RTEMS 5.2
cpu.h
1
10/*
11 * COPYRIGHT (c) 1989-2008.
12 * On-Line Applications Research Corporation (OAR).
13 *
14 * The license and distribution terms for this file may be
15 * found in the file LICENSE in this distribution or at
16 * http://www.rtems.org/license/LICENSE.
17 */
18
19#ifndef _RTEMS_SCORE_CPU_H
20#define _RTEMS_SCORE_CPU_H
21
22#ifdef __cplusplus
23extern "C" {
24#endif
25
27#include <rtems/score/lm32.h>
28
29/* conditional compilation parameters */
30
42#define CPU_SIMPLE_VECTORED_INTERRUPTS TRUE
43
53#define CPU_ISR_PASSES_FRAME_POINTER TRUE
54
55#define CPU_HARDWARE_FP FALSE
56
57#define CPU_SOFTWARE_FP FALSE
58
83#define CPU_ALL_TASKS_ARE_FP FALSE
84
100#define CPU_IDLE_TASK_IS_FP FALSE
101
131#define CPU_USE_DEFERRED_FP_SWITCH TRUE
132
133#define CPU_ENABLE_ROBUST_THREAD_DISPATCH FALSE
134
146#define CPU_STACK_GROWS_UP FALSE
147
148/* L2 cache lines are 32 bytes in Milkymist SoC */
149#define CPU_CACHE_LINE_BYTES 32
150
151#define CPU_STRUCTURE_ALIGNMENT RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES )
152
163#define CPU_MODES_INTERRUPT_MASK 0x00000001
164
165#define CPU_MAXIMUM_PROCESSORS 32
166
167/*
168 * Processor defined structures required for cpukit/score.
169 *
170 * Port Specific Information:
171 *
172 * XXX document implementation including references if appropriate
173 */
174
175/* may need to put some structures here. */
176
227typedef struct {
228 uint32_t r11;
229 uint32_t r12;
230 uint32_t r13;
231 uint32_t r14;
232 uint32_t r15;
233 uint32_t r16;
234 uint32_t r17;
235 uint32_t r18;
236 uint32_t r19;
237 uint32_t r20;
238 uint32_t r21;
239 uint32_t r22;
240 uint32_t r23;
241 uint32_t r24;
242 uint32_t r25;
243 uint32_t gp;
244 uint32_t fp;
245 uint32_t sp;
246 uint32_t ra;
247 uint32_t ie;
248 uint32_t epc;
250
259#define _CPU_Context_Get_SP( _context ) \
260 (_context)->sp
261
267typedef struct {
268 uint32_t r1;
269 uint32_t r2;
270 uint32_t r3;
271 uint32_t r4;
272 uint32_t r5;
273 uint32_t r6;
274 uint32_t r7;
275 uint32_t r8;
276 uint32_t r9;
277 uint32_t r10;
278 uint32_t ra;
279 uint32_t ba;
280 uint32_t ea;
282
293#if 0
295#endif
296
307/*
308 * Nothing prevents the porter from declaring more CPU specific variables.
309 *
310 * Port Specific Information:
311 *
312 * XXX document implementation including references if appropriate
313 */
314
315/* XXX: if needed, put more variables here */
316
327#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0
328
338#define CPU_INTERRUPT_NUMBER_OF_VECTORS 32
339
344#define CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER (CPU_INTERRUPT_NUMBER_OF_VECTORS - 1)
345
351#define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
352
353
363#define CPU_STACK_MINIMUM_SIZE (1024*4)
364
365#define CPU_SIZEOF_POINTER 4
366
377#define CPU_ALIGNMENT 4
378
402#define CPU_HEAP_ALIGNMENT CPU_ALIGNMENT
403
414#define CPU_STACK_ALIGNMENT CPU_ALIGNMENT
415
416#define CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES
417
418/*
419 * ISR handler macros
420 */
421
434#define _CPU_Initialize_vectors()
435
446#define _CPU_ISR_Disable( _isr_cookie ) \
447 lm32_disable_interrupts( _isr_cookie );
448
460#define _CPU_ISR_Enable( _isr_cookie ) \
461 lm32_enable_interrupts( _isr_cookie );
462
475#define _CPU_ISR_Flash( _isr_cookie ) \
476 lm32_flash_interrupts( _isr_cookie );
477
478RTEMS_INLINE_ROUTINE bool _CPU_ISR_Is_enabled( uint32_t level )
479{
480 return ( level & 0x0001 ) != 0;
481}
482
498#define _CPU_ISR_Set_level( new_level ) \
499 { \
500 _CPU_ISR_Enable( ( new_level==0 ) ? 1 : 0 ); \
501 }
502
513uint32_t _CPU_ISR_Get_level( void );
514
515/* end of ISR handler macros */
516
519/* Context handler macros */
520
552extern char _gp[];
553
554#define _CPU_Context_Initialize( _the_context, _stack_base, _size, \
555 _isr, _entry_point, _is_fp, _tls_area ) \
556 do { \
557 uint32_t _stack = (uint32_t)(_stack_base) + (_size) - 4; \
558 \
559 (void) _is_fp; /* avoid warning for being unused */ \
560 (void) _isr; /* avoid warning for being unused */ \
561 (_the_context)->gp = (uint32_t)_gp; \
562 (_the_context)->fp = (uint32_t)_stack; \
563 (_the_context)->sp = (uint32_t)_stack; \
