RTEMS 5.2
cpu.c File Reference
Motorola MC68xxx Dependent Source. More...
#include <rtems/score/isr.h>
#include <rtems/score/tls.h>
#include <rtems/config.h>
struct  _CPU_ISR_handler_entry
#define M68K_MOVE_A7   0x3F3C
#define M68K_JMP   0x4EF9
void _CPU_Initialize (void)
 CPU initialization. More...
uint32_t _CPU_ISR_Get_level (void)
 Returns the interrupt level of the executing thread. More...
void _CPU_ISR_install_raw_handler (uint32_t vector, CPU_ISR_raw_handler new_handler, CPU_ISR_raw_handler *old_handler)
 SPARC specific raw ISR installer. More...
void _CPU_ISR_install_vector (uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler)
 SPARC specific RTEMS ISR installer. More...
void _CPU_Context_save_fp (Context_Control_fp **fp_context_ptr)
void _CPU_Context_restore_fp (Context_Control_fp **fp_context_ptr)
void _CPU_Context_Initialize (Context_Control *the_context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area)
 Initializes the CPU context. More...
const unsigned char _CPU_m68k_BFFFO_table [256]
Context_Control_fp _fpCCR
Variable Documentation
◆ _CPU_m68k_BFFFO_table
const unsigned char _CPU_m68k_BFFFO_table[256]
Initial value:
8, 7, 6, 6, 5, 5, 5, 5, 4, 4, 4, 4, 4, 4, 4, 4,
3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3,
2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2,
1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
