RTEMS 5.2
Deterministic Priority Scheduler. More...
Files | |
| file | schedulerpriority.h |
| Thread Manipulation with the Priority-Based Scheduler. | |
| file | schedulerpriorityimpl.h |
| Inlined Routines Associated with the Manipulation of the Priority-Based Scheduling Structures. | |
| struct | Scheduler_priority_Context |
| struct | Scheduler_priority_Ready_queue |
| Data for ready queue operations. More... | |
| struct | Scheduler_priority_Node |
| Scheduler node specialization for Deterministic Priority schedulers. More... | |
| #define | SCHEDULER_PRIORITY_ENTRY_POINTS |
| #define SCHEDULER_PRIORITY_ENTRY_POINTS |
Entry points for the Deterministic Priority Based Scheduler.
| void _Scheduler_priority_Block | ( | const Scheduler_Control * | scheduler, |
| Thread_Control * | the_thread, | ||
| Scheduler_Node * | node | ||
Blocks the thread.
| scheduler | The scheduler instance. | |
| [in,out] | the_thread | The thread to block. |
| [in,out] | node | The thread's scheduler node. |
| RTEMS_INLINE_ROUTINE void _Scheduler_priority_Extract_body | ( | const Scheduler_Control * | scheduler, |
Extracts a node from the context of the scheduler.
| the_thread | The thread of which the node will be extracted. | |
| [in,out] | The | node which preserves the ready queue. |
| RTEMS_INLINE_ROUTINE Scheduler_priority_Context * _Scheduler_priority_Get_context | ( | const Scheduler_Control * | scheduler | ) |
Gets the context of the scheduler.
| scheduler | The scheduler to get the context of. |
| void _Scheduler_priority_Initialize | ( | const Scheduler_Control * | scheduler | ) |
Initializes the priority scheduler.
This routine initializes the priority scheduler.
| scheduler | The scheduler to initialize. |
| RTEMS_INLINE_ROUTINE Scheduler_priority_Node * _Scheduler_priority_Node_downcast | ( | Scheduler_Node * | node | ) |
Gets the priority node of the scheduler node.
| node | The node to get the priority node of. |
| void _Scheduler_priority_Node_initialize | ( | const Scheduler_Control * | scheduler, |
| Scheduler_Node * | node, | ||
| Priority_Control | priority | ||
Initializes the node with the given priority.
| [out] | node | The node to initialize. |
| the_thread | The thread of the scheduler node. | |
| priority | The priority for the initialization. |
| RTEMS_INLINE_ROUTINE void _Scheduler_priority_Ready_queue_enqueue | ( | Chain_Node * | node, |
| Scheduler_priority_Ready_queue * | ready_queue, | ||
| Priority_bit_map_Control * | bit_map | ||
Enqueues a node on the specified ready queue.
The node is placed as the last element of its priority group.
| node | The node to enqueue. | |
| [in,out] | ready_queue | The ready queue. |
| [out] | bit_map | The priority bit map of the scheduler instance. |
| RTEMS_INLINE_ROUTINE void _Scheduler_priority_Ready_queue_enqueue_first | ( | Chain_Node * | node, |
Enqueues a node on the specified ready queue as first.
The node is placed as the first element of its priority group.
| node | The node to enqueue as first. | |
| RTEMS_INLINE_ROUTINE void _Scheduler_priority_Ready_queue_extract | ( | Chain_Node * | node, |
Extracts a node from the specified ready queue.
| node | The node to extract. | |
| RTEMS_INLINE_ROUTINE Chain_Node * _Scheduler_priority_Ready_queue_first | ( | Priority_bit_map_Control * | bit_map, |
| Chain_Control * | ready_queues | ||
Returns a pointer to the first node.
This routines returns a pointer to the first node on ready_queues.
| ready_queues | The ready queues of the scheduler instance. |
| RTEMS_INLINE_ROUTINE void _Scheduler_priority_Ready_queue_initialize | ( | Chain_Control * | ready_queues, |
| Priority_Control | maximum_priority | ||
Ready queue initialization.
This routine initializes ready_queues for priority-based scheduling.
| [out] | ready_queues | The ready queue to initialize. |
| maximum_priority | The maximum priority in the ready queue. |
| RTEMS_INLINE_ROUTINE void _Scheduler_priority_Ready_queue_update | ( | Scheduler_priority_Ready_queue * | ready_queue, |
| unsigned int | new_priority, | ||
| Priority_bit_map_Control * | bit_map, | ||
Updates the specified ready queue data according to the new priority value.
| new_priority | The new priority. | |
| bit_map | The priority bit map of the scheduler instance. | |
| void _Scheduler_priority_Schedule | ( | const Scheduler_Control * | scheduler, |
| Thread_Control * | the_thread | ||
Sets the heir thread to be the next ready thread.
This kernel routine sets the heir thread to be the next ready thread by invoking the_scheduler->ready_queue->operations->first().
| the_thread | The thread for the operation. |
| RTEMS_INLINE_ROUTINE void _Scheduler_priority_Schedule_body | ( | const Scheduler_Control * | scheduler, |
| bool | force_dispatch | ||
Scheduling decision logic.
This kernel routine implements scheduling decision logic for priority-based scheduling.
| [in,out] | scheduler | The scheduler instance. |
| the_thread | This parameter is unused. | |
| force_dispatch | Indicates whether the dispatch happens also if the currently executing thread is set as not preemptible. |
| RTEMS_INLINE_ROUTINE Scheduler_priority_Node * _Scheduler_priority_Thread_get_node | ( | Thread_Control * | the_thread | ) |
Gets the scheduler node of the thread.
| the_thread | The thread to get the scheduler node of. |
| void _Scheduler_priority_Unblock | ( | const Scheduler_Control * | scheduler, |
Unblocks the thread.
| [in,out] | the_thread | The thread to unblock. |
| void _Scheduler_priority_Update_priority | ( | const Scheduler_Control * | scheduler, |
| Scheduler_Node * | base_node | ||
Updates the priority of the node.
| base_node | The thread's scheduler node. |
| void _Scheduler_priority_Yield | ( | const Scheduler_Control * | scheduler, |
Performs the yield of a thread.
| [in,out] | the_thread | The thread that performed the yield operation. |
| node | The scheduler node of the_thread. |
