RTEMS 5.2
grlib.h
1
7/*
8 * COPYRIGHT (c) 2012
9 * Aeroflex Gaisler
10 *
11 * The license and distribution terms for this file may be
12 * found in the file LICENSE in this distribution or at
13 * http://www.rtems.org/license/LICENSE.
14 */
15
16#ifndef __GRLIB_H__
17#define __GRLIB_H__
18
19#ifdef __cplusplus
20extern "C" {
21#endif
22
31/* ESA MEMORY CONTROLLER */
32struct mctrl_regs {
33 unsigned int mcfg1;
34 unsigned int mcfg2;
35 unsigned int mcfg3;
36};
37
38/* APB UART */
40 volatile unsigned int data;
41 volatile unsigned int status;
42 volatile unsigned int ctrl;
43 volatile unsigned int scaler;
44};
45
46/* IRQMP and IRQAMP interrupt controller timestamps */
48 volatile unsigned int counter; /* 0x00 */
49 volatile unsigned int control; /* 0x04 */
50 volatile unsigned int assertion; /* 0x08 */
51 volatile unsigned int ack; /* 0x0c */
52};
53
54/* IRQMP and IRQAMP interrupt controllers */
55struct irqmp_regs {
56 volatile unsigned int ilevel; /* 0x00 */
57 volatile unsigned int ipend; /* 0x04 */
58 volatile unsigned int iforce; /* 0x08 */
59 volatile unsigned int iclear; /* 0x0c */
60 volatile unsigned int mpstat; /* 0x10 */
61 volatile unsigned int bcast; /* 0x14 */
62 volatile unsigned int notused02; /* 0x18 */
63 volatile unsigned int wdgctrl; /* 0x1c */
64 volatile unsigned int ampctrl; /* 0x20 */
65 volatile unsigned int icsel[2]; /* 0x24,0x28 */
66 volatile unsigned int notused13; /* 0x2c */
67 volatile unsigned int notused20; /* 0x30 */
68 volatile unsigned int notused21; /* 0x34 */
69 volatile unsigned int notused22; /* 0x38 */
70 volatile unsigned int notused23; /* 0x3c */
71 volatile unsigned int mask[16]; /* 0x40 */
72 volatile unsigned int force[16]; /* 0x80 */
73 /* Extended IRQ registers */
74 volatile unsigned int intid[16]; /* 0xc0 */
75 volatile struct irqmp_timestamp_regs timestamp[16]; /* 0x100 */
76 volatile unsigned int resetaddr[4]; /* 0x200 */
77 volatile unsigned int resv0[12]; /* 0x210 - 0x23C */
78 volatile unsigned int pboot; /* 0x240 */
79 volatile unsigned int resv1[47]; /* 0x244 - 0x2FC */
80 volatile unsigned int irqmap[8]; /* 0x300 - 0x31C */
81 volatile unsigned int resv2[824]; /* 0x320 - 0x1000 */
82};
83
84/* GPTIMER Timer instance */
86 volatile unsigned int value;
87 volatile unsigned int reload;
88 volatile unsigned int ctrl;
89 volatile unsigned int notused;
90};
91
92#define GPTIMER_TIMER_CTRL_EN 0x00000001U
93#define GPTIMER_TIMER_CTRL_RS 0x00000002U
94#define GPTIMER_TIMER_CTRL_LD 0x00000004U
95#define GPTIMER_TIMER_CTRL_IE 0x00000008U
96#define GPTIMER_TIMER_CTRL_IP 0x00000010U
97#define GPTIMER_TIMER_CTRL_CH 0x00000020U
98#define GPTIMER_TIMER_CTRL_DH 0x00000040U
99
100/* GPTIMER common registers */
102 volatile unsigned int scaler_value; /* common timer registers */
103 volatile unsigned int scaler_reload;
104 volatile unsigned int cfg;
105 volatile unsigned int notused;
106 struct gptimer_timer_regs timer[7];
107};
108
109/* GRGPIO GPIO */
111 volatile unsigned int data; /* 0x00 I/O port data register */
112 volatile unsigned int output; /* 0x04 I/O port output register */
113 volatile unsigned int dir; /* 0x08 I/O port direction register */
114 volatile unsigned int imask; /* 0x0C Interrupt mask register */
115 volatile unsigned int ipol; /* 0x10 Interrupt polarity register */
116 volatile unsigned int iedge; /* 0x14 Interrupt edge register */
117 volatile unsigned int bypass; /* 0x18 Bypass register */
