RTEMS 5.2
Data Structures | Macros | Typedefs | Enumerations | Functions
Enhanced Direct Memory Access (eDMA). More...
#include <mpc55xx/regs.h>
#include <rtems/chain.h>
struct  edma_channel_context
#define EDMA_CHANNEL_COUNT   64U
#define EDMA_MODULE_COUNT   ((EDMA_CHANNEL_COUNT + 63U) / 64U)
#define EDMA_CHANNELS_PER_MODULE   64U
#define EDMA_TCD_BY_CHANNEL_INDEX(channel_index)    (&EDMA.TCD[(channel_index)])
typedef struct edma_channel_context edma_channel_context
enum  edma_channel {
  EDMA_EQADC_A_FISR0_CFFF0 = 0 , EDMA_EQADC_A_FISR0_RFDF0 = 1 , EDMA_EQADC_A_FISR1_CFFF1 = 2 , EDMA_EQADC_A_FISR1_RFDF1 = 3 ,
  EDMA_EQADC_A_FISR2_CFFF2 = 4 , EDMA_EQADC_A_FISR2_RFDF2 = 5 , EDMA_EQADC_A_FISR3_CFFF3 = 6 , EDMA_EQADC_A_FISR3_RFDF3 = 7 ,
  EDMA_EQADC_A_FISR4_CFFF4 = 8 , EDMA_EQADC_A_FISR4_RFDF4 = 9 , EDMA_EQADC_A_FISR5_CFFF5 = 10 , EDMA_EQADC_A_FISR5_RFDF5 = 11 ,
  EDMA_DSPI_B_SR_TFFF = 12 , EDMA_DSPI_B_SR_RFDF = 13 , EDMA_DSPI_C_SR_TFFF = 14 , EDMA_DSPI_C_SR_RFDF = 15 ,
  EDMA_DSPI_D_SR_TFFF = 16 , EDMA_DSPI_D_SR_RFDF = 17 , EDMA_ESCI_A_COMBTX = 18 , EDMA_ESCI_A_COMBRX = 19 ,
  EDMA_EMIOS_GFR_F0 = 20 , EDMA_EMIOS_GFR_F1 = 21 , EDMA_EMIOS_GFR_F2 = 22 , EDMA_EMIOS_GFR_F3 = 23 ,
  EDMA_EMIOS_GFR_F4 = 24 , EDMA_EMIOS_GFR_F8 = 25 , EDMA_EMIOS_GFR_F9 = 26 , EDMA_ETPU_CDTRSR_A_DTRS0 = 27 ,
  EDMA_ETPU_CDTRSR_A_DTRS1 = 28 , EDMA_ETPU_CDTRSR_A_DTRS2 = 29 , EDMA_ETPU_CDTRSR_A_DTRS14 = 30 , EDMA_ETPU_CDTRSR_A_DTRS15 = 31 ,
  EDMA_DSPI_A_SR_TFFF = 32 , EDMA_DSPI_A_SR_RFDF = 33 , EDMA_ESCI_B_COMBTX = 34 , EDMA_ESCI_B_COMBRX = 35 ,
  EDMA_EMIOS_GFR_F6 = 36 , EDMA_EMIOS_GFR_F7 = 37 , EDMA_EMIOS_GFR_F10 = 38 , EDMA_EMIOS_GFR_F11 = 39 ,
  EDMA_EMIOS_GFR_F16 = 40 , EDMA_EMIOS_GFR_F17 = 41 , EDMA_EMIOS_GFR_F18 = 42 , EDMA_EMIOS_GFR_F19 = 43 ,
  EDMA_ETPU_CDTRSR_A_DTRS12 = 44 , EDMA_ETPU_CDTRSR_A_DTRS13 = 45 , EDMA_ETPU_CDTRSR_A_DTRS28 = 46 , EDMA_ETPU_CDTRSR_A_DTRS29 = 47 ,
  EDMA_SIU_EISR_EIF0 = 48 , EDMA_SIU_EISR_EIF1 = 49 , EDMA_SIU_EISR_EIF2 = 50 , EDMA_SIU_EISR_EIF3 = 51 ,
  EDMA_ETPU_CDTRSR_B_DTRS0 = 52 , EDMA_ETPU_CDTRSR_B_DTRS1 = 53 , EDMA_ETPU_CDTRSR_B_DTRS2 = 54 , EDMA_ETPU_CDTRSR_B_DTRS3 = 55 ,
  EDMA_ETPU_CDTRSR_B_DTRS12 = 56 , EDMA_ETPU_CDTRSR_B_DTRS13 = 57 , EDMA_ETPU_CDTRSR_B_DTRS14 = 58 , EDMA_ETPU_CDTRSR_B_DTRS15 = 59 ,
  EDMA_ETPU_CDTRSR_B_DTRS28 = 60 , EDMA_ETPU_CDTRSR_B_DTRS29 = 61 , EDMA_ETPU_CDTRSR_B_DTRS30 = 62 , EDMA_ETPU_CDTRSR_B_DTRS31 = 63
void mpc55xx_edma_init (void)
rtems_status_code mpc55xx_edma_obtain_channel_by_tcd (volatile struct tcd_t *edma_tcd)
 Obtains an eDMA channel. More...
void mpc55xx_edma_release_channel_by_tcd (volatile struct tcd_t *edma_tcd)
rtems_status_code mpc55xx_edma_obtain_channel (edma_channel_context *ctx, unsigned irq_priority)
 Obtains an eDMA channel and registers the channel context. More...
void mpc55xx_edma_release_channel (edma_channel_context *ctx)
void mpc55xx_edma_copy (volatile struct tcd_t *edma_tcd, const struct tcd_t *source_tcd)
 Copies a source TCD to an eDMA TCD. More...
void mpc55xx_edma_copy_and_enable_hardware_requests (volatile struct tcd_t *edma_tcd, const struct tcd_t *source_tcd)
 Copies a source TCD to an eDMA TCD and enables hardware requests. More...
void mpc55xx_edma_sg_link (volatile struct tcd_t *edma_tcd, const struct tcd_t *source_tcd)
◆ mpc55xx_edma_copy()
void mpc55xx_edma_copy ( volatile struct tcd_t *  edma_tcd,
const struct tcd_t *  source_tcd
The DONE flag of the eDMA TCD is cleared before the actual copy operation. This enables the setting of channel link or scatter/gather options.
This function can be used to start the channel if the START flags is set in the source TCD.
◆ mpc55xx_edma_copy_and_enable_hardware_requests()
void mpc55xx_edma_copy_and_enable_hardware_requests ( volatile struct tcd_t *  edma_tcd,
◆ mpc55xx_edma_obtain_channel()
rtems_status_code mpc55xx_edma_obtain_channel ( edma_channel_context ctx,
The done handler of the channel context will be called
  • during minor or major loop completions if interrupts are enabled in the corresponding TCD, or
  • in case a channel error occurs.
An error status value not equal to zero indicates an error.
Return values
RTEMS_SUCCESSFULSuccessful operation.
RTEMS_RESOURCE_IN_USEThe channel is already in use.
RTEMS_IO_ERRORUnable to install interrupt handler for this channel.
◆ mpc55xx_edma_obtain_channel_by_tcd()
rtems_status_code mpc55xx_edma_obtain_channel_by_tcd ( volatile struct tcd_t *  edma_tcd)
Return values
