RTEMS 5.2
Files | Macros | Typedefs | Functions | Variables
Timecounter Handler
Timecounter Handler. More...
file  timecounter.h
 Timecounter API.
file  timecounterimpl.h
 Timecounter Implementation.
#define _Timecounter_Acquire(lock_context)    _ISR_lock_ISR_disable_and_acquire( &_Timecounter_Lock, lock_context )
 Lock to protect the timecounter mechanic. More...
#define _Timecounter_Release(lock_context)    _ISR_lock_Release_and_ISR_enable(&_Timecounter_Lock, lock_context)
 Releases the timecounter lock. More...
typedef void(* Timecounter_NTP_update_second) (int64_t *adjustment, time_t *newsec)
 Handler doing the NTP update second processing shall have this type. More...
void _Timecounter_Bintime (struct bintime *bt)
 Returns the wall clock time in the bintime format. More...
void _Timecounter_Nanotime (struct timespec *ts)
 Returns the wall clock time in the timespec format. More...
void _Timecounter_Microtime (struct timeval *tv)
 Returns the wall clock time in the timeval format. More...
void _Timecounter_Binuptime (struct bintime *bt)
 Returns the uptime in the bintime format. More...
int64_t _Timecounter_Sbinuptime (void)
 Returns the uptime in the sbintime_t format. More...
void _Timecounter_Nanouptime (struct timespec *ts)
 Returns the uptime in the timespec format. More...
void _Timecounter_Microuptime (struct timeval *tv)
 Returns the uptime in the timeval format. More...
void _Timecounter_Getbintime (struct bintime *bt)
void _Timecounter_Getnanotime (struct timespec *ts)
void _Timecounter_Getmicrotime (struct timeval *tv)
void _Timecounter_Getbinuptime (struct bintime *bt)
void _Timecounter_Getnanouptime (struct timespec *ts)
void _Timecounter_Getmicrouptime (struct timeval *tv)
void _Timecounter_Getboottime (struct timeval *tv)
 Returns the boot time in the timeval format. More...
void _Timecounter_Getboottimebin (struct bintime *bt)
 Returns the boot time in the bintime format. More...
void _Timecounter_Install (struct timecounter *tc)
 Installs the timecounter. More...
void _Timecounter_Tick (void)
 Performs a timecounter tick.
void _Timecounter_Tick_simple (uint32_t delta, uint32_t offset, ISR_lock_Context *lock_context)
 Performs a simple timecounter tick. More...
void _Timecounter_Set_NTP_update_second (Timecounter_NTP_update_second handler)
 Sets the NTP update second handler. More...
void _Timecounter_Set_clock (const struct bintime *bt, ISR_lock_Context *lock_context)
 Sets the timecounter clock to the given value. More...
volatile time_t _Timecounter_Time_second
 The wall clock time in seconds.
volatile int32_t _Timecounter_Time_uptime
 The uptime in seconds. More...
struct timecounter_Timecounter
 The current timecounter.
◆ _Timecounter_Acquire
#define _Timecounter_Acquire (   lock_context)     _ISR_lock_ISR_disable_and_acquire( &_Timecounter_Lock, lock_context )
Acquires the timecounter lock.
Parameters
lock_contextThe lock context.
See _Timecounter_Tick_simple().
◆ _Timecounter_Release
#define _Timecounter_Release (   lock_context)     _ISR_lock_Release_and_ISR_enable(&_Timecounter_Lock, lock_context)
Parameters
Typedef Documentation
◆ Timecounter_NTP_update_second
Parameters
[in,out]adjustmentis the NTP time adjustment.
[in,out]newsecis the number of seconds since Unix epoch.
◆ _Timecounter_Bintime()
void _Timecounter_Bintime ( struct bintime *  bt)
Parameters
[out]btReturns the wall clock time.
◆ _Timecounter_Binuptime()
void _Timecounter_Binuptime ( struct bintime *  bt)
Parameters
[out]btReturns the uptime.
