RTEMS 5.2
grgpio_regs Struct Reference
volatile unsigned int data
volatile unsigned int output
volatile unsigned int dir
volatile unsigned int imask
volatile unsigned int ipol
volatile unsigned int iedge
volatile unsigned int bypass
volatile unsigned int cap
volatile unsigned int irqmap [4]
volatile unsigned int res_30
volatile unsigned int res_34
volatile unsigned int res_38
volatile unsigned int res_3C
volatile unsigned int iavail
volatile unsigned int iflag
volatile unsigned int res_48
volatile unsigned int pulse
volatile unsigned int res_50
volatile unsigned int output_or
volatile unsigned int dir_or
volatile unsigned int imask_or
volatile unsigned int res_60
volatile unsigned int output_and
volatile unsigned int dir_and
volatile unsigned int imask_and
volatile unsigned int res_70
volatile unsigned int output_xor
volatile unsigned int dir_xor
volatile unsigned int imask_xor
