RTEMS 5.2
fsl-mpc567x.h
1/*
2 * Modifications of the original file provided by Freescale are:
3 *
4 * Copyright (c) 2011 embedded brains GmbH. All rights reserved.
5 *
6 * embedded brains GmbH
7 * Obere Lagerstr. 30
8 * 82178 Puchheim
9 * Germany
10 * <info@embedded-brains.de>
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 * 1. Redistributions of source code must retain the above copyright
16 * notice, this list of conditions and the following disclaimer.
17 * 2. Redistributions in binary form must reproduce the above copyright
18 * notice, this list of conditions and the following disclaimer in the
19 * documentation and/or other materials provided with the distribution.
20 *
21 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
22 * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
23 * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
24 * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
25 * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
26 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
27 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
28 * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
29 * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
30 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
31 * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
32 */
33
34/**************************************************************************/
35/* FILE NAME: mpc5674f.h COPYRIGHT (c) Freescale 2009 */
36/* VERSION: 1.04 All Rights Reserved */
37/* */
38/* DESCRIPTION: */
39/* This file contains all of the register and bit field definitions for */
40/* MPC5674F. */
41/*========================================================================*/
42/* UPDATE HISTORY */
43/* REV AUTHOR DATE DESCRIPTION OF CHANGE */
44/* --- ----------- --------- --------------------- */
45/* NOTE: Branch pulled at version 0.87 for mpc5674_c.h version 1.00 */
46/* 1.00 B. Terry Corrected DECFILT addresses and added */
47/* 4 additional filters for Rev. 2 */
48/* 1.01 B. Terry 16/Nov/09 Corrected bit definitions in SIUDIV */
49/* register. */
50/* 1.02 B. Terry 19/Nov/09 Added ISEL8, ISEL9, ISEL10, and ISEL11 */
51/* regs to SIU tag. (Mamba 2 features) */
52/* 1.03 B. Terry 19/Nov/09 Renamed ISEL10 and ISEL11 to DECFIL1 */
53/* and DECFIL2 to match RM. */
54/* 1.04 B. Terry 22/Jan/10 Updated bitfields of MPU RGDx Word2 */
55/* register to reflect Mamba 2. Added */
56/* MXCR and MXSR registers to DecFilt. */
57/* Removed pre-release rev history. */
58/**************************************************************************/
59
60#ifndef _MPC5674F_H_
61#define _MPC5674F_H_
62
63#ifndef ASM
64
65#include <stdint.h>
66
67#include <mpc55xx/regs-edma.h>
68
69#ifdef __cplusplus
70extern "C" {
71#endif
72
73#ifdef __MWERKS__
74#pragma push
75#pragma ANSI_strict off
76#endif
77
78/****************************************************************************/
79/* MODULE : PBRIDGE_A Peripheral Bridge */
80/****************************************************************************/
81
82 struct PBRIDGE_A_tag {
83
84 union { /* Master Privilege Control Register 0*/
85 uint32_t R;
86 struct {
87 uint32_t MBW0:1; /* z7 Core */
88 uint32_t MTR0:1;
89 uint32_t MTW0:1;
90 uint32_t MPL0:1;
91 uint32_t MBW1:1; /* Nexus */
92 uint32_t MTR1:1;
93 uint32_t MTW1:1;
94 uint32_t MPL1:1;
95 uint32_t MBW2:1; /* Reserved */
96 uint32_t MTR2:1;
97 uint32_t MTW2:1;
98 uint32_t MPL2:1;
99 uint32_t MBW3:1; /* Reserved */
100 uint32_t MTR3:1;
101 uint32_t MTW3:1;
102 uint32_t MPL3:1;
103 uint32_t MBW4:1; /* eDMA A */
104 uint32_t MTR4:1;
105 uint32_t MTW4:1;
106 uint32_t MPL4:1;
107 uint32_t MBW5:1; /* eDMA B */
108 uint32_t MTR5:1;
109 uint32_t MTW5:1;
110 uint32_t MPL5:1;
111 uint32_t MBW6:1; /* FLEXRAY */
112 uint32_t MTR6:1;
113 uint32_t MTW6:1;
114 uint32_t MPL6:1;
115 uint32_t MBW7:1; /* EBI */
116 uint32_t MTR7:1;
117 uint32_t MTW7:1;
118 uint32_t MPL7:1;
119 } B;
120 } MPCR;
121
122 union { /* Master Privilege Control Register 1 */
123 uint32_t R;
124 struct {
125 uint32_t:32; /* reserved */
126 } B;
127 } MPCR1;
128
129 uint32_t PBRIDGE_A_reserved0008[6]; /* 0x0008-0x001F */
130
131 union { /* Peripheral Access Control Register 0 */
132 uint32_t R;
133 struct {
134 uint32_t BW0:1; /* PBRIDGE_A */
135 uint32_t SP0:1;
136 uint32_t WP0:1;
137 uint32_t TP0:1;
138 uint32_t:4; /* Reserved */
139 uint32_t:4; /* Reserved */
140 uint32_t:4; /* Reserved */
141 uint32_t:4; /* Reserved */
142 uint32_t:4; /* Reserved */
143 uint32_t:4; /* Reserved */
144 uint32_t:4; /* Reserved */
145 } B;
146 } PACR0;
147
148 uint32_t PBRIDGE_A_reserved0024[7]; /* 0x0024-0x003F */
149
150 union { /* Off-Platform Peripheral Access Control Register 0 */
151 uint32_t R;
152 struct {
153 uint32_t BW0:1; /* FMPLL */
154 uint32_t SP0:1;
155 uint32_t WP0:1;
156 uint32_t TP0:1;
157 uint32_t BW1:1; /* EBI control */
158 uint32_t SP1:1;
159 uint32_t WP1:1;
160 uint32_t TP1:1;
161 uint32_t BW2:1; /* Flash A control */
162 uint32_t SP2:1;
163 uint32_t WP2:1;
164 uint32_t TP2:1;
165 uint32_t BW3:1; /* Flash B control */
166 uint32_t SP3:1;
167 uint32_t WP3:1;
168 uint32_t TP3:1;
169 uint32_t BW4:1; /* SIU */
170 uint32_t SP4:1;
171 uint32_t WP4:1;
172 uint32_t TP4:1;
173 uint32_t:4; /* Reserved */
174 uint32_t:4; /* Reserved */
175 uint32_t:4; /* Reserved */
176 } B;
177 } OPACR0;
178
179 union { /* Off-Platform Peripheral Access Control Register 1 */
180 uint32_t R;
181 struct {
182 uint32_t BW0:1; /* EMIOS */
183 uint32_t SP0:1;
184 uint32_t WP0:1;
185 uint32_t TP0:1;
186 uint32_t:4; /* Reserved */
187 uint32_t:4; /* Reserved */
188 uint32_t:4; /* Reserved */
189 uint32_t:4; /* Reserved */
190 uint32_t:4; /* Reserved */
191 uint32_t:4; /* Reserved */
192 uint32_t BW7:1; /* PMC */
193 uint32_t SP7:1;
194 uint32_t WP7:1;
195 uint32_t TP7:1;
196 } B;
197 } OPACR1;
198
199 union { /* Off-Platform Peripheral Access Control Register 2 */
200 uint32_t R;
201 struct {
202 uint32_t BW0:1; /* eTPU */
203 uint32_t SP0:1;
204 uint32_t WP0:1;
205 uint32_t TP0:1;
206 uint32_t:4; /* Reserved */
207 uint32_t BW2:1; /* eTPU PRAM */
208 uint32_t SP2:1;
209 uint32_t WP2:1;
210 uint32_t TP2:1;
211 uint32_t BW3:1; /* eTPU PRAM mirror */
212 uint32_t SP3:1;
213 uint32_t WP3:1;
214 uint32_t TP3:1;
215 uint32_t BW4:1; /* eTPU SCM */
216 uint32_t SP4:1;
217 uint32_t WP4:1;
218 uint32_t TP4:1;
219 uint32_t BW5:1; /* eTPU SCM */
220 uint32_t SP5:1;
221 uint32_t WP5:1;
222 uint32_t TP5:1;
223 uint32_t:4; /* Reserved */
224 uint32_t:4; /* Reserved */
225 } B;
226 } OPACR2;
227
228 union { /* Off-Platform Peripheral Access Control Register 3 */
229 uint32_t R;
230 struct {
231 uint32_t:4; /* Reserved */
232 uint32_t:4; /* Reserved */
233 uint32_t:4; /* Reserved */
234 uint32_t:4; /* Reserved */
235 uint32_t BW4:1; /* PIT/RTI */
236 uint32_t SP4:1;
237 uint32_t WP4:1;
238 uint32_t TP4:1;
239 uint32_t:4; /* Reserved */
240 uint32_t:4; /* Reserved */
241 uint32_t:4; /* Reserved */
242 } B;
243 } OPACR3;
244
245 uint32_t PBRIDGE_A_reserved0050[4076]; /* 0x0050-0x3FFF */
246
247 };
248
249/****************************************************************************/
250/* MODULE : PBRIDGE_B Peripheral Bridge */
251/****************************************************************************/
252
253 struct PBRIDGE_B_tag {
254
255 union { /* Master Privilege Control Register 0 */
256 uint32_t R;
257 struct {
258 uint32_t MBW0:1; /* z7 Core */
259 uint32_t MTR0:1;
260 uint32_t MTW0:1;
261 uint32_t MPL0:1;
262 uint32_t MBW1:1; /* Nexus */
263 uint32_t MTR1:1;
264 uint32_t MTW1:1;
265 uint32_t MPL1:1;
266 uint32_t MBW2:1; /* Reserved */
267 uint32_t MTR2:1;
268 uint32_t MTW2:1;
269 uint32_t MPL2:1;
270 uint32_t MBW3:1; /* Reserved */
271 uint32_t MTR3:1;
272 uint32_t MTW3:1;
273 uint32_t MPL3:1;
274 uint32_t MBW4:1; /* eDMA A */
275 uint32_t MTR4:1;
276 uint32_t MTW4:1;
277 uint32_t MPL4:1;
278 uint32_t MBW5:1; /* eDMA B */
279 uint32_t MTR5:1;
280 uint32_t MTW5:1;
281 uint32_t MPL5:1;
282 uint32_t MBW6:1; /* FLEXRAY */
283 uint32_t MTR6:1;
284 uint32_t MTW6:1;
285 uint32_t MPL6:1;
286 uint32_t MBW7:1; /* EBI */
287 uint32_t MTR7:1;
288 uint32_t MTW7:1;
289 uint32_t MPL7:1;
290 } B;
291 } MPCR;
292
293 union { /* Master Privilege Control Register 1 */
294 uint32_t R;
295 struct {
296 uint32_t:32; /* Reserved */
297
298 } B;
299 } MPCR1;
300
301 uint32_t PBRIDGE_B_reserved0008[6]; /* 0x0008-0x001F */
302
303 union { /* Peripheral Access Control Register 0 */
304 uint32_t R;
305 struct {
306 uint32_t BW0:1; /* PBRIDGE B */
307 uint32_t SP0:1;
308 uint32_t WP0:1;
309 uint32_t TP0:1;
310 uint32_t BW1:1; /* XBAR */
311 uint32_t SP1:1;
312 uint32_t WP1:1;
313 uint32_t TP1:1;
314 uint32_t:4; /* Reserved */
315 uint32_t:4; /* Reserved */
316 uint32_t BW4:1; /* MPU */
317 uint32_t SP4:1;
318 uint32_t WP4:1;
319 uint32_t TP4:1;
320 uint32_t:4; /* Reserved */
321 uint32_t:4; /* Reserved */
322 uint32_t:4; /* Reserved */
323 } B;
324 } PACR0;
325
326 union { /* Peripheral Access Control Register 1 */
327 uint32_t R;
328 struct {
329 uint32_t:4; /* Reserved */
330 uint32_t:4; /* Reserved */
331 uint32_t:4; /* Reserved */
332 uint32_t:4; /* Reserved */
333 uint32_t:4; /* Reserved */
334 uint32_t:4; /* Reserved */
335 uint32_t BW6:1; /* SWT */
336 uint32_t SP6:1;
337 uint32_t WP6:1;
338 uint32_t TP6:1;
339 uint32_t BW7:1; /* STM */
340 uint32_t SP7:1;
341 uint32_t WP7:1;
342 uint32_t TP7:1;
343 } B;
344 } PACR1;
345
346 union { /* Peripheral Access Control Register 2 */
347 uint32_t R;
348 struct {
349 uint32_t BW0:1; /* ECSM */
350 uint32_t SP0:1;
351 uint32_t WP0:1;
352 uint32_t TP0:1;
353 uint32_t BW1:1; /* eDMA A */
354 uint32_t SP1:1;
355 uint32_t WP1:1;
356 uint32_t TP1:1;
357 uint32_t BW2:1; /* INTC */
358 uint32_t SP2:1;
359 uint32_t WP2:1;
360 uint32_t TP2:1;
361 uint32_t:4; /* Reserved */
362 uint32_t:4; /* Reserved */
363 uint32_t BW5:1; /* eDMA B */
364 uint32_t SP5:1;
365 uint32_t WP5:1;
366 uint32_t TP5:1;
367 uint32_t:4; /* Reserved */
368 uint32_t:4; /* Reserved */
369 } B;
370 } PACR2;
371
372 uint32_t PBRIDGE_B_reserved002C[5]; /* 0x002C-0x003F */
373
374 union { /* Off-Platform Peripheral Access Control Register 0 */
375 uint32_t R;
376 struct {
377 uint32_t BW0:1; /* eQADC A */
378 uint32_t SP0:1;
379 uint32_t WP0:1;
380 uint32_t TP0:1;
381 uint32_t BW1:1; /* eQADC B */
382 uint32_t SP1:1;
383 uint32_t WP1:1;
384 uint32_t TP1:1;
385 uint32_t BW2:1; /* Decimation Filters A, B, C, D */
386 uint32_t SP2:1;
387 uint32_t WP2:1;
388 uint32_t TP2:1;
389 uint32_t:4; /* Reserved */
390 uint32_t BW4:1; /* DSPI_A */
391 uint32_t SP4:1;
392 uint32_t WP4:1;
393 uint32_t TP4:1;
394 uint32_t BW5:1; /* DSPI_B */
395 uint32_t SP5:1;
396 uint32_t WP5:1;
397 uint32_t TP5:1;
398 uint32_t BW6:1; /* DSPI_C */
399 uint32_t SP6:1;
400 uint32_t WP6:1;
401 uint32_t TP6:1;
402 uint32_t BW7:1; /* DSPI_D */
403 uint32_t SP7:1;
404 uint32_t WP7:1;
405 uint32_t TP7:1;
406 } B;
407 } OPACR0;
408
409 union { /* Off-Platform Peripheral Access Control Register 1 */
410 uint32_t R;
411 struct {
412 uint32_t:4; /* Reserved */
413 uint32_t:4; /* Reserved */
414 uint32_t:4; /* Reserved */
415 uint32_t:4; /* Reserved */
416 uint32_t BW4:1; /* ESCI_A */
417 uint32_t SP4:1;
418 uint32_t WP4:1;
419 uint32_t TP4:1;
420 uint32_t BW5:1; /* ESCI_B */
421 uint32_t SP5:1;
422 uint32_t WP5:1;
423 uint32_t TP5:1;
424 uint32_t BW6:1; /* ESCI_C */
425 uint32_t SP6:1;
426 uint32_t WP6:1;
427 uint32_t TP6:1;
428 uint32_t:4; /* Reserved */
429 } B;
430 } OPACR1;
431
432 union { /* Off-Platform Peripheral Access Control Register 2 */
433 uint32_t R;
434 struct {
435 uint32_t BW0:1; /* FlexCAN_A */
436 uint32_t SP0:1;
437 uint32_t WP0:1;
438 uint32_t TP0:1;
439 uint32_t BW1:1; /* FlexCAN_B */
440 uint32_t SP1:1;
441 uint32_t WP1:1;
442 uint32_t TP1:1;
443 uint32_t BW2:1; /* FlexCAN_C */
444 uint32_t SP2:1;
445 uint32_t WP2:1;
446 uint32_t TP2:1;
447 uint32_t BW3:1; /* FlexCAN_D */
448 uint32_t SP3:1;
449 uint32_t WP3:1;
450 uint32_t TP3:1;
451 uint32_t:4; /* Reserved */
452 uint32_t:4; /* Reserved */
453 uint32_t:4; /* Reserved */
454 uint32_t:4; /* Reserved */
455 } B;
456 } OPACR2;
457
458 union { /* Off-Platform Peripheral Access Control Register 3 */
459 uint32_t R;
460 struct {
461 uint32_t BW0:1; /* FlexRAY */
462 uint32_t SP0:1;
463 uint32_t WP0:1;
464 uint32_t TP0:1;
465 uint32_t:4; /* Reserved */
466 uint32_t:4; /* Reserved */
467 uint32_t BW3:1; /* Temp Sensor */
468 uint32_t SP3:1;
469 uint32_t WP3:1;
470 uint32_t TP3:1;
471 uint32_t:4; /* Reserved */
472 uint32_t:4; /* Reserved */
473 uint32_t:4; /* Reserved */
474 uint32_t BW7:1; /* BAM */
475 uint32_t SP7:1;
476 uint32_t WP7:1;
477 uint32_t TP7:1;
478 } B;
479 } OPACR3;
480
481 uint32_t PBRIDGE_B_reserved0050[4076]; /* 0x0050-0x3FFF */
482
483 };
484
485/****************************************************************************/
486/* MODULE : FMPLL */
487/****************************************************************************/
488
489 struct FMPLL_tag {
490
491 uint32_t FMPLL_reserved0000; /* 0x0000-0x0003 */
492
493 union FMPLL_SYNSR_tag { /* FMPLL Synthesizer Status Register */
494 uint32_t R;
495 struct {
496 uint32_t:22;
497 uint32_t LOLF:1;
498 uint32_t LOC:1;
499 uint32_t MODE:1;
500 uint32_t PLLSEL:1;
501 uint32_t PLLREF:1;
502 uint32_t LOCKS:1;
503 uint32_t LOCK:1;
504 uint32_t LOCF:1;
505 uint32_t CALDONE:1;
506 uint32_t CALPASS:1;
507 } B;
508 } SYNSR;
509
510 union FMPLL_ESYNCR1_tag {/* FMPLL Enhanced Synthesizer Control Register 1 */
511 uint32_t R;
512 struct {
513 uint32_t:1;
514 uint32_t CLKCFG:3;
515 uint32_t:8;
516 uint32_t EPREDIV:4;
517 uint32_t :8;
518 uint32_t EMFD:8;
519 } B;
520 } ESYNCR1;
521
522 union FMPLL_ESYNCR2_tag {/* FMPLL Enhanced Synthesizer Control Register 2 */
523 uint32_t R;
524 struct {
525 uint32_t:8;
526 uint32_t LOCEN:1;
527 uint32_t LOLRE:1;
528 uint32_t LOCRE:1;
529 uint32_t LOLIRQ:1;
530 uint32_t LOCIRQ:1;
531 uint32_t:1;
532 uint32_t ERATE:2;
533 uint32_t CLKCFG_DIS:1;
534 uint32_t:4;
535 uint32_t EDEPTH:3;
536 uint32_t:2;
537 uint32_t ERFD:6;
538 } B;
539 } ESYNCR2;
540
541 uint32_t FMPLL_reserved0010[4092]; /* 0x0010-0x3FFF */
542
543 };
544
545/****************************************************************************/
546/* MODULE : External Bus Interface (EBI) */
547/****************************************************************************/
548
549 struct EBI_CS_tag {
550 uint32_t ebi_cs_reserved [2];
551 };
552
553 struct EBI_CAL_CS_tag {
554 union { /* Calibration Base Register Bank */
555 uint32_t R;
556 struct {
557 uint32_t BA:17;
558 uint32_t:3;
559 uint32_t PS:1;
560 uint32_t:3;
561 uint32_t AD_MUX:1;
562 uint32_t BL:1;
563 uint32_t WEBS:1;
564 uint32_t TBDIP:1;
565 uint32_t:1;
566 uint32_t SETA:1;
567 uint32_t BI:1;
568 uint32_t V:1;
569 } B;
570 } BR;
571
572 union { /* Calibration Option Register Bank */
573 uint32_t R;
574 struct {
575 uint32_t AM:17;
576 uint32_t:7;
577 uint32_t SCY:4;
578 uint32_t:1;
579 uint32_t BSCY:2;
580 uint32_t:1;
581 } B;
582 } OR;
583 };
584
585 struct EBI_tag {
586
587 union EBI_MCR_tag { /* Module Configuration Register */
588 uint32_t R;
589 struct {
590 uint32_t:16;
591 uint32_t ACGE:1;
592 uint32_t:8;
593 uint32_t MDIS:1;
594 uint32_t:3;
595 uint32_t D16_31:1;
596 uint32_t AD_MUX:1;
597 uint32_t DBM:1;
598 } B;
599 } MCR;
600
601 uint32_t EBI_reserved0004; /* 0x0004-0x0007 */
602
603 union { /* Transfer Error Status Register */
604 uint32_t R;
605 struct {
606 uint32_t:30;
607 uint32_t TEAF:1;
608 uint32_t BMTF:1;
609 } B;
610 } TESR;
611
612 union { /* Bus Monitor Control Register */
613 uint32_t R;
614 struct {
615 uint32_t:16;
616 uint32_t BMT:8;
617 uint32_t BME:1;
618 uint32_t:7;
619 } B;
620 } BMCR;
621
622 /* Base/Option registers */
623 struct EBI_CS_tag CS[4];
624
625 uint32_t EBI_reserved0030[4]; /* 0x0030-0x003F */
626
627 /* Calibration registers */
628 struct EBI_CAL_CS_tag CAL_CS[4];
629
630 uint32_t EBI_reserved0060[4000]; /* 0x0060-0x3FFF */
631
632 };
633
634/****************************************************************************/
635/* MODULE : FLASH */
636/****************************************************************************/
637
638 struct FLASH_tag {
639
640 union { /* Module Configuration Register */
641 uint32_t R;
642 struct {
643 uint32_t:5;
644 uint32_t SIZE:3;
645 uint32_t:1;
646 uint32_t LAS:3;
647 uint32_t:3;
648 uint32_t MAS:1;
649 uint32_t EER:1;
650 uint32_t RWE:1;
651 uint32_t SBC:1;
652 uint32_t:1;
653 uint32_t PEAS:1;
654 uint32_t DONE:1;
655 uint32_t PEG:1;
656 uint32_t:4;
657 uint32_t PGM:1;
658 uint32_t PSUS:1;
659 uint32_t ERS:1;
660 uint32_t ESUS:1;
661 uint32_t EHV:1;
662 } B;
663 } MCR;
664
665 union LMLR_tag { /* Low/Mid Address Space Block Locking Register */
666 uint32_t R;
667 struct {
668 uint32_t LME:1;
669 uint32_t:10;
670 uint32_t SLOCK:1;
671 uint32_t:2;
672 uint32_t MLOCK:2;
673 uint32_t:6;
674 uint32_t LLOCK:10;
675 } B;
676 } LMLR; /* Legacy naming - refer to LML in Reference Manual */
677
678 union HLR_tag { /* High Address Space Block Locking Register */
679 uint32_t R;
680 struct {
681 uint32_t HBE:1;
682 uint32_t:25;
683 uint32_t HBLOCK:6; /* Legacy naming - refer to HLOCK in Reference Manual */
684 } B;
685 } HLR; /* Legacy naming - refer to HBL in Reference Manual */
686
687 union SLMLR_tag { /* Secondary Low/Mid Block Locking Register */
688 uint32_t R;
689 struct {
690 uint32_t SLE:1;
691 uint32_t:10;
692 uint32_t SSLOCK:1;
693 uint32_t:2;
694 uint32_t SMLOCK:2;
695 uint32_t:6;
696 uint32_t SLLOCK:10;
697 } B;
698 } SLMLR; /* Legacy naming - refer to SLL in Reference Manual */
699
700 union { /* Low/Mid Address Space Block Select Register */
701 uint32_t R;
702 struct {
703 uint32_t:14;
704 uint32_t MSEL:2;
705 uint32_t:6;
706 uint32_t LSEL:10;
707 } B;
708 } LMSR; /* Legacy naming - refer to LMS in Reference Manual */
709
710 union { /* High Address Space Block Select Register */
711 uint32_t R;
712 struct {
713 uint32_t:26;
714 uint32_t HBSEL:6; /* Legacy naming - refer to HSEL in Reference Manual */
715 } B;
716 } HSR; /* Legacy naming - refer to HBS in Reference Manual */
717
718 union { /* Address Register */
719 uint32_t R;
720 struct {
721 uint32_t SAD:1;
722 uint32_t:13;
723 uint32_t ADDR:15;
724 uint32_t:3;
725 } B;
726 } AR; /* Legacy naming - refer to ADR in Reference Manual */
727
728 union { /* Platform Flash Configuration Register 1 */
729 uint32_t R;
730 struct {
731 uint32_t:7;
732 uint32_t M8PFE:1; /* z7 Nexus */
733 uint32_t:1; /* EBI Testing - Reserved */
734 uint32_t M6PFE:1; /* FlexRay */
735 uint32_t M5PFE:1; /* eDMA_B */
736 uint32_t M4PFE:1; /* eDMA_A */
737 uint32_t:1; /* Reserved */
738 uint32_t:1; /* Reserved */
739 uint32_t:1; /* Reserved */
740 uint32_t M0PFE:1; /* z7 Core */
741 uint32_t APC:3;
742 uint32_t WWSC:2;
743 uint32_t RWSC:3;
744 uint32_t:1;
745 uint32_t DPFEN:1;
746 uint32_t:1;
747 uint32_t IPFEN:1;
748 uint32_t:1;
749 uint32_t PFLIM:2;
750 uint32_t BFEN:1;
751 } B;
752 } BIUCR; /* Legacy naming - PFCR1 */
753
754 union { /*Platform Flash Access Protection Register */
755 uint32_t R;
756 struct {
757 uint32_t:14;
758 uint32_t M8AP:2; /* z7 Nexus */
759 uint32_t:2; /* EBI Testing - Reserved */
760 uint32_t M6AP:2; /* FlexRay */
761 uint32_t M5AP:2; /* eDMA_B */
762 uint32_t M4AP:2; /* eDMA_A */
763 uint32_t:2; /* Reserved */
764 uint32_t:2; /* Reserved */
765 uint32_t:2; /* Reserved */
766 uint32_t M0AP:2; /* z7 Core */
767 } B;
768 } BIUAPR; /* Legacy naming - refer to PFAPR in Reference Manual */
769
770 union { /* Platform Flash Configuration Register 2 */
771 uint32_t R;
772 struct {
773 uint32_t LBCFG:2;
774 uint32_t:30;
775 } B;
776 } BIUCR2;
777
778 uint32_t FLASH_reserved0028[4086]; /* 0x0028-0x3FFF */
779 };
780
781/****************************************************************************/
782/* MODULE : SIU */
783/****************************************************************************/
784 struct SIU_tag {
785 int32_t SIU_reserved0000 /* 0x0000-0x0003 */;
786
787 union { /* MCU ID Register */
788 uint32_t R;
789 struct {
790 uint32_t PARTNUM:16;
791 uint32_t PKG:4;
792 uint32_t:4;
793 uint32_t MAJOR_REV:4;
794 uint32_t MINOR_REV:4;
795 } B;
796 } MIDR;
797
798 int32_t SIU_reserved0008; /* 0x0008-0x000B */
799
800 union { /* Reset Status Register */
801 uint32_t R;
802 struct {
803 uint32_t PORS:1;
804 uint32_t ERS:1;
805 uint32_t LLRS:1;
806 uint32_t LCRS:1;
807 uint32_t WDRS:1;
808 uint32_t CRS:1;
809 uint32_t SWTRS:1;
810 uint32_t:7;
811 uint32_t SSRS:1;
812 uint32_t SERF:1;
813 uint32_t WKPCFG:1;
814 uint32_t:11;
815 uint32_t ABR:1;
816 uint32_t BOOTCFG:2;
817 uint32_t RGF:1;
818 } B;
819 } RSR;
820
821 union { /* System Reset Control Register */
822 uint32_t R;
823 struct {
824 uint32_t SSR:1;
825 uint32_t SER:1;
826 uint32_t:30; // Removed CRE bit
827 } B;
828 } SRCR;
829
830 union SIU_EISR_tag { /* External Interrupt Status Register */
831 uint32_t R;
832 struct {
833 uint32_t NMI:1;
834 uint32_t:15;
835 uint32_t EIF15:1;
836 uint32_t EIF14:1;
837 uint32_t EIF13:1;
838 uint32_t EIF12:1;
839 uint32_t EIF11:1;
840 uint32_t EIF10:1;
841 uint32_t EIF9:1;
842 uint32_t EIF8:1;
843 uint32_t EIF7:1;
844 uint32_t EIF6:1;
845 uint32_t EIF5:1;
846 uint32_t EIF4:1;
847 uint32_t EIF3:1;
848 uint32_t EIF2:1;
849 uint32_t EIF1:1;
850 uint32_t EIF0:1;
851 } B;
852 } EISR;
853
854 union SIU_DIRER_tag { /* DMA/Interrupt Request Enable Register */
855 uint32_t R;
856 struct {
857 uint32_t NMISEL8:1;
858 uint32_t:7;
859 uint32_t NMISEL0:1;
860 uint32_t:7;
861 uint32_t EIRE15:1;
862 uint32_t EIRE14:1;
863 uint32_t EIRE13:1;
864 uint32_t EIRE12:1;
865 uint32_t EIRE11:1;
866 uint32_t EIRE10:1;
867 uint32_t EIRE9:1;
868 uint32_t EIRE8:1;
869 uint32_t EIRE7:1;
870 uint32_t EIRE6:1;
871 uint32_t EIRE5:1;
872 uint32_t EIRE4:1;
873 uint32_t EIRE3:1;
874 uint32_t EIRE2:1;
875 uint32_t EIRE1:1;
876 uint32_t EIRE0:1;
877 } B;
878 } DIRER;
879
880 union SIU_DIRSR_tag { /* DMA/Interrupt Request Select Register */
881 uint32_t R;
882 struct {
883 uint32_t:28;
884 uint32_t DIRS3:1;
885 uint32_t DIRS2:1;
886 uint32_t DIRS1:1;
887 uint32_t DIRS0:1;
888 } B;
889 } DIRSR;
890
891 union { /* Overrun Status Register */
892 uint32_t R;
893 struct {
894 uint32_t:16;
895 uint32_t OVF15:1;
896 uint32_t OVF14:1;
897 uint32_t OVF13:1;
898 uint32_t OVF12:1;
899 uint32_t OVF11:1;
900 uint32_t OVF10:1;
901 uint32_t OVF9:1;
902 uint32_t OVF8:1;
903 uint32_t OVF7:1;
904 uint32_t OVF6:1;
905 uint32_t OVF5:1;
906 uint32_t OVF4:1;
907 uint32_t OVF3:1;
908 uint32_t OVF2:1;
909 uint32_t OVF1:1;
910 uint32_t OVF0:1;
911 } B;
912 } OSR;
913
914 union SIU_ORER_tag { /* Overrun Request Enable Register */
915 uint32_t R;
916 struct {
917 uint32_t:16;
918 uint32_t ORE15:1;
919 uint32_t ORE14:1;
920 uint32_t ORE13:1;
921 uint32_t ORE12:1;
922 uint32_t ORE11:1;
923 uint32_t ORE10:1;
924 uint32_t ORE9:1;
925 uint32_t ORE8:1;
926 uint32_t ORE7:1;
927 uint32_t ORE6:1;
928 uint32_t ORE5:1;
929 uint32_t ORE4:1;
930 uint32_t ORE3:1;
931 uint32_t ORE2:1;
932 uint32_t ORE1:1;
933 uint32_t ORE0:1;
934 } B;
935 } ORER;
936
937 union SIU_IREER_tag { /* External IRQ Rising-Edge Event Enable Register */
938 uint32_t R;
939 struct {
940 uint32_t IREE_NMI8:1;
941 uint32_t:7;
942 uint32_t IREE_NMI0:1;
943 uint32_t:7;
944 uint32_t IREE15:1;
945 uint32_t IREE14:1;
946 uint32_t IREE13:1;
947 uint32_t IREE12:1;
948 uint32_t IREE11:1;
949 uint32_t IREE10:1;
950 uint32_t IREE9:1;
951 uint32_t IREE8:1;
952 uint32_t IREE7:1;
953 uint32_t IREE6:1;
954 uint32_t IREE5:1;
955 uint32_t IREE4:1;
956 uint32_t IREE3:1;
957 uint32_t IREE2:1;
958 uint32_t IREE1:1;
959 uint32_t IREE0:1;
960 } B;
961 } IREER;
962
963 union SIU_IFEER_tag { /* External IRQ Falling-Edge Event Enable Register */
964 uint32_t R;
965 struct {
966 uint32_t IFEE_NMI8:1;
967 uint32_t:7;
968 uint32_t IFEE_NMI0:1;
969 uint32_t:7;
970 uint32_t IFEE15:1;
971 uint32_t IFEE14:1;
972 uint32_t IFEE13:1;
973 uint32_t IFEE12:1;
974 uint32_t IFEE11:1;
975 uint32_t IFEE10:1;
976 uint32_t IFEE9:1;
977 uint32_t IFEE8:1;
978 uint32_t IFEE7:1;
979 uint32_t IFEE6:1;
980 uint32_t IFEE5:1;
981 uint32_t IFEE4:1;
982 uint32_t IFEE3:1;
983 uint32_t IFEE2:1;
984 uint32_t IFEE1:1;
985 uint32_t IFEE0:1;
986 } B;
987 } IFEER;
988
989 union SIU_IDFR_tag { /* External IRQ Digital Filter Register */
990 uint32_t R;
991 struct {
992 uint32_t:28;
993 uint32_t DFL:4;
994 } B;
995 } IDFR;
996
997 union { /* External IRQ Filtered Input Register */
998 uint32_t R;
999 struct {
1000 uint32_t FI31:1;
1001 uint32_t FI30:1;
1002 uint32_t FI29:1;
1003 uint32_t FI28:1;
1004 uint32_t FI27:1;
1005 uint32_t FI26:1;
1006 uint32_t FI25:1;
1007 uint32_t FI24:1;
1008 uint32_t FI23:1;
1009 uint32_t FI22:1;
1010 uint32_t FI21:1;
1011 uint32_t FI20:1;
1012 uint32_t FI19:1;
1013 uint32_t FI18:1;
1014 uint32_t FI17:1;
1015 uint32_t FI16:1;
1016 uint32_t FI15:1;
1017 uint32_t FI14:1;
1018 uint32_t FI13:1;
1019 uint32_t FI12:1;
1020 uint32_t FI11:1;
1021 uint32_t FI10:1;
1022 uint32_t FI9:1;
1023 uint32_t FI8:1;
1024 uint32_t FI7:1;
1025 uint32_t FI6:1;
1026 uint32_t FI5:1;
1027 uint32_t FI4:1;
1028 uint32_t FI3:1;
1029 uint32_t FI2:1;
1030 uint32_t FI1:1;
1031 uint32_t FI0:1;
1032 } B;
1033 } IFIR;
1034
1035 int32_t SIU_reserved0038[2]; /* 0x0038-0x003F */
1036
1037 union SIU_PCR_tag { /* Pad Configuration Registers */
1038 uint16_t R;
1039 struct {
1040 uint16_t:3;
1041 uint16_t PA:3;
1042 uint16_t OBE:1;
1043 uint16_t IBE:1;
1044 uint16_t DSC:2;
1045 uint16_t ODE:1;
1046 uint16_t HYS:1;
1047 uint16_t SRC:2;
1048 uint16_t WPE:1;
1049 uint16_t WPS:1;
1050 } B;
1051 } PCR[512];
1052
1053 int16_t SIU_reserved0440[224]; /* 0x0440-0x05FF */
1054
1055 union { /* GPIO Pin Data Output Registers */
1056 uint8_t R;
1057 struct {
1058 uint8_t:7;
1059 uint8_t PDO:1;
1060 } B;
1061 } GPDO[512];
1062
1063 union { /* GPIO Pin Data Input Registers */
1064 uint8_t R;
1065 struct {
1066 uint8_t:7;
1067 uint8_t PDI:1;
1068 } B;
1069 } GPDI[256];
1070
1071 uint32_t SIU_reserved0900; /* 0x0900-0x0903 */
1072
1073 union { /* External IRQ Input Select Register */
1074 uint32_t R;
1075 struct {
1076 uint32_t ESEL15:2;
1077 uint32_t ESEL14:2;
1078 uint32_t ESEL13:2;
1079 uint32_t ESEL12:2;
1080 uint32_t ESEL11:2;
1081 uint32_t ESEL10:2;
1082 uint32_t ESEL9:2;
1083 uint32_t ESEL8:2;
1084 uint32_t ESEL7:2;
1085 uint32_t ESEL6:2;
1086 uint32_t ESEL5:2;
1087 uint32_t ESEL4:2;
1088 uint32_t ESEL3:2;
1089 uint32_t ESEL2:2;
1090 uint32_t ESEL1:2;
1091 uint32_t ESEL0:2;
1092 } B;
1093 } EIISR;
1094
1095 union { /* DSPI Input Select Register */
1096 uint32_t R;
1097 struct {
1098 uint32_t SINSELA:2;
1099 uint32_t SSSELA:2;
1100 uint32_t SCKSELA:2;
1101 uint32_t TRIGSELA:2;
1102 uint32_t SINSELB:2;
1103 uint32_t SSSELB:2;
1104 uint32_t SCKSELB:2;
1105 uint32_t TRIGSELB:2;
1106 uint32_t SINSELC:2;
1107 uint32_t SSSELC:2;
1108 uint32_t SCKSELC:2;
1109 uint32_t TRIGSELC:2;
1110 uint32_t SINSELD:2;
1111 uint32_t SSSELD:2;
1112 uint32_t SCKSELD:2;
1113 uint32_t TRIGSELD:2;
1114 } B;
1115 } DISR;
1116
1117 int32_t SIU_reserved090C; /* 0x090C-0x090F */
1118
1119 union { /* eQADC Command FIFO Trigger Source Select - IMUX Select Registers */
1120 uint32_t R;
1121 struct {
1122 uint32_t:1;
1123 uint32_t CTSEL5_0:7;
1124 uint32_t:1;
1125 uint32_t CTSEL4_0:7;
1126 uint32_t:1;
1127 uint32_t CTSEL3_0:7;
1128 uint32_t:1;
1129 uint32_t CTSEL2_0:7;
1130 } B;
1131 } ISEL4;
1132
1133 union { /* eQADC Command FIFO Trigger Source Select - IMUX Select Registers */
1134 uint32_t R;
1135 struct {
1136 uint32_t:1;
1137 uint32_t CTSEL1_0:7;
1138 uint32_t:1;
1139 uint32_t CTSEL0_0:7;
1140 uint32_t:16;
1141 } B;
1142 } ISEL5;
1143
1144 union { /* eQADC Command FIFO Trigger Source Select - IMUX Select Registers */
1145 uint32_t R;
1146 struct {
1147 uint32_t:1;
1148 uint32_t CTSEL5_1:7;
1149 uint32_t:1;
1150 uint32_t CTSEL4_1:7;
1151 uint32_t:1;
1152 uint32_t CTSEL3_1:7;
1153 uint32_t:1;
1154 uint32_t CTSEL2_1:7;
1155 } B;
1156 } ISEL6;
1157
1158 union { /* eQADC Command FIFO Trigger Source Select - IMUX Select Registers */
1159 uint32_t R;
1160 struct {
1161 uint32_t:1;
1162 uint32_t CTSEL1_1:7;
1163 uint32_t:1;
1164 uint32_t CTSEL0_1:7;
1165 uint32_t:16;
1166 } B;
1167 } ISEL7;
1168
1169 union { /* eTPU Input Select Register */
1170 uint32_t R;
1171 struct {
1172 uint32_t:11;
1173 uint32_t ETPU29:1;
1174 uint32_t:3;
1175 uint32_t ETPU28:1;
1176 uint32_t:3;
1177 uint32_t ETPU27:1;
1178 uint32_t:3;
1179 uint32_t ETPU26:1;
1180 uint32_t:3;
1181 uint32_t ETPU25:1;
1182 uint32_t:3;
1183 uint32_t ETPU24:1;
1184 } B;
1185 } ISEL8;
1186
1187 union { /* eQADC Advanced Trigger Select */
1188 uint32_t R;
1189 struct {
1190 uint32_t:27;
1191 uint32_t ETSEL0A:5;
1192 } B;
1193 } ISEL9;
1194
1195 union { /* DecFilter Integrator Control */
1196 uint32_t R;
1197 struct {
1198 uint32_t ZSELA:4;
1199 uint32_t HSELA:4;
1200 uint32_t ZSELB:4;
1201 uint32_t HSELB:4;
1202 uint32_t ZSELC:4;
1203 uint32_t HSELC:4;
1204 uint32_t ZSELD:4;
1205 uint32_t HSELD:4;
1206 } B;
1207 } DECFIL1;
1208
1209 union { /* DecFilter Integrator Control */
1210 uint32_t R;
1211 struct {
1212 uint32_t ZSELE:4;
1213 uint32_t HSELE:4;
1214 uint32_t ZSELF:4;
1215 uint32_t HSELF:4;
1216 uint32_t ZSELG:4;
1217 uint32_t HSELG:4;
1218 uint32_t ZSELH:4;
1219 uint32_t HSELH:4;
1220 } B;
1221 } DECFIL2;
1222
1223
1224 int32_t SIU_reserved0920[20]; /* 0x0930-0x097F */
1225
1226 union { /* Chip Configuration Register Register */
1227 uint32_t R;
1228 struct {
1229 uint32_t:14;
1230 uint32_t MATCH:1;
1231 uint32_t DISNEX:1;
1232 uint32_t:16;
1233 } B;
1234 } CCR;
1235
1236 union { /* External Clock Configuration Register Register */
1237 uint32_t R;
1238 struct {
1239 uint32_t:16;
1240 uint32_t ENGDIV:8;
1241 uint32_t ECSS:1;
1242 uint32_t:3;
1243 uint32_t EBTS:1;
1244 uint32_t:1;
1245 uint32_t EBDF:2;
1246 } B;
1247 } ECCR;
1248
1249 union { /* Compare A Register High */
1250 uint32_t R;
1251 struct {
1252 uint32_t CMPAH:32;
1253 } B;
1254 } CARH;
1255
1256 union { /* Compare A Register Low */
1257 uint32_t R;
1258 struct {
1259 uint32_t CMPAL:32;
1260 } B;
1261 } CARL;
1262
1263 union { /* Compare B Register High */
1264 uint32_t R;
1265 struct {
1266 uint32_t CMPBH:32;
1267 } B;
1268 } CBRH;
1269
1270 union { /* Compare B Register Low */
1271 uint32_t R;
1272 struct {
1273 uint32_t CMPBL:32;
1274 } B;
1275 } CBRL;
1276
1277 int32_t SIU_reserved0998[2]; /* 0x0998-0x099F */
1278
1279 union { /* System Clock Register */
1280 uint32_t R;
1281 struct {
1282 uint32_t:22;
1283 uint32_t IPCLKDIV:2;
1284 uint32_t:3;
1285 uint32_t BYPASS:1;
1286 uint32_t SYSCLKDIV:2;
1287 uint32_t:2;
1288 } B;
1289 } SYSDIV;
1290
1291 union { /* Halt Register */
1292 uint32_t R;
1293 struct {
1294 uint32_t CPUSTP:1; /* CPU and Platform stop request */
1295 uint32_t:4; /* Reserved */
1296 uint32_t TPUSTP:1; /* eTPU_A stop request */
1297 uint32_t NPCSTP:1; /* Nexus stop request */
1298 uint32_t EBISTP:1; /* EBI stop request*/
1299 uint32_t ADCSTP:1; /* eQADC stop request */
1300 uint32_t:1; /* Reserved */
1301 uint32_t MIOSSTP:1; /* eMIOS stop request */
1302 uint32_t DFILSTP:1; /* Decimation filter stop request */
1303 uint32_t:1; /* Reserved */
1304 uint32_t PITSTP:1; /* PIT stop request */
1305 uint32_t:2; /* Reserved */
1306 uint32_t CNDSTP:1; /* FlexCAN D stop request */
1307 uint32_t CNCSTP:1; /* FlexCAN C stop request */
1308 uint32_t CNBSTP:1; /* FlexCAN B stop request */
1309 uint32_t CNASTP:1; /* FlexCAN A stop request */
1310 uint32_t SPIDSTP:1; /* DSPI D stop request */
1311 uint32_t SPICSTP:1; /* DSPI C stop request */
1312 uint32_t SPIBSTP:1; /* DSPI B stop request */
1313 uint32_t SPIASTP:1; /* DSPI C stop request */
1314 uint32_t:5; /* Reserved */
1315 uint32_t SCICSTP:1; /* eSCI C stop request */
1316 uint32_t SCIBSTP:1; /* eSCI B stop request */
1317 uint32_t SCIASTP:1; /* eSCI A stop request */
1318 } B;
1319 } HLT;
1320
1321 union { /* Halt Acknowledge Register */
1322 uint32_t R;
1323 struct {
1324 uint32_t CPUACK:1; /* CPU and Platform stop acknowledge */
1325 uint32_t:4; /* Reserved */
1326 uint32_t TPUACK:1; /* eTPU_A stop acknowledge */
1327 uint32_t NPCACK:1; /* Nexus stop acknowledge */
1328 uint32_t EBIACK:1; /* EBI stop acknowledge*/
1329 uint32_t ADCACK:1; /* eQADC stop acknowledge */
1330 uint32_t:1; /* Reserved */
1331 uint32_t MIOSACK:1; /* eMIOS stop acknowledge */
1332 uint32_t DFILACK:1; /* Decimation filter stop acknowledge */
1333 uint32_t:1; /* Reserved */
1334 uint32_t PITACK:1; /* PIT stop acknowledge */
1335 uint32_t:2; /* Reserved */
1336 uint32_t CNDACK:1; /* FlexCAN D stop acknowledge */
1337 uint32_t CNCACK:1; /* FlexCAN C stop acknowledge */
1338 uint32_t CNBACK:1; /* FlexCAN B stop acknowledge */
1339 uint32_t CNAACK:1; /* FlexCAN A stop acknowledge */
1340 uint32_t SPIDACK:1; /* DSPI D stop acknowledge */
1341 uint32_t SPICACK:1; /* DSPI C stop acknowledge */
1342 uint32_t SPIBACK:1; /* DSPI B stop acknowledge */
1343 uint32_t SPIAACK:1; /* DSPI C stop acknowledge */
1344 uint32_t:5; /* Reserved */
1345 uint32_t SCICACK:1; /* eSCI C stop acknowledge */
1346 uint32_t SCIBACK:1; /* eSCI B stop acknowledge */
1347 uint32_t SCIAACK:1; /* eSCI A stop acknowledge */
1348 } B;
1349 } HLTACK;
1350
1351 int32_t SIU_reserved09AC[21]; /* 0x09AC-0x09FF */
1352
1353 int32_t SIU_reserved0A00[128]; /* 0x0A00-0x0BFF */
1354
1355 union { /* Parallel GPIO Pin Data Output Register */
1356 uint32_t R;
1357 struct {
1358 uint32_t PGPDO0:1;
1359 uint32_t PGPDO1:1;
1360 uint32_t PGPDO2:1;
1361 uint32_t PGPDO3:1;
1362 uint32_t PGPDO4:1;
1363 uint32_t PGPDO5:1;
1364 uint32_t PGPDO6:1;
1365 uint32_t PGPDO7:1;
1366 uint32_t PGPDO8:1;
1367 uint32_t PGPDO9:1;
1368 uint32_t PGPDO10:1;
1369 uint32_t PGPDO11:1;
1370 uint32_t PGPDO12:1;
1371 uint32_t PGPDO13:1;
1372 uint32_t PGPDO14:1;
1373 uint32_t PGPDO15:1;
1374 uint32_t PGPDO16:1;
1375 uint32_t PGPDO17:1;
1376 uint32_t PGPDO18:1;
1377 uint32_t PGPDO19:1;
1378 uint32_t PGPDO20:1;
1379 uint32_t PGPDO21:1;
1380 uint32_t PGPDO22:1;
1381 uint32_t PGPDO23:1;
1382 uint32_t PGPDO24:1;
1383 uint32_t PGPDO25:1;
1384 uint32_t PGPDO26:1;
1385 uint32_t PGPDO27:1;
1386 uint32_t PGPDO28:1;
1387 uint32_t PGPDO29:1;
1388 uint32_t PGPDO30:1;
1389 uint32_t PGPDO31:1;
1390 } B;
1391 } PGPDO[16];
1392
1393 union { /* Parallel GPIO Pin Data Input Register */
1394 uint32_t R;
1395 struct {
1396 uint32_t PGPDI0:1;
1397 uint32_t PGPDI1:1;
1398 uint32_t PGPDI2:1;
1399 uint32_t PGPDI3:1;
1400 uint32_t PGPDI4:1;
1401 uint32_t PGPDI5:1;
1402 uint32_t PGPDI6:1;
1403 uint32_t PGPDI7:1;
1404 uint32_t PGPDI8:1;
1405 uint32_t PGPDI9:1;
1406 uint32_t PGPDI10:1;
1407 uint32_t PGPDI11:1;
1408 uint32_t PGPDI12:1;
1409 uint32_t PGPDI13:1;
1410 uint32_t PGPDI14:1;
1411 uint32_t PGPDI15:1;
1412 uint32_t PGPDI16:1;
1413 uint32_t PGPDI17:1;
1414 uint32_t PGPDI18:1;
1415 uint32_t PGPDI19:1;
1416 uint32_t PGPDI20:1;
1417 uint32_t PGPDI21:1;
1418 uint32_t PGPDI22:1;
1419 uint32_t PGPDI23:1;
1420 uint32_t PGPDI24:1;
1421 uint32_t PGPDI25:1;
1422 uint32_t PGPDI26:1;
1423 uint32_t PGPDI27:1;
1424 uint32_t PGPDI28:1;
1425 uint32_t PGPDI29:1;
1426 uint32_t PGPDI30:1;
1427 uint32_t PGPDI31:1;
1428 } B;
1429 } PGPDI[16];
1430
1431 union { /* Masked Parallel GPIO Pin Data Input Register */
1432 uint32_t R;
1433 struct {
1434 uint32_t MASK0:1;
1435 uint32_t MASK1:1;
1436 uint32_t MASK2:1;
1437 uint32_t MASK3:1;
1438 uint32_t MASK4:1;
1439 uint32_t MASK5:1;
1440 uint32_t MASK6:1;
1441 uint32_t MASK7:1;
1442 uint32_t MASK8:1;
1443 uint32_t MASK9:1;
1444 uint32_t MASK10:1;
1445 uint32_t MASK11:1;
1446 uint32_t MASK12:1;
1447 uint32_t MASK13:1;
1448 uint32_t MASK14:1;
1449 uint32_t MASK15:1;
1450 uint32_t DATA0:1;
1451 uint32_t DATA1:1;
1452 uint32_t DATA2:1;
1453 uint32_t DATA3:1;
1454 uint32_t DATA4:1;
1455 uint32_t DATA5:1;
1456 uint32_t DATA6:1;
1457 uint32_t DATA7:1;
1458 uint32_t DATA8:1;
1459 uint32_t DATA9:1;
1460 uint32_t DATA10:1;
1461 uint32_t DATA11:1;
1462 uint32_t DATA12:1;
1463 uint32_t DATA13:1;
1464 uint32_t DATA14:1;
1465 uint32_t DATA15:1;
1466 } B;
1467 } MPGPDO[32];
1468
1469 union { /* DSPI_A Mask Output High Register */
1470 uint32_t R;
1471 struct {
1472 uint32_t MASK0:1;
1473 uint32_t MASK1:1;
1474 uint32_t MASK2:1;
1475 uint32_t MASK3:1;
1476 uint32_t MASK4:1;
1477 uint32_t MASK5:1;
1478 uint32_t MASK6:1;
1479 uint32_t MASK7:1;
1480 uint32_t MASK8:1;
1481 uint32_t MASK9:1;
1482 uint32_t MASK10:1;
1483 uint32_t MASK11:1;
1484 uint32_t MASK12:1;
1485 uint32_t MASK13:1;
1486 uint32_t MASK14:1;
1487 uint32_t MASK15:1;
1488 uint32_t DATA0:1;
1489 uint32_t DATA1:1;
1490 uint32_t DATA2:1;
1491 uint32_t DATA3:1;
1492 uint32_t DATA4:1;
1493 uint32_t DATA5:1;
1494 uint32_t DATA6:1;
1495 uint32_t DATA7:1;
1496 uint32_t DATA8:1;
1497 uint32_t DATA9:1;
1498 uint32_t DATA10:1;
1499 uint32_t DATA11:1;
1500 uint32_t DATA12:1;
1501 uint32_t DATA13:1;
1502 uint32_t DATA14:1;
1503 uint32_t DATA15:1;
1504 } B;
1505 } DSPIAH;
1506
1507 union { /* DSPI_A Mask Output Low Register */
1508 uint32_t R;
1509 struct {
1510 uint32_t MASK16:1;
1511 uint32_t MASK17:1;
1512 uint32_t MASK18:1;
1513 uint32_t MASK19:1;
1514 uint32_t MASK20:1;
1515 uint32_t MASK21:1;
1516 uint32_t MASK22:1;
1517 uint32_t MASK23:1;
1518 uint32_t MASK24:1;
1519 uint32_t MASK25:1;
1520 uint32_t MASK26:1;
1521 uint32_t MASK27:1;
1522 uint32_t MASK28:1;
1523 uint32_t MASK29:1;
1524 uint32_t MASK30:1;
1525 uint32_t MASK31:1;
1526 uint32_t DATA16:1;
1527 uint32_t DATA17:1;
1528 uint32_t DATA18:1;
1529 uint32_t DATA19:1;
1530 uint32_t DATA20:1;
1531 uint32_t DATA21:1;
1532 uint32_t DATA22:1;
1533 uint32_t DATA23:1;
1534 uint32_t DATA24:1;
1535 uint32_t DATA25:1;
1536 uint32_t DATA26:1;
1537 uint32_t DATA27:1;
1538 uint32_t DATA28:1;
1539 uint32_t DATA29:1;
1540 uint32_t DATA30:1;
1541 uint32_t DATA31:1;
1542 } B;
1543 } DSPIAL;
1544
1545 union { /* DSPI_B Mask Output High Register */
1546 uint32_t R;
1547 struct {
1548 uint32_t MASK0:1;
1549 uint32_t MASK1:1;
1550 uint32_t MASK2:1;
1551 uint32_t MASK3:1;
1552 uint32_t MASK4:1;
1553 uint32_t MASK5:1;
1554 uint32_t MASK6:1;
1555 uint32_t MASK7:1;
1556 uint32_t MASK8:1;
1557 uint32_t MASK9:1;
1558 uint32_t MASK10:1;
1559 uint32_t MASK11:1;
1560 uint32_t MASK12:1;
1561 uint32_t MASK13:1;
1562 uint32_t MASK14:1;
1563 uint32_t MASK15:1;
1564 uint32_t DATA0:1;
1565 uint32_t DATA1:1;
1566 uint32_t DATA2:1;
1567 uint32_t DATA3:1;
1568 uint32_t DATA4:1;
1569 uint32_t DATA5:1;
1570 uint32_t DATA6:1;
1571 uint32_t DATA7:1;
1572 uint32_t DATA8:1;
1573 uint32_t DATA9:1;
1574 uint32_t DATA10:1;
1575 uint32_t DATA11:1;
1576 uint32_t DATA12:1;
1577 uint32_t DATA13:1;
1578 uint32_t DATA14:1;
1579 uint32_t DATA15:1;
1580 } B;
1581 } DSPIBH;
1582
1583 union { /* DSPI_B Mask Output Low Register */
1584 uint32_t R;
1585 struct {
1586 uint32_t MASK16:1;
1587 uint32_t MASK17:1;
1588 uint32_t MASK18:1;
1589 uint32_t MASK19:1;
1590 uint32_t MASK20:1;
1591 uint32_t MASK21:1;
1592 uint32_t MASK22:1;
1593 uint32_t MASK23:1;
1594 uint32_t MASK24:1;
1595 uint32_t MASK25:1;
1596 uint32_t MASK26:1;
1597 uint32_t MASK27:1;
1598 uint32_t MASK28:1;
1599 uint32_t MASK29:1;
1600 uint32_t MASK30:1;
1601 uint32_t MASK31:1;
1602 uint32_t DATA16:1;
1603 uint32_t DATA17:1;
1604 uint32_t DATA18:1;
1605 uint32_t DATA19:1;
1606 uint32_t DATA20:1;
1607 uint32_t DATA21:1;
1608 uint32_t DATA22:1;
1609 uint32_t DATA23:1;
1610 uint32_t DATA24:1;
1611 uint32_t DATA25:1;
1612 uint32_t DATA26:1;
1613 uint32_t DATA27:1;
1614 uint32_t DATA28:1;
1615 uint32_t DATA29:1;
1616 uint32_t DATA30:1;
1617 uint32_t DATA31:1;
1618 } B;
1619 } DSPIBL;
1620
1621 union { /* DSPI_C Mask Output High Register */
1622 uint32_t R;
1623 struct {
1624 uint32_t MASK0:1;
1625 uint32_t MASK1:1;
1626 uint32_t MASK2:1;
1627 uint32_t MASK3:1;
1628 uint32_t MASK4:1;
1629 uint32_t MASK5:1;
1630 uint32_t MASK6:1;
1631 uint32_t MASK7:1;
1632 uint32_t MASK8:1;
1633 uint32_t MASK9:1;
1634 uint32_t MASK10:1;
1635 uint32_t MASK11:1;
1636 uint32_t MASK12:1;
1637 uint32_t MASK13:1;
1638 uint32_t MASK14:1;
1639 uint32_t MASK15:1;
1640 uint32_t DATA0:1;
1641 uint32_t DATA1:1;
1642 uint32_t DATA2:1;
1643 uint32_t DATA3:1;
1644 uint32_t DATA4:1;
1645 uint32_t DATA5:1;
1646 uint32_t DATA6:1;
1647 uint32_t DATA7:1;
1648 uint32_t DATA8:1;
1649 uint32_t DATA9:1;
1650 uint32_t DATA10:1;
1651 uint32_t DATA11:1;
1652 uint32_t DATA12:1;
1653 uint32_t DATA13:1;
1654 uint32_t DATA14:1;
1655 uint32_t DATA15:1;
1656 } B;
1657 } DSPICH;
1658
1659 union { /* DSPI_C Mask Output Low Register */
1660 uint32_t R;
1661 struct {
1662 uint32_t MASK16:1;
1663 uint32_t MASK17:1;
1664 uint32_t MASK18:1;
1665 uint32_t MASK19:1;
1666 uint32_t MASK20:1;
1667 uint32_t MASK21:1;
1668 uint32_t MASK22:1;
1669 uint32_t MASK23:1;
1670 uint32_t MASK24:1;
1671 uint32_t MASK25:1;
1672 uint32_t MASK26:1;
1673 uint32_t MASK27:1;
1674 uint32_t MASK28:1;
1675 uint32_t MASK29:1;
1676 uint32_t MASK30:1;
1677 uint32_t MASK31:1;
1678 uint32_t DATA16:1;
1679 uint32_t DATA17:1;
1680 uint32_t DATA18:1;
1681 uint32_t DATA19:1;
1682 uint32_t DATA20:1;
1683 uint32_t DATA21:1;
1684 uint32_t DATA22:1;
1685 uint32_t DATA23:1;
1686 uint32_t DATA24:1;
1687 uint32_t DATA25:1;
1688 uint32_t DATA26:1;
1689 uint32_t DATA27:1;
1690 uint32_t DATA28:1;
1691 uint32_t DATA29:1;
1692 uint32_t DATA30:1;
1693 uint32_t DATA31:1;
1694 } B;
1695 } DSPICL;
1696
1697 union { /* DSPI_D Mask Output High Register */
1698 uint32_t R;
1699 struct {
1700 uint32_t MASK0:1;
1701 uint32_t MASK1:1;
1702 uint32_t MASK2:1;
1703 uint32_t MASK3:1;
1704 uint32_t MASK4:1;
1705 uint32_t MASK5:1;
1706 uint32_t MASK6:1;
1707 uint32_t MASK7:1;
1708 uint32_t MASK8:1;
1709 uint32_t MASK9:1;
1710 uint32_t MASK10:1;
1711 uint32_t MASK11:1;
1712 uint32_t MASK12:1;
1713 uint32_t MASK13:1;
1714 uint32_t MASK14:1;
1715 uint32_t MASK15:1;
1716 uint32_t DATA0:1;
1717 uint32_t DATA1:1;
1718 uint32_t DATA2:1;
1719 uint32_t DATA3:1;
1720 uint32_t DATA4:1;
1721 uint32_t DATA5:1;
1722 uint32_t DATA6:1;
1723 uint32_t DATA7:1;
1724 uint32_t DATA8:1;
1725 uint32_t DATA9:1;
1726 uint32_t DATA10:1;
1727 uint32_t DATA11:1;
1728 uint32_t DATA12:1;
1729 uint32_t DATA13:1;
1730 uint32_t DATA14:1;
1731 uint32_t DATA15:1;
1732 } B;
1733 } DSPIDH;
1734
1735 union { /* DSPI_D Mask Output Low Register */
1736 uint32_t R;
1737 struct {
1738 uint32_t MASK16:1;
1739 uint32_t MASK17:1;
1740 uint32_t MASK18:1;
1741 uint32_t MASK19:1;
1742 uint32_t MASK20:1;
1743 uint32_t MASK21:1;
1744 uint32_t MASK22:1;
1745 uint32_t MASK23:1;
1746 uint32_t MASK24:1;
1747 uint32_t MASK25:1;
1748 uint32_t MASK26:1;
1749 uint32_t MASK27:1;
1750 uint32_t MASK28:1;
1751 uint32_t MASK29:1;
1752 uint32_t MASK30:1;
1753 uint32_t MASK31:1;
1754 uint32_t DATA16:1;
1755 uint32_t DATA17:1;
1756 uint32_t DATA18:1;
1757 uint32_t DATA19:1;
1758 uint32_t DATA20:1;
1759 uint32_t DATA21:1;
1760 uint32_t DATA22:1;
1761 uint32_t DATA23:1;
1762 uint32_t DATA24:1;
1763 uint32_t DATA25:1;
1764 uint32_t DATA26:1;
1765 uint32_t DATA27:1;
1766 uint32_t DATA28:1;
1767 uint32_t DATA29:1;
1768 uint32_t DATA30:1;
1769 uint32_t DATA31:1;
1770 } B;
1771 } DSPIDL;
1772
1773 int32_t SIU_reserved0D20[8]; /* 0x0D20-0x0D3F */
1774
1775 union { /* ETPU B Select Register */
1776 uint32_t R;
1777 struct {
1778 uint32_t ETPUB15:1;
1779 uint32_t ETPUB14:1;
1780 uint32_t ETPUB13:1;
1781 uint32_t ETPUB12:1;
1782 uint32_t ETPUB11:1;
1783 uint32_t ETPUB10:1;
1784 uint32_t ETPUB9:1;
1785 uint32_t ETPUB8:1;
1786 uint32_t ETPUB7:1;
1787 uint32_t ETPUB6:1;
1788 uint32_t ETPUB5:1;
1789 uint32_t ETPUB4:1;
1790 uint32_t ETPUB3:1;
1791 uint32_t ETPUB2:1;
1792 uint32_t ETPUB1:1;
1793 uint32_t ETPUB0:1;
1794 uint32_t ETPUB31:1;
1795 uint32_t ETPUB30:1;
1796 uint32_t ETPUB29:1;
1797 uint32_t ETPUB28:1;
1798 uint32_t ETPUB27:1;
1799 uint32_t ETPUB26:1;
1800 uint32_t ETPUB25:1;
1801 uint32_t ETPUB24:1;
1802 uint32_t ETPUB23:1;
1803 uint32_t ETPUB22:1;
1804 uint32_t ETPUB21:1;
1805 uint32_t ETPUB20:1;
1806 uint32_t ETPUB19:1;
1807 uint32_t ETPUB18:1;
1808 uint32_t ETPUB17:1;
1809 uint32_t ETPUB16:1;
1810 } B ;
1811 } ETPUBA;
1812
1813 union { /* EMIOS A Select Register */
1814 uint32_t R;
1815 struct {
1816 uint32_t EMIOS7:1;
1817 uint32_t EMIOS6:1;
1818 uint32_t EMIOS5:1;
1819 uint32_t EMIOS4:1;
1820 uint32_t EMIOS3:1;
1821 uint32_t EMIOS2:1;
1822 uint32_t EMIOS1:1;
1823 uint32_t EMIOS0:1;
1824 uint32_t EMIOS8:1;
1825 uint32_t EMIOS9:1;
1826 uint32_t EMIOS10:1;
1827 uint32_t EMIOS11:1;
1828 uint32_t EMIOS12:1;
1829 uint32_t EMIOS13:1;
1830 uint32_t EMIOS14:1;
1831 uint32_t EMIOS15:1;
1832 uint32_t EMIOS16:1;
1833 uint32_t EMIOS17:1;
1834 uint32_t EMIOS18:1;
1835 uint32_t EMIOS19:1;
1836 uint32_t EMIOS20:1;
1837 uint32_t EMIOS21:1;
1838 uint32_t EMIOS22:1;
1839 uint32_t EMIOS23:1;
1840 uint32_t EMIOS0_0:1;
1841 uint32_t EMIOS1_1:1;
1842 uint32_t EMIOS2_2:1;
1843 uint32_t EMIOS3_3:1;
1844 uint32_t EMIOS4_4:1;
1845 uint32_t EMIOS5_5:1;
1846 uint32_t EMIOS6_6:1;
1847 uint32_t EMIOS7_7:1;
1848 } B;
1849 } EMIOSA;
1850
1851 union { /* DSPIAH/L Select Register for DSPI A */
1852 uint32_t R;
1853 struct {
1854 uint32_t DSPIAH0:1;
1855 uint32_t DSPIAH1:1;
1856 uint32_t DSPIAH2:1;
1857 uint32_t DSPIAH3:1;
1858 uint32_t DSPIAH4:1;
1859 uint32_t DSPIAH5:1;
1860 uint32_t DSPIAH6:1;
1861 uint32_t DSPIAH7:1;
1862 uint32_t DSPIAH8:1;
1863 uint32_t DSPIAH9:1;
1864 uint32_t DSPIAH10:1;
1865 uint32_t DSPIAH11:1;
1866 uint32_t DSPIAH12:1;
1867 uint32_t DSPIAH13:1;
1868 uint32_t DSPIAH14:1;
1869 uint32_t DSPIAH15:1;
1870 uint32_t DSPIAL16:1;
1871 uint32_t DSPIAL17:1;
1872 uint32_t DSPIAL18:1;
1873 uint32_t DSPIAL19:1;
1874 uint32_t DSPIAL20:1;
1875 uint32_t DSPIAL21:1;
1876 uint32_t DSPIAL22:1;
1877 uint32_t DSPIAL23:1;
1878 uint32_t DSPIAL24:1;
1879 uint32_t DSPIAL25:1;
1880 uint32_t DSPIAL26:1;
1881 uint32_t DSPIAL27:1;
1882 uint32_t DSPIAL28:1;
1883 uint32_t DSPIAL29:1;
1884 uint32_t DSPIAL30:1;
1885 uint32_t DSPIAL31:1;
1886 } B;
1887 } DSPIAHLA;
1888
1889 int32_t SIU_reserved0D4C; /* 0x0D4C-0x0D4F */
1890
1891 union { /* ETPU A Select Register */
1892 uint32_t R;
1893 struct {
1894 uint32_t ETPUA23:1;
1895 uint32_t ETPUA22:1;
1896 uint32_t ETPUA21:1;
1897 uint32_t ETPUA20:1;
1898 uint32_t ETPUA19:1;
1899 uint32_t ETPUA18:1;
1900 uint32_t ETPUA17:1;
1901 uint32_t ETPUA16:1;
1902 uint32_t ETPUA29:1;
1903 uint32_t ETPUA28:1;
1904 uint32_t ETPUA27:1;
1905 uint32_t ETPUA26:1;
1906 uint32_t ETPUA25:1;
1907 uint32_t ETPUA24:1;
1908 uint32_t ETPUA31:1;
1909 uint32_t ETPUA30:1;
1910 uint32_t ETPUA12:1;
1911 uint32_t ETPUA13:1;
1912 uint32_t ETPUA14:1;
1913 uint32_t ETPUA15:1;
1914 uint32_t ETPUA0:1;
1915 uint32_t ETPUA1:1;
1916 uint32_t ETPUA2:1;
1917 uint32_t ETPUA3:1;
1918 uint32_t ETPUA4:1;
1919 uint32_t ETPUA5:1;
1920 uint32_t ETPUA6:1;
1921 uint32_t ETPUA7:1;
1922 uint32_t ETPUA8:1;
1923 uint32_t ETPUA9:1;
1924 uint32_t ETPUA10:1;
1925 uint32_t ETPUA11:1;
1926 } B ;
1927 } ETPUAB;
1928
1929 union { /* EMIOS B Select Register */
1930 uint32_t R;
1931 struct {
1932 uint32_t EMIOS11:1;
1933 uint32_t EMIOS10:1;
1934 uint32_t EMIOS9:1;
1935 uint32_t EMIOS8:1;
1936 uint32_t EMIOS6:1;
1937 uint32_t EMIOS5:1;
1938 uint32_t EMIOS4:1;
1939 uint32_t EMIOS3:1;
1940 uint32_t EMIOS2:1;
1941 uint32_t EMIOS1:1;
1942 uint32_t EMIOS0:1;
1943 uint32_t EMIOS23:1;
1944 uint32_t EMIOS15:1;
1945 uint32_t EMIOS14:1;
1946 uint32_t EMIOS13:1;
1947 uint32_t EMIOS12:1;
1948 uint32_t EMIOS23_23:1;
1949 uint32_t EMIOS15_15:1;
1950 uint32_t EMIOS14_14:1;
1951 uint32_t EMIOS13_13:1;
1952 uint32_t EMIOS12_12:1;
1953 uint32_t EMIOS11_11:1;
1954 uint32_t EMIOS10_10:1;
1955 uint32_t EMIOS9_9:1;
1956 uint32_t EMIOS8_8:1;
1957 uint32_t EMIOS6_6:1;
1958 uint32_t EMIOS5_5:1;
1959 uint32_t EMIOS4_4:1;
1960 uint32_t EMIOS3_3:1;
1961 uint32_t EMIOS2_2:1;
1962 uint32_t EMIOS1_1:1;
1963 uint32_t EMIOS0_0:1;
1964 } B;
1965 } EMIOSB;
1966
1967 union { /* DSPIBH/L Select Register for DSPI B */
1968 uint32_t R;
1969 struct {
1970 uint32_t DSPIBH0:1;
1971 uint32_t DSPIBH1:1;
1972 uint32_t DSPIBH2:1;
1973 uint32_t DSPIBH3:1;
1974 uint32_t DSPIBH4:1;
1975 uint32_t DSPIBH5:1;
1976 uint32_t DSPIBH6:1;
1977 uint32_t DSPIBH7:1;
1978 uint32_t DSPIBH8:1;
1979 uint32_t DSPIBH9:1;
1980 uint32_t DSPIBH10:1;
1981 uint32_t DSPIBH11:1;
1982 uint32_t DSPIBH12:1;
1983 uint32_t DSPIBH13:1;
1984 uint32_t DSPIBH14:1;
1985 uint32_t DSPIBH15:1;
1986 uint32_t DSPIBL16:1;
1987 uint32_t DSPIBL17:1;
1988 uint32_t DSPIBL18:1;
1989 uint32_t DSPIBL19:1;
1990 uint32_t DSPIBL20:1;
1991 uint32_t DSPIBL21:1;
1992 uint32_t DSPIBL22:1;
1993 uint32_t DSPIBL23:1;
1994 uint32_t DSPIBL24:1;
1995 uint32_t DSPIBL25:1;
1996 uint32_t DSPIBL26:1;
1997 uint32_t DSPIBL27:1;
1998 uint32_t DSPIBL28:1;
1999 uint32_t DSPIBL29:1;
2000 uint32_t DSPIBL30:1;
2001 uint32_t DSPIBL31:1;
2002 } B;
2003 } DSPIBHLB;
2004
2005 int32_t SIU_reserved0D5C; /* 0x0D5C-0x0D5F */
2006
2007 union { /* ETPU A Select Register */
2008 uint32_t R;
2009 struct {
2010 uint32_t ETPUA12:1;
2011 uint32_t ETPUA13:1;
2012 uint32_t ETPUA14:1;
2013 uint32_t ETPUA15:1;
2014 uint32_t ETPUA0:1;
2015 uint32_t ETPUA1:1;
2016 uint32_t ETPUA2:1;
2017 uint32_t ETPUA3:1;
2018 uint32_t ETPUA4:1;
2019 uint32_t ETPUA5:1;
2020 uint32_t ETPUA6:1;
2021 uint32_t ETPUA7:1;
2022 uint32_t ETPUA8:1;
2023 uint32_t ETPUA9:1;
2024 uint32_t ETPUA10:1;
2025 uint32_t ETPUA11:1;
2026 uint32_t ETPUA23:1;
2027 uint32_t ETPUA22:1;
2028 uint32_t ETPUA21:1;
2029 uint32_t ETPUA20:1;
2030 uint32_t ETPUA19:1;
2031 uint32_t ETPUA18:1;
2032 uint32_t ETPUA17:1;
2033 uint32_t ETPUA16:1;
2034 uint32_t ETPUA29:1;
2035 uint32_t ETPUA28:1;
2036 uint32_t ETPUA27:1;
2037 uint32_t ETPUA26:1;
2038 uint32_t ETPUA25:1;
2039 uint32_t ETPUA24:1;
2040 uint32_t ETPUA31:1;
2041 uint32_t ETPUA30:1;
2042 } B ;
2043 } ETPUAC;
2044
2045 union { /* EMIOS C Select Register */
2046 uint32_t R;
2047 struct {
2048 uint32_t EMIOS12:1;
2049 uint32_t EMIOS13:1;
2050 uint32_t EMIOS14:1;
2051 uint32_t EMIOS15:1;
2052 uint32_t EMIOS23:1;
2053 uint32_t EMIOS0:1;
2054 uint32_t EMIOS1:1;
2055 uint32_t EMIOS2:1;
2056 uint32_t EMIOS3:1;
2057 uint32_t EMIOS4:1;
2058 uint32_t EMIOS5:1;
2059 uint32_t EMIOS6:1;
2060 uint32_t EMIOS8:1;
2061 uint32_t EMIOS9:1;
2062 uint32_t EMIOS10:1;
2063 uint32_t EMIOS11:1;
2064 uint32_t EMIOS23_23:1;
2065 uint32_t EMIOS22:1;
2066 uint32_t EMIOS21:1;
2067 uint32_t EMIOS20:1;
2068 uint32_t EMIOS19:1;
2069 uint32_t EMIOS18:1;
2070 uint32_t EMIOS17:1;
2071 uint32_t EMIOS16:1;
2072 uint32_t EMIOS29:1;
2073 uint32_t EMIOS28:1;
2074 uint32_t EMIOS27:1;
2075 uint32_t EMIOS26:1;
2076 uint32_t EMIOS25:1;
2077 uint32_t EMIOS24:1;
2078 uint32_t EMIOS31:1;
2079 uint32_t EMIOS30:1;
2080 } B;
2081 } EMIOSC;
2082
2083 union { /* DSPICH/L Select Register for DSPI C */
2084 uint32_t R;
2085 struct {
2086 uint32_t DSPICH0:1;
2087 uint32_t DSPICH1:1;
2088 uint32_t DSPICH2:1;
2089 uint32_t DSPICH3:1;
2090 uint32_t DSPICH4:1;
2091 uint32_t DSPICH5:1;
2092 uint32_t DSPICH6:1;
2093 uint32_t DSPICH7:1;
2094 uint32_t DSPICH8:1;
2095 uint32_t DSPICH9:1;
2096 uint32_t DSPICH10:1;
2097 uint32_t DSPICH11:1;
2098 uint32_t DSPICH12:1;
2099 uint32_t DSPICH13:1;
2100 uint32_t DSPICH14:1;
2101 uint32_t DSPICH15:1;
2102 uint32_t DSPICL16:1;
2103 uint32_t DSPICL17:1;
2104 uint32_t DSPICL18:1;
2105 uint32_t DSPICL19:1;
2106 uint32_t DSPICL20:1;
2107 uint32_t DSPICL21:1;
2108 uint32_t DSPICL22:1;
2109 uint32_t DSPICL23:1;
2110 uint32_t DSPICL24:1;
2111 uint32_t DSPICL25:1;
2112 uint32_t DSPICL26:1;
2113 uint32_t DSPICL27:1;
2114 uint32_t DSPICL28:1;
2115 uint32_t DSPICL29:1;
2116 uint32_t DSPICL30:1;
2117 uint32_t DSPICL31:1;
2118 } B;
2119 } DSPICHLC;
2120
2121 int32_t SIU_reserved0D6C; /* 0x0D6C-0x0D6F */
2122
2123 union { /* ETPU B Select Register */
2124 uint32_t R;
2125 struct {
2126 uint32_t ETPUB21:1;
2127 uint32_t ETPUB20:1;
2128 uint32_t ETPUB19:1;
2129 uint32_t ETPUB18:1;
2130 uint32_t ETPUB17:1;
2131 uint32_t ETPUB16:1;
2132 uint32_t:4;
2133 uint32_t ETPUB29:1;
2134 uint32_t ETPUB28:1;
2135 uint32_t ETPUB27:1;
2136 uint32_t ETPUB26:1;
2137 uint32_t ETPUB25:1;
2138 uint32_t ETPUB24:1;
2139 uint32_t:16;
2140 } B ;
2141 } ETPUBD;
2142
2143 union { /* EMIOS D Select Register */
2144 uint32_t R;
2145 struct {
2146 uint32_t:6;
2147 uint32_t EMIOS11:1;
2148 uint32_t EMIOS10:1;
2149 uint32_t EMIOS13:1;
2150 uint32_t EMIOS12:1;
2151 uint32_t:22;
2152 } B;
2153 } EMIOSD;
2154
2155 union { /* DSPIDH/L Select Register for DSPI D */
2156 uint32_t R;
2157 struct {
2158 uint32_t:32;
2159 } B;
2160 } DSPIDHLD;
2161
2162 int32_t SIU_reserved0D7C; /* 0x0D7C-0x0D7F */
2163
2164 int32_t SIU_reserved0D80[32]; /* 0x0D80-0x0DFF */
2165
2166 union { /* GPIO Pin Data Input Registers */
2167 uint8_t R;
2168 struct {
2169 uint8_t:7;
2170 uint8_t PDI:1;
2171 } B;
2172 } GPDI0_511[512];
2173
2174 uint32_t SIU_reserved1000[3072]; /* 0x1000-0x3FFF */
2175 };
2176
2177/****************************************************************************/
2178/* MODULE : EMIOS */
2179/****************************************************************************/
2180
2181 struct EMIOS_tag {
2182
2183 union EMIOS_MCR_tag { /* Module Configuration Register */
2184 uint32_t R;
2185 struct {
2186 uint32_t:1;
2187 uint32_t MDIS:1;
2188 uint32_t FRZ:1;
2189 uint32_t GTBE:1;
2190 uint32_t ETB:1;
2191 uint32_t GPREN:1;
2192 uint32_t:6;
2193 uint32_t SRV:4;
2194 uint32_t GPRE:8;
2195 uint32_t:8;
2196 } B;
2197 } MCR;
2198
2199 union { /* Global FLAG Register */
2200 uint32_t R;
2201 struct {
2202 uint32_t F31:1;
2203 uint32_t F30:1;
2204 uint32_t F29:1;
2205 uint32_t F28:1;
2206 uint32_t F27:1;
2207 uint32_t F26:1;
2208 uint32_t F25:1;
2209 uint32_t F24:1;
2210 uint32_t F23:1;
2211 uint32_t F22:1;
2212 uint32_t F21:1;
2213 uint32_t F20:1;
2214 uint32_t F19:1;
2215 uint32_t F18:1;
2216 uint32_t F17:1;
2217 uint32_t F16:1;
2218 uint32_t F15:1;
2219 uint32_t F14:1;
2220 uint32_t F13:1;
2221 uint32_t F12:1;
2222 uint32_t F11:1;
2223 uint32_t F10:1;
2224 uint32_t F9:1;
2225 uint32_t F8:1;
2226 uint32_t F7:1;
2227 uint32_t F6:1;
2228 uint32_t F5:1;
2229 uint32_t F4:1;
2230 uint32_t F3:1;
2231 uint32_t F2:1;
2232 uint32_t F1:1;
2233 uint32_t F0:1;
2234 } B;
2235 } GFR;
2236
2237 union { /* Output Update Disable Register */
2238 uint32_t R;
2239 struct {
2240 uint32_t OU31:1;
2241 uint32_t OU30:1;
2242 uint32_t OU29:1;
2243 uint32_t OU28:1;
2244 uint32_t OU27:1;
2245 uint32_t OU26:1;
2246 uint32_t OU25:1;
2247 uint32_t OU24:1;
2248 uint32_t OU23:1;
2249 uint32_t OU22:1;
2250 uint32_t OU21:1;
2251 uint32_t OU20:1;
2252 uint32_t OU19:1;
2253 uint32_t OU18:1;
2254 uint32_t OU17:1;
2255 uint32_t OU16:1;
2256 uint32_t OU15:1;
2257 uint32_t OU14:1;
2258 uint32_t OU13:1;
2259 uint32_t OU12:1;
2260 uint32_t OU11:1;
2261 uint32_t OU10:1;
2262 uint32_t OU9:1;
2263 uint32_t OU8:1;
2264 uint32_t OU7:1;
2265 uint32_t OU6:1;
2266 uint32_t OU5:1;
2267 uint32_t OU4:1;
2268 uint32_t OU3:1;
2269 uint32_t OU2:1;
2270 uint32_t OU1:1;
2271 uint32_t OU0:1;
2272 } B;
2273 } OUDR;
2274
2275 uint32_t eMIOS_reserved000C[5]; /* 0x000C-0x001F */
2276
2277 struct EMIOS_CH_tag {
2278 union { /* Channel A Data Register */
2279 uint32_t R;
2280 } CADR;
2281
2282 union { /* Channel B Data Register */
2283 uint32_t R;
2284 } CBDR;
2285
2286 union { /* Channel Counter Register */
2287 uint32_t R;
2288 } CCNTR;
2289
2290 union EMIOS_CCR_tag {/* Channel Control Register */
2291 uint32_t R;
2292 struct {
2293 uint32_t FREN:1;
2294 uint32_t ODIS:1;
2295 uint32_t ODISSL:2;
2296 uint32_t UCPRE:2;
2297 uint32_t UCPREN:1;
2298 uint32_t DMA:1;
2299 uint32_t:1;
2300 uint32_t IF:4;
2301 uint32_t FCK:1;
2302 uint32_t FEN:1;
2303 uint32_t:3;
2304 uint32_t FORCMA:1;
2305 uint32_t FORCMB:1;
2306 uint32_t:1;
2307 uint32_t BSL:2;
2308 uint32_t EDSEL:1;
2309 uint32_t EDPOL:1;
2310 uint32_t MODE:7;
2311 } B;
2312 } CCR;
2313
2314 union EMIOS_CSR_tag {/* Channel Status Register */
2315 uint32_t R;
2316 struct {
2317 uint32_t OVR:1;
2318 uint32_t:15;
2319 uint32_t OVFL:1;
2320 uint32_t:12;
2321 uint32_t UCIN:1;
2322 uint32_t UCOUT:1;
2323 uint32_t FLAG:1;
2324 } B;
2325 } CSR;
2326
2327 union { /* Alternate Channel A Data Register */
2328 uint32_t R;
2329 } ALTA;
2330
2331 uint32_t eMIOS_channel_reserved0018[2]; /* 0x0018-0x001F */
2332
2333 } CH[32];
2334
2335 uint32_t eMIOS_reserved0420[3832]; /* 0x0420-0x3FFF */
2336
2337 };
2338
2339/****************************************************************************/
2340/* MODULE : PMC */
2341/****************************************************************************/
2342
2343 struct PMC_tag {
2344
2345 union {
2346 uint32_t R;
2347 struct {
2348 uint32_t LVRER:1;
2349 uint32_t LVREH:1;
2350 uint32_t LVRE50:1;
2351 uint32_t LVRE33:1;
2352 uint32_t LVREC:1;
2353 uint32_t LVREA:1;
2354 uint32_t:1;
2355 uint32_t:1;
2356 uint32_t LVIER:1;
2357 uint32_t LVIEH:1;
2358 uint32_t LVIE50:1;
2359 uint32_t LVIE33:1;
2360 uint32_t LVIEC:1;
2361 uint32_t LVIEA:1;
2362 uint32_t:1;
2363 uint32_t TLK:1;
2364 uint32_t:16;
2365 } B;
2366 } MCR; /* Module Configuration Register */
2367
2368 union {
2369 uint32_t R;
2370 struct {
2371 uint32_t :8;
2372 uint32_t LVDATRIM:4;
2373 uint32_t LVDREGTRIM:4;
2374 uint32_t VDD33TRIM:4;
2375 uint32_t LVD33TRIM:4;
2376 uint32_t VDDCTRIM:4;
2377 uint32_t LVDCTRIM:4;
2378 } B;
2379 } TRIMR; /* Trimming register */
2380
2381 union {
2382 uint32_t R;
2383 struct {
2384 uint32_t :5;
2385 uint32_t LVFSTBY:1;
2386 uint32_t BGRDY:1;
2387 uint32_t BGTS:1;
2388 uint32_t :5;
2389 uint32_t LVFCSTBY:1;
2390 uint32_t :2;
2391 uint32_t LVFCR:1;
2392 uint32_t LVFCH:1;
2393 uint32_t LVFC50:1;
2394 uint32_t LVFC33:1;
2395 uint32_t LVFCC:1;
2396 uint32_t LVFCA:1;
2397 uint32_t :2;
2398 uint32_t LVFR:1;
2399 uint32_t LVFH:1;
2400 uint32_t LVF50:1;
2401 uint32_t LVF33:1;
2402 uint32_t LVFC:1;
2403 uint32_t LVFA:1;
2404 uint32_t :2;
2405 } B;
2406 } SR; /* status register */
2407
2408 uint32_t PMC_reserved000C[4093]; /* 0x000C-0x3FFF */
2409 };
2410
2411/****************************************************************************/
2412/* MODULE :ETPU */
2413/****************************************************************************/
2414
2415/***************************Configuration Registers**************************/
2416
2417 struct ETPU_tag {
2418 union { /* MODULE CONFIGURATION REGISTER */
2419 uint32_t R;
2420 struct {
2421 uint32_t GEC:1; /* Global Exception Clear */
2422 uint32_t SDMERR:1; /* SDM Read Error */
2423 uint32_t WDTOA:1; /* Watchdog Timeout-eTPU_A */
2424 uint32_t WDTOB:1; /* Watchdog Timeout-eTPU_B */
2425 uint32_t MGE1:1; /* Microcode Global Exception-ETPU_A */
2426 uint32_t MGE2:1; /* Microcode Global Exception-ETPU_B */
2427 uint32_t ILF1:1; /* Illegal Instruction Flag-ETPU_A */
2428 uint32_t ILF2:1; /* Illegal Instruction Flag-ETPU_B */
2429 uint32_t:3;
2430 uint32_t SCMSIZE:5; /* Shared Code Memory size */
2431 uint32_t:4;
2432 uint32_t SCMMISC:1; /* SCM MISC Complete/Clear */
2433 uint32_t SCMMISF:1; /* SCM MISC Flag */
2434 uint32_t SCMMISEN:1; /* SCM MISC Enable */
2435 uint32_t:2;
2436 uint32_t VIS:1; /* SCM Visability */
2437 uint32_t:5;
2438 uint32_t GTBE:1; /* Global Time Base Enable */
2439 } B;
2440 } MCR;
2441
2442 union { /* COHERENT DUAL-PARAMETER CONTROL */
2443 uint32_t R;
2444 struct {
2445 uint32_t STS:1; /* Start Status bit */
2446 uint32_t CTBASE:5; /* Channel Transfer Base */
2447 uint32_t PBASE:10; /* Parameter Buffer Base Address */
2448 uint32_t PWIDTH:1; /* Parameter Width */
2449 uint32_t PARAM0:7; /* Channel Parameter 0 */
2450 uint32_t WR:1; /* Read/Write selection */
2451 uint32_t PARAM1:7; /* Channel Parameter 1 */
2452 } B;
2453 } CDCR;
2454
2455 uint32_t eTPU_reserved0008; /* 0x0008-0x000B */
2456
2457 union { /* MISC Compare Register */
2458 uint32_t R;
2459 struct {
2460 uint32_t ETPUMISCCMP:32;
2461 } B;
2462 } MISCCMPR;
2463
2464 union { /* SCM off-range Date Register */
2465 uint32_t R;
2466 struct {
2467 uint32_t ETPUSCMOFFDATA:32;
2468 } B;
2469 } SCMOFFDATAR;
2470
2471 union { /* ETPU_A Configuration Register */
2472 uint32_t R;
2473 struct {
2474 uint32_t FEND:1; /* Force END */
2475 uint32_t MDIS:1; /* Low power Stop */
2476 uint32_t:1;
2477 uint32_t STF:1; /* Stop Flag */
2478 uint32_t:4;
2479 uint32_t HLTF:1; /* Halt Mode Flag */
2480 uint32_t:3;
2481 uint32_t FCSS:1; /* Filter Clock Source Select */
2482 uint32_t FPSCK:3; /* Filter Prescaler Clock Control */
2483 uint32_t CDFC:2;
2484 uint32_t:1;
2485 uint32_t ERBA:5; /* Engine Relative Base Address */
2486 uint32_t SPPDIS:1; /* Schedule Priority Passing Disable */
2487 uint32_t:2;
2488 uint32_t ETB:5; /* Entry Table Base */
2489 } B;
2490 } ECR_A;
2491
2492 union { /* ETPU_B Configuration Register */
2493 uint32_t R;
2494 struct {
2495 uint32_t FEND:1; /* Force END */
2496 uint32_t MDIS:1; /* Low power Stop */
2497 uint32_t:1;
2498 uint32_t STF:1; /* Stop Flag */
2499 uint32_t:4;
2500 uint32_t HLTF:1; /* Halt Mode Flag */
2501 uint32_t:3;
2502 uint32_t FCSS:1; /* Filter Clock Source Select */
2503 uint32_t FPSCK:3; /* Filter Prescaler Clock Control */
2504 uint32_t CDFC:2;
2505 uint32_t:1;
2506 uint32_t ERBA:5; /* Engine Relative Base Address */
2507 uint32_t SPPDIS:1; /* Schedule Priority Passing Disable */
2508 uint32_t:2;
2509 uint32_t ETB:5; /* Entry Table Base */
2510 } B;
2511 } ECR_B;
2512
2513 uint32_t eTPU_reserved001C; /* 0x001C-0x001F */
2514
2515 union { /* ETPU_A Timebase Configuration Register */
2516 uint32_t R;
2517 struct {
2518 uint32_t TCR2CTL:3; /* TCR2 Clock/Gate Control */
2519 uint32_t TCRCF:2; /* TCRCLK Signal Filter Control */
2520 uint32_t AM:2; /* Angle Mode */
2521 uint32_t:3;
2522 uint32_t TCR2P:6; /* TCR2 Prescaler Control */
2523 uint32_t TCR1CTL:2; /* TCR1 Clock/Gate Control */
2524 uint32_t TCR1CS:1; /* TCR1 Clock Source */
2525 uint32_t:5;
2526 uint32_t TCR1P:8; /* TCR1 Prescaler Control */
2527 } B;
2528 } TBCR_A;
2529
2530 union { /* ETPU_A TCR1 Visibility Register */
2531 uint32_t R;
2532 struct {
2533 uint32_t:8;
2534 uint32_t TCR1:24;
2535 } B;
2536 } TB1R_A;
2537
2538 union { /* ETPU_A TCR2 Visibility Register */
2539 uint32_t R;
2540 struct {
2541 uint32_t:8;
2542 uint32_t TCR2:24;
2543 } B;
2544 } TB2R_A;
2545
2546 union { /* ETPU_A STAC Configuration Register */
2547 uint32_t R;
2548 struct {
2549 uint32_t REN1:1; /* Resource Enable TCR1 */
2550 uint32_t RSC1:1; /* Resource Control TCR1 */
2551 uint32_t:2;
2552 uint32_t SERVER_ID1:4; /* TCR1 Server ID */
2553 uint32_t:4;
2554 uint32_t SRV1:4; /* Resource Server Slot */
2555 uint32_t REN2:1; /* Resource Enable TCR2 */
2556 uint32_t RSC2:1; /* Resource Control TCR2 */
2557 uint32_t:2;
2558 uint32_t SERVER_ID2:4; /* TCR2 Server ID */
2559 uint32_t:4;
2560 uint32_t SRV2:4; /* Resource Server Slot */
2561 } B;
2562 } REDCR_A;
2563
2564 uint32_t eTPU_reserved0030[4]; /* 0x0030-0x003F */
2565
2566 union { /* ETPU_B Timebase Configuration Register */
2567 uint32_t R;
2568 struct {
2569 uint32_t TCR2CTL:3; /* TCR2 Clock/Gate Control */
2570 uint32_t TCRCF:2; /* TCRCLK Signal Filter Control */
2571 uint32_t AM:2; /* Angle Mode */
2572 uint32_t:3;
2573 uint32_t TCR2P:6; /* TCR2 Prescaler Control */
2574 uint32_t TCR1CTL:2; /* TCR1 Clock/Gate Control */
2575 uint32_t TCR1CS:1; /* TCR1 Clock Source */
2576 uint32_t:5;
2577 uint32_t TCR1P:8; /* TCR1 Prescaler Control */
2578 } B;
2579 } TBCR_B;
2580
2581 union { /* ETPU_B TCR1 Visibility Register */
2582 uint32_t R;
2583 struct {
2584 uint32_t:8;
2585 uint32_t TCR1:24;
2586 } B;
2587 } TB1R_B;
2588
2589 union { /* ETPU_B TCR2 Visibility Register */
2590 uint32_t R;
2591 struct {
2592 uint32_t:8;
2593 uint32_t TCR2:24;
2594 } B;
2595 } TB2R_B;
2596
2597 union { /* ETPU_B STAC Configuration Register */
2598 uint32_t R;
2599 struct {
2600 uint32_t REN1:1; /* Resource Enable TCR1 */
2601 uint32_t RSC1:1; /* Resource Control TCR1 */
2602 uint32_t:2;
2603 uint32_t SERVER_ID1:4; /* TCR1 Server ID */
2604 uint32_t:4;
2605 uint32_t SRV1:4; /* Resource Server Slot */
2606 uint32_t REN2:1; /* Resource Enable TCR2 */
2607 uint32_t RSC2:1; /* Resource Control TCR2 */
2608 uint32_t:2;
2609 uint32_t SERVER_ID2:4; /* TCR2 Server ID */
2610 uint32_t:4;
2611 uint32_t SRV2:4; /* Resource Server Slot */
2612 } B;
2613 } REDCR_B;
2614
2615 uint32_t eTPU_reserved0050[4]; /* 0x0050-0x005F */
2616
2617 union { /* Watchdog Timer Register A */
2618 uint32_t R;
2619 struct {
2620 uint32_t WDM:2; /* Watchdog Mode */
2621 uint32_t:14;
2622 uint32_t WDCNT:16; /* Watchdog Count */
2623 } B;
2624 } WDTR_A;
2625
2626 uint32_t eTPU_reserved0064; /* 0x0064-0x0067 */
2627
2628 union { /* Idle Counter Register A*/
2629 uint32_t R;
2630 struct {
2631 uint32_t IDLE_CNT:31;
2632 uint32_t ICLR:1; /* Idle Clear */
2633 } B;
2634
2635 } IDLE_A;
2636
2637 uint32_t eTPU_reserved006C; /* 0x006C-0x006F */
2638
2639 union { /* Watchdog Timer Register B */
2640 uint32_t R;
2641 struct {
2642 uint32_t WDM:2; /* Watchdog Mode */
2643 uint32_t:14;
2644 uint32_t WDCNT:16; /* Watchdog Count */
2645 } B;
2646 } WDTR_B;
2647
2648 uint32_t eTPU_reserved0074; /* 0x0074-0x0077 */
2649
2650 union { /* Idle Counter Register B*/
2651 uint32_t R;
2652 struct {
2653 uint32_t IDLE_CNT:31;
2654 uint32_t ICLR:1; /* Idle Clear */
2655 } B;
2656 } IDLE_B;
2657
2658 uint32_t eTPU_reserved007C; /* 0x007C-0x007F */
2659
2660 uint32_t eTPU_reserved0080[96]; /* 0x0080-0x01FF */
2661
2662/*****************************Status and Control Registers**************************/
2663
2664 union { /* ETPU_A Channel Interrut Status */
2665 uint32_t R;
2666 struct {
2667 uint32_t CIS31:1; /* Channel 31 Interrut Status */
2668 uint32_t CIS30:1; /* Channel 30 Interrut Status */
2669 uint32_t CIS29:1; /* Channel 29 Interrut Status */
2670 uint32_t CIS28:1; /* Channel 28 Interrut Status */
2671 uint32_t CIS27:1; /* Channel 27 Interrut Status */
2672 uint32_t CIS26:1; /* Channel 26 Interrut Status */
2673 uint32_t CIS25:1; /* Channel 25 Interrut Status */
2674 uint32_t CIS24:1; /* Channel 24 Interrut Status */
2675 uint32_t CIS23:1; /* Channel 23 Interrut Status */
2676 uint32_t CIS22:1; /* Channel 22 Interrut Status */
2677 uint32_t CIS21:1; /* Channel 21 Interrut Status */
2678 uint32_t CIS20:1; /* Channel 20 Interrut Status */
2679 uint32_t CIS19:1; /* Channel 19 Interrut Status */
2680 uint32_t CIS18:1; /* Channel 18 Interrut Status */
2681 uint32_t CIS17:1; /* Channel 17 Interrut Status */
2682 uint32_t CIS16:1; /* Channel 16 Interrut Status */
2683 uint32_t CIS15:1; /* Channel 15 Interrut Status */
2684 uint32_t CIS14:1; /* Channel 14 Interrut Status */
2685 uint32_t CIS13:1; /* Channel 13 Interrut Status */
2686 uint32_t CIS12:1; /* Channel 12 Interrut Status */
2687 uint32_t CIS11:1; /* Channel 11 Interrut Status */
2688 uint32_t CIS10:1; /* Channel 10 Interrut Status */
2689 uint32_t CIS9:1; /* Channel 9 Interrut Status */
2690 uint32_t CIS8:1; /* Channel 8 Interrut Status */
2691 uint32_t CIS7:1; /* Channel 7 Interrut Status */
2692 uint32_t CIS6:1; /* Channel 6 Interrut Status */
2693 uint32_t CIS5:1; /* Channel 5 Interrut Status */
2694 uint32_t CIS4:1; /* Channel 4 Interrut Status */
2695 uint32_t CIS3:1; /* Channel 3 Interrut Status */
2696 uint32_t CIS2:1; /* Channel 2 Interrut Status */
2697 uint32_t CIS1:1; /* Channel 1 Interrut Status */
2698 uint32_t CIS0:1; /* Channel 0 Interrut Status */
2699 } B;
2700 } CISR_A;
2701
2702 union { /* ETPU_B Channel Interruput Status */
2703 uint32_t R;
2704 struct {
2705 uint32_t CIS31:1; /* Channel 31 Interrut Status */
2706 uint32_t CIS30:1; /* Channel 30 Interrut Status */
2707 uint32_t CIS29:1; /* Channel 29 Interrut Status */
2708 uint32_t CIS28:1; /* Channel 28 Interrut Status */
2709 uint32_t CIS27:1; /* Channel 27 Interrut Status */
2710 uint32_t CIS26:1; /* Channel 26 Interrut Status */
2711 uint32_t CIS25:1; /* Channel 25 Interrut Status */
2712 uint32_t CIS24:1; /* Channel 24 Interrut Status */
2713 uint32_t CIS23:1; /* Channel 23 Interrut Status */
2714 uint32_t CIS22:1; /* Channel 22 Interrut Status */
2715 uint32_t CIS21:1; /* Channel 21 Interrut Status */
2716 uint32_t CIS20:1; /* Channel 20 Interrut Status */
2717 uint32_t CIS19:1; /* Channel 19 Interrut Status */
2718 uint32_t CIS18:1; /* Channel 18 Interrut Status */
2719 uint32_t CIS17:1; /* Channel 17 Interrut Status */
2720 uint32_t CIS16:1; /* Channel 16 Interrut Status */
2721 uint32_t CIS15:1; /* Channel 15 Interrut Status */
2722 uint32_t CIS14:1; /* Channel 14 Interrut Status */
2723 uint32_t CIS13:1; /* Channel 13 Interrut Status */
2724 uint32_t CIS12:1; /* Channel 12 Interrut Status */
2725 uint32_t CIS11:1; /* Channel 11 Interrut Status */
2726 uint32_t CIS10:1; /* Channel 10 Interrut Status */
2727 uint32_t CIS9:1; /* Channel 9 Interrut Status */
2728 uint32_t CIS8:1; /* Channel 8 Interrut Status */
2729 uint32_t CIS7:1; /* Channel 7 Interrut Status */
2730 uint32_t CIS6:1; /* Channel 6 Interrut Status */
2731 uint32_t CIS5:1; /* Channel 5 Interrut Status */
2732 uint32_t CIS4:1; /* Channel 4 Interrut Status */
2733 uint32_t CIS3:1; /* Channel 3 Interrut Status */
2734 uint32_t CIS2:1; /* Channel 2 Interrut Status */
2735 uint32_t CIS1:1; /* Channel 1 Interrupt Status */
2736 uint32_t CIS0:1; /* Channel 0 Interrupt Status */
2737 } B;
2738 } CISR_B;
2739
2740 uint32_t eTPU_reserved0208[2]; /* 0x0208-0x020F */
2741
2742 union { /* ETPU_A Data Transfer Request Status */
2743 uint32_t R;
2744 struct {
2745 uint32_t DTRS31:1; /* Channel 31 Data Transfer Request Status */
2746 uint32_t DTRS30:1; /* Channel 30 Data Transfer Request Status */
2747 uint32_t DTRS29:1; /* Channel 29 Data Transfer Request Status */
2748 uint32_t DTRS28:1; /* Channel 28 Data Transfer Request Status */
2749 uint32_t DTRS27:1; /* Channel 27 Data Transfer Request Status */
2750 uint32_t DTRS26:1; /* Channel 26 Data Transfer Request Status */
2751 uint32_t DTRS25:1; /* Channel 25 Data Transfer Request Status */
2752 uint32_t DTRS24:1; /* Channel 24 Data Transfer Request Status */
2753 uint32_t DTRS23:1; /* Channel 23 Data Transfer Request Status */
2754 uint32_t DTRS22:1; /* Channel 22 Data Transfer Request Status */
2755 uint32_t DTRS21:1; /* Channel 21 Data Transfer Request Status */
2756 uint32_t DTRS20:1; /* Channel 20 Data Transfer Request Status */
2757 uint32_t DTRS19:1; /* Channel 19 Data Transfer Request Status */
2758 uint32_t DTRS18:1; /* Channel 18 Data Transfer Request Status */
2759 uint32_t DTRS17:1; /* Channel 17 Data Transfer Request Status */
2760 uint32_t DTRS16:1; /* Channel 16 Data Transfer Request Status */
2761 uint32_t DTRS15:1; /* Channel 15 Data Transfer Request Status */
2762 uint32_t DTRS14:1; /* Channel 14 Data Transfer Request Status */
2763 uint32_t DTRS13:1; /* Channel 13 Data Transfer Request Status */
2764 uint32_t DTRS12:1; /* Channel 12 Data Transfer Request Status */
2765 uint32_t DTRS11:1; /* Channel 11 Data Transfer Request Status */
2766 uint32_t DTRS10:1; /* Channel 10 Data Transfer Request Status */
2767 uint32_t DTRS9:1; /* Channel 9 Data Transfer Request Status */
2768 uint32_t DTRS8:1; /* Channel 8 Data Transfer Request Status */
2769 uint32_t DTRS7:1; /* Channel 7 Data Transfer Request Status */
2770 uint32_t DTRS6:1; /* Channel 6 Data Transfer Request Status */
2771 uint32_t DTRS5:1; /* Channel 5 Data Transfer Request Status */
2772 uint32_t DTRS4:1; /* Channel 4 Data Transfer Request Status */
2773 uint32_t DTRS3:1; /* Channel 3 Data Transfer Request Status */
2774 uint32_t DTRS2:1; /* Channel 2 Data Transfer Request Status */
2775 uint32_t DTRS1:1; /* Channel 1 Data Transfer Request Status */
2776 uint32_t DTRS0:1; /* Channel 0 Data Transfer Request Status */
2777 } B;
2778 } CDTRSR_A;
2779
2780 union { /* ETPU_B Data Transfer Request Status */
2781 uint32_t R;
2782 struct {
2783 uint32_t DTRS31:1; /* Channel 31 Data Transfer Request Status */
2784 uint32_t DTRS30:1; /* Channel 30 Data Transfer Request Status */
2785 uint32_t DTRS29:1; /* Channel 29 Data Transfer Request Status */
2786 uint32_t DTRS28:1; /* Channel 28 Data Transfer Request Status */
2787 uint32_t DTRS27:1; /* Channel 27 Data Transfer Request Status */
2788 uint32_t DTRS26:1; /* Channel 26 Data Transfer Request Status */
2789 uint32_t DTRS25:1; /* Channel 25 Data Transfer Request Status */
2790 uint32_t DTRS24:1; /* Channel 24 Data Transfer Request Status */
2791 uint32_t DTRS23:1; /* Channel 23 Data Transfer Request Status */
2792 uint32_t DTRS22:1; /* Channel 22 Data Transfer Request Status */
2793 uint32_t DTRS21:1; /* Channel 21 Data Transfer Request Status */
2794 uint32_t DTRS20:1; /* Channel 20 Data Transfer Request Status */
2795 uint32_t DTRS19:1; /* Channel 19 Data Transfer Request Status */
2796 uint32_t DTRS18:1; /* Channel 18 Data Transfer Request Status */
2797 uint32_t DTRS17:1; /* Channel 17 Data Transfer Request Status */
2798 uint32_t DTRS16:1; /* Channel 16 Data Transfer Request Status */
2799 uint32_t DTRS15:1; /* Channel 15 Data Transfer Request Status */
2800 uint32_t DTRS14:1; /* Channel 14 Data Transfer Request Status */
2801 uint32_t DTRS13:1; /* Channel 13 Data Transfer Request Status */
2802 uint32_t DTRS12:1; /* Channel 12 Data Transfer Request Status */
2803 uint32_t DTRS11:1; /* Channel 11 Data Transfer Request Status */
2804 uint32_t DTRS10:1; /* Channel 10 Data Transfer Request Status */
2805 uint32_t DTRS9:1; /* Channel 9 Data Transfer Request Status */
2806 uint32_t DTRS8:1; /* Channel 8 Data Transfer Request Status */
2807 uint32_t DTRS7:1; /* Channel 7 Data Transfer Request Status */
2808 uint32_t DTRS6:1; /* Channel 6 Data Transfer Request Status */
2809 uint32_t DTRS5:1; /* Channel 5 Data Transfer Request Status */
2810 uint32_t DTRS4:1; /* Channel 4 Data Transfer Request Status */
2811 uint32_t DTRS3:1; /* Channel 3 Data Transfer Request Status */
2812 uint32_t DTRS2:1; /* Channel 2 Data Transfer Request Status */
2813 uint32_t DTRS1:1; /* Channel 1 Data Transfer Request Status */
2814 uint32_t DTRS0:1; /* Channel 0 Data Transfer Request Status */
2815 } B;
2816 } CDTRSR_B;
2817
2818 uint32_t eTPU_reserved0218[2]; /* 0x0218-0x021F */
2819
