RTEMS 5.2
Priority_bit_map_Control Struct Reference
Priority_bit_map_Word major_bit_map
 Each sixteen bit entry in this word is associated with one of the sixteen entries in the bit map.
Priority_bit_map_Word bit_map [16]
 Each bit in the bit map indicates whether or not there are threads ready at a particular priority. More...
Field Documentation
◆ bit_map
Priority_bit_map_Word Priority_bit_map_Control::bit_map[16]
The mapping of individual priority levels to particular bits is processor dependent as is the value of each bit used to indicate that threads are ready at that priority.
