RTEMS 5.2
#include <mppkt.h>
Data Fields | |
| MP_packet_Classes | the_class |
| Objects_Id | id |
| Objects_Id | source_tid |
| uint32_t | source_priority |
| uint32_t | return_code |
| uint32_t | length |
| uint32_t | to_convert |
| Watchdog_Interval | timeout |
The following record contains the prefix for every packet passed between nodes in an MP system.
| Objects_Id MP_packet_Prefix::id |
This field is the id of the object to be acted upon.
| uint32_t MP_packet_Prefix::length |
This field is the length of the data following the prefix.
| uint32_t MP_packet_Prefix::return_code |
This field is where the status of the operation will be returned.
| uint32_t MP_packet_Prefix::source_priority |
This field is the priority of the originating thread.
| Objects_Id MP_packet_Prefix::source_tid |
This field is the ID of the originating thread.
| MP_packet_Classes MP_packet_Prefix::the_class |
This field indicates the API class of the operation being performed.
| Watchdog_Interval MP_packet_Prefix::timeout |
This field is the requested timeout for this operation.
| uint32_t MP_packet_Prefix::to_convert |
This field is the length of the data which required network conversion.
