| #define | rtems_build_id(_api, _class, _node, _index) _Objects_Build_id( _api, _class, _node, _index ) |
| | Build Object Id. More...
| #define | rtems_build_name(_C1, _C2, _C3, _C4) _Objects_Build_name( _C1, _C2, _C3, _C4 ) |
| | Build Thirty-Two Bit Object Name. More...
| #define | rtems_object_id_get_api(_id) _Objects_Get_API( _id ) |
| | Get API Portion of Object Id. More...
| #define | rtems_object_id_get_class(_id) _Objects_Get_class( _id ) |
| | Get Class Portion of Object Id. More...
| #define | rtems_object_id_get_node(_id) _Objects_Get_node( _id ) |
| | Get Node Portion of Object Id. More...
| #define | rtems_object_id_get_index(_id) _Objects_Get_index( _id ) |
| | Get Index Portion of Object Id. More...
| #define | rtems_object_id_api_minimum() OBJECTS_INTERNAL_API |
| | Get Lowest Valid API Index. More...
| #define | rtems_object_id_api_maximum() OBJECTS_APIS_LAST |
| | Get Highest Valid API Index. More...
This encapsulates functionality related to the Classic API Object Class Services.
◆ rtems_build_id
| #define rtems_build_id |
_api, |
_class, |
_node, |
_index |
Build Object Id.
This function returns an object id composed of the specified api, class, node, and index.
- Parameters
| [in] | _api | indicates the api to use for the Id |
| [in] | _class | indicates the class to use for the Id |
| [in] | _node | indicates the node to use for the Id |
| [in] | _index | indicates the index to use for the Id |
- Return values
| This | method returns an object Id built from the specified values. |
- Note
- A body is also provided.
◆ rtems_build_name
RTEMS Object Helper – Build an Object Id
This function returns an object name composed of the four characters C1, C2, C3, and C4.
- Parameters
| [in] | _C1 | is the first character of the name |
| [in] | _C2 | is the second character of the name |
| [in] | _C3 | is the third character of the name |
| [in] | _C4 | is the fourth character of the name |
- Note
- This must be implemented as a macro for use in Configuration Tables. A body is also provided.
◆ rtems_object_id_api_maximum
This method returns the highest valid value for the API portion of an RTEMS object Id.
- Return values
| This | method returns the greatest valid value for the API portion of an RTEMS object Id. |
- Note
◆ rtems_object_id_api_minimum
| int rtems_object_id_api_minimum |
void | ) |
This method returns the lowest valid value for the API portion of an RTEMS object Id.
- Return values
| This | method returns the least valid value for the API portion of an RTEMS object Id. |
- Note
◆ rtems_object_id_get_api
RTEMS Object Helper – Extract API From Id
This function returns the API portion of the Id.
- Parameters
| [in] | _id | is the Id of the object to obtain the API from |
- Return values
| This | method returns the API portion of the provided _id. |
- Note
- This method does NOT validate the _id provided.
◆ rtems_object_id_get_class
This function returns the class portion of the _id ID.
- Parameters
| [in] | _id | is the Id of the object to obtain the class from |
- Return values
| This | method returns the class portion of the provided _id. |
- Note
◆ rtems_object_id_get_index
This function returns the index portion of the ID.
- Parameters
| [in] | _id | is the Id of the object to obtain the index from |
- Return values
| This | method returns the index portion of the provided _id. |
- Note
◆ rtems_object_id_get_node
This function returns the node portion of the ID.
- Parameters
| [in] | _id | is the Id of the object to obtain the node from |
- Return values
| This | method returns the node portion of the provided _id. |
- Note
◆ rtems_object_api_maximum_class()
| int rtems_object_api_maximum_class |
int |
api | ) |
Get Highest Valid Class Value.
This method returns the highest valid value Class for the specified api. Each API supports a different number of object classes.
- Parameters
| [in] | api | is the API to obtain the maximum class of |
- Return values
| This | method returns the greatet valid value for class number for the specified api. |
◆ rtems_object_api_minimum_class()
| int rtems_object_api_minimum_class |
int |
api | ) |
Get Lowest Valid Class Value.
This method returns the lowest valid value Class for the specified api. Each API supports a different number of object classes.
- Parameters
| [in] | api | is the API to obtain the minimum class of |
- Return values
| This | method returns the least valid value for class number for the specified api. RTEMS Object Helper – Get Least Valid Class for an API |
◆ rtems_object_get_api_class_name()
| const char * rtems_object_get_api_class_name |
int |
the_api, |
int |
the_class |
Get Class Name.
This method returns a string containing the name of the class from the specified api.
- Parameters
| [in] | the_api | is the API for the class |
| [in] | the_class | is the class to obtain the name of |
- Return values
| If | successful, this method returns the name of the specified class. Otherwise, it returns the string "BAD CLASS" |
◆ rtems_object_get_api_name()
| const char * rtems_object_get_api_name |
int |
api | ) |
Get API Name.
This method returns a string containing the name of the specified api.
- Parameters
| [in] | api | is the API to obtain the name of |
- Return values
| If | successful, this method returns the name of the specified api. Otherwise, it returns the string "BAD API" |
◆ rtems_object_get_class_information()
Get Class Information.
This method returns a string containing the name of the the_class from the specified api.
- Parameters
| [in] | the_class | is the class to obtain information about |
| [in] | info | points to the information structure to fill in |
- Return values
| If | successful, this method returns the name of RTEMS_SUCCESSFUL with *info filled in. Otherwise, a status is returned to indicate the error. |
◆ rtems_object_get_classic_name()
Obtain Name of Object.
This directive returns the name associated with the specified object ID.
- Parameters
| [in] | id | is the Id of the object to obtain the name of. |
| [out] | name | will be set to the name of the object |
- Note
- The object must be have a name of the 32-bit form.
- Return values
a *name will contain user defined object name
- Return values
a RTEMS_SUCCESSFUL - if successful
- Return values
| error | code - if unsuccessful |
◆ rtems_object_get_local_node()
Get the local MPCI node number.
- Returns
- The local MPCI node number.
◆ rtems_object_get_name()
| char * rtems_object_get_name |
rtems_id |
id, |
size_t |
length, |
char * |
name |
Obtain Object Name as String.
- Parameters
| [in] | id | is the Id of the object to obtain the name of |
| [in] | length | is the length of the output name buffer |
- Return values
- Return values
a name - if successful
- Return values
a NULL - if unsuccessful
◆ rtems_object_id_api_maximum_class()
| int rtems_object_id_api_maximum_class |
int |
api | ) |
- Parameters
- Return values
| This | method returns the least valid value for class number for the specified api. |
◆ rtems_object_set_name()
Set Name of Object.
This method allows the caller to set the name of an object. This can be used to set the name of objects which do not have a naming scheme per their API.
RTEMS Object Helper – Set Name of Object as String
- Parameters
- Return values
- Return values
- Return values