◆ _Timecounter_Getbintime()
void _Timecounter_Getbintime ( struct bintime *  bt)
This function obtains the time with a lower overhead and lower accuracy compared to the _Timecounter_Bintime() variant.
Parameters
[out]tsReturns the wall clock time.
◆ _Timecounter_Getbinuptime()
void _Timecounter_Getbinuptime ( struct bintime *  bt)
This function obtains the time with a lower overhead and lower accuracy compared to the _Timecounter_Binuptime() variant.
Parameters
[out]tsReturns the uptime.
◆ _Timecounter_Getboottime()
void _Timecounter_Getboottime ( struct timeval *  tv)
Parameters
[out]tvReturns the boot time.
◆ _Timecounter_Getboottimebin()
void _Timecounter_Getboottimebin ( struct bintime *  bt)
Parameters
◆ _Timecounter_Getmicrotime()
void _Timecounter_Getmicrotime ( struct timeval *  tv)
This function obtains the time with a lower overhead and lower accuracy compared to the _Timecounter_Microtime() variant.
Parameters
[out]tvReturns the wall clock time.
See also
_Timecounter_Getbintime().
◆ _Timecounter_Getmicrouptime()
void _Timecounter_Getmicrouptime ( struct timeval *  tv)
This function obtains the time with a lower overhead and lower accuracy compared to the _Timecounter_Microuptime() variant.
Parameters
[out]tvReturns the uptime.
◆ _Timecounter_Getnanotime()
void _Timecounter_Getnanotime ( struct timespec *  ts)
This function obtains the time with a lower overhead and lower accuracy compared to the _Timecounter_Nanotime() variant.
Parameters
See also
◆ _Timecounter_Getnanouptime()
void _Timecounter_Getnanouptime ( struct timespec *  ts)
This function obtains the time with a lower overhead and lower accuracy compared to the _Timecounter_Nanouptime() variant.
Parameters
◆ _Timecounter_Install()
void _Timecounter_Install ( struct timecounter tc)
The timecounter structure must contain valid values in the fields tc_get_timecount, tc_counter_mask, tc_frequency and tc_quality. All other fields must be zero initialized.
Parameters
tcThe timecounter.
◆ _Timecounter_Microtime()
void _Timecounter_Microtime ( struct timeval *  tv)
Parameters
◆ _Timecounter_Microuptime()
void _Timecounter_Microuptime ( struct timeval *  tv)
Parameters
◆ _Timecounter_Nanotime()
void _Timecounter_Nanotime ( struct timespec *  ts)
Parameters
◆ _Timecounter_Nanouptime()
void _Timecounter_Nanouptime ( struct timespec *  ts)
Parameters
◆ _Timecounter_Sbinuptime()
int64_t _Timecounter_Sbinuptime ( void  )
Returns
Returns the uptime.
◆ _Timecounter_Set_clock()
void _Timecounter_Set_clock ( const struct bintime *  bt,
ISR_lock_Context lock_context
Parameters
btThe value to set the clock to.
lock_contextThe interrupt lock context.
◆ _Timecounter_Set_NTP_update_second()
void _Timecounter_Set_NTP_update_second ( Timecounter_NTP_update_second  handler)
Parameters
handleris the new NTP update second handler used to carry out the NTP update second processing.
◆ _Timecounter_Tick_simple()
void _Timecounter_Tick_simple ( uint32_t  delta,
uint32_t  offset,
This is a special purpose tick function for simple timecounter to support legacy clock drivers.
Parameters
deltaThe time in timecounter ticks elapsed since the last call to _Timecounter_Tick_simple().
offsetThe current value of the timecounter.
]lock_context The lock context of the corresponding _Timecounter_Acquire().
Variable Documentation
◆ _Timecounter_Time_uptime
extern
For compatibility with the FreeBSD network stack the initial value is one second.
