RTEMS 5.2
l2c_regs Struct Reference
volatile unsigned int control
volatile unsigned int status
volatile unsigned int flush_mem_addr
volatile unsigned int flush_set_index
volatile unsigned int access_counter
volatile unsigned int hit_counter
volatile unsigned int bus_cycle_counter
volatile unsigned int bus_usage_counter
volatile unsigned int error_status_control
volatile unsigned int error_addr
volatile unsigned int tag_check_bit
volatile unsigned int data_check_bit
volatile unsigned int scrub_control_status
volatile unsigned int scrub_delay
volatile unsigned int error_injection
volatile unsigned int access_control
volatile unsigned int reserved_40 [16]
volatile unsigned int mtrr [32]
volatile unsigned int reserved_100 [131008]
volatile unsigned int diag_iface_tag [16384]
volatile unsigned int reserved_90000 [376832]
volatile unsigned int diag_iface_data [524288]