564 (_the_context)->ra = (uint32_t)(_entry_point); \
565 } while ( 0 )
566
582#define _CPU_Context_Restart_self( _the_context ) \
583 _CPU_Context_restore( (_the_context) );
584
603#define _CPU_Context_Initialize_fp( _destination )
604#if 0
605 { \
606 *(*(_destination)) = _CPU_Null_fp_context; \
607 }
608#endif
609
610/* end of Context handler macros */
611
612/* Fatal Error manager macros */
613
623#define _CPU_Fatal_halt( _source, _error ) \
624 { \
625 }
626
627/* end of Fatal Error manager macros */
628
629#define CPU_USE_GENERIC_BITFIELD_CODE TRUE
630
631/* functions */
632
640void _CPU_Initialize(void);
641
647typedef void ( *CPU_ISR_raw_handler )( void );
648
650 uint32_t vector,
651 CPU_ISR_raw_handler new_handler,
652 CPU_ISR_raw_handler *old_handler
653)
654{
655 /* TODO */
656}
657
658typedef void ( *CPU_ISR_handler )( uint32_t );
659
661 uint32_t vector,
662 CPU_ISR_handler new_handler,
663 CPU_ISR_handler *old_handler
664);
665
668void *_CPU_Thread_Idle_body( uintptr_t ignored );
669
682 Context_Control *run,
683 Context_Control *heir
684);
685
704 Context_Control *new_context
706
709/* FIXME */
711
713
750static inline uint32_t CPU_swap_u32(
751 uint32_t value
752)
753{
754 uint32_t byte1, byte2, byte3, byte4, swapped;
755
756 byte4 = (value >> 24) & 0xff;
757 byte3 = (value >> 16) & 0xff;
758 byte2 = (value >> 8) & 0xff;
759 byte1 = value & 0xff;
760
761 swapped = (byte1 << 24) | (byte2 << 16) | (byte3 << 8) | byte4;
762 return swapped;
763}
764
771static inline uint16_t CPU_swap_u16(uint16_t v)
772{
773 return v << 8 | v >> 8;
774}
775
778typedef uint32_t CPU_Counter_ticks;
779
780uint32_t _CPU_Counter_frequency( void );
781
782CPU_Counter_ticks _CPU_Counter_read( void );
783
784static inline CPU_Counter_ticks _CPU_Counter_difference(
785 CPU_Counter_ticks second,
786 CPU_Counter_ticks first
787)
788{
789 return second - first;
790}
791
793typedef uintptr_t CPU_Uint32ptr;
794
795#ifdef __cplusplus
796}
797#endif
798
799#endif
Basic Definitions.
#define RTEMS_NO_RETURN
Definition: basedefs.h:102
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
bool _CPU_ISR_Is_enabled(uint32_t level)
Returns true if interrupts are enabled in the specified ISR level, otherwise returns false.
Definition: cpu.h:375
void * _CPU_Thread_Idle_body(uintptr_t ignored)
Definition: idle-mcf5272.c:20
CPU initialization.
Definition: cpu.c:45
Definition: cpu.h:662
RTEMS_INLINE_ROUTINE void _CPU_ISR_install_vector(uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler)
SPARC specific RTEMS ISR installer.
Definition: cpu.h:493
uint32_t _CPU_Counter_frequency(void)
Returns the current CPU counter frequency in Hz.
Definition: system-clocks.c:112
void _CPU_Context_switch(Context_Control *run, Context_Control *heir)
CPU switch context.
Definition: cpu_asm.c:91
CPU_Counter_ticks _CPU_Counter_read(void)
Returns the current CPU counter value.
Definition: system-clocks.c:117
void _CPU_Context_restore(Context_Control *new_context) RTEMS_NO_RETURN
Definition: cpu_asm.c:111
#define CPU_swap_u16(value)
Definition: cpu.h:642
uint32_t _CPU_ISR_Get_level(void)
Definition: cpu.c:88
void _CPU_Exception_frame_print(const CPU_Exception_frame *frame)
Prints the exception frame via printk().
Definition: vectorexceptions.c:45
RTEMS_INLINE_ROUTINE void _CPU_ISR_install_raw_handler(uint32_t vector, CPU_ISR_raw_handler new_handler, CPU_ISR_raw_handler *old_handler)
SPARC specific raw ISR installer.
Definition: cpu.h:649
#define ra
return address *‍/
Definition: regs.h:66
#define sp
stack-pointer *‍/
Definition: regs.h:64
#define fp
frame-pointer *‍/
Definition: regs.h:65
#define gp
global data pointer *‍/
Definition: regs.h:63
LM32 Set up Basic CPU Dependency Settings Based on Compiler Settings.
Unsigned integer type for CPU counter values.
Definition: cpu.h:1210
Context_Control_fp _CPU_Null_fp_context
The set of registers that specifies the complete processor state.
Definition: cpu.h:629
Interrupt stack frame (ISF).
Definition: cpu.h:191
SPARC basic context.
Definition: cpu.h:194
Thread register context.
unsigned v
Definition: tte.h:0
unsigned ie
Definition: tte.h:3