2820 union { /* ETPU_A Interruput Overflow Status */
2821 uint32_t R;
2822 struct {
2823 uint32_t CIOS31:1; /* Channel 31 Interruput Overflow Status */
2824 uint32_t CIOS30:1; /* Channel 30 Interruput Overflow Status */
2825 uint32_t CIOS29:1; /* Channel 29 Interruput Overflow Status */
2826 uint32_t CIOS28:1; /* Channel 28 Interruput Overflow Status */
2827 uint32_t CIOS27:1; /* Channel 27 Interruput Overflow Status */
2828 uint32_t CIOS26:1; /* Channel 26 Interruput Overflow Status */
2829 uint32_t CIOS25:1; /* Channel 25 Interruput Overflow Status */
2830 uint32_t CIOS24:1; /* Channel 24 Interruput Overflow Status */
2831 uint32_t CIOS23:1; /* Channel 23 Interruput Overflow Status */
2832 uint32_t CIOS22:1; /* Channel 22 Interruput Overflow Status */
2833 uint32_t CIOS21:1; /* Channel 21 Interruput Overflow Status */
2834 uint32_t CIOS20:1; /* Channel 20 Interruput Overflow Status */
2835 uint32_t CIOS19:1; /* Channel 19 Interruput Overflow Status */
2836 uint32_t CIOS18:1; /* Channel 18 Interruput Overflow Status */
2837 uint32_t CIOS17:1; /* Channel 17 Interruput Overflow Status */
2838 uint32_t CIOS16:1; /* Channel 16 Interruput Overflow Status */
2839 uint32_t CIOS15:1; /* Channel 15 Interruput Overflow Status */
2840 uint32_t CIOS14:1; /* Channel 14 Interruput Overflow Status */
2841 uint32_t CIOS13:1; /* Channel 13 Interruput Overflow Status */
2842 uint32_t CIOS12:1; /* Channel 12 Interruput Overflow Status */
2843 uint32_t CIOS11:1; /* Channel 11 Interruput Overflow Status */
2844 uint32_t CIOS10:1; /* Channel 10 Interruput Overflow Status */
2845 uint32_t CIOS9:1; /* Channel 9 Interruput Overflow Status */
2846 uint32_t CIOS8:1; /* Channel 8 Interruput Overflow Status */
2847 uint32_t CIOS7:1; /* Channel 7 Interruput Overflow Status */
2848 uint32_t CIOS6:1; /* Channel 6 Interruput Overflow Status */
2849 uint32_t CIOS5:1; /* Channel 5 Interruput Overflow Status */
2850 uint32_t CIOS4:1; /* Channel 4 Interruput Overflow Status */
2851 uint32_t CIOS3:1; /* Channel 3 Interruput Overflow Status */
2852 uint32_t CIOS2:1; /* Channel 2 Interruput Overflow Status */
2853 uint32_t CIOS1:1; /* Channel 1 Interruput Overflow Status */
2854 uint32_t CIOS0:1; /* Channel 0 Interruput Overflow Status */
2855 } B;
2856 } CIOSR_A;
2857
2858 union { /* ETPU_B Interruput Overflow Status */
2859 uint32_t R;
2860 struct {
2861 uint32_t CIOS31:1; /* Channel 31 Interruput Overflow Status */
2862 uint32_t CIOS30:1; /* Channel 30 Interruput Overflow Status */
2863 uint32_t CIOS29:1; /* Channel 29 Interruput Overflow Status */
2864 uint32_t CIOS28:1; /* Channel 28 Interruput Overflow Status */
2865 uint32_t CIOS27:1; /* Channel 27 Interruput Overflow Status */
2866 uint32_t CIOS26:1; /* Channel 26 Interruput Overflow Status */
2867 uint32_t CIOS25:1; /* Channel 25 Interruput Overflow Status */
2868 uint32_t CIOS24:1; /* Channel 24 Interruput Overflow Status */
2869 uint32_t CIOS23:1; /* Channel 23 Interruput Overflow Status */
2870 uint32_t CIOS22:1; /* Channel 22 Interruput Overflow Status */
2871 uint32_t CIOS21:1; /* Channel 21 Interruput Overflow Status */
2872 uint32_t CIOS20:1; /* Channel 20 Interruput Overflow Status */
2873 uint32_t CIOS19:1; /* Channel 19 Interruput Overflow Status */
2874 uint32_t CIOS18:1; /* Channel 18 Interruput Overflow Status */
2875 uint32_t CIOS17:1; /* Channel 17 Interruput Overflow Status */
2876 uint32_t CIOS16:1; /* Channel 16 Interruput Overflow Status */
2877 uint32_t CIOS15:1; /* Channel 15 Interruput Overflow Status */
2878 uint32_t CIOS14:1; /* Channel 14 Interruput Overflow Status */
2879 uint32_t CIOS13:1; /* Channel 13 Interruput Overflow Status */
2880 uint32_t CIOS12:1; /* Channel 12 Interruput Overflow Status */
2881 uint32_t CIOS11:1; /* Channel 11 Interruput Overflow Status */
2882 uint32_t CIOS10:1; /* Channel 10 Interruput Overflow Status */
2883 uint32_t CIOS9:1; /* Channel 9 Interruput Overflow Status */
2884 uint32_t CIOS8:1; /* Channel 8 Interruput Overflow Status */
2885 uint32_t CIOS7:1; /* Channel 7 Interruput Overflow Status */
2886 uint32_t CIOS6:1; /* Channel 6 Interruput Overflow Status */
2887 uint32_t CIOS5:1; /* Channel 5 Interruput Overflow Status */
2888 uint32_t CIOS4:1; /* Channel 4 Interruput Overflow Status */
2889 uint32_t CIOS3:1; /* Channel 3 Interruput Overflow Status */
2890 uint32_t CIOS2:1; /* Channel 2 Interruput Overflow Status */
2891 uint32_t CIOS1:1; /* Channel 1 Interruput Overflow Status */
2892 uint32_t CIOS0:1; /* Channel 0 Interruput Overflow Status */
2893 } B;
2894 } CIOSR_B;
2895
2896 uint32_t eTPU_reserved0228[2]; /* 0x0228-0x022F */
2897
2898 union { /* ETPU_A Data Transfer Overflow Status */
2899 uint32_t R;
2900 struct {
2901 uint32_t DTROS31:1; /* Channel 31 Data Transfer Overflow Status */
2902 uint32_t DTROS30:1; /* Channel 30 Data Transfer Overflow Status */
2903 uint32_t DTROS29:1; /* Channel 29 Data Transfer Overflow Status */
2904 uint32_t DTROS28:1; /* Channel 28 Data Transfer Overflow Status */
2905 uint32_t DTROS27:1; /* Channel 27 Data Transfer Overflow Status */
2906 uint32_t DTROS26:1; /* Channel 26 Data Transfer Overflow Status */
2907 uint32_t DTROS25:1; /* Channel 25 Data Transfer Overflow Status */
2908 uint32_t DTROS24:1; /* Channel 24 Data Transfer Overflow Status */
2909 uint32_t DTROS23:1; /* Channel 23 Data Transfer Overflow Status */
2910 uint32_t DTROS22:1; /* Channel 22 Data Transfer Overflow Status */
2911 uint32_t DTROS21:1; /* Channel 21 Data Transfer Overflow Status */
2912 uint32_t DTROS20:1; /* Channel 20 Data Transfer Overflow Status */
2913 uint32_t DTROS19:1; /* Channel 19 Data Transfer Overflow Status */
2914 uint32_t DTROS18:1; /* Channel 18 Data Transfer Overflow Status */
2915 uint32_t DTROS17:1; /* Channel 17 Data Transfer Overflow Status */
2916 uint32_t DTROS16:1; /* Channel 16 Data Transfer Overflow Status */
2917 uint32_t DTROS15:1; /* Channel 15 Data Transfer Overflow Status */
2918 uint32_t DTROS14:1; /* Channel 14 Data Transfer Overflow Status */
2919 uint32_t DTROS13:1; /* Channel 13 Data Transfer Overflow Status */
2920 uint32_t DTROS12:1; /* Channel 12 Data Transfer Overflow Status */
2921 uint32_t DTROS11:1; /* Channel 11 Data Transfer Overflow Status */
2922 uint32_t DTROS10:1; /* Channel 10 Data Transfer Overflow Status */
2923 uint32_t DTROS9:1; /* Channel 9 Data Transfer Overflow Status */
2924 uint32_t DTROS8:1; /* Channel 8 Data Transfer Overflow Status */
2925 uint32_t DTROS7:1; /* Channel 7 Data Transfer Overflow Status */
2926 uint32_t DTROS6:1; /* Channel 6 Data Transfer Overflow Status */
2927 uint32_t DTROS5:1; /* Channel 5 Data Transfer Overflow Status */
2928 uint32_t DTROS4:1; /* Channel 4 Data Transfer Overflow Status */
2929 uint32_t DTROS3:1; /* Channel 3 Data Transfer Overflow Status */
2930 uint32_t DTROS2:1; /* Channel 2 Data Transfer Overflow Status */
2931 uint32_t DTROS1:1; /* Channel 1 Data Transfer Overflow Status */
2932 uint32_t DTROS0:1; /* Channel 0 Data Transfer Overflow Status */
2933 } B;
2934 } CDTROSR_A;
2935
2936 union { /* ETPU_B Data Transfer Overflow Status */
2937 uint32_t R;
2938 struct {
2939 uint32_t DTROS31:1; /* Channel 31 Data Transfer Overflow Status */
2940 uint32_t DTROS30:1; /* Channel 30 Data Transfer Overflow Status */
2941 uint32_t DTROS29:1; /* Channel 29 Data Transfer Overflow Status */
2942 uint32_t DTROS28:1; /* Channel 28 Data Transfer Overflow Status */
2943 uint32_t DTROS27:1; /* Channel 27 Data Transfer Overflow Status */
2944 uint32_t DTROS26:1; /* Channel 26 Data Transfer Overflow Status */
2945 uint32_t DTROS25:1; /* Channel 25 Data Transfer Overflow Status */
2946 uint32_t DTROS24:1; /* Channel 24 Data Transfer Overflow Status */
2947 uint32_t DTROS23:1; /* Channel 23 Data Transfer Overflow Status */
2948 uint32_t DTROS22:1; /* Channel 22 Data Transfer Overflow Status */
2949 uint32_t DTROS21:1; /* Channel 21 Data Transfer Overflow Status */
2950 uint32_t DTROS20:1; /* Channel 20 Data Transfer Overflow Status */
2951 uint32_t DTROS19:1; /* Channel 19 Data Transfer Overflow Status */
2952 uint32_t DTROS18:1; /* Channel 18 Data Transfer Overflow Status */
2953 uint32_t DTROS17:1; /* Channel 17 Data Transfer Overflow Status */
2954 uint32_t DTROS16:1; /* Channel 16 Data Transfer Overflow Status */
2955 uint32_t DTROS15:1; /* Channel 15 Data Transfer Overflow Status */
2956 uint32_t DTROS14:1; /* Channel 14 Data Transfer Overflow Status */
2957 uint32_t DTROS13:1; /* Channel 13 Data Transfer Overflow Status */
2958 uint32_t DTROS12:1; /* Channel 12 Data Transfer Overflow Status */
2959 uint32_t DTROS11:1; /* Channel 11 Data Transfer Overflow Status */
2960 uint32_t DTROS10:1; /* Channel 10 Data Transfer Overflow Status */
2961 uint32_t DTROS9:1; /* Channel 9 Data Transfer Overflow Status */
2962 uint32_t DTROS8:1; /* Channel 8 Data Transfer Overflow Status */
2963 uint32_t DTROS7:1; /* Channel 7 Data Transfer Overflow Status */
2964 uint32_t DTROS6:1; /* Channel 6 Data Transfer Overflow Status */
2965 uint32_t DTROS5:1; /* Channel 5 Data Transfer Overflow Status */
2966 uint32_t DTROS4:1; /* Channel 4 Data Transfer Overflow Status */
2967 uint32_t DTROS3:1; /* Channel 3 Data Transfer Overflow Status */
2968 uint32_t DTROS2:1; /* Channel 2 Data Transfer Overflow Status */
2969 uint32_t DTROS1:1; /* Channel 1 Data Transfer Overflow Status */
2970 uint32_t DTROS0:1; /* Channel 0 Data Transfer Overflow Status */
2971 } B;
2972 } CDTROSR_B;
2973
2974 uint32_t eTPU_reserved0238[2]; /* 0x0238-0x023F */
2975
2976 union { /* ETPU_A Channel Interruput Enable */
2977 uint32_t R;
2978 struct {
2979 uint32_t CIE31:1; /* Channel 31 Interruput Enable */
2980 uint32_t CIE30:1; /* Channel 30 Interruput Enable */
2981 uint32_t CIE29:1; /* Channel 29 Interruput Enable */
2982 uint32_t CIE28:1; /* Channel 28 Interruput Enable */
2983 uint32_t CIE27:1; /* Channel 27 Interruput Enable */
2984 uint32_t CIE26:1; /* Channel 26 Interruput Enable */
2985 uint32_t CIE25:1; /* Channel 25 Interruput Enable */
2986 uint32_t CIE24:1; /* Channel 24 Interruput Enable */
2987 uint32_t CIE23:1; /* Channel 23 Interruput Enable */
2988 uint32_t CIE22:1; /* Channel 22 Interruput Enable */
2989 uint32_t CIE21:1; /* Channel 21 Interruput Enable */
2990 uint32_t CIE20:1; /* Channel 20 Interruput Enable */
2991 uint32_t CIE19:1; /* Channel 19 Interruput Enable */
2992 uint32_t CIE18:1; /* Channel 18 Interruput Enable */
2993 uint32_t CIE17:1; /* Channel 17 Interruput Enable */
2994 uint32_t CIE16:1; /* Channel 16 Interruput Enable */
2995 uint32_t CIE15:1; /* Channel 15 Interruput Enable */
2996 uint32_t CIE14:1; /* Channel 14 Interruput Enable */
2997 uint32_t CIE13:1; /* Channel 13 Interruput Enable */
2998 uint32_t CIE12:1; /* Channel 12 Interruput Enable */
2999 uint32_t CIE11:1; /* Channel 11 Interruput Enable */
3000 uint32_t CIE10:1; /* Channel 10 Interruput Enable */
3001 uint32_t CIE9:1; /* Channel 9 Interruput Enable */
3002 uint32_t CIE8:1; /* Channel 8 Interruput Enable */
3003 uint32_t CIE7:1; /* Channel 7 Interruput Enable */
3004 uint32_t CIE6:1; /* Channel 6 Interruput Enable */
3005 uint32_t CIE5:1; /* Channel 5 Interruput Enable */
3006 uint32_t CIE4:1; /* Channel 4 Interruput Enable */
3007 uint32_t CIE3:1; /* Channel 3 Interruput Enable */
3008 uint32_t CIE2:1; /* Channel 2 Interruput Enable */
3009 uint32_t CIE1:1; /* Channel 1 Interruput Enable */
3010 uint32_t CIE0:1; /* Channel 0 Interruput Enable */
3011 } B;
3012 } CIER_A;
3013
3014 union { /* ETPU_B Channel Interruput Enable */
3015 uint32_t R;
3016 struct {
3017 uint32_t CIE31:1; /* Channel 31 Interruput Enable */
3018 uint32_t CIE30:1; /* Channel 30 Interruput Enable */
3019 uint32_t CIE29:1; /* Channel 29 Interruput Enable */
3020 uint32_t CIE28:1; /* Channel 28 Interruput Enable */
3021 uint32_t CIE27:1; /* Channel 27 Interruput Enable */
3022 uint32_t CIE26:1; /* Channel 26 Interruput Enable */
3023 uint32_t CIE25:1; /* Channel 25 Interruput Enable */
3024 uint32_t CIE24:1; /* Channel 24 Interruput Enable */
3025 uint32_t CIE23:1; /* Channel 23 Interruput Enable */
3026 uint32_t CIE22:1; /* Channel 22 Interruput Enable */
3027 uint32_t CIE21:1; /* Channel 21 Interruput Enable */
3028 uint32_t CIE20:1; /* Channel 20 Interruput Enable */
3029 uint32_t CIE19:1; /* Channel 19 Interruput Enable */
3030 uint32_t CIE18:1; /* Channel 18 Interruput Enable */
3031 uint32_t CIE17:1; /* Channel 17 Interruput Enable */
3032 uint32_t CIE16:1; /* Channel 16 Interruput Enable */
3033 uint32_t CIE15:1; /* Channel 15 Interruput Enable */
3034 uint32_t CIE14:1; /* Channel 14 Interruput Enable */
3035 uint32_t CIE13:1; /* Channel 13 Interruput Enable */
3036 uint32_t CIE12:1; /* Channel 12 Interruput Enable */
3037 uint32_t CIE11:1; /* Channel 11 Interruput Enable */
3038 uint32_t CIE10:1; /* Channel 10 Interruput Enable */
3039 uint32_t CIE9:1; /* Channel 9 Interruput Enable */
3040 uint32_t CIE8:1; /* Channel 8 Interruput Enable */
3041 uint32_t CIE7:1; /* Channel 7 Interruput Enable */
3042 uint32_t CIE6:1; /* Channel 6 Interruput Enable */
3043 uint32_t CIE5:1; /* Channel 5 Interruput Enable */
3044 uint32_t CIE4:1; /* Channel 4 Interruput Enable */
3045 uint32_t CIE3:1; /* Channel 3 Interruput Enable */
3046 uint32_t CIE2:1; /* Channel 2 Interruput Enable */
3047 uint32_t CIE1:1; /* Channel 1 Interruput Enable */
3048 uint32_t CIE0:1; /* Channel 0 Interruput Enable */
3049 } B;
3050 } CIER_B;
3051
3052 uint32_t eTPU_reserved0248[2]; /* 0x0248-0x024F */
3053
3054 union { /* ETPU_A Channel Data Transfer Request Enable */
3055 uint32_t R;
3056 struct {
3057 uint32_t DTRE31:1; /* Channel 31 Data Transfer Request Enable */
3058 uint32_t DTRE30:1; /* Channel 30 Data Transfer Request Enable */
3059 uint32_t DTRE29:1; /* Channel 29 Data Transfer Request Enable */
3060 uint32_t DTRE28:1; /* Channel 28 Data Transfer Request Enable */
3061 uint32_t DTRE27:1; /* Channel 27 Data Transfer Request Enable */
3062 uint32_t DTRE26:1; /* Channel 26 Data Transfer Request Enable */
3063 uint32_t DTRE25:1; /* Channel 25 Data Transfer Request Enable */
3064 uint32_t DTRE24:1; /* Channel 24 Data Transfer Request Enable */
3065 uint32_t DTRE23:1; /* Channel 23 Data Transfer Request Enable */
3066 uint32_t DTRE22:1; /* Channel 22 Data Transfer Request Enable */
3067 uint32_t DTRE21:1; /* Channel 21 Data Transfer Request Enable */
3068 uint32_t DTRE20:1; /* Channel 20 Data Transfer Request Enable */
3069 uint32_t DTRE19:1; /* Channel 19 Data Transfer Request Enable */
3070 uint32_t DTRE18:1; /* Channel 18 Data Transfer Request Enable */
3071 uint32_t DTRE17:1; /* Channel 17 Data Transfer Request Enable */
3072 uint32_t DTRE16:1; /* Channel 16 Data Transfer Request Enable */
3073 uint32_t DTRE15:1; /* Channel 15 Data Transfer Request Enable */
3074 uint32_t DTRE14:1; /* Channel 14 Data Transfer Request Enable */
3075 uint32_t DTRE13:1; /* Channel 13 Data Transfer Request Enable */
3076 uint32_t DTRE12:1; /* Channel 12 Data Transfer Request Enable */
3077 uint32_t DTRE11:1; /* Channel 11 Data Transfer Request Enable */
3078 uint32_t DTRE10:1; /* Channel 10 Data Transfer Request Enable */
3079 uint32_t DTRE9:1; /* Channel 9 Data Transfer Request Enable */
3080 uint32_t DTRE8:1; /* Channel 8 Data Transfer Request Enable */
3081 uint32_t DTRE7:1; /* Channel 7 Data Transfer Request Enable */
3082 uint32_t DTRE6:1; /* Channel 6 Data Transfer Request Enable */
3083 uint32_t DTRE5:1; /* Channel 5 Data Transfer Request Enable */
3084 uint32_t DTRE4:1; /* Channel 4 Data Transfer Request Enable */
3085 uint32_t DTRE3:1; /* Channel 3 Data Transfer Request Enable */
3086 uint32_t DTRE2:1; /* Channel 2 Data Transfer Request Enable */
3087 uint32_t DTRE1:1; /* Channel 1 Data Transfer Request Enable */
3088 uint32_t DTRE0:1; /* Channel 0 Data Transfer Request Enable */
3089 } B;
3090 } CDTRER_A;
3091
3092 union { /* ETPU_B Channel Data Transfer Request Enable */
3093 uint32_t R;
3094 struct {
3095 uint32_t DTRE31:1; /* Channel 31 Data Transfer Request Enable */
3096 uint32_t DTRE30:1; /* Channel 30 Data Transfer Request Enable */
3097 uint32_t DTRE29:1; /* Channel 29 Data Transfer Request Enable */
3098 uint32_t DTRE28:1; /* Channel 28 Data Transfer Request Enable */
3099 uint32_t DTRE27:1; /* Channel 27 Data Transfer Request Enable */
3100 uint32_t DTRE26:1; /* Channel 26 Data Transfer Request Enable */
3101 uint32_t DTRE25:1; /* Channel 25 Data Transfer Request Enable */
3102 uint32_t DTRE24:1; /* Channel 24 Data Transfer Request Enable */
3103 uint32_t DTRE23:1; /* Channel 23 Data Transfer Request Enable */
3104 uint32_t DTRE22:1; /* Channel 22 Data Transfer Request Enable */
3105 uint32_t DTRE21:1; /* Channel 21 Data Transfer Request Enable */
3106 uint32_t DTRE20:1; /* Channel 20 Data Transfer Request Enable */
3107 uint32_t DTRE19:1; /* Channel 19 Data Transfer Request Enable */
3108 uint32_t DTRE18:1; /* Channel 18 Data Transfer Request Enable */
3109 uint32_t DTRE17:1; /* Channel 17 Data Transfer Request Enable */
3110 uint32_t DTRE16:1; /* Channel 16 Data Transfer Request Enable */
3111 uint32_t DTRE15:1; /* Channel 15 Data Transfer Request Enable */
3112 uint32_t DTRE14:1; /* Channel 14 Data Transfer Request Enable */
3113 uint32_t DTRE13:1; /* Channel 13 Data Transfer Request Enable */
3114 uint32_t DTRE12:1; /* Channel 12 Data Transfer Request Enable */
3115 uint32_t DTRE11:1; /* Channel 11 Data Transfer Request Enable */
3116 uint32_t DTRE10:1; /* Channel 10 Data Transfer Request Enable */
3117 uint32_t DTRE9:1; /* Channel 9 Data Transfer Request Enable */
3118 uint32_t DTRE8:1; /* Channel 8 Data Transfer Request Enable */
3119 uint32_t DTRE7:1; /* Channel 7 Data Transfer Request Enable */
3120 uint32_t DTRE6:1; /* Channel 6 Data Transfer Request Enable */
3121 uint32_t DTRE5:1; /* Channel 5 Data Transfer Request Enable */
3122 uint32_t DTRE4:1; /* Channel 4 Data Transfer Request Enable */
3123 uint32_t DTRE3:1; /* Channel 3 Data Transfer Request Enable */
3124 uint32_t DTRE2:1; /* Channel 2 Data Transfer Request Enable */
3125 uint32_t DTRE1:1; /* Channel 1 Data Transfer Request Enable */
3126 uint32_t DTRE0:1; /* Channel 0 Data Transfer Request Enable */
3127 } B;
3128 } CDTRER_B;
3129
3130 uint32_t eTPU_reserved0258[2]; /* 0x0258-0x025F */
3131
3132 union { /* Watchdog Status Register A */
3133 uint32_t R;
3134 struct {
3135 uint32_t WDS31:1;
3136 uint32_t WDS30:1;
3137 uint32_t WDS29:1;
3138 uint32_t WDS28:1;
3139 uint32_t WDS27:1;
3140 uint32_t WDS26:1;
3141 uint32_t WDS25:1;
3142 uint32_t WDS24:1;
3143 uint32_t WDS23:1;
3144 uint32_t WDS22:1;
3145 uint32_t WDS21:1;
3146 uint32_t WDS20:1;
3147 uint32_t WDS19:1;
3148 uint32_t WDS18:1;
3149 uint32_t WDS17:1;
3150 uint32_t WDS16:1;
3151 uint32_t WDS15:1;
3152 uint32_t WDS14:1;
3153 uint32_t WDS13:1;
3154 uint32_t WDS12:1;
3155 uint32_t WDS11:1;
3156 uint32_t WDS10:1;
3157 uint32_t WDS9:1;
3158 uint32_t WDS8:1;
3159 uint32_t WDS7:1;
3160 uint32_t WDS6:1;
3161 uint32_t WDS5:1;
3162 uint32_t WDS4:1;
3163 uint32_t WDS3:1;
3164 uint32_t WDS2:1;
3165 uint32_t WDS1:1;
3166 uint32_t WDS0:1;
3167 } B;
3168 } WDSR_A;
3169
3170 union { /* Watchdog Status Register B */
3171 uint32_t R;
3172 struct {
3173 uint32_t WDS31:1;
3174 uint32_t WDS30:1;
3175 uint32_t WDS29:1;
3176 uint32_t WDS28:1;
3177 uint32_t WDS27:1;
3178 uint32_t WDS26:1;
3179 uint32_t WDS25:1;
3180 uint32_t WDS24:1;
3181 uint32_t WDS23:1;
3182 uint32_t WDS22:1;
3183 uint32_t WDS21:1;
3184 uint32_t WDS20:1;
3185 uint32_t WDS19:1;
3186 uint32_t WDS18:1;
3187 uint32_t WDS17:1;
3188 uint32_t WDS16:1;
3189 uint32_t WDS15:1;
3190 uint32_t WDS14:1;
3191 uint32_t WDS13:1;
3192 uint32_t WDS12:1;
3193 uint32_t WDS11:1;
3194 uint32_t WDS10:1;
3195 uint32_t WDS9:1;
3196 uint32_t WDS8:1;
3197 uint32_t WDS7:1;
3198 uint32_t WDS6:1;
3199 uint32_t WDS5:1;
3200 uint32_t WDS4:1;
3201 uint32_t WDS3:1;
3202 uint32_t WDS2:1;
3203 uint32_t WDS1:1;
3204 uint32_t WDS0:1;
3205 } B;
3206 } WDSR_B;
3207
3208 uint32_t eTPU_reserved0268[6]; /* 0x0268-0x027F */
3209
3210 union { /* ETPU_A Channel Pending Service Status */
3211 uint32_t R;
3212 struct {
3213 uint32_t SR31:1; /* Channel 31 Pending Service Status */
3214 uint32_t SR30:1; /* Channel 30 Pending Service Status */
3215 uint32_t SR29:1; /* Channel 29 Pending Service Status */
3216 uint32_t SR28:1; /* Channel 28 Pending Service Status */
3217 uint32_t SR27:1; /* Channel 27 Pending Service Status */
3218 uint32_t SR26:1; /* Channel 26 Pending Service Status */
3219 uint32_t SR25:1; /* Channel 25 Pending Service Status */
3220 uint32_t SR24:1; /* Channel 24 Pending Service Status */
3221 uint32_t SR23:1; /* Channel 23 Pending Service Status */
3222 uint32_t SR22:1; /* Channel 22 Pending Service Status */
3223 uint32_t SR21:1; /* Channel 21 Pending Service Status */
3224 uint32_t SR20:1; /* Channel 20 Pending Service Status */
3225 uint32_t SR19:1; /* Channel 19 Pending Service Status */
3226 uint32_t SR18:1; /* Channel 18 Pending Service Status */
3227 uint32_t SR17:1; /* Channel 17 Pending Service Status */
3228 uint32_t SR16:1; /* Channel 16 Pending Service Status */
3229 uint32_t SR15:1; /* Channel 15 Pending Service Status */
3230 uint32_t SR14:1; /* Channel 14 Pending Service Status */
3231 uint32_t SR13:1; /* Channel 13 Pending Service Status */
3232 uint32_t SR12:1; /* Channel 12 Pending Service Status */
3233 uint32_t SR11:1; /* Channel 11 Pending Service Status */
3234 uint32_t SR10:1; /* Channel 10 Pending Service Status */
3235 uint32_t SR9:1; /* Channel 9 Pending Service Status */
3236 uint32_t SR8:1; /* Channel 8 Pending Service Status */
3237 uint32_t SR7:1; /* Channel 7 Pending Service Status */
3238 uint32_t SR6:1; /* Channel 6 Pending Service Status */
3239 uint32_t SR5:1; /* Channel 5 Pending Service Status */
3240 uint32_t SR4:1; /* Channel 4 Pending Service Status */
3241 uint32_t SR3:1; /* Channel 3 Pending Service Status */
3242 uint32_t SR2:1; /* Channel 2 Pending Service Status */
3243 uint32_t SR1:1; /* Channel 1 Pending Service Status */
3244 uint32_t SR0:1; /* Channel 0 Pending Service Status */
3245 } B;
3246 } CPSSR_A;
3247
3248 union { /* ETPU_B Channel Pending Service Status */
3249 uint32_t R;
3250 struct {
3251 uint32_t SR31:1; /* Channel 31 Pending Service Status */
3252 uint32_t SR30:1; /* Channel 30 Pending Service Status */
3253 uint32_t SR29:1; /* Channel 29 Pending Service Status */
3254 uint32_t SR28:1; /* Channel 28 Pending Service Status */
3255 uint32_t SR27:1; /* Channel 27 Pending Service Status */
3256 uint32_t SR26:1; /* Channel 26 Pending Service Status */
3257 uint32_t SR25:1; /* Channel 25 Pending Service Status */
3258 uint32_t SR24:1; /* Channel 24 Pending Service Status */
3259 uint32_t SR23:1; /* Channel 23 Pending Service Status */
3260 uint32_t SR22:1; /* Channel 22 Pending Service Status */
3261 uint32_t SR21:1; /* Channel 21 Pending Service Status */
3262 uint32_t SR20:1; /* Channel 20 Pending Service Status */
3263 uint32_t SR19:1; /* Channel 19 Pending Service Status */
3264 uint32_t SR18:1; /* Channel 18 Pending Service Status */
3265 uint32_t SR17:1; /* Channel 17 Pending Service Status */
3266 uint32_t SR16:1; /* Channel 16 Pending Service Status */
3267 uint32_t SR15:1; /* Channel 15 Pending Service Status */
3268 uint32_t SR14:1; /* Channel 14 Pending Service Status */
3269 uint32_t SR13:1; /* Channel 13 Pending Service Status */
3270 uint32_t SR12:1; /* Channel 12 Pending Service Status */
3271 uint32_t SR11:1; /* Channel 11 Pending Service Status */
3272 uint32_t SR10:1; /* Channel 10 Pending Service Status */
3273 uint32_t SR9:1; /* Channel 9 Pending Service Status */
3274 uint32_t SR8:1; /* Channel 8 Pending Service Status */
3275 uint32_t SR7:1; /* Channel 7 Pending Service Status */
3276 uint32_t SR6:1; /* Channel 6 Pending Service Status */
3277 uint32_t SR5:1; /* Channel 5 Pending Service Status */
3278 uint32_t SR4:1; /* Channel 4 Pending Service Status */
3279 uint32_t SR3:1; /* Channel 3 Pending Service Status */
3280 uint32_t SR2:1; /* Channel 2 Pending Service Status */
3281 uint32_t SR1:1; /* Channel 1 Pending Service Status */
3282 uint32_t SR0:1; /* Channel 0 Pending Service Status */
3283 } B;
3284 } CPSSR_B;
3285
3286 uint32_t eTPU_reserved0288[2]; /* 0x0288-0x028F */
3287
3288 union { /* ETPU_A Channel Service Status */
3289 uint32_t R;
3290 struct {
3291 uint32_t SS31:1; /* Channel 31 Service Status */
3292 uint32_t SS30:1; /* Channel 30 Service Status */
3293 uint32_t SS29:1; /* Channel 29 Service Status */
3294 uint32_t SS28:1; /* Channel 28 Service Status */
3295 uint32_t SS27:1; /* Channel 27 Service Status */
3296 uint32_t SS26:1; /* Channel 26 Service Status */
