RTEMS 5.2
SWT_tag Struct Reference
union {
   uint32_t   R
   struct {
      uint32_t   MAP0:1
      uint32_t   MAP1:1
      uint32_t   MAP2:1
      uint32_t   MAP3:1
      uint32_t   MAP4:1
      uint32_t   MAP5:1
      uint32_t   MAP6:1
      uint32_t   MAP7:1
      uint32_t   __pad0__:14
      uint32_t   KEY:1
      uint32_t   RIA:1
      uint32_t   WND:1
      uint32_t   ITR:1
      uint32_t   HLK:1
      uint32_t   SLK:1
      uint32_t   __pad1__:2
      uint32_t   FRZ:1
      uint32_t   WEN:1
   }   B
CR
union {
   uint32_t   R
   struct {
      uint32_t   __pad0__:31
      uint32_t   TIF:1
   }   B
IR
union {
   uint32_t   R
   struct {
      uint32_t   WTO:32
   }   B
TO
union {
   uint32_t   R
   struct {
      uint32_t   WST:32
   }   B
WN
union {
   uint32_t   R
   struct {
      uint32_t   __pad0__:16
      uint32_t   WSC:16
   }   B
SR
union {
   uint32_t   R
   struct {
      uint32_t   CNT:32
   }   B
CO
union {
   uint32_t   R
   struct {
      uint32_t   SK:16
   }   B
SK
union {
   uint32_t   R
   struct {
      uint32_t   MAP0:1
      uint32_t   MAP1:1
      uint32_t   __pad0__:1
      uint32_t   __pad1__:1
      uint32_t   MAP4:1
      uint32_t   MAP5:1
      uint32_t   MAP6:1
      uint32_t   MAP7:1
      uint32_t   __pad2__:14
      uint32_t   KEY:1
      uint32_t   RIA:1
      uint32_t   WND:1
      uint32_t   ITR:1
      uint32_t   HLK:1
      uint32_t   SLK:1
      uint32_t   CSL:1
      uint32_t   STP:1
      uint32_t   FRZ:1
      uint32_t   WEN:1
   }   B
MCR
union {
   uint32_t   R
   struct {
      uint32_t   TIF:1
   }   B
IR
union {
   uint32_t   R
   struct {
      uint32_t   WTO:32
   }   B
TO
union {
   uint32_t   R
   struct {
      uint32_t   WST:32
   }   B
WN
union {
   uint32_t   R
   struct {
      uint32_t   WSC:16
   }   B
SR
union {
   uint32_t   R
   struct {
      uint32_t   CNT:32
   }   B
CO
union {
   uint32_t   R
   struct {
      uint32_t   SK:16
   }   B
SK
uint32_t SWT_reserved001C [4089]
The documentation for this struct was generated from the following files:
