RTEMS 5.2
Files | Data Structures | Macros | Enumerations | Functions | Variables
Semaphore Manager Implementation
file  semdata.h
 Classic Semaphore Manager Data Structures.
file  semimpl.h
 Classic Semaphore Manager Implementation.
struct  Semaphore_Control
#define SEMAPHORE_INFORMATION_DEFINE(max, scheduler_count)
 Macro to define the objects information for the Classic Semaphore objects. More...
enum  Semaphore_Variant {
  SEMAPHORE_VARIANT_MUTEX_INHERIT_PRIORITY , SEMAPHORE_VARIANT_MUTEX_PRIORITY_CEILING , SEMAPHORE_VARIANT_MUTEX_NO_PROTOCOL , SEMAPHORE_VARIANT_SIMPLE_BINARY ,
  SEMAPHORE_VARIANT_COUNTING
 Classic semaphore variants. More...
enum  Semaphore_Discipline { SEMAPHORE_DISCIPLINE_PRIORITY , SEMAPHORE_DISCIPLINE_FIFO }
RTEMS_INLINE_ROUTINE uintptr_t _Semaphore_Get_flags (const Semaphore_Control *the_semaphore)
RTEMS_INLINE_ROUTINE void _Semaphore_Set_flags (Semaphore_Control *the_semaphore, uintptr_t flags)
RTEMS_INLINE_ROUTINE Semaphore_Variant _Semaphore_Get_variant (uintptr_t flags)
RTEMS_INLINE_ROUTINE uintptr_t _Semaphore_Set_variant (uintptr_t flags, Semaphore_Variant variant)
RTEMS_INLINE_ROUTINE Semaphore_Discipline _Semaphore_Get_discipline (uintptr_t flags)
RTEMS_INLINE_ROUTINE uintptr_t _Semaphore_Set_discipline (uintptr_t flags, Semaphore_Discipline discipline)
RTEMS_INLINE_ROUTINE const Thread_queue_Operations_Semaphore_Get_operations (uintptr_t flags)
RTEMS_INLINE_ROUTINE Semaphore_Control_Semaphore_Allocate (void)
 Allocates a semaphore control block from the inactive chain of free semaphore control blocks. More...
RTEMS_INLINE_ROUTINE void _Semaphore_Free (Semaphore_Control *the_semaphore)
 Frees a semaphore control block to the inactive chain of free semaphore control blocks. More...
RTEMS_INLINE_ROUTINE Semaphore_Control_Semaphore_Get (Objects_Id id, Thread_queue_Context *queue_context)
Objects_Information _Semaphore_Information
 The Classic Semaphore objects information.
◆ SEMAPHORE_INFORMATION_DEFINE
#define SEMAPHORE_INFORMATION_DEFINE (   max,
  scheduler_count
Value:
_Semaphore, \
OBJECTS_CLASSIC_API, \
OBJECTS_RTEMS_SEMAPHORES, \
max, \
_Semaphore_MP_Send_extract_proxy \
#define OBJECTS_NO_STRING_NAME
Constant for the object information string name length to indicate that this object class has no stri...
Definition: objectdata.h:101
#define OBJECTS_INFORMATION_DEFINE(name, api, cls, type, max, nl, ex)
Statically initializes an objects information.
Definition: objectdata.h:427
Definition: semdata.h:40
This macro should only be used by <rtems/confdefs.h>.
Parameters
maxThe configured object maximum (the OBJECTS_UNLIMITED_OBJECTS flag may be set).
scheduler_countThe configured scheduler count (only used in SMP configurations).
◆ Semaphore_Variant
Must be in synchronization with Semaphore_Control::variant.
◆ _Semaphore_Allocate()
RTEMS_INLINE_ROUTINE Semaphore_Control * _Semaphore_Allocate ( void  )
This function allocates a semaphore control block from the inactive chain of free semaphore control blocks.
◆ _Semaphore_Free()
RTEMS_INLINE_ROUTINE void _Semaphore_Free ( Semaphore_Control the_semaphore)
This routine frees a semaphore control block to the inactive chain of free semaphore control blocks.