118 volatile unsigned int cap; /* 0x1C Capability register */
119 volatile unsigned int irqmap[4]; /* 0x20 - 0x2C Interrupt map registers */
120 volatile unsigned int res_30; /* 0x30 Reserved */
121 volatile unsigned int res_34; /* 0x34 Reserved */
122 volatile unsigned int res_38; /* 0x38 Reserved */
123 volatile unsigned int res_3C; /* 0x3C Reserved */
124 volatile unsigned int iavail; /* 0x40 Interrupt available register */
125 volatile unsigned int iflag; /* 0x44 Interrupt flag register */
126 volatile unsigned int res_48; /* 0x48 Reserved */
127 volatile unsigned int pulse; /* 0x4C Pulse register */
128 volatile unsigned int res_50; /* 0x50 Reserved */
129 volatile unsigned int output_or; /* 0x54 I/O port output register, logical-OR */
130 volatile unsigned int dir_or; /* 0x58 I/O port direction register, logical-OR */
131 volatile unsigned int imask_or; /* 0x5C Interrupt mask register, logical-OR */
132 volatile unsigned int res_60; /* 0x60 Reserved */
133 volatile unsigned int output_and; /* 0x64 I/O port output register, logical-AND */
134 volatile unsigned int dir_and; /* 0x68 I/O port direction register, logical-AND */
135 volatile unsigned int imask_and; /* 0x6C Interrupt mask register, logical-AND */
136 volatile unsigned int res_70; /* 0x70 Reserved */
137 volatile unsigned int output_xor; /* 0x74 I/O port output register, logical-XOR */
138 volatile unsigned int dir_xor; /* 0x78 I/O port direction register, logical-XOR */
139 volatile unsigned int imask_xor; /* 0x7C Interrupt mask register, logical-XOR */
140};
141
142/* L2C - Level 2 Cache Controller registers */
143struct l2c_regs {
144 volatile unsigned int control; /* 0x00 Control register */
145 volatile unsigned int status; /* 0x04 Status register */
146 volatile unsigned int flush_mem_addr; /* 0x08 Flush (Memory address) */
147 volatile unsigned int flush_set_index; /* 0x0c Flush (set, index) */
148 volatile unsigned int access_counter; /* 0x10 */
149 volatile unsigned int hit_counter; /* 0x14 */
150 volatile unsigned int bus_cycle_counter; /* 0x18 */
151 volatile unsigned int bus_usage_counter; /* 0x1c */
152 volatile unsigned int error_status_control; /* 0x20 Error status/control */
153 volatile unsigned int error_addr; /* 0x24 Error address */
154 volatile unsigned int tag_check_bit; /* 0x28 TAG-check-bit */
155 volatile unsigned int data_check_bit; /* 0x2c Data-check-bit */
156 volatile unsigned int scrub_control_status; /* 0x30 Scrub Control/Status */
157 volatile unsigned int scrub_delay; /* 0x34 Scrub Delay */
158 volatile unsigned int error_injection; /* 0x38 Error injection */
159 volatile unsigned int access_control; /* 0x3c Access control */
160 volatile unsigned int reserved_40[16]; /* 0x40 Reserved */
161 volatile unsigned int mtrr[32]; /* 0x80 - 0xFC MTRR registers */
162 volatile unsigned int reserved_100[131008]; /* 0x100 Reserved */
163 volatile unsigned int diag_iface_tag[16384]; /* 0x80000 - 0x8FFFC Diagnostic interface (Tag) */
164 volatile unsigned int reserved_90000[376832]; /* 0x90000 Reserved */
165 volatile unsigned int diag_iface_data[524288];/* 0x200000 - 0x3FFFFC Diagnostic interface (Data) */
166};
167
168#ifdef __cplusplus
169}
170#endif
171
172#endif
Definition: grlib.h:39
Definition: intercom.c:74
Definition: grlib.h:101
Definition: grlib.h:85
Definition: grlib.h:110
Definition: grlib.h:55
Definition: grlib.h:47
Definition: grlib.h:143
Definition: grlib.h:32