3297 uint32_t SS25:1; /* Channel 25 Service Status */
3298 uint32_t SS24:1; /* Channel 24 Service Status */
3299 uint32_t SS23:1; /* Channel 23 Service Status */
3300 uint32_t SS22:1; /* Channel 22 Service Status */
3301 uint32_t SS21:1; /* Channel 21 Service Status */
3302 uint32_t SS20:1; /* Channel 20 Service Status */
3303 uint32_t SS19:1; /* Channel 19 Service Status */
3304 uint32_t SS18:1; /* Channel 18 Service Status */
3305 uint32_t SS17:1; /* Channel 17 Service Status */
3306 uint32_t SS16:1; /* Channel 16 Service Status */
3307 uint32_t SS15:1; /* Channel 15 Service Status */
3308 uint32_t SS14:1; /* Channel 14 Service Status */
3309 uint32_t SS13:1; /* Channel 13 Service Status */
3310 uint32_t SS12:1; /* Channel 12 Service Status */
3311 uint32_t SS11:1; /* Channel 11 Service Status */
3312 uint32_t SS10:1; /* Channel 10 Service Status */
3313 uint32_t SS9:1; /* Channel 9 Service Status */
3314 uint32_t SS8:1; /* Channel 8 Service Status */
3315 uint32_t SS7:1; /* Channel 7 Service Status */
3316 uint32_t SS6:1; /* Channel 6 Service Status */
3317 uint32_t SS5:1; /* Channel 5 Service Status */
3318 uint32_t SS4:1; /* Channel 4 Service Status */
3319 uint32_t SS3:1; /* Channel 3 Service Status */
3320 uint32_t SS2:1; /* Channel 2 Service Status */
3321 uint32_t SS1:1; /* Channel 1 Service Status */
3322 uint32_t SS0:1; /* Channel 0 Service Status */
3323 } B;
3324 } CSSR_A;
3325
3326 union { /* ETPU_B Channel Service Status */
3327 uint32_t R;
3328 struct {
3329 uint32_t SS31:1; /* Channel 31 Service Status */
3330 uint32_t SS30:1; /* Channel 30 Service Status */
3331 uint32_t SS29:1; /* Channel 29 Service Status */
3332 uint32_t SS28:1; /* Channel 28 Service Status */
3333 uint32_t SS27:1; /* Channel 27 Service Status */
3334 uint32_t SS26:1; /* Channel 26 Service Status */
3335 uint32_t SS25:1; /* Channel 25 Service Status */
3336 uint32_t SS24:1; /* Channel 24 Service Status */
3337 uint32_t SS23:1; /* Channel 23 Service Status */
3338 uint32_t SS22:1; /* Channel 22 Service Status */
3339 uint32_t SS21:1; /* Channel 21 Service Status */
3340 uint32_t SS20:1; /* Channel 20 Service Status */
3341 uint32_t SS19:1; /* Channel 19 Service Status */
3342 uint32_t SS18:1; /* Channel 18 Service Status */
3343 uint32_t SS17:1; /* Channel 17 Service Status */
3344 uint32_t SS16:1; /* Channel 16 Service Status */
3345 uint32_t SS15:1; /* Channel 15 Service Status */
3346 uint32_t SS14:1; /* Channel 14 Service Status */
3347 uint32_t SS13:1; /* Channel 13 Service Status */
3348 uint32_t SS12:1; /* Channel 12 Service Status */
3349 uint32_t SS11:1; /* Channel 11 Service Status */
3350 uint32_t SS10:1; /* Channel 10 Service Status */
3351 uint32_t SS9:1; /* Channel 9 Service Status */
3352 uint32_t SS8:1; /* Channel 8 Service Status */
3353 uint32_t SS7:1; /* Channel 7 Service Status */
3354 uint32_t SS6:1; /* Channel 6 Service Status */
3355 uint32_t SS5:1; /* Channel 5 Service Status */
3356 uint32_t SS4:1; /* Channel 4 Service Status */
3357 uint32_t SS3:1; /* Channel 3 Service Status */
3358 uint32_t SS2:1; /* Channel 2 Service Status */
3359 uint32_t SS1:1; /* Channel 1 Service Status */
3360 uint32_t SS0:1; /* Channel 0 Service Status */
3361 } B;
3362 } CSSR_B;
3363
3364 uint32_t eTPU_reserved0298[2]; /* 0x0298-0x029F */
3365
3366 uint32_t eTPU_reserved02A0[88]; /* 0x02A0-0x03FF */
3367
3368/*****************************Channels********************************/
3369
3370 struct {
3371 union { /* Channel Configuration Register */
3372 uint32_t R;
3373 struct {
3374 uint32_t CIE:1; /* Channel Interruput Enable */
3375 uint32_t DTRE:1; /* Data Transfer Request Enable */
3376 uint32_t CPR:2; /* Channel Priority */
3377 uint32_t:2;
3378 uint32_t ETPD:1;
3379 uint32_t ETCS:1; /* Entry Table Condition Select */
3380 uint32_t:3;
3381 uint32_t CFS:5; /* Channel Function Select */
3382 uint32_t ODIS:1; /* Output disable */
3383 uint32_t OPOL:1; /* output polarity */
3384 uint32_t:3;
3385 uint32_t CPBA:11; /* Channel Parameter Base Address */
3386 } B;
3387 } CR;
3388
3389 union { /* Channel Status Control Register */
3390 uint32_t R;
3391 struct {
3392 uint32_t CIS:1; /* Channel Interruput Status */
3393 uint32_t CIOS:1; /* Channel Interruput Overflow Status */
3394 uint32_t:6;
3395 uint32_t DTRS:1; /* Data Transfer Status */
3396 uint32_t DTROS:1; /* Data Transfer Overflow Status */
3397 uint32_t:6;
3398 uint32_t IPS:1; /* Input Pin State */
3399 uint32_t OPS:1; /* Output Pin State */
3400 uint32_t OBE:1; /* Output Buffer Enable */
3401 uint32_t:11;
3402 uint32_t FM1:1; /* Function mode */
3403 uint32_t FM0:1; /* Function mode */
3404 } B;
3405 } SCR;
3406
3407 union { /* Channel Host Service Request Register */
3408 uint32_t R;
3409 struct {
3410 uint32_t:29; /* Host Service Request */
3411 uint32_t HSR:3;
3412 } B;
3413 } HSRR;
3414
3415 uint32_t eTPU_ch_reserved00C; /* channel offset 0x00C-0x00F */
3416
3417 } CHAN[127];
3418
3419 uint32_t eTPU_reserved1000[7168]; /* 0x1000-0x7FFF */
3420
3421 };
3422
3423/****************************************************************************/
3424/* MODULE : PIT / RTI */
3425/****************************************************************************/
3426
3427 struct PIT_tag {
3428 union { /* Module Configuration Register */
3429 uint32_t R;
3430 struct {
3431 uint32_t:29;
3432 uint32_t MDIS_RTI:1;
3433 uint32_t MDIS:1;
3434 uint32_t FRZ:1;
3435 } B;
3436 } MCR;
3437
3438 uint32_t PIT_reserved0004[59]; /* 0x0004-0x00EF */
3439
3440 struct {
3441 union {
3442 uint32_t R; /* <URM>TSVn</URM> */
3443 } LDVAL; /* Timer Load Value Register */
3444
3445 union {
3446 uint32_t R; /* <URM>TVLn</URM> */
3447 } CVAL; /* Current Timer Value Register */
3448
3449 union {
3450 uint32_t R;
3451 struct {
3452 uint32_t:30;
3453 uint32_t TIE:1;
3454 uint32_t TEN:1;
3455 } B;
3456 } TCTRL; /* Timer Control Register */
3457
3458 union {
3459 uint32_t R;
3460 struct {
3461 uint32_t:31;
3462 uint32_t TIF:1;
3463 } B;
3464 } TFLG; /* Timer Flag Register */
3465 } RTI; /* RTI Channel */
3466
3467 struct {
3468 union {
3469 uint32_t R;
3470 struct {
3471 uint32_t TSV:32;
3472 } B;
3473 } LDVAL;
3474
3475 union {
3476 uint32_t R;
3477 struct {
3478 uint32_t TVL:32;
3479 } B;
3480 } CVAL;
3481
3482 union {
3483 uint32_t R;
3484 struct {
3485 uint32_t:30;
3486 uint32_t TIE:1;
3487 uint32_t TEN:1;
3488 } B;
3489 } TCTRL;
3490
3491 union {
3492 uint32_t R;
3493 struct {
3494 uint32_t:31;
3495 uint32_t TIF:1;
3496 } B;
3497 } TFLG;
3498 } CH[4];
3499
3500 uint32_t PIT_reserved00140[4016]; /* 0x0140-0x3FFF */
3501 };
3502
3503/****************************************************************************/
3504/* MODULE : XBAR CrossBar */
3505/****************************************************************************/
3506
3507 struct XBAR_tag {
3508
3509 union { /* Master Priority Register for Slave Port 0 */
3510 uint32_t R;
3511 struct {
3512 uint32_t:1;
3513 uint32_t MSTR7:3; /* EBI (development bus) */
3514 uint32_t:1;
3515 uint32_t MSTR6:3; /* FlexRay */
3516 uint32_t:1;
3517 uint32_t MSTR5:3; /* eDMA_B */
3518 uint32_t:1;
3519 uint32_t MSTR4:3; /* eDMA_A */
3520 uint32_t:1;
3521 uint32_t MSTR3:3; /* !!! Unsupported in Mamba !!! - Legacy FEC */
3522 uint32_t:1;
3523 uint32_t MSTR2:3; /* !!! Unsupported in Mamba !!! - Legacy EBI */
3524 uint32_t:1;
3525 uint32_t MSTR1:3; /* e200z7 core-Data, and Nexus 3 - Legacy was eDMA_A */
3526 uint32_t:1;
3527 uint32_t MSTR0:3; /* e200z7 core-CPU Instruction - Legacy was z6 core-Instruction/Data & Nexus */
3528 } B;
3529 } MPR0;
3530
3531 uint32_t XBAR_reserved0004[3]; /* 0x0004-0x000F */
3532
3533 union { /* General Purpose Control Register for Slave Port 0 */
3534 uint32_t R;
3535 struct {
3536 uint32_t RO:1;
3537 uint32_t:21;
3538 uint32_t ARB:2;
3539 uint32_t:2;
3540 uint32_t PCTL:2;
3541 uint32_t:1;
3542 uint32_t PARK:3;
3543 } B;
3544 } SGPCR0;
3545
3546 uint32_t XBAR_reserved0014[59]; /* 0x0014-0x00FF */
3547
3548 union { /* Master Priority Register for Slave Port 1 */
3549 uint32_t R;
3550 struct {
3551 uint32_t:1;
3552 uint32_t MSTR7:3; /* EBI (development bus) */
3553 uint32_t:1;
3554 uint32_t MSTR6:3; /* FlexRay */
3555 uint32_t:1;
3556 uint32_t MSTR5:3; /* eDMA_B */
3557 uint32_t:1;
3558 uint32_t MSTR4:3; /* eDMA_A */
3559 uint32_t:1;
3560 uint32_t MSTR3:3; /* !!! Unsupported in Mamba !!! - Legacy FEC */
3561 uint32_t:1;
3562 uint32_t MSTR2:3; /* !!! Unsupported in Mamba !!! - Legacy EBI */
3563 uint32_t:1;
3564 uint32_t MSTR1:3; /* e200z7 core-Data, and Nexus 3 - Legacy was eDMA_A */
3565 uint32_t:1;
3566 uint32_t MSTR0:3; /* e200z7 core-CPU Instruction - Legacy was z6 core-Instruction/Data & Nexus */
3567 } B;
3568 } MPR1;
3569
3570 uint32_t XBAR_reserved0104[3]; /* 0x0104-0x010F */
3571
3572 union { /* General Purpose Control Register for Slave Port 1 */
3573 uint32_t R;
3574 struct {
3575 uint32_t RO:1;
3576 uint32_t:21;
3577 uint32_t ARB:2;
3578 uint32_t:2;
3579 uint32_t PCTL:2;
3580 uint32_t:1;
3581 uint32_t PARK:3;
3582 } B;
3583 } SGPCR1;
3584
3585 uint32_t XBAR_reserved0114[59]; /* 0x0114-0x01FF */
3586
3587 union { /* Master Priority Register for Slave Port 2 */
3588 uint32_t R;
3589 struct {
3590 uint32_t:1;
3591 uint32_t MSTR7:3; /* EBI (development bus) */
3592 uint32_t:1;
3593 uint32_t MSTR6:3; /* FlexRay */
3594 uint32_t:1;
3595 uint32_t MSTR5:3; /* eDMA_B */
3596 uint32_t:1;
3597 uint32_t MSTR4:3; /* eDMA_A */
3598 uint32_t:1;
3599 uint32_t MSTR3:3; /* !!! Unsupported in Mamba !!! - Legacy FEC */
3600 uint32_t:1;
3601 uint32_t MSTR2:3; /* !!! Unsupported in Mamba !!! - Legacy EBI */
3602 uint32_t:1;
3603 uint32_t MSTR1:3; /* e200z7 core-Data, and Nexus 3 - Legacy was eDMA_A */
3604 uint32_t:1;
3605 uint32_t MSTR0:3; /* e200z7 core-CPU Instruction - Legacy was z6 core-Instruction/Data & Nexus */
3606 } B;
3607 } MPR2;
3608
3609 uint32_t XBAR_reserved0204[3]; /* 0x0204-0x020F */
3610
3611 union { /* General Purpose Control Register for Slave Port 2 */
3612 uint32_t R;
3613 struct {
3614 uint32_t RO:1;
3615 uint32_t:21;
3616 uint32_t ARB:2;
3617 uint32_t:2;
3618 uint32_t PCTL:2;
3619 uint32_t:1;
3620 uint32_t PARK:3;
3621 } B;
3622 } SGPCR2;
3623
3624 uint32_t XBAR_reserved0214[59]; /* 0x0214-0x02FF */
3625
3626 uint32_t XBAR_reserved0300[64]; /* 0x0300-0x03FF */
3627
3628 uint32_t XBAR_reserved0400[64]; /* 0x0400-0x04FF */
3629
3630 uint32_t XBAR_reserved0500[64]; /* 0x0500-0x05FF */
3631
3632 union { /* Master Priority Register for Slave Port 6 */
3633 uint32_t R;
3634 struct {
3635 uint32_t:1;
3636 uint32_t MSTR7:3; /* EBI (development bus) */
3637 uint32_t:1;
3638 uint32_t MSTR6:3; /* FlexRay */
3639 uint32_t:1;
3640 uint32_t MSTR5:3; /* eDMA_B */
3641 uint32_t:1;
3642 uint32_t MSTR4:3; /* eDMA_A */
3643 uint32_t:1;
3644 uint32_t MSTR3:3; /* !!! Unsupported in Mamba !!! - Legacy FEC */
3645 uint32_t:1;
3646 uint32_t MSTR2:3; /* !!! Unsupported in Mamba !!! - Legacy EBI */
3647 uint32_t:1;
3648 uint32_t MSTR1:3; /* e200z7 core-Data, and Nexus 3 - Legacy was eDMA_A */
3649 uint32_t:1;
3650 uint32_t MSTR0:3; /* e200z7 core-CPU Instruction - Legacy was z6 core-Instruction/Data & Nexus */
3651 } B;
3652 } MPR6;
3653
3654 uint32_t XBAR_reserved604[3]; /* 0x0604-0x060F */
3655
3656 union { /* General Purpose Control Register for Slave Port 6 */
3657 uint32_t R;
3658 struct {
3659 uint32_t RO:1;
3660 uint32_t:21;
3661 uint32_t ARB:2;
3662 uint32_t:2;
3663 uint32_t PCTL:2;
3664 uint32_t:1;
3665 uint32_t PARK:3;
3666 } B;
3667 } SGPCR6;
3668
3669 uint32_t XBAR_reserved0614[59]; /* 0x0614-0x06FF */
3670
3671 union { /* Master Priority Register for Slave Port 7 */
3672 uint32_t R;
3673 struct {
3674 uint32_t:1;
3675 uint32_t MSTR7:3; /* EBI (development bus) */
3676 uint32_t:1;
3677 uint32_t MSTR6:3; /* FlexRay */
3678 uint32_t:1;
3679 uint32_t MSTR5:3; /* eDMA_B */
3680 uint32_t:1;
3681 uint32_t MSTR4:3; /* eDMA_A */
3682 uint32_t:1;
3683 uint32_t MSTR3:3; /* !!! Unsupported in Mamba !!! - Legacy FEC */
3684 uint32_t:1;
3685 uint32_t MSTR2:3; /* !!! Unsupported in Mamba !!! - Legacy EBI */
3686 uint32_t:1;
3687 uint32_t MSTR1:3; /* e200z7 core-Data, and Nexus 3 - Legacy was eDMA_A */
3688 uint32_t:1;
3689 uint32_t MSTR0:3; /* e200z7 core-CPU Instruction - Legacy was z6 core-Instruction/Data & Nexus */
3690 } B;
3691 } MPR7;
3692
3693 uint32_t XBAR_reserved704[3]; /* 0x0704-0x070F */
3694
3695 union {
3696 uint32_t R;
3697 struct {
3698 uint32_t RO:1;
3699 uint32_t:21;
3700 uint32_t ARB:2;
3701 uint32_t:2;
3702 uint32_t PCTL:2;
3703 uint32_t:1;
3704 uint32_t PARK:3;
3705 } B;
3706 } SGPCR7; /* General Purpose Control Register for Slave Port 7 */
3707
3708 uint32_t XBAR_reserved0714[59]; /* 0x0714-0x07FF */
3709
3710 uint32_t XBAR_reserved0800[3584]; /* 0x0800-0x3FFF */
3711 };
3712
3713/****************************************************************************/
3714/* MODULE : MPU */
3715/****************************************************************************/
3716
3717 struct MPU_tag {
3718
3719 union { /* Module Control/Error Status Register */
3720 uint32_t R;
3721 struct {
3722 uint32_t SPERR:8;
3723 uint32_t:4;
3724 uint32_t HRL:4;
3725 uint32_t NSP:4;
3726 uint32_t NRGD:4;
3727 uint32_t:7;
3728 uint32_t VLD:1;
3729 } B;
3730 } CESR;
3731
3732 uint32_t MPU_reserved0004[3]; /* 0x0004-0x000F */
3733
3734 struct {
3735 union { /* MPU Error Address Registers */
3736 uint32_t R;
3737 struct {
3738 uint32_t EADDR:32;
3739 } B;
3740 } EAR;
3741
3742 union { /* MPU Error Detail Registers */
3743 uint32_t R;
3744 struct {
3745 uint32_t EACD:16;
3746 uint32_t EPID:8;
3747 uint32_t EMN:4;
3748 uint32_t EATTR:3;
3749 uint32_t ERW:1;
3750 } B;
3751 } EDR;
3752 } PORT[3];
3753
3754 uint32_t MPU_reserved0028[246]; /* 0x0028-0x03FF */
3755
3756 struct {
3757 union { /* Region Descriptor n Word 0 */
3758 uint32_t R;
3759 struct {
3760 uint32_t SRTADDR:27;
3761 uint32_t:5;
3762 } B;
3763 } WORD0;
3764
3765 union { /* Region Descriptor n Word 1 */
3766 uint32_t R;
3767 struct {
3768 uint32_t ENDADDR:27;
3769 uint32_t:5;
3770 } B;
3771 } WORD1;
3772
3773 union { /* Region Descriptor n Word 2 */
3774 uint32_t R;
3775 struct {
3776 uint32_t M7RE:1;
3777 uint32_t M7WE:1;
3778 uint32_t M6RE:1;
3779 uint32_t M6WE:1;
3780 uint32_t M5RE:1;
3781 uint32_t M5WE:1;
3782 uint32_t M4RE:1;
3783 uint32_t M4WE:1;
3784 uint32_t: 18;
3785 uint32_t M0PE:1;
3786 uint32_t M0SM:2;
3787 uint32_t M0UM:3;
3788 } B;
3789 } WORD2;
3790
3791 union { /* Region Descriptor n Word 3 */
3792 uint32_t R;
3793 struct {
3794 uint32_t PID:8;
3795 uint32_t PIDMASK:8;
3796 uint32_t:15;
3797 uint32_t VLD:1;
3798 } B;
3799 } WORD3;
3800 } RGD[16];
3801
3802 uint32_t MPU_reserved0500[192]; /* 0x0500-0x07FF */
3803
3804 union { /* Region Descriptor Alternate Access Control n */
3805 uint32_t R;
3806 struct {
3807 uint32_t:6;
3808 uint32_t M4RE:1;
3809 uint32_t M4WE:1;
3810 uint32_t M3PE:1;
3811 uint32_t M3SM:2;
3812 uint32_t M3UM:3;
3813 uint32_t M2PE:1;
3814 uint32_t M2SM:2;
3815 uint32_t M2UM:3;
3816 uint32_t M1PE:1;
3817 uint32_t M1SM:2;
3818 uint32_t M1UM:3;
3819 uint32_t M0PE:1;
3820 uint32_t M0SM:2;
3821 uint32_t M0UM:3;
3822 } B;
3823 } RGDAAC[16];
3824
3825 uint32_t MPU_reserved0840[3568]; /* 0x0840-0x3FFF */
3826
3827 };
3828
3829/****************************************************************************/
3830/* MODULE : SWT */
3831/****************************************************************************/
3832
3833 struct SWT_tag {
3834
3835 union { /* Module Configuration Register */
3836 uint32_t R;
3837 struct {
3838 uint32_t MAP0:1;
3839 uint32_t MAP1:1;
3840 uint32_t:1;
3841 uint32_t:1;
3842 uint32_t MAP4:1;
3843 uint32_t MAP5:1;
3844 uint32_t MAP6:1;
3845 uint32_t MAP7:1;
3846 uint32_t:14;
3847 uint32_t KEY:1;
3848 uint32_t RIA:1;
3849 uint32_t WND:1;
3850 uint32_t ITR:1;
3851 uint32_t HLK:1;
3852 uint32_t SLK:1;
3853 uint32_t CSL:1;
3854 uint32_t STP:1;
3855 uint32_t FRZ:1;
3856 uint32_t WEN:1;
3857 } B;
3858 } MCR;
3859
3860 union { /* Interrupt register */
3861 uint32_t R;
3862 struct {
3863 uint32_t :31;
3864 uint32_t TIF:1;
3865 } B;
3866 } IR;
3867
3868 union { /* Timeout register */
3869 uint32_t R;
3870 struct {
3871 uint32_t WTO:32;
3872 } B;
3873 } TO;
3874
3875 union { /* Window register */
3876 uint32_t R;
3877 struct {
3878 uint32_t WST:32;
3879 } B;
3880 } WN;
3881
3882 union { /* Service register */
3883 uint32_t R;
3884 struct {
3885 uint32_t :16;
3886 uint32_t WSC:16;
3887 } B;
3888 } SR;
3889
3890 union { /* Counter output register */
3891 uint32_t R;
3892 struct {
3893 uint32_t CNT:32;
3894 } B;
3895 } CO;
3896
3897 union { /* Service key register */
3898 uint32_t R;
3899 struct {
3900 uint32_t :16;
3901 uint32_t SK:16;
3902 } B;
3903 } SK;
3904
3905 uint32_t SWT_reserved001C[4089]; /* 0x001C-0x3FFF */
3906
3907 };
3908
3909/****************************************************************************/
3910/* MODULE : STM */
3911/****************************************************************************/
3912
3913 struct STM_tag {
3914
3915 union { /* Control Register */
3916 uint32_t R;
3917 struct {
3918 uint32_t :16;
3919 uint32_t CPS:8;
3920 uint32_t :6;
3921 uint32_t FRZ:1;
3922 uint32_t TEN:1;
3923 } B;
3924 } CR;
3925
3926 union { /* STM Counter */
3927 uint32_t R;
3928 } CNT;
3929
3930 uint32_t STM_reserved0008[2]; /* 0x0008-0x000F */
3931
3932 /* channel 0 registers */
3933 union {
3934 uint32_t R;
3935 struct {
3936 uint32_t :31;
3937 uint32_t CEN:1;
3938 } B;
3939 } CCR0; /* Chan 0 Control Register */
3940
3941 union {
3942 uint32_t R;
3943 struct {
3944 uint32_t :31;
3945 uint32_t CIF:1;
3946 } B;
3947 } CIR0; /* Chan 0 Interrupt Register */
3948
3949 union {
3950 uint32_t R;
3951 } CMP0; /* Chan 0 Compare Register */
3952
3953 uint32_t STM_reserved2[1];
3954
3955/* channel 1 registers */
3956 union {
3957 uint32_t R;
3958 struct {
3959 uint32_t :31;
3960 uint32_t CEN:1;
3961 } B;
3962 } CCR1; /* Chan 1 Control Register */
3963
3964 union {
3965 uint32_t R;
3966 struct {
3967 uint32_t :31;
3968 uint32_t CIF:1;
3969 } B;
3970 } CIR1; /* Chan 1 Interrupt Register */
3971
3972 union {
3973 uint32_t R;
3974 } CMP1; /* Chan 1 Compare Register */
3975
3976 uint32_t STM_reserved3[1];
3977
3978/* channel 2 registers */
3979 union {
3980 uint32_t R;
3981 struct {
3982 uint32_t :31;
3983 uint32_t CEN:1;
3984 } B;
3985 } CCR2; /* Chan 2 Control Register */
3986
3987 union {
3988 uint32_t R;
3989 struct {
3990 uint32_t :31;
3991 uint32_t CIF:1;
3992 } B;
3993 } CIR2; /* Chan 2 Interrupt Register */
3994
3995 union {
3996 uint32_t R;
3997 } CMP2; /* Chan 2 Compare Register */
3998
3999 uint32_t STM_reserved4[1];
4000
4001/* channel 3 registers */
4002 union {
4003 uint32_t R;
4004 struct {
4005 uint32_t :31;
4006 uint32_t CEN:1;
4007 } B;
4008 } CCR3; /* Chan 3 Control Register */
4009
4010 union {
4011 uint32_t R;
4012 struct {
4013 uint32_t :31;
4014 uint32_t CIF:1;
4015 } B;
4016 } CIR3; /* Chan 3 Interrupt Register */
4017
4018 union {
4019 uint32_t R;
4020 } CMP3; /* Chan 3 Compare Register */
4021
4022 uint32_t STM_reserved0050[4076]; /* 0x0050-0x3FFF */
4023
4024 };
4025
4026/****************************************************************************/
4027/* MODULE : ECSM */
4028/****************************************************************************/
4029
4030 struct ECSM_tag {
4031
4032 union { /* Processor core type */
4033 uint16_t R;
4034 } PCT;
4035
4036 union { /* Platform revision */
4037 uint16_t R;
4038 } REV;
4039
4040 uint32_t ECSM_reserved0004; /* 0x0004-0x0007 */
4041
4042 union { /* IPS Module Configuration */
4043 uint32_t R;
4044 } IMC;
4045
4046 uint8_t ECSM_reserved000C[3]; /* 0x000C-0x000E */
4047
4048 union { /* Miscellaneous Reset Status Register */
4049 uint8_t R;
4050 struct {
4051 uint8_t POR:1;
4052 uint8_t DIR:1;
4053 uint8_t SWTR:1;
4054 uint8_t:5;
4055 } B;
4056 } MRSR;
4057
4058 uint8_t ECSM_reserved0010[51]; /* 0x0010-0x0042 */
4059
4060 union { /* ECC Configuration Register */
4061 uint8_t R;
4062 struct {
4063 uint8_t:2;
4064 uint8_t ER1BR:1;
4065 uint8_t EF1BR:1;
4066 uint8_t:2;
4067 uint8_t ERNCR:1;
4068 uint8_t EFNCR:1;
4069 } B;
4070 } ECR;
4071
4072 uint8_t ECSM_reserved0044[3]; /* 0x0044-0x0046 */
4073
4074 union { /* ECC Status Register */
4075 uint8_t R;
4076 struct {
4077 uint8_t:2;
4078 uint8_t R1BC:1;
4079 uint8_t F1BC:1;
4080 uint8_t:2;
4081 uint8_t RNCE:1;
4082 uint8_t FNCE:1;
4083 } B;
4084 } ESR;
4085
4086 uint16_t ECSM_reserved0048; /* 0x0048-0x0049 */
4087
4088 union { /* ECC Error Generation Register */
4089 uint16_t R;
4090 struct {
4091 uint16_t:2;
4092 uint16_t FRC1BI:1;
4093 uint16_t FR11BI:1;
4094 uint16_t:2;
4095 uint16_t FRCNCI:1;
4096 uint16_t FR1NCI:1;
4097 uint16_t:1;
4098 uint16_t ERRBIT:7;
4099 } B;
4100 } EEGR;
4101
4102 uint32_t ECSM_reserved004C; /* 0x004C-0x004F */
4103
4104 union { /* Flash ECC Address Register */
4105 uint32_t R;
4106 struct {
4107 uint32_t FEAR:32;
4108 } B;
4109 } FEAR;
4110
4111 uint16_t ECSM_reserved0054; /* 0x0054-0x0055 */
4112
4113 union { /* Flash ECC Master Number Register */
4114 uint8_t R;
4115 struct {
4116 uint8_t:4;
4117 uint8_t FEMR:4;
4118 } B;
4119 } FEMR;
4120
4121 union { /* Flash ECC Attributes Register */
4122 uint8_t R;
4123 struct {
4124 uint8_t WRITE:1;
4125 uint8_t SIZE:3;
4126 uint8_t PROT0:1;
4127 uint8_t PROT1:1;
4128 uint8_t PROT2:1;
4129 uint8_t PROT3:1;
4130 } B;
4131 } FEAT;
4132
4133 union { /* Flash ECC Data Register High */
4134 uint32_t R;
4135 struct {
4136 uint32_t FEDH:32;
4137 } B;
4138 } FEDRH;
4139
4140 union { /* Flash ECC Data Register Low */
4141 uint32_t R;
4142 struct {
4143 uint32_t FEDL:32;
4144 } B;
4145 } FEDRL;
4146
4147 union { /* RAM ECC Address Register */
4148 uint32_t R;
4149 struct {
4150 uint32_t REAR:32;
4151 } B;
4152 } REAR;
4153
4154 uint16_t ECSM_reserved0064; /* 0x0064-0x0065 */
4155
4156 union { /* RAM ECC Master Number Register */
4157 uint8_t R;
4158 struct {
4159 uint8_t:4;
4160 uint8_t REMR:4;
4161 } B;
4162 } REMR;
4163
4164 union { /* RAM ECC Attributes Register */
4165 uint8_t R;
4166 struct {
4167 uint8_t WRITE:1;
4168 uint8_t SIZE:3;
4169 uint8_t PROT0:1;
4170 uint8_t PROT1:1;
4171 uint8_t PROT2:1;
4172 uint8_t PROT3:1;
4173 } B;
4174 } REAT;
4175
4176 union { /* RAM ECC Data Register */
4177 uint32_t R;
4178 struct {
4179 uint32_t REDH:32;
4180 } B;
4181 } REDRH;
4182
4183 union { /* RAM ECC Data Register */
4184 uint32_t R;
4185 struct {
4186 uint32_t REDL:32;
4187 } B;
4188 } REDRL;
4189
4190 uint32_t ECSM_reserved0070[4068]; /* 0x0070-0x3FFF */
4191
4192 };
4193
4194/****************************************************************************/
4195/* MODULE : INTC */
4196/****************************************************************************/
4197
4198 struct INTC_tag {
4199
4200 union { /* Module Configuration Register */
4201 uint32_t R;
4202 struct {
4203 uint32_t:26;
4204 uint32_t VTES:1;
4205 uint32_t:4;
4206 uint32_t HVEN:1;
4207 } B;
4208 } MCR;
4209
4210 uint32_t INTC_reserved0004; /* 0x0004-0x0007 */
4211
4212 union { /* Current Priority Register */
4213 uint32_t R;
4214 struct {
4215 uint32_t:28;
4216 uint32_t PRI:4;
4217 } B;
4218 } CPR;
4219
4220 uint32_t INTC_reserved000C; /* 0x000C-0x000F */
4221
4222 union { /* Interrupt Acknowledge Register */
4223 uint32_t R;
4224 struct {
4225 uint32_t VTBA:21;
4226 uint32_t INTVEC:9;
4227 uint32_t:2;
4228 } B;
4229 } IACKR;
4230
4231 uint32_t INTC_reserved0014; /* 0x0014-0x0017 */
4232
4233 union { /* End of Interrupt Register */
4234 uint32_t R;
4235 struct {
4236 uint32_t EOIR:32;
4237 } B;
4238 } EOIR;
4239
4240 uint32_t INTC_reserved001C; /* 0x001C-0x001F */
4241
4242 union { /* Software Set/Clear Interruput Register */
4243 uint8_t R;
4244 struct {
4245 uint8_t:6;
4246 uint8_t SET:1;
4247 uint8_t CLR:1;
4248 } B;
4249 } SSCIR[8];
4250
4251 uint32_t INTC_reserved0028[6]; /* 0x0028-0x003F */
4252
4253 union { /* Software Set/Clear Interrupt Register */
4254 uint8_t R;
4255 struct {
4256 uint8_t:4;
4257 uint8_t PRI:4;
4258 } B;
4259 } PSR[480];
4260
4261 uint16_t INTC_reserved0220[7920]; /* 0x0220-0x3FFF */
4262
4263 };
4264
4265/****************************************************************************/
4266/* MODULE : EQADC */
4267/****************************************************************************/
4268
4269 struct EQADC_tag {
4270
4271 union EQADC_MCR_tag { /* Module Configuration Register */
4272 uint32_t R;
4273 struct {
4274 uint32_t:24;
4275 uint32_t ICEA0:1;
4276 uint32_t ICEA1:1;
4277 uint32_t:1;
4278 uint32_t ESSIE:2;
4279 uint32_t:1;
4280 uint32_t DBG:2;
4281 } B;
4282 } MCR;
4283
