RTEMS 5.2
Timecounter API. More...
#include <sys/time.h>
#include <sys/timetc.h>
#include <machine/_timecounter.h>
#include <rtems/score/isrlock.h>
#define | _Timecounter_Acquire(lock_context) _ISR_lock_ISR_disable_and_acquire( &_Timecounter_Lock, lock_context ) |
Lock to protect the timecounter mechanic. More... | |
#define | _Timecounter_Release(lock_context) _ISR_lock_Release_and_ISR_enable(&_Timecounter_Lock, lock_context) |
Releases the timecounter lock. More... | |
Typedefs | |
typedef void(* | Timecounter_NTP_update_second) (int64_t *adjustment, time_t *newsec) |
Handler doing the NTP update second processing shall have this type. More... | |
void | _Timecounter_Bintime (struct bintime *bt) |
Returns the wall clock time in the bintime format. More... | |
void | _Timecounter_Nanotime (struct timespec *ts) |
Returns the wall clock time in the timespec format. More... | |
void | _Timecounter_Microtime (struct timeval *tv) |
Returns the wall clock time in the timeval format. More... | |
void | _Timecounter_Binuptime (struct bintime *bt) |
Returns the uptime in the bintime format. More... | |
int64_t | _Timecounter_Sbinuptime (void) |
Returns the uptime in the sbintime_t format. More... | |
void | _Timecounter_Nanouptime (struct timespec *ts) |
Returns the uptime in the timespec format. More... | |
void | _Timecounter_Microuptime (struct timeval *tv) |
Returns the uptime in the timeval format. More... | |
void | _Timecounter_Getbintime (struct bintime *bt) |
void | _Timecounter_Getnanotime (struct timespec *ts) |
void | _Timecounter_Getmicrotime (struct timeval *tv) |
void | _Timecounter_Getbinuptime (struct bintime *bt) |
void | _Timecounter_Getnanouptime (struct timespec *ts) |
void | _Timecounter_Getmicrouptime (struct timeval *tv) |
void | _Timecounter_Getboottime (struct timeval *tv) |
Returns the boot time in the timeval format. More... | |
void | _Timecounter_Getboottimebin (struct bintime *bt) |
Returns the boot time in the bintime format. More... | |
void | _Timecounter_Install (struct timecounter *tc) |
Installs the timecounter. More... | |
void | _Timecounter_Tick (void) |
Performs a timecounter tick. | |
void | _Timecounter_Tick_simple (uint32_t delta, uint32_t offset, ISR_lock_Context *lock_context) |
Performs a simple timecounter tick. More... | |
void | _Timecounter_Set_NTP_update_second (Timecounter_NTP_update_second handler) |
Sets the NTP update second handler. More... | |
volatile time_t | _Timecounter_Time_second |
The wall clock time in seconds. | |
volatile int32_t | _Timecounter_Time_uptime |
The uptime in seconds. More... | |
struct timecounter * | _Timecounter |
The current timecounter. | |
Timecounter API.
