint16_t mode,
664 uint16_t links,
665 uid_t uid,
666 gid_t gid,
667 rtems_rfs_ino* ino);
668
680 rtems_rfs_inode_handle* handle);
681
695 uint16_t links,
696 uint16_t mode,
697 uid_t uid,
698 gid_t gid);
699
713 bool atime,
714 bool mtime);
715
725 rtems_rfs_inode_handle* handle);
726
727#endif
728
int32_t rtems_rfs_bitmap_bit
Definition: rtems-rfs-bitmaps.h:84
uint32_t rtems_rfs_buffer_block
Definition: rtems-rfs-buffer.h:62
#define rtems_rfs_buffer_mark_dirty(_h)
Definition: rtems-rfs-buffer.h:144
RTEMS File System Data.
#define rtems_rfs_write_u32(_d, _v)
Definition: rtems-rfs-data.h:81
#define rtems_rfs_read_u16(_d)
Definition: rtems-rfs-data.h:50
#define rtems_rfs_write_u16(_d, _v)
Definition: rtems-rfs-data.h:72
#define rtems_rfs_read_u32(_d)
Definition: rtems-rfs-data.h:57
#define RTEMS_RFS_INODE_BLOCKS
Definition: rtems-rfs-file-system.h:67
uint64_t rtems_rfs_pos
Definition: rtems-rfs-file-system.h:90
struct _rtems_rfs_inode_handle rtems_rfs_inode_handle
int rtems_rfs_inode_alloc(rtems_rfs_file_system *fs, rtems_rfs_bitmap_bit goal, rtems_rfs_ino *ino)
Definition: rtems-rfs-inode.c:32
int rtems_rfs_inode_open(rtems_rfs_file_system *fs, rtems_rfs_ino ino, rtems_rfs_inode_handle *handle, bool load)
Definition: rtems-rfs-inode.c:53
int rtems_rfs_inode_delete(rtems_rfs_file_system *fs, rtems_rfs_inode_handle *handle)
Definition: rtems-rfs-inode.c:320
int rtems_rfs_inode_close(rtems_rfs_file_system *fs, rtems_rfs_inode_handle *handle)
Definition: rtems-rfs-inode.c:91
int rtems_rfs_inode_free(rtems_rfs_file_system *fs, rtems_rfs_ino ino)
Definition: rtems-rfs-inode.c:44
Definition: rtems-rfs-inode.h:83
int rtems_rfs_inode_initialise(rtems_rfs_inode_handle *handle, uint16_t links, uint16_t mode, uid_t uid, gid_t gid)
Definition: rtems-rfs-inode.c:373
int rtems_rfs_inode_create(rtems_rfs_file_system *fs, rtems_rfs_ino parent, const char *name, size_t length, uint16_t mode, uint16_t links, uid_t uid, gid_t gid, rtems_rfs_ino *ino)
Definition: rtems-rfs-inode.c:179
Definition: rtems-rfs-inode.h:89
Definition: rtems-rfs-inode.h:94
struct _rtems_rfs_inode rtems_rfs_inode
int rtems_rfs_inode_load(rtems_rfs_file_system *fs, rtems_rfs_inode_handle *handle)
Definition: rtems-rfs-inode.c:114
rtems_rfs_pos rtems_rfs_inode_get_size(rtems_rfs_file_system *fs, rtems_rfs_inode_handle *handle)
Definition: rtems-rfs-inode.c:410
int rtems_rfs_inode_unload(rtems_rfs_file_system *fs, rtems_rfs_inode_handle *handle, bool update_ctime)
Definition: rtems-rfs-inode.c:145
int rtems_rfs_inode_time_stamp_now(rtems_rfs_inode_handle *handle, bool atime, bool mtime)
Definition: rtems-rfs-inode.c:394
Definition: rtems-rfs-inode.h:78
Definition: chain.h:68
Definition: rtems-rfs-file-system.h:116
Definition: rtems-rfs-inode.h:182
rtems_rfs_buffer_block block
Definition: rtems-rfs-inode.h:206
int offset
Definition: rtems-rfs-inode.h:211
int loads
Definition: rtems-rfs-inode.h:216
rtems_rfs_ino ino
Definition: rtems-rfs-inode.h:191
rtems_rfs_buffer_handle buffer
Definition: rtems-rfs-inode.h:201
rtems_chain_node link
Definition: rtems-rfs-inode.h:186
rtems_rfs_inode * node
Definition: rtems-rfs-inode.h:196
Definition: rtems-rfs-inode.h:101
uint16_t mode
Definition: rtems-rfs-inode.h:110
Definition: rtems-rfs-inode.h:130
Definition: rtems-rfs-inode.h:125
union _rtems_rfs_inode::@3973 data
uint16_t links
Definition: rtems-rfs-inode.h:105
uint16_t flags
Definition: rtems-rfs-inode.h:120
rtems_rfs_inode_block last_map_block
Definition: rtems-rfs-inode.h:164
uint32_t owner
Definition: rtems-rfs-inode.h:115
Definition: rtems-rfs-inode.h:140
Definition: rtems-rfs-inode.h:145
rtems_rfs_inode_block last_data_block
Definition: rtems-rfs-inode.h:169
Definition: rtems-rfs-inode.h:135
Definition: rtems-rfs-buffer.h:92
