RTEMS 5.2
prioritybitmap.h
1
12/*
13 * COPYRIGHT (c) 1989-2010.
14 * On-Line Applications Research Corporation (OAR).
15 *
16 * The license and distribution terms for this file may be
17 * found in the file LICENSE in this distribution or at
18 * http://www.rtems.org/license/LICENSE.
19 */
20
21#ifndef _RTEMS_SCORE_PRIORITYBITMAP_H
22#define _RTEMS_SCORE_PRIORITYBITMAP_H
23
24#include <rtems/score/cpu.h>
25
26#ifdef __cplusplus
27extern "C" {
28#endif
29
40typedef uint16_t Priority_bit_map_Word;
41
42typedef struct {
47 Priority_bit_map_Word major_bit_map;
48
57 Priority_bit_map_Word bit_map[ 16 ];
59
64typedef struct {
66 Priority_bit_map_Word *minor;
68 Priority_bit_map_Word ready_major;
70 Priority_bit_map_Word ready_minor;
72 Priority_bit_map_Word block_major;
74 Priority_bit_map_Word block_minor;
76
79#ifdef __cplusplus
80}
81#endif
82
83#endif
84/* end of include file */
Definition: prioritybitmap.h:42
Each sixteen bit entry in this word is associated with one of the sixteen entries in the bit map.
Definition: prioritybitmap.h:47
Definition: prioritybitmap.h:64
Definition: prioritybitmap.h:72
Definition: prioritybitmap.h:74
Definition: prioritybitmap.h:68
Definition: prioritybitmap.h:70
Priority_bit_map_Word * minor
Definition: prioritybitmap.h:66
