RTEMS 5.2
#include <dpmemdata.h>
Data Fields | |
| Objects_Control | Object |
| void * | internal_base |
| void * | external_base |
| uint32_t | length |
The following structure defines the port control block. Each port has a control block associated with it. This control block contains all information required to support the port related operations.
| void* Dual_ported_memory_Control::external_base |
This field is the base external address of the port.
| void* Dual_ported_memory_Control::internal_base |
This field is the base internal address of the port.
| uint32_t Dual_ported_memory_Control::length |
This field is the length of dual-ported area of the port.
| Objects_Control Dual_ported_memory_Control::Object |
This field is the object management portion of a Port instance.