4284 uint32_t eQADC_reserved0004; /* 0x0004-0x0007 */
4285
4286 union EQADC_NMSFR_tag { /* Null Message Send Format Register */
4287 uint32_t R;
4288 struct {
4289 uint32_t:6;
4290 uint32_t NMF:26;
4291 } B;
4292 } NMSFR;
4293
4294 union EQADC_ETDFR_tag { /* External Trigger Digital Filter Register */
4295 uint32_t R;
4296 struct {
4297 uint32_t:28;
4298 uint32_t DFL:4;
4299 } B;
4300 } ETDFR;
4301
4302 union EQADC_CFPR_tag { /* CFIFO Push Registers */
4303 uint32_t R;
4304 struct {
4305 uint32_t CFPUSH:32;
4306 } B;
4307 } CFPR[6];
4308
4309 uint32_t eQADC_reserved0028[2]; /* 0x0028-0x002F */
4310
4311 union EQADC_RFPR_tag { /* Result FIFO Pop Registers */
4312 uint32_t R;
4313 struct {
4314 uint32_t:16;
4315 uint32_t RFPOP:16;
4316 } B;
4317 } RFPR[6];
4318
4319 uint32_t eQADC_reserved0048[2]; /* 0x0048-0x004F */
4320
4321 union EQADC_CFCR_tag { /* CFIFO Control Registers */
4322 uint16_t R;
4323 struct {
4324 uint16_t:3;
4325 uint16_t CFEEE0:1;
4326 uint16_t STRME0:1;
4327 uint16_t SSE:1;
4328 uint16_t CFINV:1;
4329 uint16_t:1;
4330 uint16_t MODE:4;
4331 uint16_t AMODE0:4;
4332 } B;
4333 } CFCR[6];
4334
4335 uint32_t eQADC_reserved005C; /* 0x005C-0x005F */
4336
4337 union EQADC_IDCR_tag { /* Interrupt and DMA Control Registers */
4338 uint16_t R;
4339 struct {
4340 uint16_t NCIE:1;
4341 uint16_t TORIE:1;
4342 uint16_t PIE:1;
4343 uint16_t EOQIE:1;
4344 uint16_t CFUIE:1;
4345 uint16_t:1;
4346 uint16_t CFFE:1;
4347 uint16_t CFFS:1;
4348 uint16_t:4;
4349 uint16_t RFOIE:1;
4350 uint16_t:1;
4351 uint16_t RFDE:1;
4352 uint16_t RFDS:1;
4353 } B;
4354 } IDCR[6];
4355
4356 uint32_t eQADC_reserved006C; /* 0x006C-0x006F */
4357
4358 union { /* FIFO and Interrupt Status Registers */
4359 uint32_t R;
4360 struct {
4361 uint32_t NCF:1;
4362 uint32_t TORF:1;
4363 uint32_t PF:1;
4364 uint32_t EOQF:1;
4365 uint32_t CFUF:1;
4366 uint32_t SSS:1;
4367 uint32_t CFFF:1;
4368 uint32_t:5;
4369 uint32_t RFOF:1;
4370 uint32_t:1;
4371 uint32_t RFDF:1;
4372 uint32_t:1;
4373 uint32_t CFCTR:4;
4374 uint32_t TNXTPTR:4;
4375 uint32_t RFCTR:4;
4376 uint32_t POPNXTPTR:4;
4377 } B;
4378 } FISR[6];
4379
4380 uint32_t eQADC_reserved0088[2]; /* 0x0088-0x008F */
4381
4382 union { /* CFIFO Transfer Counter Registers */
4383 uint16_t R;
4384 struct {
4385 uint16_t:5;
4386 uint16_t TCCF:11; /* Legacy naming - refer to TC_CF in Reference Manual */
4387 } B;
4388 } CFTCR[6];
4389
4390 uint32_t eQADC_reserved009C[1]; /* 0x009F */
4391
4392 union { /* CFIFO Status Register 0 */
4393 uint32_t R;
4394 struct {
4395 uint32_t CFS0:2; /* Legacy naming - refer to CFS0_TCB0 in Reference Manual */
4396 uint32_t CFS1:2; /* Legacy naming - refer to CFS1_TCB0 in Reference Manual */
4397 uint32_t CFS2:2; /* Legacy naming - refer to CFS2_TCB0 in Reference Manual */
4398 uint32_t CFS3:2; /* Legacy naming - refer to CFS3_TCB0 in Reference Manual */
4399 uint32_t CFS4:2; /* Legacy naming - refer to CFS4_TCB0 in Reference Manual */
4400 uint32_t CFS5:2; /* Legacy naming - refer to CFS5_TCB0 in Reference Manual */
4401 uint32_t:5;
4402 uint32_t LCFTCB0:4;
4403 uint32_t TC_LCFTCB0:11;
4404 } B;
4405 } CFSSR0;
4406
4407 union { /* CFIFO Status Register 1 */
4408 uint32_t R;
4409 struct {
4410 uint32_t CFS0:2; /* Legacy naming - refer to CFS0_TCB1 in Reference Manual */
4411 uint32_t CFS1:2; /* Legacy naming - refer to CFS1_TCB1 in Reference Manual */
4412 uint32_t CFS2:2; /* Legacy naming - refer to CFS2_TCB1 in Reference Manual */
4413 uint32_t CFS3:2; /* Legacy naming - refer to CFS3_TCB1 in Reference Manual */
4414 uint32_t CFS4:2; /* Legacy naming - refer to CFS4_TCB1 in Reference Manual */
4415 uint32_t CFS5:2; /* Legacy naming - refer to CFS5_TCB1 in Reference Manual */
4416 uint32_t:5;
4417 uint32_t LCFTCB1:4;
4418 uint32_t TC_LCFTCB1:11;
4419 } B;
4420 } CFSSR1;
4421
4422 union { /* CFIFO Status Register 2 */
4423 uint32_t R;
4424 struct {
4425 uint32_t CFS0:2; /* Legacy naming - refer to CFS0_TSSI in Reference Manual */
4426 uint32_t CFS1:2; /* Legacy naming - refer to CFS1_TSSI in Reference Manual */
4427 uint32_t CFS2:2; /* Legacy naming - refer to CFS2_TSSI in Reference Manual */
4428 uint32_t CFS3:2; /* Legacy naming - refer to CFS3_TSSI in Reference Manual */
4429 uint32_t CFS4:2; /* Legacy naming - refer to CFS4_TSSI in Reference Manual */
4430 uint32_t CFS5:2; /* Legacy naming - refer to CFS5_TSSI in Reference Manual */
4431 uint32_t:4;
4432 uint32_t ECBNI:1;
4433 uint32_t LCFTSSI:4;
4434 uint32_t TC_LCFTSSI:11;
4435 } B;
4436 } CFSSR2;
4437
4438 union { /* CFIFO Status Register */
4439 uint32_t R;
4440 struct {
4441 uint32_t CFS0:2;
4442 uint32_t CFS1:2;
4443 uint32_t CFS2:2;
4444 uint32_t CFS3:2;
4445 uint32_t CFS4:2;
4446 uint32_t CFS5:2;
4447 uint32_t:20;
4448 } B;
4449 } CFSR;
4450
4451 uint32_t eQADC_reserved00B0; /* 0x00B0-0x00B3 */
4452
4453 union EQADC_SSICR_tag { /* SSI Control Register */
4454 uint32_t R;
4455 struct {
4456 uint32_t:21;
4457 uint32_t MDT:3;
4458 uint32_t:4;
4459 uint32_t BR:4;
4460 } B;
4461 } SSICR;
4462
4463 union { /* SSI Recieve Data Register */
4464 uint32_t R;
4465 struct {
4466 uint32_t RDV:1;
4467 uint32_t:5;
4468 uint32_t RDATA:26;
4469 } B;
4470 } SSIRDR;
4471
4472 uint32_t eQADC_reserved00BC[17]; /* 0x00BC-0x00FF */
4473
4474 struct {
4475 union {
4476 uint32_t R;
4477 struct {
4478 uint32_t CFIFO_DATA:32;
4479 } B;
4480 } R[4];
4481
4482 uint32_t eQADC_cf_reserved010[12]; /* CFIFO offset 0x010-0x03F */
4483
4484 } CF[6];
4485
4486 uint32_t eQADC_reserved0280[32]; /* 0x0280-0x02FF */
4487
4488 struct {
4489 union {
4490 uint32_t R;
4491 struct {
4492 uint32_t RFIFO_DATA:32;
4493 } B;
4494 } R[4];
4495
4496 uint32_t eQADC_rf_reserved010[12]; /* RFIFO offset 0x010-0x03F */
4497
4498 } RF[6];
4499
4500 uint32_t eQADC_reserved0480[3808]; /* 0x0480-0x3FFF */
4501 };
4502
4503/****************************************************************************/
4504/* MODULE : Decimation Filter */
4505/****************************************************************************/
4506
4507 struct DECFIL_tag {
4508
4509 union { /* Module Configuration Register */
4510 uint32_t R;
4511 struct {
4512 uint32_t MDIS:1;
4513 uint32_t FREN:1;
4514 uint32_t :1;
4515 uint32_t FRZ:1;
4516 uint32_t SRES:1;
4517 uint32_t CASCD:2;
4518 uint32_t IDEN:1;
4519 uint32_t ODEN:1;
4520 uint32_t ERREN:1;
4521 uint32_t :1;
4522 uint32_t FTYPE:2;
4523 uint32_t :1;
4524 uint32_t SCAL:2;
4525 uint32_t :1;
4526 uint32_t SAT:1;
4527 uint32_t ISEL:1;
4528 uint32_t :1;
4529 uint32_t DEC_RATE:4;
4530 uint32_t :1;
4531 uint32_t DSEL:1;
4532 uint32_t IBIE:1;
4533 uint32_t OBIE:1;
4534 uint32_t EDME:1;
4535 uint32_t TORE:1;
4536 uint32_t TRFE:1;
4537 uint32_t :1;
4538 } B;
4539 } MCR;
4540
4541 union { /* Module Status Register */
4542 uint32_t R;
4543 struct {
4544 uint32_t BSY:1;
4545 uint32_t:1;
4546 uint32_t DEC_COUNTER:4;
4547 uint32_t IDFC:1;
4548 uint32_t ODFC:1;
4549 uint32_t:1;
4550 uint32_t IBIC:1;
4551 uint32_t OBIC:1;
4552 uint32_t:1;
4553 uint32_t DIVRC:1;
4554 uint32_t OVFC:1;
4555 uint32_t OVRC:1;
4556 uint32_t IVRC:1;
4557 uint32_t:6;
4558 uint32_t IDF:1;
4559 uint32_t ODF:1;
4560 uint32_t:1;
4561 uint32_t IBIF:1;
4562 uint32_t OBIF:1;
4563 uint32_t:1;
4564 uint32_t DIVR:1;
4565 uint32_t OVF:1;
4566 uint32_t OVR:1;
4567 uint32_t IVR:1;
4568 } B;
4569 } SR;
4570
4571 union { /* Module Extended Config Register */
4572 uint32_t R;
4573 struct {
4574 uint32_t SDMAE:1;
4575 uint32_t SSIG:1;
4576 uint32_t SSAT:1;
4577 uint32_t SCSAT:1;
4578 uint32_t:10;
4579 uint32_t SRQ:1;
4580 uint32_t SZR0:1;
4581 uint32_t:1;
4582 uint32_t SISEL:1;
4583 uint32_t SZROSEL:2;
4584 uint32_t:2;
4585 uint32_t SHLTSEL:2;
4586 uint32_t:1;
4587 uint32_t SRQSEL:3;
4588 uint32_t:2;
4589 uint32_t SENSEL:2;
4590 } B;
4591 } MXCR;
4592
4593 union { /* Module Extended Status Register */
4594 uint32_t R;
4595 struct {
4596 uint32_t:7;
4597 uint32_t SDFC:1;
4598 uint32_t:2;
4599 uint32_t SSEC:1;
4600 uint32_t SCEC:1;
4601 uint32_t:1;
4602 uint32_t SSOVFC:1;
4603 uint32_t SCOVFC:1;
4604 uint32_t SVRC:1;
4605 uint32_t:7;
4606 uint32_t SDF:1;
4607 uint32_t:2;
4608 uint32_t SSE:1;
4609 uint32_t SCE:1;
4610 uint32_t:1;
4611 uint32_t SSOVF:1;
4612 uint32_t SCOVF:1;
4613 uint32_t SVR:1;
4614 } B;
4615 } MXSR;
4616
4617 union { /* Interface Input Buffer Register */
4618 uint32_t R;
4619 struct {
4620 uint32_t:14;
4621 uint32_t PREFILL:1;
4622 uint32_t FLUSH:1;
4623 uint32_t INPBUF:16;
4624 } B;
4625 } IB;
4626
4627 union { /* Interface Output Buffer Register */
4628 uint32_t R;
4629 struct {
4630 uint32_t:9;
4631 uint32_t TSI:1;
4632 uint32_t:2;
4633 uint32_t OUTTAG:4;
4634 uint32_t OUTBUF:16;
4635 } B;
4636 } OB;
4637
4638 uint32_t DFILT_reserved0018[2]; /* 0x0018-0x001F */
4639
4640 union { /* Coefficient n Register */
4641 int32_t R;
4642 struct {
4643 int32_t:8;
4644 int32_t COEF:24;
4645 } B;
4646 } COEF[9];
4647
4648 uint32_t DFILT_reserved0044[13]; /* 0x0044-0x0077 */
4649
4650 union { /* TAP n Register */
4651 int32_t R;
4652 struct {
4653 int32_t:8;
4654 int32_t TAP:24;
4655 } B;
4656 } TAP[8];
4657
4658 uint32_t DFILT_reserved0098[14]; /* 0x0098-0x00CF */
4659
4660 union { /* EDID Register */
4661 uint32_t R;
4662 struct {
4663 uint32_t:16;
4664 uint32_t SAMP_DATA:16;
4665 } B;
4666 } EDID;
4667
4668 uint32_t DFILT_reserved00D4[459]; /* 0x00D4-0x07FF */
4669
4670 };
4671
4672/****************************************************************************/
4673/* MODULE : DSPI */
4674/****************************************************************************/
4675
4676 struct DSPI_tag {
4677
4678 union DSPI_MCR_tag { /* Module Configuration Register */
4679 uint32_t R;
4680 struct {
4681 uint32_t MSTR:1;
4682 uint32_t CONT_SCKE:1;
4683 uint32_t DCONF:2;
4684 uint32_t FRZ:1;
4685 uint32_t MTFE:1;
4686 uint32_t PCSSE:1;
4687 uint32_t ROOE:1;
4688 uint32_t PCSIS7:1;
4689 uint32_t PCSIS6:1;
4690 uint32_t PCSIS5:1;
4691 uint32_t PCSIS4:1;
4692 uint32_t PCSIS3:1;
4693 uint32_t PCSIS2:1;
4694 uint32_t PCSIS1:1;
4695 uint32_t PCSIS0:1;
4696 uint32_t DOZE:1;
4697 uint32_t MDIS:1;
4698 uint32_t DIS_TXF:1;
4699 uint32_t DIS_RXF:1;
4700 uint32_t CLR_TXF:1;
4701 uint32_t CLR_RXF:1;
4702 uint32_t SMPL_PT:2;
4703 uint32_t:7;
4704 uint32_t HALT:1;
4705 } B;
4706 } MCR;
4707
4708 uint32_t DSPI_reserved0004; /* 0x0004-0x0007 */
4709
4710 union { /* Transfer Count Register */
4711 uint32_t R;
4712 struct {
4713 uint32_t TCNT:16;
4714 uint32_t:16;
4715 } B;
4716 } TCR;
4717
4718 union DSPI_CTAR_tag {/* Clock and Transfer Attributes Registers */
4719 uint32_t R;
4720 struct {
4721 uint32_t DBR:1;
4722 uint32_t FMSZ:4;
4723 uint32_t CPOL:1;
4724 uint32_t CPHA:1;
4725 uint32_t LSBFE:1;
4726 uint32_t PCSSCK:2;
4727 uint32_t PASC:2;
4728 uint32_t PDT:2;
4729 uint32_t PBR:2;
4730 uint32_t CSSCK:4;
4731 uint32_t ASC:4;
4732 uint32_t DT:4;
4733 uint32_t BR:4;
4734 } B;
4735 } CTAR[8];
4736
4737 union DSPI_SR_tag { /* Status Register */
4738 uint32_t R;
4739 struct {
4740 uint32_t TCF:1;
4741 uint32_t TXRXS:1;
4742 uint32_t:1;
4743 uint32_t EOQF:1;
4744 uint32_t TFUF:1;
4745 uint32_t:1;
4746 uint32_t TFFF:1;
4747 uint32_t:5;
4748 uint32_t RFOF:1;
4749 uint32_t:1;
4750 uint32_t RFDF:1;
4751 uint32_t:1;
4752 uint32_t TXCTR:4;
4753 uint32_t TXNXTPTR:4;
4754 uint32_t RXCTR:4;
4755 uint32_t POPNXTPTR:4;
4756 } B;
4757 } SR;
4758
4759 union DSPI_RSER_tag { /* DMA/Interrupt Request Select and Enable Register */
4760 uint32_t R;
4761 struct {
4762 uint32_t TCFRE:1;
4763 uint32_t:2;
4764 uint32_t EOQFRE:1;
4765 uint32_t TFUFRE:1;
4766 uint32_t:1;
4767 uint32_t TFFFRE:1;
4768 uint32_t TFFFDIRS:1;
4769 uint32_t:4;
4770 uint32_t RFOFRE:1;
4771 uint32_t:1;
4772 uint32_t RFDFRE:1;
4773 uint32_t RFDFDIRS:1;
4774 uint32_t:16;
4775 } B;
4776 } RSER;
4777
4778 union DSPI_PUSHR_tag { /* PUSH TX FIFO Register */
4779 uint32_t R;
4780 struct {
4781 uint32_t CONT:1;
4782 uint32_t CTAS:3;
4783 uint32_t EOQ:1;
4784 uint32_t CTCNT:1;
4785 uint32_t:2;
4786 uint32_t PCS7:1;
4787 uint32_t PCS6:1;
4788 uint32_t PCS5:1;
4789 uint32_t PCS4:1;
4790 uint32_t PCS3:1;
4791 uint32_t PCS2:1;
4792 uint32_t PCS1:1;
4793 uint32_t PCS0:1;
4794 uint32_t TXDATA:16;
4795 } B;
4796 } PUSHR;
4797
4798 union DSPI_POPR_tag { /* POP RX FIFO Register */
4799 uint32_t R;
4800 struct {
4801 uint32_t:16;
4802 uint32_t RXDATA:16;
4803 } B;
4804 } POPR;
4805
4806 union { /* Transmit FIFO Registers */
4807 uint32_t R;
4808 struct {
4809 uint32_t TXCMD:16;
4810 uint32_t TXDATA:16;
4811 } B;
4812 } TXFR[4];
4813
4814 uint32_t DSPI_reserved004C[12]; /* 0x004C-0x007B */
4815
4816 union { /* Transmit FIFO Registers */
4817 uint32_t R;
4818 struct {
4819 uint32_t:16;
4820 uint32_t RXDATA:16;
4821 } B;
4822 } RXFR[4];
4823
4824 uint32_t DSPI_reserved008C[12]; /* 0x008C-0x00BB */
4825
4826 union { /* DSI Configuration Register */
4827 uint32_t R;
4828 struct {
4829 uint32_t MTOE:1;
4830 uint32_t:1;
4831 uint32_t MTOCNT:6;
4832 uint32_t:3;
4833 uint32_t TSBC:1;
4834 uint32_t TXSS:1;
4835 uint32_t TPOL:1;
4836 uint32_t TRRE:1;
4837 uint32_t CID:1;
4838 uint32_t DCONT:1;
4839 uint32_t DSICTAS:3;
4840 uint32_t:4;
4841 uint32_t DPCS7:1;
4842 uint32_t DPCS6:1;
4843 uint32_t DPCS5:1;
4844 uint32_t DPCS4:1;
4845 uint32_t DPCS3:1;
4846 uint32_t DPCS2:1;
4847 uint32_t DPCS1:1;
4848 uint32_t DPCS0:1;
4849 } B;
4850 } DSICR;
4851
4852 union { /* DSI Serialization Data Register */
4853 uint32_t R;
4854 struct {
4855 uint32_t SER_DATA:32;
4856 } B;
4857 } SDR;
4858
4859 union { /* DSI Alternate Serialization Data Register */
4860 uint32_t R;
4861 struct {
4862 uint32_t ASER_DATA:32;
4863 } B;
4864 } ASDR;
4865
4866 union { /* DSI Transmit Comparison Register */
4867 uint32_t R;
4868 struct {
4869 uint32_t COMP_DATA:32;
4870 } B;
4871 } COMPR;
4872
4873 union { /* DSI deserialization Data Register */
4874 uint32_t R;
4875 struct {
4876 uint32_t DESER_DATA:32;
4877 } B;
4878 } DDR;
4879
4880 union {
4881 uint32_t R;
4882 struct {
4883 uint32_t:3;
4884 uint32_t TSBCNT:5;
4885 uint32_t:16;
4886 uint32_t DPCS1_7:1;
4887 uint32_t DPCS1_6:1;
4888 uint32_t DPCS1_5:1;
4889 uint32_t DPCS1_4:1;
4890 uint32_t DPCS1_3:1;
4891 uint32_t DPCS1_2:1;
4892 uint32_t DPCS1_1:1;
4893 uint32_t DPCS1_0:1;
4894 } B;
4895 } DSICR1;
4896 uint32_t DSPI_reserved00D4[4043]; /* 0x00D4-0x3FFF */
4897
4898 };
4899
4900/****************************************************************************/
4901/* MODULE : eSCI */
4902/****************************************************************************/
4903
4904 struct ESCI_tag {
4905 union ESCI_CR1_tag { /* Control Register 1 */
4906 uint32_t R;
4907 struct {
4908 uint32_t:3;
4909 uint32_t SBR:13;
4910 uint32_t LOOPS:1;
4911 uint32_t:1;
4912 uint32_t RSRC:1;
4913 uint32_t M:1;
4914 uint32_t WAKE:1;
4915 uint32_t ILT:1;
4916 uint32_t PE:1;
4917 uint32_t PT:1;
4918 uint32_t TIE:1;
4919 uint32_t TCIE:1;
4920 uint32_t RIE:1;
4921 uint32_t ILIE:1;
4922 uint32_t TE:1;
4923 uint32_t RE:1;
4924 uint32_t RWU:1;
4925 uint32_t SBK:1;
4926 } B;
4927 } CR1;
4928
4929 union ESCI_CR2_tag { /* Control Register 2 */
4930 uint16_t R;
4931 struct {
4932 uint16_t MDIS:1;
4933 uint16_t FBR:1;
4934 uint16_t BSTP:1;
4935 uint16_t IEBERR:1;
4936 uint16_t RXDMA:1;
4937 uint16_t TXDMA:1;
4938 uint16_t BRK13:1;
4939 uint16_t TXDIR:1;
4940 uint16_t BESM13:1;
4941 uint16_t SBSTP:1;
4942 uint16_t RXPOL:1;
4943 uint16_t PMSK:1;
4944 uint16_t ORIE:1;
4945 uint16_t NFIE:1;
4946 uint16_t FEIE:1;
4947 uint16_t PFIE:1;
4948 } B;
4949 } CR2;
4950
4951 union ESCI_DR_tag { /* Data Register */
4952 uint16_t R;
4953
4954 struct {
4955 uint16_t RN:1;
4956 uint16_t TN:1;
4957 uint16_t ERR:1;
4958 uint16_t:1;
4959 uint16_t RD_11:4;
4960 uint16_t D:8;
4961 } B;
4962 } DR; /* Legacy naming - refer to SDR in Reference Manual */
4963
4964 union ESCI_SR_tag { /* Status Register */
4965 uint32_t R;
4966 struct {
4967 uint32_t TDRE:1;
4968 uint32_t TC:1;
4969 uint32_t RDRF:1;
4970 uint32_t IDLE:1;
4971 uint32_t OR:1;
4972 uint32_t NF:1;
4973 uint32_t FE:1;
4974 uint32_t PF:1;
4975 uint32_t:3;
4976 uint32_t BERR:1;
4977 uint32_t:2;
4978 uint32_t TACT:1;
4979 uint32_t RAF:1;
4980 uint32_t RXRDY:1;
4981 uint32_t TXRDY:1;
4982 uint32_t LWAKE:1;
4983 uint32_t STO:1;
4984 uint32_t PBERR:1;
4985 uint32_t CERR:1;
4986 uint32_t CKERR:1;
4987 uint32_t FRC:1;
4988 uint32_t:6;
4989 uint32_t UREQ:1;
4990 uint32_t OVFL:1;
4991 } B;
4992 } SR;
4993
4994 union { /* LIN Control Register */
4995 uint32_t R;
4996 struct {
4997 uint32_t LRES:1;
4998 uint32_t WU:1;
4999 uint32_t WUD0:1;
5000 uint32_t WUD1:1;
5001 uint32_t :2;
5002 uint32_t PRTY:1;
5003 uint32_t LIN:1;
5004 uint32_t RXIE:1;
5005 uint32_t TXIE:1;
5006 uint32_t WUIE:1;
5007 uint32_t STIE:1;
5008 uint32_t PBIE:1;
5009 uint32_t CIE:1;
5010 uint32_t CKIE:1;
5011 uint32_t FCIE:1;
5012 uint32_t:6;
5013 uint32_t UQIE:1;
5014 uint32_t OFIE:1;
5015 uint32_t:8;
5016 } B;
5017 } LCR;
5018
5019 union { /* LIN Transmit Register */
5020 uint8_t R;
5021 } LTR;
5022
5023 uint8_t eSCI_reserved0011[3]; /* 0x0011-0x0013 */
5024
5025 union { /* LIN Recieve Register */
5026 uint8_t R;
5027 struct {
5028 uint8_t D:8;
5029 } B;
5030 } LRR;
5031
5032 uint8_t eSCI_reserved0015[3]; /* 0x0015-0x0017 */
5033
5034 union { /* LIN CRC Polynom Register */
5035 uint16_t R;
5036 struct {
5037 uint16_t P:16;
5038 } B;
5039 } LPR;
5040
5041 union { /* Control Register 3 */
5042 uint16_t R;
5043 struct {
5044 uint16_t:3;
5045 uint16_t SYNM:1;
5046 uint16_t EROE:1;
5047 uint16_t ERFE:1;
5048 uint16_t ERPE:1;
5049 uint16_t M2:1;
5050 uint16_t:8;
5051 } B;
5052 } CR3;
5053
5054 uint32_t eSCI_reserved001C; /* 0x001C-0x001F */
5055
5056 uint32_t eSCI_reserved0020[4088]; /* 0x0020-0x3FFF */
5057
5058 };
5059
5060/****************************************************************************/
5061/* MODULE : FlexCAN */
5062/****************************************************************************/
5063
5064 struct FLEXCAN2_tag {
5065 union { /* Module Configuration Register */
5066 uint32_t R;
5067 struct {
5068 uint32_t MDIS:1;
5069 uint32_t FRZ:1;
5070 uint32_t FEN:1;
5071 uint32_t HALT:1;
5072 uint32_t NOTRDY:1;
5073 uint32_t WAK_MSK:1;
5074 uint32_t SOFTRST:1;
5075 uint32_t FRZACK:1;
5076 uint32_t SUPV:1;
5077 uint32_t SLF_WAK:1;
5078 uint32_t WRNEN:1;
5079 uint32_t MDISACK:1;
5080 uint32_t WAK_SRC:1;
5081 uint32_t DOZE:1;
5082 uint32_t SRXDIS:1;
5083 uint32_t BCC:1;
5084 uint32_t:2;
5085 uint32_t LPRIO_EN:1;
5086 uint32_t AEN:1;
5087 uint32_t:2;
5088 uint32_t IDAM:2;
5089 uint32_t:2;
5090 uint32_t MAXMB:6;
5091 } B;
5092 } MCR;
5093
5094 union { /* Control Register */
5095 uint32_t R;
5096 struct {
5097 uint32_t PRESDIV:8;
5098 uint32_t RJW:2;
5099 uint32_t PSEG1:3;
5100 uint32_t PSEG2:3;
5101 uint32_t BOFFMSK:1;
5102 uint32_t ERRMSK:1;
5103 uint32_t CLKSRC:1;
5104 uint32_t LPB:1;
5105 uint32_t TWRNMSK:1;
5106 uint32_t RWRNMSK:1;
5107 uint32_t:2;
5108 uint32_t SMP:1;
5109 uint32_t BOFFREC:1;
5110 uint32_t TSYN:1;
5111 uint32_t LBUF:1;
5112 uint32_t LOM:1;
5113 uint32_t PROPSEG:3;
5114 } B;
5115 } CR; /* Legacy naming - refer to CTRL in Reference Manual */
5116
5117 union { /* Free Running Timer */
5118 uint32_t R;
5119 } TIMER;
5120
5121 int32_t FLEXCAN_reserved000C; /* 0x000C-0x000F */
5122
5123 union { /* RX Global Mask */
5124 uint32_t R;
5125 struct {
5126 uint32_t MI31:1;
5127 uint32_t MI30:1;
5128 uint32_t MI29:1;
5129 uint32_t MI28:1;
5130 uint32_t MI27:1;
5131 uint32_t MI26:1;
5132 uint32_t MI25:1;
5133 uint32_t MI24:1;
5134 uint32_t MI23:1;
5135 uint32_t MI22:1;
5136 uint32_t MI21:1;
5137 uint32_t MI20:1;
5138 uint32_t MI19:1;
5139 uint32_t MI18:1;
5140 uint32_t MI17:1;
5141 uint32_t MI16:1;
5142 uint32_t MI15:1;
5143 uint32_t MI14:1;
5144 uint32_t MI13:1;
5145 uint32_t MI12:1;
5146 uint32_t MI11:1;
5147 uint32_t MI10:1;
5148 uint32_t MI9:1;
5149 uint32_t MI8:1;
5150 uint32_t MI7:1;
5151 uint32_t MI6:1;
5152 uint32_t MI5:1;
5153 uint32_t MI4:1;
5154 uint32_t MI3:1;
5155 uint32_t MI2:1;
5156 uint32_t MI1:1;
5157 uint32_t MI0:1;
5158 } B;
5159 } RXGMASK;
5160
5161 union { /* RX 14 Mask */
5162 uint32_t R;
5163 struct {
5164 uint32_t MI31:1;
5165 uint32_t MI30:1;
5166 uint32_t MI29:1;
5167 uint32_t MI28:1;
5168 uint32_t MI27:1;
5169 uint32_t MI26:1;
5170 uint32_t MI25:1;
5171 uint32_t MI24:1;
5172 uint32_t MI23:1;
5173 uint32_t MI22:1;
5174 uint32_t MI21:1;
5175 uint32_t MI20:1;
5176 uint32_t MI19:1;
5177 uint32_t MI18:1;
5178 uint32_t MI17:1;
5179 uint32_t MI16:1;
5180 uint32_t MI15:1;
5181 uint32_t MI14:1;
5182 uint32_t MI13:1;
5183 uint32_t MI12:1;
5184 uint32_t MI11:1;
5185 uint32_t MI10:1;
5186 uint32_t MI9:1;
5187 uint32_t MI8:1;
5188 uint32_t MI7:1;
5189 uint32_t MI6:1;
5190 uint32_t MI5:1;
5191 uint32_t MI4:1;
5192 uint32_t MI3:1;
5193 uint32_t MI2:1;
5194 uint32_t MI1:1;
5195 uint32_t MI0:1;
5196 } B;
5197 } RX14MASK;
5198
5199 union { /* RX 15 Mask */
5200 uint32_t R;
5201 struct {
5202 uint32_t MI31:1;
5203 uint32_t MI30:1;
5204 uint32_t MI29:1;
5205 uint32_t MI28:1;
5206 uint32_t MI27:1;
5207 uint32_t MI26:1;
5208 uint32_t MI25:1;
5209 uint32_t MI24:1;
5210 uint32_t MI23:1;
5211 uint32_t MI22:1;
5212 uint32_t MI21:1;
5213 uint32_t MI20:1;
5214 uint32_t MI19:1;
5215 uint32_t MI18:1;
5216 uint32_t MI17:1;
5217 uint32_t MI16:1;
5218 uint32_t MI15:1;
5219 uint32_t MI14:1;
5220 uint32_t MI13:1;
5221 uint32_t MI12:1;
5222 uint32_t MI11:1;
5223 uint32_t MI10:1;
5224 uint32_t MI9:1;
5225 uint32_t MI8:1;
5226 uint32_t MI7:1;
5227 uint32_t MI6:1;
5228 uint32_t MI5:1;
5229 uint32_t MI4:1;
5230 uint32_t MI3:1;
5231 uint32_t MI2:1;
5232 uint32_t MI1:1;
5233 uint32_t MI0:1;
5234 } B;
5235 } RX15MASK;
5236
5237 union { /* Error Counter Register */
5238 uint32_t R;
5239 struct {
5240 uint32_t:16;
5241 uint32_t RXECNT:8;
5242 uint32_t TXECNT:8;
5243 } B;
5244 } ECR;
5245
5246 union { /* Error and Status Register */
5247 uint32_t R;
5248 struct {
5249 uint32_t:14;
5250
5251 uint32_t TWRNINT:1;
5252 uint32_t RWRNINT:1;
5253 uint32_t BIT1ERR:1;
5254 uint32_t BIT0ERR:1;
5255 uint32_t ACKERR:1;
5256 uint32_t CRCERR:1;
5257 uint32_t FRMERR:1;
5258 uint32_t STFERR:1;
5259 uint32_t TXWRN:1;
5260 uint32_t RXWRN:1;
5261 uint32_t IDLE:1;
5262 uint32_t TXRX:1;
5263 uint32_t FLTCONF:2;
5264 uint32_t:1;
5265 uint32_t BOFFINT:1;
5266 uint32_t ERRINT:1;
5267 uint32_t WAKINT:1;
5268 } B;
5269 } ESR;
5270
5271 union { /* Interruput Masks Register */
5272 uint32_t R;
5273 struct {
5274 uint32_t BUF63M:1;
5275 uint32_t BUF62M:1;
5276 uint32_t BUF61M:1;
5277 uint32_t BUF60M:1;
5278 uint32_t BUF59M:1;
5279 uint32_t BUF58M:1;
5280 uint32_t BUF57M:1;
5281 uint32_t BUF56M:1;
5282 uint32_t BUF55M:1;
5283 uint32_t BUF54M:1;
5284 uint32_t BUF53M:1;
5285 uint32_t BUF52M:1;
5286 uint32_t BUF51M:1;
5287 uint32_t BUF50M:1;
5288 uint32_t BUF49M:1;
5289 uint32_t BUF48M:1;
5290 uint32_t BUF47M:1;
5291 uint32_t BUF46M:1;
5292 uint32_t BUF45M:1;
5293 uint32_t BUF44M:1;
5294 uint32_t BUF43M:1;
5295 uint32_t BUF42M:1;
5296 uint32_t BUF41M:1;
5297 uint32_t BUF40M:1;
5298 uint32_t BUF39M:1;
5299 uint32_t BUF38M:1;
5300 uint32_t BUF37M:1;
5301 uint32_t BUF36M:1;
5302 uint32_t BUF35M:1;
5303 uint32_t BUF34M:1;
5304 uint32_t BUF33M:1;
5305 uint32_t BUF32M:1;
5306 } B;
5307 } IMRH; /* Legacy naming - refer to IMASK2 in Reference Manual */
5308
5309 union { /* Interruput Masks Register */
5310 uint32_t R;
5311 struct {
5312 uint32_t BUF31M:1;
5313 uint32_t BUF30M:1;
5314 uint32_t BUF29M:1;
5315 uint32_t BUF28M:1;
5316 uint32_t BUF27M:1;
5317 uint32_t BUF26M:1;
5318 uint32_t BUF25M:1;
5319 uint32_t BUF24M:1;
5320 uint32_t BUF23M:1;
5321 uint32_t BUF22M:1;
5322 uint32_t BUF21M:1;
5323 uint32_t BUF20M:1;
5324 uint32_t BUF19M:1;
5325 uint32_t BUF18M:1;
5326 uint32_t BUF17M:1;
5327 uint32_t BUF16M:1;
5328 uint32_t BUF15M:1;
5329 uint32_t BUF14M:1;
5330 uint32_t BUF13M:1;
5331 uint32_t BUF12M:1;
5332 uint32_t BUF11M:1;
5333 uint32_t BUF10M:1;
5334 uint32_t BUF09M:1;
5335 uint32_t BUF08M:1;
5336 uint32_t BUF07M:1;
5337 uint32_t BUF06M:1;
5338 uint32_t BUF05M:1;
5339 uint32_t BUF04M:1;
5340 uint32_t BUF03M:1;
5341 uint32_t BUF02M:1;
5342 uint32_t BUF01M:1;
5343 uint32_t BUF00M:1;
5344 } B;
5345 } IMRL; /* Legacy naming - refer to IMASK1 in Reference Manual */
5346
5347 union { /* Interruput Flag Register */
5348 uint32_t R;
5349 struct {
5350 uint32_t BUF63I:1;
5351 uint32_t BUF62I:1;
5352 uint32_t BUF61I:1;
5353 uint32_t BUF60I:1;
5354 uint32_t BUF59I:1;
5355 uint32_t BUF58I:1;
5356 uint32_t BUF57I:1;
5357 uint32_t BUF56I:1;
5358 uint32_t BUF55I:1;
5359 uint32_t BUF54I:1;
5360 uint32_t BUF53I:1;
5361 uint32_t BUF52I:1;
5362 uint32_t BUF51I:1;
5363 uint32_t BUF50I:1;
5364 uint32_t BUF49I:1;
5365 uint32_t BUF48I:1;
5366 uint32_t BUF47I:1;
5367 uint32_t BUF46I:1;
5368 uint32_t BUF45I:1;
5369 uint32_t BUF44I:1;
5370 uint32_t BUF43I:1;
5371 uint32_t BUF42I:1;
5372 uint32_t BUF41I:1;
5373 uint32_t BUF40I:1;
5374 uint32_t BUF39I:1;
5375 uint32_t BUF38I:1;
5376 uint32_t BUF37I:1;
5377 uint32_t BUF36I:1;
5378 uint32_t BUF35I:1;
5379 uint32_t BUF34I:1;
5380 uint32_t BUF33I:1;
5381 uint32_t BUF32I:1;
5382 } B;
5383 } IFRH; /* Legacy naming - refer to IFLAG2 in Reference Manual */
5384
5385 union { /* Interruput Flag Register */
5386 uint32_t R;
5387 struct {
5388 uint32_t BUF31I:1;
5389 uint32_t BUF30I:1;
5390 uint32_t BUF29I:1;
5391 uint32_t BUF28I:1;
5392 uint32_t BUF27I:1;
5393 uint32_t BUF26I:1;
5394 uint32_t BUF25I:1;
5395 uint32_t BUF24I:1;
5396 uint32_t BUF23I:1;
5397 uint32_t BUF22I:1;
5398 uint32_t BUF21I:1;
5399 uint32_t BUF20I:1;
5400 uint32_t BUF19I:1;
5401 uint32_t BUF18I:1;
5402 uint32_t BUF17I:1;
5403 uint32_t BUF16I:1;
5404 uint32_t BUF15I:1;
5405 uint32_t BUF14I:1;
5406 uint32_t BUF13I:1;
5407 uint32_t BUF12I:1;
5408 uint32_t BUF11I:1;
5409 uint32_t BUF10I:1;
5410 uint32_t BUF09I:1;
5411 uint32_t BUF08I:1;
5412 uint32_t BUF07I:1;
5413 uint32_t BUF06I:1;
5414 uint32_t BUF05I:1;
5415 uint32_t BUF04I:1;
5416 uint32_t BUF03I:1;
5417 uint32_t BUF02I:1;
5418 uint32_t BUF01I:1;
5419 uint32_t BUF00I:1;
5420 } B;
5421 } IFRL; /* Legacy naming - refer to IFLAG1 in Reference Manual */
5422
5423 uint32_t FLEXCAN_reserved0034[19]; /* 0x0034-0x007F */
5424
5425 struct canbuf_t {
5426 union {
5427 uint32_t R;
5428 struct {
5429 uint32_t:4;
5430 uint32_t CODE:4;
5431 uint32_t:1;
5432 uint32_t SRR:1;
5433 uint32_t IDE:1;
5434 uint32_t RTR:1;
5435 uint32_t LENGTH:4;
5436 uint32_t TIMESTAMP:16;
5437 } B;
5438 } CS;
5439
5440 union {
5441 uint32_t R;
5442 struct {
5443 uint32_t PRIO:3;
5444 uint32_t STD_ID:11;
5445 uint32_t EXT_ID:18;
5446 } B;
5447 } ID;
5448
5449 union {
5450 uint8_t B[8]; /* Data buffer in Bytes (8 bits) */
5451 uint16_t H[4]; /* Data buffer in Half-words (16 bits) */
5452 uint32_t W[2]; /* Data buffer in words (32 bits) */
5453 uint32_t R[2]; /* Data buffer in words (32 bits) */
5454 } DATA;
5455
5456 } BUF[64];
5457
5458 int32_t FLEXCAN_reserved0480[256]; /* 0x0480-0x087F */
5459
5460 union { /* RX Individual Mask Registers */
5461 uint32_t R;
5462 struct {
5463 uint32_t MI31:1;
5464 uint32_t MI30:1;
5465 uint32_t MI29:1;
5466 uint32_t MI28:1;
5467 uint32_t MI27:1;
5468 uint32_t MI26:1;
5469 uint32_t MI25:1;
5470 uint32_t MI24:1;
5471 uint32_t MI23:1;
5472 uint32_t MI22:1;
5473 uint32_t MI21:1;
5474 uint32_t MI20:1;
5475 uint32_t MI19:1;
5476 uint32_t MI18:1;
5477 uint32_t MI17:1;
5478 uint32_t MI16:1;
5479 uint32_t MI15:1;
5480 uint32_t MI14:1;
5481 uint32_t MI13:1;
5482 uint32_t MI12:1;
5483 uint32_t MI11:1;
5484 uint32_t MI10:1;
5485 uint32_t MI9:1;
5486 uint32_t MI8:1;
5487 uint32_t MI7:1;
5488 uint32_t MI6:1;
5489 uint32_t MI5:1;
5490 uint32_t MI4:1;
5491 uint32_t MI3:1;
5492 uint32_t MI2:1;
5493 uint32_t MI1:1;
5494 uint32_t MI0:1;
5495 } B;
5496 } RXIMR[64];
5497
5498 int32_t FLEXCAN_reserved0980[3488]; /* 0x0980-0x3FFF */
5499
5500 };
5501
5502/****************************************************************************/
5503/* MODULE : FlexRay */
5504/****************************************************************************/
5505
5506 typedef union uMVR {
5507 uint16_t R;
5508 struct {
5509 uint16_t CHIVER:8; /* CHI Version Number */
5510 uint16_t PEVER:8; /* PE Version Number */
5511 } B;
5512 } MVR_t;
5513
5514 typedef union uMCR {
5515 uint16_t R;
5516 struct {
5517 uint16_t MEN:1; /* module enable */
5518 uint16_t:1;
5519 uint16_t SCMD:1; /* single channel mode */
5520 uint16_t CHB:1; /* channel B enable */
5521 uint16_t CHA:1; /* channel A enable */
5522 uint16_t SFFE:1; /* synchronization frame filter enable */
5523 uint16_t:5;
5524 uint16_t CLKSEL:1; /* protocol engine clock source select */
5525 uint16_t PRESCALE:3; /* protocol engine clock prescaler */
5526 uint16_t:1;
5527 } B;
5528 } MCR_t;
5529
5530 typedef union uSTBSCR {
5531 uint16_t R;
5532 struct {
5533 uint16_t WMD:1; /* write mode */
5534 uint16_t STBSSEL:7; /* strobe signal select */
5535 uint16_t:3;
5536 uint16_t ENB:1; /* strobe signal enable */
5537 uint16_t:2;
5538 uint16_t STBPSEL:2; /* strobe port select */
5539 } B;
5540 } STBSCR_t;
5541 typedef union uSTBPCR {
5542 uint16_t R;
5543 struct {
5544 uint16_t:12;
5545 uint16_t STB3EN:1; /* strobe port enable */
5546 uint16_t STB2EN:1; /* strobe port enable */
5547 uint16_t STB1EN:1; /* strobe port enable */
5548 uint16_t STB0EN:1; /* strobe port enable */
5549 } B;
5550 } STBPCR_t;
5551
5552 typedef union uMBDSR {
5553 uint16_t R;
5554 struct {
5555 uint16_t:1;
5556 uint16_t MBSEG2DS:7; /* message buffer segment 2 data size */
5557 uint16_t:1;
5558 uint16_t MBSEG1DS:7; /* message buffer segment 1 data size */
5559 } B;
5560 } MBDSR_t;
5561 typedef union uMBSSUTR {
5562 uint16_t R;
5563 struct {
5564
5565 uint16_t:1;
5566 uint16_t LAST_MB_SEG1:7; /* last message buffer control register for message buffer segment 1 */
5567 uint16_t:1;
5568 uint16_t LAST_MB_UTIL:7; /* last message buffer utilized */
5569 } B;
5570 } MBSSUTR_t;
5571
5572 typedef union uPOCR {
5573 uint16_t R;
5574 uint8_t byte[2];
5575 struct {
5576 uint16_t WME:1; /* write mode external correction command */
5577 uint16_t:3;
5578 uint16_t EOC_AP:2; /* external offset correction application */
5579 uint16_t ERC_AP:2; /* external rate correction application */
5580 uint16_t BSY:1; /* command write busy / write mode command */
5581 uint16_t:3;
5582 uint16_t POCCMD:4; /* protocol command */
5583 } B;
5584 } POCR_t;
5585/* protocol commands */
5586 typedef union uGIFER {
5587 uint16_t R;
5588 struct {
5589 uint16_t MIF:1; /* module interrupt flag */
5590 uint16_t PRIF:1; /* protocol interrupt flag */
5591 uint16_t CHIF:1; /* CHI interrupt flag */
5592 uint16_t WKUPIF:1; /* wakeup interrupt flag */
5593 uint16_t FNEBIF:1; /* receive FIFO channel B not empty interrupt flag */
5594 uint16_t FNEAIF:1; /* receive FIFO channel A not empty interrupt flag */
5595 uint16_t RBIF:1; /* receive message buffer interrupt flag */
5596 uint16_t TBIF:1; /* transmit buffer interrupt flag */
5597 uint16_t MIE:1; /* module interrupt enable */
5598 uint16_t PRIE:1; /* protocol interrupt enable */
5599 uint16_t CHIE:1; /* CHI interrupt enable */
5600 uint16_t WKUPIE:1; /* wakeup interrupt enable */
5601 uint16_t FNEBIE:1; /* receive FIFO channel B not empty interrupt enable */
5602 uint16_t FNEAIE:1; /* receive FIFO channel A not empty interrupt enable */
5603 uint16_t RBIE:1; /* receive message buffer interrupt enable */
5604 uint16_t TBIE:1; /* transmit buffer interrupt enable */
5605 } B;
5606 } GIFER_t;
5607 typedef union uPIFR0 {
5608 uint16_t R;
5609 struct {
5610 uint16_t FATLIF:1; /* fatal protocol error interrupt flag */
5611 uint16_t INTLIF:1; /* internal protocol error interrupt flag */
5612 uint16_t ILCFIF:1; /* illegal protocol configuration flag */
5613 uint16_t CSAIF:1; /* cold start abort interrupt flag */
5614 uint16_t MRCIF:1; /* missing rate correctio interrupt flag */
5615 uint16_t MOCIF:1; /* missing offset correctio interrupt flag */
5616 uint16_t CCLIF:1; /* clock correction limit reached interrupt flag */
5617 uint16_t MXSIF:1; /* max sync frames detected interrupt flag */
5618 uint16_t MTXIF:1; /* media access test symbol received flag */
5619 uint16_t LTXBIF:1; /* pdLatestTx violation on channel B interrupt flag */
5620 uint16_t LTXAIF:1; /* pdLatestTx violation on channel A interrupt flag */
5621 uint16_t TBVBIF:1; /* Transmission across boundary on channel B Interrupt Flag */
5622 uint16_t TBVAIF:1; /* Transmission across boundary on channel A Interrupt Flag */
5623 uint16_t TI2IF:1; /* timer 2 expired interrupt flag */
5624 uint16_t TI1IF:1; /* timer 1 expired interrupt flag */
5625 uint16_t CYSIF:1; /* cycle start interrupt flag */
5626 } B;
5627 } PIFR0_t;
5628 typedef union uPIFR1 {
5629 uint16_t R;
5630 struct {
5631 uint16_t EMCIF:1; /* error mode changed interrupt flag */
5632 uint16_t IPCIF:1; /* illegal protocol command interrupt flag */
5633 uint16_t PECFIF:1; /* protocol engine communication failure interrupt flag */
5634 uint16_t PSCIF:1; /* Protocol State Changed Interrupt Flag */
5635 uint16_t SSI3IF:1; /* slot status counter incremented interrupt flag */
5636 uint16_t SSI2IF:1; /* slot status counter incremented interrupt flag */
5637 uint16_t SSI1IF:1; /* slot status counter incremented interrupt flag */
5638 uint16_t SSI0IF:1; /* slot status counter incremented interrupt flag */
5639 uint16_t:2;
5640 uint16_t EVTIF:1; /* even cycle table written interrupt flag */
5641 uint16_t ODTIF:1; /* odd cycle table written interrupt flag */
5642 uint16_t:4;
5643 } B;
5644 } PIFR1_t;
5645 typedef union uPIER0 {
5646 uint16_t R;
5647 struct {
5648 uint16_t FATLIE:1; /* fatal protocol error interrupt enable */
5649 uint16_t INTLIE:1; /* internal protocol error interrupt interrupt enable */
5650 uint16_t ILCFIE:1; /* illegal protocol configuration interrupt enable */
5651 uint16_t CSAIE:1; /* cold start abort interrupt enable */
5652 uint16_t MRCIE:1; /* missing rate correctio interrupt enable */
5653 uint16_t MOCIE:1; /* missing offset correctio interrupt enable */
5654 uint16_t CCLIE:1; /* clock correction limit reached interrupt enable */
5655 uint16_t MXSIE:1; /* max sync frames detected interrupt enable */
5656 uint16_t MTXIE:1; /* media access test symbol received interrupt enable */
5657 uint16_t LTXBIE:1; /* pdLatestTx violation on channel B interrupt enable */
5658 uint16_t LTXAIE:1; /* pdLatestTx violation on channel A interrupt enable */
5659 uint16_t TBVBIE:1; /* Transmission across boundary on channel B Interrupt enable */
5660 uint16_t TBVAIE:1; /* Transmission across boundary on channel A Interrupt enable */
5661 uint16_t TI2IE:1; /* timer 2 expired interrupt enable */
5662 uint16_t TI1IE:1; /* timer 1 expired interrupt enable */
5663 uint16_t CYSIE:1; /* cycle start interrupt enable */
5664 } B;
5665 } PIER0_t;
5666 typedef union uPIER1 {
5667 uint16_t R;
5668 struct {
5669 uint16_t EMCIE:1; /* error mode changed interrupt enable */
5670 uint16_t IPCIE:1; /* illegal protocol command interrupt enable */
5671 uint16_t PECFIE:1; /* protocol engine communication failure interrupt enable */
5672 uint16_t PSCIE:1; /* Protocol State Changed Interrupt enable */
5673 uint16_t SSI3IE:1; /* slot status counter incremented interrupt enable */
5674 uint16_t SSI2IE:1; /* slot status counter incremented interrupt enable */
5675 uint16_t SSI1IE:1; /* slot status counter incremented interrupt enable */
5676 uint16_t SSI0IE:1; /* slot status counter incremented interrupt enable */
5677 uint16_t:2;
5678 uint16_t EVTIE:1; /* even cycle table written interrupt enable */
5679 uint16_t ODTIE:1; /* odd cycle table written interrupt enable */
5680 uint16_t:4;
5681 } B;
5682 } PIER1_t;
5683 typedef union uCHIERFR {
5684 uint16_t R;
5685 struct {
5686 uint16_t FRLBEF:1; /* flame lost channel B error flag */
5687 uint16_t FRLAEF:1; /* frame lost channel A error flag */
5688 uint16_t PCMIEF:1; /* command ignored error flag */
5689 uint16_t FOVBEF:1; /* receive FIFO overrun channel B error flag */
5690 uint16_t FOVAEF:1; /* receive FIFO overrun channel A error flag */
5691 uint16_t MSBEF:1; /* message buffer search error flag */
5692 uint16_t MBUEF:1; /* message buffer utilization error flag */
5693 uint16_t LCKEF:1; /* lock error flag */
5694 uint16_t DBLEF:1; /* double transmit message buffer lock error flag */
5695 uint16_t SBCFEF:1; /* system bus communication failure error flag */
5696 uint16_t FIDEF:1; /* frame ID error flag */
5697 uint16_t DPLEF:1; /* dynamic payload length error flag */
5698 uint16_t SPLEF:1; /* static payload length error flag */
5699 uint16_t NMLEF:1; /* network management length error flag */
5700 uint16_t NMFEF:1; /* network management frame error flag */
5701 uint16_t ILSAEF:1; /* illegal access error flag */
5702 } B;
5703 } CHIERFR_t;
5704 typedef union uMBIVEC {
5705 uint16_t R;
5706 struct {
5707
5708 uint16_t:1;
5709 uint16_t TBIVEC:7; /* transmit buffer interrupt vector */
5710 uint16_t:1;
5711 uint16_t RBIVEC:7; /* receive buffer interrupt vector */
5712 } B;
5713 } MBIVEC_t;
5714
5715 typedef union uPSR0 {
5716 uint16_t R;
5717 struct {
5718 uint16_t ERRMODE:2; /* error mode */
5719 uint16_t SLOTMODE:2; /* slot mode */
5720 uint16_t:1;
5721 uint16_t PROTSTATE:3; /* protocol state */
5722 uint16_t SUBSTATE:4; /* protocol sub state */
5723 uint16_t:1;
5724 uint16_t WAKEUPSTATUS:3; /* wakeup status */
5725 } B;
5726 } PSR0_t;
5727
5728/* protocol states */
5729/* protocol sub-states */
5730/* wakeup status */
5731 typedef union uPSR1 {
5732 uint16_t R;
5733 struct {
5734 uint16_t CSAA:1; /* cold start attempt abort flag */
5735 uint16_t SCP:1; /* cold start path */
5736 uint16_t:1;
5737 uint16_t REMCSAT:5; /* remanining coldstart attempts */
5738 uint16_t CPN:1; /* cold start noise path */
5739 uint16_t HHR:1; /* host halt request pending */
5740 uint16_t FRZ:1; /* freeze occured */
5741 uint16_t APTAC:5; /* allow passive to active counter */
5742 } B;
5743 } PSR1_t;
5744 typedef union uPSR2 {
5745 uint16_t R;
5746 struct {
5747 uint16_t NBVB:1; /* NIT boundary violation on channel B */
5748 uint16_t NSEB:1; /* NIT syntax error on channel B */
5749 uint16_t STCB:1; /* symbol window transmit conflict on channel B */
5750 uint16_t SBVB:1; /* symbol window boundary violation on channel B */
5751 uint16_t SSEB:1; /* symbol window syntax error on channel B */
5752 uint16_t MTB:1; /* media access test symbol MTS received on channel B */
5753 uint16_t NBVA:1; /* NIT boundary violation on channel A */
5754 uint16_t NSEA:1; /* NIT syntax error on channel A */
5755 uint16_t STCA:1; /* symbol window transmit conflict on channel A */
5756 uint16_t SBVA:1; /* symbol window boundary violation on channel A */
5757 uint16_t SSEA:1; /* symbol window syntax error on channel A */
5758 uint16_t MTA:1; /* media access test symbol MTS received on channel A */
5759 uint16_t CLKCORRFAILCNT:4; /* clock correction failed counter */
5760 } B;
5761 } PSR2_t;
5762 typedef union uPSR3 {
5763 uint16_t R;
5764 struct {
5765 uint16_t:2;
5766 uint16_t WUB:1; /* wakeup symbol received on channel B */
5767 uint16_t ABVB:1; /* aggregated boundary violation on channel B */
5768 uint16_t AACB:1; /* aggregated additional communication on channel B */
5769 uint16_t ACEB:1; /* aggregated content error on channel B */
5770 uint16_t ASEB:1; /* aggregated syntax error on channel B */
5771 uint16_t AVFB:1; /* aggregated valid frame on channel B */
5772 uint16_t:2;
5773 uint16_t WUA:1; /* wakeup symbol received on channel A */
5774 uint16_t ABVA:1; /* aggregated boundary violation on channel A */
5775 uint16_t AACA:1; /* aggregated additional communication on channel A */
5776 uint16_t ACEA:1; /* aggregated content error on channel A */
5777 uint16_t ASEA:1; /* aggregated syntax error on channel A */
5778 uint16_t AVFA:1; /* aggregated valid frame on channel A */
5779 } B;
5780 } PSR3_t;
5781 typedef union uCIFRR {
5782 uint16_t R;
5783 struct {
5784 uint16_t:8;
5785 uint16_t MIFR:1; /* module interrupt flag */
5786 uint16_t PRIFR:1; /* protocol interrupt flag */
5787 uint16_t CHIFR:1; /* CHI interrupt flag */
5788 uint16_t WUPIFR:1; /* wakeup interrupt flag */
5789 uint16_t FNEBIFR:1; /* receive fifo channel B no empty interrupt flag */
5790 uint16_t FNEAIFR:1; /* receive fifo channel A no empty interrupt flag */
5791 uint16_t RBIFR:1; /* receive message buffer interrupt flag */
5792 uint16_t TBIFR:1; /* transmit buffer interrupt flag */
5793 } B;
5794 } CIFRR_t;
5795 typedef union uSFCNTR {
5796 uint16_t R;
5797 struct {
5798 uint16_t SFEVB:4; /* sync frames channel B, even cycle */
5799 uint16_t SFEVA:4; /* sync frames channel A, even cycle */
5800 uint16_t SFODB:4; /* sync frames channel B, odd cycle */
5801 uint16_t SFODA:4; /* sync frames channel A, odd cycle */
5802 } B;
5803 } SFCNTR_t;
5804
5805 typedef union uSFTCCSR {
5806 uint16_t R;
5807 struct {
5808 uint16_t ELKT:1; /* even cycle tables lock and unlock trigger */
5809 uint16_t OLKT:1; /* odd cycle tables lock and unlock trigger */
5810 uint16_t CYCNUM:6; /* cycle number */
5811 uint16_t ELKS:1; /* even cycle tables lock status */
5812 uint16_t OLKS:1; /* odd cycle tables lock status */
5813 uint16_t EVAL:1; /* even cycle tables valid */
5814 uint16_t OVAL:1; /* odd cycle tables valid */
5815 uint16_t:1;
5816 uint16_t OPT:1; /*one pair trigger */
5817 uint16_t SDVEN:1; /* sync frame deviation table enable */
5818 uint16_t SIDEN:1; /* sync frame ID table enable */
5819 } B;
5820 } SFTCCSR_t;
5821 typedef union uSFIDRFR {
5822 uint16_t R;
5823 struct {
5824 uint16_t:6;
5825 uint16_t SYNFRID:10; /* sync frame rejection ID */
5826 } B;
5827 } SFIDRFR_t;
5828
5829 typedef union uTICCR {
5830 uint16_t R;
5831 struct {
5832 uint16_t:2;
5833 uint16_t T2CFG:1; /* timer 2 configuration */
5834 uint16_t T2REP:1; /* timer 2 repetitive mode */
5835 uint16_t:1;
5836 uint16_t T2SP:1; /* timer 2 stop */
5837 uint16_t T2TR:1; /* timer 2 trigger */
5838 uint16_t T2ST:1; /* timer 2 state */
5839 uint16_t:3;
5840 uint16_t T1REP:1; /* timer 1 repetitive mode */
5841 uint16_t:1;
5842 uint16_t T1SP:1; /* timer 1 stop */
5843 uint16_t T1TR:1; /* timer 1 trigger */
5844 uint16_t T1ST:1; /* timer 1 state */
5845
5846 } B;
5847 } TICCR_t;
5848 typedef union uTI1CYSR {
5849 uint16_t R;
5850 struct {
5851 uint16_t:2;
5852 uint16_t TI1CYCVAL:6; /* timer 1 cycle filter value */
5853 uint16_t:2;
5854 uint16_t TI1CYCMSK:6; /* timer 1 cycle filter mask */
5855
5856 } B;
5857 } TI1CYSR_t;
5858
5859 typedef union uSSSR {
5860 uint16_t R;
5861 struct {
5862 uint16_t WMD:1; /* write mode */
5863 uint16_t:1;
5864 uint16_t SEL:2; /* static slot number */
5865 uint16_t:1;
5866 uint16_t SLOTNUMBER:11; /* selector */
5867 } B;
5868 } SSSR_t;
5869
5870 typedef union uSSCCR {
5871 uint16_t R;
5872 struct {
5873 uint16_t WMD:1; /* write mode */
5874 uint16_t:1;
5875 uint16_t SEL:2; /* selector */
5876 uint16_t:1;
5877 uint16_t CNTCFG:2; /* counter configuration */
5878 uint16_t MCY:1; /* multi cycle selection */
5879 uint16_t VFR:1; /* valid frame selection */
5880 uint16_t SYF:1; /* sync frame selection */
5881 uint16_t NUF:1; /* null frame selection */
5882 uint16_t SUF:1; /* startup frame selection */
5883 uint16_t STATUSMASK:4; /* slot status mask */
5884 } B;
5885 } SSCCR_t;
5886 typedef union uSSR {
5887 uint16_t R;
5888 struct {
5889 uint16_t VFB:1; /* valid frame on channel B */
5890 uint16_t SYB:1; /* valid sync frame on channel B */
5891 uint16_t NFB:1; /* valid null frame on channel B */
5892 uint16_t SUB:1; /* valid startup frame on channel B */
5893 uint16_t SEB:1; /* syntax error on channel B */
5894 uint16_t CEB:1; /* content error on channel B */
5895 uint16_t BVB:1; /* boundary violation on channel B */
5896 uint16_t TCB:1; /* tx conflict on channel B */
5897 uint16_t VFA:1; /* valid frame on channel A */
5898 uint16_t SYA:1; /* valid sync frame on channel A */
5899 uint16_t NFA:1; /* valid null frame on channel A */
5900 uint16_t SUA:1; /* valid startup frame on channel A */
5901 uint16_t SEA:1; /* syntax error on channel A */
5902 uint16_t CEA:1; /* content error on channel A */
5903 uint16_t BVA:1; /* boundary violation on channel A */
5904 uint16_t TCA:1; /* tx conflict on channel A */
5905 } B;
5906 } SSR_t;
5907 typedef union uMTSCFR {
5908 uint16_t R;
5909 struct {
5910 uint16_t MTE:1; /* media access test symbol transmission enable */
5911 uint16_t:1;
5912 uint16_t CYCCNTMSK:6; /* cycle counter mask */
5913 uint16_t:2;
5914 uint16_t CYCCNTVAL:6; /* cycle counter value */
5915 } B;
5916 } MTSCFR_t;
5917 typedef union uRSBIR {
5918 uint16_t R;
5919 struct {
5920 uint16_t WMD:1; /* write mode */
5921 uint16_t:1;
5922 uint16_t SEL:2; /* selector */
5923 uint16_t:4;
5924 uint16_t RSBIDX:8; /* receive shadow buffer index */
5925 } B;
5926 } RSBIR_t;
5927 typedef union uRFDSR {
5928 uint16_t R;
5929 struct {
5930 uint16_t FIFODEPTH:8; /* fifo depth */
5931 uint16_t:1;
5932 uint16_t ENTRYSIZE:7; /* entry size */
5933 } B;
5934 } RFDSR_t;
5935
5936 typedef union uRFRFCFR {
5937 uint16_t R;
5938 struct {
5939 uint16_t WMD:1; /* write mode */
5940 uint16_t IBD:1; /* interval boundary */
5941 uint16_t SEL:2; /* filter number */
5942 uint16_t:1;
5943 uint16_t SID:11; /* slot ID */
5944 } B;
5945 } RFRFCFR_t;
5946
5947 typedef union uRFRFCTR {
5948 uint16_t R;
5949 struct {
5950 uint16_t:4;
5951 uint16_t F3MD:1; /* filter mode */
5952 uint16_t F2MD:1; /* filter mode */
5953 uint16_t F1MD:1; /* filter mode */
5954 uint16_t F0MD:1; /* filter mode */
5955 uint16_t:4;
5956 uint16_t F3EN:1; /* filter enable */
5957 uint16_t F2EN:1; /* filter enable */
5958 uint16_t F1EN:1; /* filter enable */
5959 uint16_t F0EN:1; /* filter enable */
5960 } B;
5961 } RFRFCTR_t;
5962 typedef union uPCR0 {
5963 uint16_t R;
5964 struct {
5965 uint16_t ACTION_POINT_OFFSET:6;
5966 uint16_t STATIC_SLOT_LENGTH:10;
5967 } B;
5968 } PCR0_t;
5969
5970 typedef union uPCR1 {
5971 uint16_t R;
5972 struct {
5973 uint16_t:2;
5974 uint16_t MACRO_AFTER_FIRST_STATIC_SLOT:14;
5975 } B;
5976 } PCR1_t;
5977
5978 typedef union uPCR2 {
5979 uint16_t R;
5980 struct {
5981 uint16_t MINISLOT_AFTER_ACTION_POINT:6;
5982 uint16_t NUMBER_OF_STATIC_SLOTS:10;
5983 } B;
5984 } PCR2_t;
5985
5986 typedef union uPCR3 {
5987 uint16_t R;
5988 struct {
5989 uint16_t WAKEUP_SYMBOL_RX_LOW:6;
5990 uint16_t MINISLOT_ACTION_POINT_OFFSET:5;
5991 uint16_t COLDSTART_ATTEMPTS:5;
5992 } B;
5993 } PCR3_t;
5994
5995 typedef union uPCR4 {
5996 uint16_t R;
5997 struct {
5998 uint16_t CAS_RX_LOW_MAX:7;
5999 uint16_t WAKEUP_SYMBOL_RX_WINDOW:9;
6000 } B;
6001 } PCR4_t;
6002
6003 typedef union uPCR5 {
6004 uint16_t R;
6005 struct {
6006 uint16_t TSS_TRANSMITTER:4;
6007 uint16_t WAKEUP_SYMBOL_TX_LOW:6;
6008 uint16_t WAKEUP_SYMBOL_RX_IDLE:6;
6009 } B;
6010 } PCR5_t;
6011
6012 typedef union uPCR6 {
6013 uint16_t R;
6014 struct {
6015 uint16_t:1;
6016 uint16_t SYMBOL_WINDOW_AFTER_ACTION_POINT:8;
6017 uint16_t MACRO_INITIAL_OFFSET_A:7;
6018 } B;
6019 } PCR6_t;
6020
6021 typedef union uPCR7 {
6022 uint16_t R;
6023 struct {
6024 uint16_t DECODING_CORRECTION_B:9;
6025 uint16_t MICRO_PER_MACRO_NOM_HALF:7;
6026 } B;
6027 } PCR7_t;
6028
6029 typedef union uPCR8 {
6030 uint16_t R;
6031 struct {
6032 uint16_t MAX_WITHOUT_CLOCK_CORRECTION_FATAL:4;
6033 uint16_t MAX_WITHOUT_CLOCK_CORRECTION_PASSIVE:4;
6034 uint16_t WAKEUP_SYMBOL_TX_IDLE:8;
6035 } B;
6036 } PCR8_t;
6037
6038 typedef union uPCR9 {
6039 uint16_t R;
6040 struct {
6041 uint16_t MINISLOT_EXISTS:1;
6042 uint16_t SYMBOL_WINDOW_EXISTS:1;
6043 uint16_t OFFSET_CORRECTION_OUT:14;
6044 } B;
6045 } PCR9_t;
6046
6047 typedef union uPCR10 {
6048 uint16_t R;
6049 struct {
6050 uint16_t SINGLE_SLOT_ENABLED:1;
6051 uint16_t WAKEUP_CHANNEL:1;
6052 uint16_t MACRO_PER_CYCLE:14;
6053 } B;
6054 } PCR10_t;
6055
6056 typedef union uPCR11 {
6057 uint16_t R;
6058 struct {
6059 uint16_t KEY_SLOT_USED_FOR_STARTUP:1;
6060 uint16_t KEY_SLOT_USED_FOR_SYNC:1;
6061 uint16_t OFFSET_CORRECTION_START:14;
6062 } B;
6063 } PCR11_t;
6064
6065 typedef union uPCR12 {
6066 uint16_t R;
6067 struct {
6068 uint16_t ALLOW_PASSIVE_TO_ACTIVE:5;
6069 uint16_t KEY_SLOT_HEADER_CRC:11;
6070 } B;
6071 } PCR12_t;
6072
6073 typedef union uPCR13 {
6074 uint16_t R;
6075 struct {
6076 uint16_t FIRST_MINISLOT_ACTION_POINT_OFFSET:6;
6077 uint16_t STATIC_SLOT_AFTER_ACTION_POINT:10;
6078 } B;
6079 } PCR13_t;
6080
6081 typedef union uPCR14 {
6082 uint16_t R;
6083 struct {
6084 uint16_t RATE_CORRECTION_OUT:11;
6085 uint16_t LISTEN_TIMEOUT_H:5;
6086 } B;
6087 } PCR14_t;
6088
6089 typedef union uPCR15 {
6090 uint16_t R;
6091 struct {
6092 uint16_t LISTEN_TIMEOUT_L:16;
6093 } B;
6094 } PCR15_t;
6095
6096 typedef union uPCR16 {
6097 uint16_t R;
6098 struct {
6099 uint16_t MACRO_INITIAL_OFFSET_B:7;
6100 uint16_t NOISE_LISTEN_TIMEOUT_H:9;
6101 } B;
6102 } PCR16_t;
6103
6104 typedef union uPCR17 {
6105 uint16_t R;
6106 struct {
6107 uint16_t NOISE_LISTEN_TIMEOUT_L:16;
6108 } B;
6109 } PCR17_t;
6110
6111 typedef union uPCR18 {
6112 uint16_t R;
6113 struct {
6114 uint16_t WAKEUP_PATTERN:6;
6115 uint16_t KEY_SLOT_ID:10;
6116 } B;
6117 } PCR18_t;
6118
6119 typedef union uPCR19 {
6120 uint16_t R;
6121 struct {
6122 uint16_t DECODING_CORRECTION_A:9;
6123 uint16_t PAYLOAD_LENGTH_STATIC:7;
6124 } B;
6125 } PCR19_t;
6126
6127 typedef union uPCR20 {
6128 uint16_t R;
6129 struct {
6130 uint16_t MICRO_INITIAL_OFFSET_B:8;
6131 uint16_t MICRO_INITIAL_OFFSET_A:8;
6132 } B;
6133 } PCR20_t;
6134
6135 typedef union uPCR21 {
6136 uint16_t R;
6137 struct {
6138 uint16_t EXTERN_RATE_CORRECTION:3;
6139 uint16_t LATEST_TX:13;
6140 } B;
6141 } PCR21_t;
6142
6143 typedef union uPCR22 {
6144 uint16_t R;
6145 struct {
6146 uint16_t:1;
6147 uint16_t COMP_ACCEPTED_STARTUP_RANGE_A:11;
6148 uint16_t MICRO_PER_CYCLE_H:4;
6149 } B;
6150 } PCR22_t;
6151
6152 typedef union uPCR23 {
6153 uint16_t R;
6154 struct {
6155 uint16_t micro_per_cycle_l:16;
6156 } B;
6157 } PCR23_t;
6158
6159 typedef union uPCR24 {
6160 uint16_t R;
6161 struct {
6162 uint16_t CLUSTER_DRIFT_DAMPING:5;
6163 uint16_t MAX_PAYLOAD_LENGTH_DYNAMIC:7;
6164 uint16_t MICRO_PER_CYCLE_MIN_H:4;
6165 } B;
6166 } PCR24_t;
6167
6168 typedef union uPCR25 {
6169 uint16_t R;
6170 struct {
6171 uint16_t MICRO_PER_CYCLE_MIN_L:16;
6172 } B;
6173 } PCR25_t;
6174
6175 typedef union uPCR26 {
6176 uint16_t R;
6177 struct {
6178 uint16_t ALLOW_HALT_DUE_TO_CLOCK:1;
6179 uint16_t COMP_ACCEPTED_STARTUP_RANGE_B:11;
6180 uint16_t MICRO_PER_CYCLE_MAX_H:4;
6181 } B;
6182 } PCR26_t;
6183
6184 typedef union uPCR27 {
6185 uint16_t R;
6186 struct {
6187 uint16_t MICRO_PER_CYCLE_MAX_L:16;
6188 } B;
6189 } PCR27_t;
6190
6191 typedef union uPCR28 {
6192 uint16_t R;
6193 struct {
6194 uint16_t DYNAMIC_SLOT_IDLE_PHASE:2;
6195 uint16_t MACRO_AFTER_OFFSET_CORRECTION:14;
6196 } B;
6197 } PCR28_t;
6198
6199 typedef union uPCR29 {
6200 uint16_t R;
6201 struct {
6202 uint16_t EXTERN_OFFSET_CORRECTION:3;
6203 uint16_t MINISLOTS_MAX:13;
6204 } B;
6205 } PCR29_t;
6206
6207 typedef union uPCR30 {
6208 uint16_t R;
6209 struct {
6210 uint16_t:12;
6211 uint16_t SYNC_NODE_MAX:4;
6212 } B;
6213 } PCR30_t;
6214
6215 typedef struct uMSG_BUFF_CCS {
6216 union {
6217 uint16_t R;
6218 struct {
6219 uint16_t:1;
6220 uint16_t MCM:1; /* message buffer commit mode */
6221 uint16_t MBT:1; /* message buffer type */
6222 uint16_t MTD:1; /* message buffer direction */
6223 uint16_t CMT:1; /* commit for transmission */
6224 uint16_t EDT:1; /* enable / disable trigger */
6225 uint16_t LCKT:1; /* lock request trigger */
6226 uint16_t MBIE:1; /* message buffer interrupt enable */
6227 uint16_t:3;
6228 uint16_t DUP:1; /* data updated */
6229 uint16_t DVAL:1; /* data valid */
6230 uint16_t EDS:1; /* lock status */
6231 uint16_t LCKS:1; /* enable / disable status */
6232 uint16_t MBIF:1; /* message buffer interrupt flag */
6233 } B;
6234 } MBCCSR;
6235 union {
6236 uint16_t R;
6237 struct {
6238 uint16_t MTM:1; /* message buffer transmission mode */
6239 uint16_t CHNLA:1; /* channel assignement */
6240 uint16_t CHNLB:1; /* channel assignement */
6241 uint16_t CCFE:1; /* cycle counter filter enable */
6242 uint16_t CCFMSK:6; /* cycle counter filter mask */
6243 uint16_t CCFVAL:6; /* cycle counter filter value */
6244 } B;
6245 } MBCCFR;
6246 union {
6247 uint16_t R;
6248 struct {
6249 uint16_t:5;
6250 uint16_t FID:11; /* frame ID */
6251 } B;
6252 } MBFIDR;
6253 union {
6254 uint16_t R;
6255 struct {
6256 uint16_t:8;
6257 uint16_t MBIDX:8; /* message buffer index */
6258 } B;
6259 } MBIDXR;
6261 typedef union uSYSBADHR {
6262 uint16_t R;
6263 } SYSBADHR_t;
6264 typedef union uSYSBADLR {
6265 uint16_t R;
6266 } SYSBADLR_t;
6267 typedef union uPDAR {
6268 uint16_t R;
6269 } PDAR_t;
6270 typedef union uCASERCR {
6271 uint16_t R;
6272 } CASERCR_t;
6273 typedef union uCBSERCR {
6274 uint16_t R;
6275 } CBSERCR_t;
6276 typedef union uCYCTR {
6277 uint16_t R;
6278 } CYCTR_t;
6279 typedef union uMTCTR {
6280 uint16_t R;
6281 } MTCTR_t;
6282 typedef union uSLTCTAR {
6283 uint16_t R;
6284 } SLTCTAR_t;
6285 typedef union uSLTCTBR {
6286 uint16_t R;
6287 } SLTCTBR_t;
6288 typedef union uRTCORVR {
6289 uint16_t R;
6290 } RTCORVR_t;
6291 typedef union uOFCORVR {
6292 uint16_t R;
6293 } OFCORVR_t;
6294 typedef union uSFTOR {
6295 uint16_t R;
6296 } SFTOR_t;
6297 typedef union uSFIDAFVR {
6298 uint16_t R;
6299 } SFIDAFVR_t;
6300 typedef union uSFIDAFMR {
6301 uint16_t R;
6302 } SFIDAFMR_t;
6303 typedef union uNMVR {
6304 uint16_t R;
6305 } NMVR_t;
6306 typedef union uNMVLR {
6307 uint16_t R;
6308 } NMVLR_t;
6309 typedef union uT1MTOR {
6310 uint16_t R;
6311 } T1MTOR_t;
6312 typedef union uTI2CR0 {
6313 uint16_t R;
6314 } TI2CR0_t;
6315 typedef union uTI2CR1 {
6316 uint16_t R;
6317 } TI2CR1_t;
6318 typedef union uSSCR {
6319 uint16_t R;
6320 } SSCR_t;
6321 typedef union uRFSR {
6322 uint16_t R;
6323 } RFSR_t;
6324 typedef union uRFSIR {
6325 uint16_t R;
6326 } RFSIR_t;
6327 typedef union uRFARIR {
6328 uint16_t R;
6329 } RFARIR_t;
6330 typedef union uRFBRIR {
6331 uint16_t R;
6332 } RFBRIR_t;
6333 typedef union uRFMIDAFVR {
6334 uint16_t R;
6335 } RFMIDAFVR_t;
6336 typedef union uRFMIAFMR {
6337 uint16_t R;
6338 } RFMIAFMR_t;
6339 typedef union uRFFIDRFVR {
6340 uint16_t R;
6341 } RFFIDRFVR_t;
6342 typedef union uRFFIDRFMR {
6343 uint16_t R;
6344 } RFFIDRFMR_t;
6345 typedef union uLDTXSLAR {
6346 uint16_t R;
6347 } LDTXSLAR_t;
6348 typedef union uLDTXSLBR {
6349 uint16_t R;
6350 } LDTXSLBR_t;
6351
6352 typedef struct FR_tag {
6353 volatile MVR_t MVR; /*module version register *//*0 */
6354 volatile MCR_t MCR; /*module configuration register *//*2 */
6355 volatile SYSBADHR_t SYSBADHR; /*system memory base address high register *//*4 */
6356 volatile SYSBADLR_t SYSBADLR; /*system memory base address low register *//*6 */
6357 volatile STBSCR_t STBSCR; /*strobe signal control register *//*8 */
6358 volatile STBPCR_t STBPCR; /*strobe port control register *//*A */
6359 volatile MBDSR_t MBDSR; /*message buffer data size register *//*C */
6360 volatile MBSSUTR_t MBSSUTR; /*message buffer segment size and utilization register *//*E */
6361 uint16_t reserved3a[1]; /*10 */
6362 volatile PDAR_t PDAR; /*PE data register *//*12 */
6363 volatile POCR_t POCR; /*Protocol operation control register *//*14 */
6364 volatile GIFER_t GIFER; /*global interrupt flag and enable register *//*16 */
6365 volatile PIFR0_t PIFR0; /*protocol interrupt flag register 0 *//*18 */
6366 volatile PIFR1_t PIFR1; /*protocol interrupt flag register 1 *//*1A */
6367 volatile PIER0_t PIER0; /*protocol interrupt enable register 0 *//*1C */
6368 volatile PIER1_t PIER1; /*protocol interrupt enable register 1 *//*1E */
6369 volatile CHIERFR_t CHIERFR; /*CHI error flag register *//*20 */
6370 volatile MBIVEC_t MBIVEC; /*message buffer interrupt vector register *//*22 */
6371 volatile CASERCR_t CASERCR; /*channel A status error counter register *//*24 */
6372 volatile CBSERCR_t CBSERCR; /*channel B status error counter register *//*26 */
6373 volatile PSR0_t PSR0; /*protocol status register 0 *//*28 */
6374 volatile PSR1_t PSR1; /*protocol status register 1 *//*2A */
6375 volatile PSR2_t PSR2; /*protocol status register 2 *//*2C */
6376 volatile PSR3_t PSR3; /*protocol status register 3 *//*2E */
6377 volatile MTCTR_t MTCTR; /*macrotick counter register *//*30 */
6378 volatile CYCTR_t CYCTR; /*cycle counter register *//*32 */
6379 volatile SLTCTAR_t SLTCTAR; /*slot counter channel A register *//*34 */
6380 volatile SLTCTBR_t SLTCTBR; /*slot counter channel B register *//*36 */
6381 volatile RTCORVR_t RTCORVR; /*rate correction value register *//*38 */
6382 volatile OFCORVR_t OFCORVR; /*offset correction value register *//*3A */
6383 volatile CIFRR_t CIFRR; /*combined interrupt flag register *//*3C */
6384 uint16_t reserved3[1]; /*3E */
6385 volatile SFCNTR_t SFCNTR; /*sync frame counter register *//*40 */
6386 volatile SFTOR_t SFTOR; /*sync frame table offset register *//*42 */
6387 volatile SFTCCSR_t SFTCCSR; /*sync frame table configuration, control, status register *//*44 */
6388 volatile SFIDRFR_t SFIDRFR; /*sync frame ID rejection filter register *//*46 */
6389 volatile SFIDAFVR_t SFIDAFVR; /*sync frame ID acceptance filter value regiater *//*48 */
6390 volatile SFIDAFMR_t SFIDAFMR; /*sync frame ID acceptance filter mask register *//*4A */
6391 volatile NMVR_t NMVR[6]; /*network management vector registers (12 bytes) *//*4C */
6392 volatile NMVLR_t NMVLR; /*network management vector length register *//*58 */
6393 volatile TICCR_t TICCR; /*timer configuration and control register *//*5A */
6394 volatile TI1CYSR_t TI1CYSR; /*timer 1 cycle set register *//*5C */
6395 volatile T1MTOR_t T1MTOR; /*timer 1 macrotick offset register *//*5E */
6396 volatile TI2CR0_t TI2CR0; /*timer 2 configuration register 0 *//*60 */
6397 volatile TI2CR1_t TI2CR1; /*timer 2 configuration register 1 *//*62 */
6398 volatile SSSR_t SSSR; /*slot status selection register *//*64 */
6399 volatile SSCCR_t SSCCR; /*slot status counter condition register *//*66 */
6400 volatile SSR_t SSR[8]; /*slot status registers 0-7 *//*68 */
6401 volatile SSCR_t SSCR[4]; /*slot status counter registers 0-3 *//*78 */
6402 volatile MTSCFR_t MTSACFR; /*mts a config register *//*80 */
6403 volatile MTSCFR_t MTSBCFR; /*mts b config register *//*82 */
6404 volatile RSBIR_t RSBIR; /*receive shadow buffer index register *//*84 */
6405 volatile RFSR_t RFSR; /*receive fifo selection register *//*86 */
6406 volatile RFSIR_t RFSIR; /*receive fifo start index register *//*88 */
6407 volatile RFDSR_t RFDSR; /*receive fifo depth and size register *//*8A */
6408 volatile RFARIR_t RFARIR; /*receive fifo a read index register *//*8C */
6409 volatile RFBRIR_t RFBRIR; /*receive fifo b read index register *//*8E */
6410 volatile RFMIDAFVR_t RFMIDAFVR; /*receive fifo message ID acceptance filter value register *//*90 */
6411 volatile RFMIAFMR_t RFMIAFMR; /*receive fifo message ID acceptance filter mask register *//*92 */
6412 volatile RFFIDRFVR_t RFFIDRFVR; /*receive fifo frame ID rejection filter value register *//*94 */
6413 volatile RFFIDRFMR_t RFFIDRFMR; /*receive fifo frame ID rejection filter mask register *//*96 */
6414 volatile RFRFCFR_t RFRFCFR; /*receive fifo range filter configuration register *//*98 */
6415 volatile RFRFCTR_t RFRFCTR; /*receive fifo range filter control register *//*9A */
6416 volatile LDTXSLAR_t LDTXSLAR; /*last dynamic transmit slot channel A register *//*9C */
6417 volatile LDTXSLBR_t LDTXSLBR; /*last dynamic transmit slot channel B register *//*9E */
6418 volatile PCR0_t PCR0; /*protocol configuration register 0 *//*A0 */
6419 volatile PCR1_t PCR1; /*protocol configuration register 1 *//*A2 */
6420 volatile PCR2_t PCR2; /*protocol configuration register 2 *//*A4 */
6421 volatile PCR3_t PCR3; /*protocol configuration register 3 *//*A6 */
6422 volatile PCR4_t PCR4; /*protocol configuration register 4 *//*A8 */
6423 volatile PCR5_t PCR5; /*protocol configuration register 5 *//*AA */
6424 volatile PCR6_t PCR6; /*protocol configuration register 6 *//*AC */
6425 volatile PCR7_t PCR7; /*protocol configuration register 7 *//*AE */
6426 volatile PCR8_t PCR8; /*protocol configuration register 8 *//*B0 */
6427 volatile PCR9_t PCR9; /*protocol configuration register 9 *//*B2 */
6428 volatile PCR10_t PCR10; /*protocol configuration register 10 *//*B4 */
6429 volatile PCR11_t PCR11; /*protocol configuration register 11 *//*B6 */
6430 volatile PCR12_t PCR12; /*protocol configuration register 12 *//*B8 */
6431 volatile PCR13_t PCR13; /*protocol configuration register 13 *//*BA */
6432 volatile PCR14_t PCR14; /*protocol configuration register 14 *//*BC */
6433 volatile PCR15_t PCR15; /*protocol configuration register 15 *//*BE */
6434 volatile PCR16_t PCR16; /*protocol configuration register 16 *//*C0 */
6435 volatile PCR17_t PCR17; /*protocol configuration register 17 *//*C2 */
6436 volatile PCR18_t PCR18; /*protocol configuration register 18 *//*C4 */
6437 volatile PCR19_t PCR19; /*protocol configuration register 19 *//*C6 */
6438 volatile PCR20_t PCR20; /*protocol configuration register 20 *//*C8 */
6439 volatile PCR21_t PCR21; /*protocol configuration register 21 *//*CA */
6440 volatile PCR22_t PCR22; /*protocol configuration register 22 *//*CC */
6441 volatile PCR23_t PCR23; /*protocol configuration register 23 *//*CE */
6442 volatile PCR24_t PCR24; /*protocol configuration register 24 *//*D0 */
6443 volatile PCR25_t PCR25; /*protocol configuration register 25 *//*D2 */
6444 volatile PCR26_t PCR26; /*protocol configuration register 26 *//*D4 */
6445 volatile PCR27_t PCR27; /*protocol configuration register 27 *//*D6 */
6446 volatile PCR28_t PCR28; /*protocol configuration register 28 *//*D8 */
6447 volatile PCR29_t PCR29; /*protocol configuration register 29 *//*DA */
6448 volatile PCR30_t PCR30; /*protocol configuration register 30 *//*DC */
6449 uint16_t reserved2[17];
6450 volatile MSG_BUFF_CCS_t MBCCS[128]; /* message buffer configuration, control & status registers 0-31 *//*100 */
6451 } FR_tag_t;
6452
6453 typedef union uF_HEADER /* frame header */
6454 {
6455 struct {
6456 uint16_t:5;
6457 uint16_t HDCRC:11; /* Header CRC */
6458 uint16_t:2;
6459 uint16_t CYCCNT:6; /* Cycle Count */
6460 uint16_t:1;
6461 uint16_t PLDLEN:7; /* Payload Length */
6462 uint16_t:1;
6463 uint16_t PPI:1; /* Payload Preamble Indicator */
6464 uint16_t NUF:1; /* Null Frame Indicator */
6465 uint16_t SYF:1; /* Sync Frame Indicator */
6466 uint16_t SUF:1; /* Startup Frame Indicator */
6467 uint16_t FID:11; /* Frame ID */
6468 } B;
6469 uint16_t WORDS[3];
6470 } F_HEADER_t;
6471 typedef union uS_STSTUS /* slot status */
6472 {
6473 struct {
6474 uint16_t VFB:1; /* Valid Frame on channel B */
6475 uint16_t SYB:1; /* Sync Frame Indicator channel B */
6476 uint16_t NFB:1; /* Null Frame Indicator channel B */
6477 uint16_t SUB:1; /* Startup Frame Indicator channel B */
6478 uint16_t SEB:1; /* Syntax Error on channel B */
6479 uint16_t CEB:1; /* Content Error on channel B */
6480 uint16_t BVB:1; /* Boundary Violation on channel B */
6481 uint16_t CH:1; /* Channel */
6482 uint16_t VFA:1; /* Valid Frame on channel A */
6483 uint16_t SYA:1; /* Sync Frame Indicator channel A */
6484 uint16_t NFA:1; /* Null Frame Indicator channel A */
6485 uint16_t SUA:1; /* Startup Frame Indicator channel A */
6486 uint16_t SEA:1; /* Syntax Error on channel A */
6487 uint16_t CEA:1; /* Content Error on channel A */
6488 uint16_t BVA:1; /* Boundary Violation on channel A */
6489 uint16_t:1;
6490 } RX;
6491 struct {
6492 uint16_t VFB:1; /* Valid Frame on channel B */
6493 uint16_t SYB:1; /* Sync Frame Indicator channel B */
6494 uint16_t NFB:1; /* Null Frame Indicator channel B */
6495 uint16_t SUB:1; /* Startup Frame Indicator channel B */
6496 uint16_t SEB:1; /* Syntax Error on channel B */
6497 uint16_t CEB:1; /* Content Error on channel B */
6498 uint16_t BVB:1; /* Boundary Violation on channel B */
6499 uint16_t TCB:1; /* Tx Conflict on channel B */
6500 uint16_t VFA:1; /* Valid Frame on channel A */
6501 uint16_t SYA:1; /* Sync Frame Indicator channel A */
6502 uint16_t NFA:1; /* Null Frame Indicator channel A */
6503 uint16_t SUA:1; /* Startup Frame Indicator channel A */
6504 uint16_t SEA:1; /* Syntax Error on channel A */
6505 uint16_t CEA:1; /* Content Error on channel A */
6506 uint16_t BVA:1; /* Boundary Violation on channel A */
6507 uint16_t TCA:1; /* Tx Conflict on channel A */
6508 } TX;
6509 uint16_t R;
6510 } S_STATUS_t;
6511
6512 typedef struct uMB_HEADER /* message buffer header */
6513 {
6514 F_HEADER_t FRAME_HEADER;
6515 uint16_t DATA_OFFSET;
6516 S_STATUS_t SLOT_STATUS;
6517 } MB_HEADER_t;
6518
6519/* Define memories */
6520
6521#define SRAM_START 0x40000000
6522#define SRAM_SIZE 0x40000
6523#define SRAM_END 0x4003FFFF
6524
6525#define FLASH_START 0x00000000
6526#define FLASH_SIZE 0x400000
6527#define FLASH_END 0x003FFFFF
6528
6529/* Define instances of modules */
6530#define PBRIDGE_A (*( volatile struct PBRIDGE_A_tag *) 0xC3F00000)
6531#define FMPLL (*( volatile struct FMPLL_tag *) 0xC3F80000)
6532#define EBI (*( volatile struct EBI_tag *) 0xC3F84000)
6533#define FLASH_A (*( volatile struct FLASH_tag *) 0xC3F88000)
6534#define FLASH FLASH_A
6535#define FLASH_B (*( volatile struct FLASH_tag *) 0xC3F8C000)
6536#define SIU (*( volatile struct SIU_tag *) 0xC3F90000)
6537
6538#define EMIOS (*( volatile struct EMIOS_tag *) 0xC3FA0000)
6539#define PMC (*( volatile struct PMC_tag *) 0xC3FBC000)
6540
6541#define ETPU (*( volatile struct ETPU_tag *) 0xC3FC0000)
6542#define ETPU_DATA_RAM (*( uint32_t *) 0xC3FC8000)
6543#define ETPU_DATA_RAM_END 0xC3FC8FFC
6544#define ETPU_DATA_RAM_EXT (*( uint32_t *) 0xC3FCC000)
6545#define CODE_RAM (*( uint32_t *) 0xC3FD0000)
6546#define ETPU_CODE_RAM (*( uint32_t *) 0xC3FD0000)
6547
6548#define PIT (*( volatile struct PIT_tag *) 0xC3FF0000)
6549
6550#define PBRIDGE_B (*( volatile struct PBRIDGE_B_tag *) 0xFFF00000)
6551#define XBAR (*( volatile struct XBAR_tag *) 0xFFF04000)
6552#define MPU (*( volatile struct MPU_tag *) 0xFFF10000)
6553#define SWT (*( volatile struct SWT_tag *) 0xFFF38000)
6554#define STM (*( volatile struct STM_tag *) 0xFFF3C000)
6555#define ECSM (*( volatile struct ECSM_tag *) 0xFFF40000)
6556#define EDMA_A (*( volatile struct EDMA_tag *) 0xFFF44000)
6557#define EDMA EDMA_A
6558#define INTC (*( volatile struct INTC_tag *) 0xFFF48000)
6559#define EDMA_B (*( volatile struct EDMA_tag *) 0xFFF54000)
6560
6561#define EQADC_A (*( volatile struct EQADC_tag *) 0xFFF80000)
6562#define EQADC EQADC_A
6563#define EQADC_B (*( volatile struct EQADC_tag *) 0xFFF84000)
6564
6565#define DECFIL_A (*( volatile struct DECFIL_tag *) 0xFFF88000)
6566#define DECFIL_B (*( volatile struct DECFIL_tag *) 0xFFF88800)
6567#define DECFIL_C (*( volatile struct DECFIL_tag *) 0xFFF89000)
6568#define DECFIL_D (*( volatile struct DECFIL_tag *) 0xFFF89800)
6569#define DECFIL_E (*( volatile struct DECFIL_tag *) 0xFFF8A000)
6570#define DECFIL_F (*( volatile struct DECFIL_tag *) 0xFFF8A800)
6571#define DECFIL_G (*( volatile struct DECFIL_tag *) 0xFFF8B000)
6572#define DECFIL_H (*( volatile struct DECFIL_tag *) 0xFFF8B800)
6573
6574#define DSPI_A (*( volatile struct DSPI_tag *) 0xFFF90000)
6575#define DSPI_B (*( volatile struct DSPI_tag *) 0xFFF94000)
6576#define DSPI_C (*( volatile struct DSPI_tag *) 0xFFF98000)
6577#define DSPI_D (*( volatile struct DSPI_tag *) 0xFFF9C000)
6578
6579#define ESCI_A (*( volatile struct ESCI_tag *) 0xFFFB0000)
6580#define ESCI_B (*( volatile struct ESCI_tag *) 0xFFFB4000)
6581#define ESCI_C (*( volatile struct ESCI_tag *) 0xFFFB8000)
6582#define ESCI_D (*( volatile struct ESCI_tag *) 0xFFFBC000)
6583
6584#define CAN_A (*( volatile struct FLEXCAN2_tag *) 0xFFFC0000)
6585#define CAN_B (*( volatile struct FLEXCAN2_tag *) 0xFFFC4000)
6586#define CAN_C (*( volatile struct FLEXCAN2_tag *) 0xFFFC8000)
6587#define CAN_D (*( volatile struct FLEXCAN2_tag *) 0xFFFCC000)
6588
6589#define FR (*( volatile struct FR_tag *) 0xFFFE0000)
6590#define TSENS (*( volatile struct TSENS_tag *) 0xFFFEC000)
6591
6592#ifdef __MWERKS__
6593#pragma pop
6594#endif
6595
6596#ifdef __cplusplus
6597}
6598#endif
6599#endif /* ASM */
6600#endif /* ifdef _MPC5674_H */
6601/*********************************************************************
6602 *
6603 * Copyright:
6604 * Freescale Semiconductor, INC. All Rights Reserved.
6605 * You are hereby granted a copyright license to use, modify, and
6606 * distribute the SOFTWARE so long as this entire notice is
6607 * retained without alteration in any modified and/or redistributed
6608 * versions, and that such modified versions are clearly identified
6609 * as such. No licenses are granted by implication, estoppel or
6610 * otherwise under any patents or trademarks of Freescale
6611 * Semiconductor, Inc. This software is provided on an "AS IS"
6612 * basis and without warranty.
6613 *
6614 * To the maximum extent permitted by applicable law, Freescale
6615 * Semiconductor DISCLAIMS ALL WARRANTIES WHETHER EXPRESS OR IMPLIED,
6616 * INCLUDING IMPLIED WARRANTIES OF MERCHANTABILITY OR FITNESS FOR A
6617 * PARTICULAR PURPOSE AND ANY WARRANTY AGAINST INFRINGEMENT WITH
6618 * REGARD TO THE SOFTWARE (INCLUDING ANY MODIFIED VERSIONS THEREOF)
6619 * AND ANY ACCOMPANYING WRITTEN MATERIALS.
6620 *
6621 * To the maximum extent permitted by applicable law, IN NO EVENT
6622 * SHALL Freescale Semiconductor BE LIABLE FOR ANY DAMAGES WHATSOEVER
6623 * (INCLUDING WITHOUT LIMITATION, DAMAGES FOR LOSS OF BUSINESS PROFITS,
6624 * BUSINESS INTERRUPTION, LOSS OF BUSINESS INFORMATION, OR OTHER
6625 * PECUNIARY LOSS) ARISING OF THE USE OR INABILITY TO USE THE SOFTWARE.
6626 *
6627 * Freescale Semiconductor assumes no responsibility for the
6628 * maintenance and support of this software
6629 *
6630 ********************************************************************/
Definition: fsl-mpc567x.h:4507
Definition: fsl-mpc551x.h:244
Definition: fsl-mpc551x.h:479
Definition: fsl-mpc551x.h:447
Definition: fsl-mpc551x.h:483
Definition: fsl-mpc555x.h:2179
Definition: fsl-mpc551x.h:531
Definition: fsl-mpc551x.h:716
Definition: fsl-mpc551x.h:899
Definition: fsl-mpc555x.h:1136
Definition: fsl-mpc551x.h:1027
Definition: fsl-mpc555x.h:2999
Definition: fsl-mpc551x.h:1484
Definition: fsl-mpc551x.h:3622
Definition: fsl-mpc551x.h:1603
Definition: fsl-mpc551x.h:1843
Definition: fsl-mpc555x.h:124
Definition: fsl-mpc555x.h:236
Definition: fsl-mpc551x.h:1991
Definition: fsl-mpc567x.h:2343
Definition: fsl-mpc551x.h:2221
Definition: fsl-mpc5668.h:6467
Definition: fsl-mpc5668.h:6576
Definition: fsl-mpc555x.h:1982
Definition: fsl-mpc551x.h:3783
Definition: fsl-mpc551x.h:3481
Definition: fsl-mpc564xL.h:16586
Definition: fsl-mpc564xL.h:16541
Definition: fsl-mpc564xL.h:16698
Definition: fsl-mpc564xL.h:16678
Definition: fsl-mpc564xL.h:16627
Definition: fsl-mpc564xL.h:16605
Definition: fsl-mpc555x.h:2451
Definition: fsl-mpc567x.h:4302
Definition: fsl-mpc567x.h:4294
Definition: fsl-mpc567x.h:4271
Definition: fsl-mpc567x.h:4286
Definition: fsl-mpc567x.h:4311
Definition: fsl-mpc567x.h:4453
Definition: fsl-mpc564xL.h:966
Definition: fsl-mpc551x.h:3540
Definition: fsl-mpc551x.h:3543
Definition: fsl-mpc551x.h:2939
Definition: fsl-mpc551x.h:3037
Definition: fsl-mpc551x.h:3546
Definition: fsl-mpc551x.h:3724
Definition: fsl-mpc551x.h:2842
Definition: fsl-mpc551x.h:3615
Definition: fsl-mpc551x.h:3618
Definition: fsl-mpc551x.h:2807
Definition: fsl-mpc551x.h:2960
Definition: fsl-mpc551x.h:2817
Definition: fsl-mpc551x.h:2781
Definition: fsl-mpc551x.h:3549
Definition: fsl-mpc551x.h:3171
Definition: fsl-mpc551x.h:2773
Definition: fsl-mpc551x.h:3576
Definition: fsl-mpc551x.h:3573
Definition: fsl-mpc551x.h:3561
Definition: fsl-mpc551x.h:3228
Definition: fsl-mpc551x.h:3313
Definition: fsl-mpc551x.h:3322
Definition: fsl-mpc551x.h:3331
Definition: fsl-mpc551x.h:3339
Definition: fsl-mpc551x.h:3347
Definition: fsl-mpc551x.h:3355
Definition: fsl-mpc551x.h:3362
Definition: fsl-mpc551x.h:3370
Definition: fsl-mpc551x.h:3377
Definition: fsl-mpc551x.h:3385
Definition: fsl-mpc551x.h:3236
Definition: fsl-mpc551x.h:3393
Definition: fsl-mpc551x.h:3401
Definition: fsl-mpc551x.h:3409
Definition: fsl-mpc551x.h:3418
Definition: fsl-mpc551x.h:3425
Definition: fsl-mpc551x.h:3434
Definition: fsl-mpc551x.h:3441
Definition: fsl-mpc551x.h:3450
Definition: fsl-mpc551x.h:3457
Definition: fsl-mpc551x.h:3465
Definition: fsl-mpc551x.h:3244
Definition: fsl-mpc551x.h:3473
Definition: fsl-mpc551x.h:3252
Definition: fsl-mpc551x.h:3261
Definition: fsl-mpc551x.h:3269
Definition: fsl-mpc551x.h:3278
Definition: fsl-mpc551x.h:3287
Definition: fsl-mpc551x.h:3295
Definition: fsl-mpc551x.h:3304
Definition: fsl-mpc551x.h:3537
Definition: fsl-mpc551x.h:2901
Definition: fsl-mpc551x.h:2922
Definition: fsl-mpc551x.h:2863
Definition: fsl-mpc551x.h:2884
Definition: fsl-mpc551x.h:2828
Definition: fsl-mpc551x.h:2971
Definition: fsl-mpc551x.h:2987
Definition: fsl-mpc551x.h:3000
Definition: fsl-mpc551x.h:3018
Definition: fsl-mpc551x.h:3597
Definition: fsl-mpc551x.h:3600
Definition: fsl-mpc551x.h:3193
Definition: fsl-mpc551x.h:3612
Definition: fsl-mpc551x.h:3609
Definition: fsl-mpc551x.h:3606
Definition: fsl-mpc551x.h:3603
Definition: fsl-mpc551x.h:3202
Definition: fsl-mpc551x.h:3213
Definition: fsl-mpc551x.h:3594
Definition: fsl-mpc551x.h:3591
Definition: fsl-mpc551x.h:3182
Definition: fsl-mpc551x.h:3558
Definition: fsl-mpc551x.h:3059
Definition: fsl-mpc551x.h:3570
Definition: fsl-mpc551x.h:3567
Definition: fsl-mpc551x.h:3085
Definition: fsl-mpc551x.h:3069
Definition: fsl-mpc551x.h:3564
Definition: fsl-mpc551x.h:3552
Definition: fsl-mpc551x.h:3555
Definition: fsl-mpc551x.h:3134
Definition: fsl-mpc551x.h:3588
Definition: fsl-mpc551x.h:3150
Definition: fsl-mpc551x.h:3123
Definition: fsl-mpc556x.h:3496
Definition: fsl-mpc551x.h:2796
Definition: fsl-mpc551x.h:3528
Definition: fsl-mpc551x.h:3531
Definition: fsl-mpc551x.h:3742
Definition: fsl-mpc551x.h:3579
Definition: fsl-mpc551x.h:3112
Definition: fsl-mpc551x.h:3582
Definition: fsl-mpc551x.h:3585
Definition: fsl-mpc551x.h:3093
