RTEMS 5.2
INTC_tag Struct Reference
union {
   uint32_t   R
   struct {
      uint32_t   __pad0__:18
      uint32_t   VTES_PRC1:1
      uint32_t   __pad1__:4
      uint32_t   HVEN_PRC1:1
      uint32_t   __pad2__:2
      uint32_t   VTES:1
      uint32_t   __pad3__:4
      uint32_t   HVEN:1
   }   B
MCR
int32_t INTC_reserved1
union {
   uint32_t   R
   struct {
      uint32_t   __pad0__:28
      uint32_t   PRI:4
   }   B
CPR
union {
   uint32_t   R
   struct {
      uint32_t   PRI:4
   }   B
CPR_PRC1
union {
   uint32_t   R
   struct {
      uint32_t   VTBA:21
      uint32_t   INTVEC:9
      uint32_t   __pad0__:2
   }   B
IACKR
union {
   uint32_t   R
   struct {
      uint32_t   VTBA_PRC1:21
      uint32_t   INTVEC_PRC1:9
      uint32_t   __pad0__:2
   }   B
IACKR_PRC1
union {
   uint32_t   R
   struct {
      uint32_t   __pad0__:32
   }   B
EOIR
union {
   uint32_t   R
   struct {
   }   B
EOIR_PRC1
union {
   uint8_t   R
   struct {
      uint8_t   __pad0__:6
      uint8_t   SET:1
      uint8_t   CLR:1
   }   B
SSCIR [8]
uint32_t intc_reserved2 [6]
union {
   uint8_t   R
   struct {
      uint8_t   PRC_SEL:2
      uint8_t   __pad0__:2
      uint8_t   PRI:4
   }   B
PSR [294]
union {
   uint32_t   R
   struct {
      uint32_t   __pad0__:26
      uint32_t   VTES:1
      uint32_t   __pad1__:4
      uint32_t   HVEN:1
   }   B
MCR
int32_t INTC_reserved00
union {
   uint32_t   R
   struct {
      uint32_t   PRI:4
   }   B
CPR
uint32_t intc_reserved1
union {
   uint32_t   R
   struct {
      uint32_t   VTBA:21
      uint32_t   INTVEC:9
      uint32_t   __pad0__:2
   }   B
IACKR
union {
   uint32_t   R
   struct {
   }   B
EOIR
uint32_t intc_reserved3
union {
   uint8_t   R
   struct {
      uint8_t   __pad0__:6
      uint8_t   SET:1
      uint8_t   CLR:1
   }   B
SSCIR [8]
uint32_t intc_reserved4 [6]
union {
   uint8_t   R
   struct {
      uint8_t   __pad0__:4
      uint8_t   PRI:4
   }   B
PSR [358]
union {
   uint32_t   R
   struct {
      uint32_t   VTES:1
      uint32_t   __pad1__:4
      uint32_t   HVEN:1
   }   B
MCR
union {
   uint32_t   R
   struct {
      uint32_t   PRI:4
   }   B
CPR
union {
   uint32_t   R
   struct {
      uint32_t   VTBA:21
      uint32_t   INTVEC:9
      uint32_t   __pad0__:2
   }   B
IACKR
union {
   uint32_t   R
   struct {
   }   B
EOIR
union {
   uint8_t   R
   struct {
      uint8_t   __pad0__:6
      uint8_t   SET:1
      uint8_t   CLR:1
   }   B
SSCIR [8]
union {
   uint8_t   R
   struct {
      uint8_t   __pad0__:4
      uint8_t   PRI:4
   }   B
PSR [358]
union {
   uint32_t   R
   struct {
      uint32_t   __pad1__:4
      uint32_t   __pad2__:2
      uint32_t   VTES:1
      uint32_t   __pad3__:4
      uint32_t   HVEN:1
   }   B
MCR
union {
   uint32_t   R
   struct {
      uint32_t   PRI:4
   }   B
CPR
union {
   uint32_t   R
   struct {
      uint32_t   PRI:4
   }   B
CPR_PRC1
union {
   uint32_t   R
   struct {
      uint32_t   VTBA:21
      uint32_t   INTVEC:9
      uint32_t   __pad0__:2
   }   B
IACKR
union {
   uint32_t   R
   struct {
      uint32_t   __pad0__:2
   }   B
IACKR_PRC1
union {
   uint32_t   R
   struct {
   }   B
EOIR
union {
   uint32_t   R
   struct {
   }   B
EOIR_PRC1
union {
   uint8_t   R
   struct {
      uint8_t   __pad0__:6
      uint8_t   SET:1
      uint8_t   CLR:1
   }   B
SSCIR [8]
union {
   uint8_t   R
   struct {
      uint8_t   PRC_SEL:2
      uint8_t   __pad0__:2
      uint8_t   PRI:4
   }   B
PSR [316]
union {
   uint32_t   R
   struct {
      uint32_t   VTES:1
      uint32_t   __pad1__:4
      uint32_t   HVEN:1
   }   B
MCR
uint32_t INTC_reserved0004
union {
   uint32_t   R
   struct {
      uint32_t   PRI:4
   }   B
CPR
uint32_t INTC_reserved000C
union {
   uint32_t   R
   struct {
      uint32_t   VTBA:21
      uint32_t   INTVEC:9
      uint32_t   __pad0__:2
   }   B
IACKR
uint32_t INTC_reserved0014
union {
   uint32_t   R
   struct {
      uint32_t   EOIR:32
   }   B
EOIR
uint32_t INTC_reserved001C
union {
   uint8_t   R
   struct {
      uint8_t   __pad0__:6
      uint8_t   SET:1
      uint8_t   CLR:1
   }   B
SSCIR [8]
uint32_t INTC_reserved0028 [6]
union {
   uint8_t   R
   struct {
      uint8_t   __pad0__:4
      uint8_t   PRI:4
   }   B
PSR [480]
uint16_t INTC_reserved0220 [7920]
The documentation for this struct was generated from the following files:
