RTEMS 5.2
bsp.h
1
9/*
10 * The license and distribution terms for this file may be
11 * found in the file LICENSE in this distribution or at
12 * http://www.rtems.org/license/LICENSE.
13 */
14
15#ifndef LIBBSP_M68K_MCF5225X_BSP_H
16#define LIBBSP_M68K_MCF5225X_BSP_H
17
28#include <bspopts.h>
30#include <rtems.h>
31#include <rtems/bspIo.h>
32
33/***************************************************************************/
35#include <mcf5225x/mcf5225x.h>
36
37#ifdef __cplusplus
38extern "C" {
39#endif
40
41/* Declare base address of peripherals area */
42#define __IPSBAR ((vuint8 *) 0x40000000)
43
44/***************************************************************************/
47/***************************************************************************/
50/* define ports for console and DPU specific for BLUETOOTH and STATIONS */
51#define STATIONS_PORT 0
52#define CONSOLE_PORT 1
53#define BLUETOOTH_PORT 2
54
55/* externals */
56
57/* constants */
58
59/* miscellaneous stuff assumed to exist */
60
61/*
62 * Device Driver Table Entries
63 */
64
65/*
66 * NOTE: Use the standard Console driver entry
67 */
68
69/*
70 * NOTE: Use the standard Clock driver entry
71 */
72
73
74/* functions */
75
76uint32_t bsp_get_CPU_clock_speed(void);
77
78rtems_isr_entry set_vector(
79 rtems_isr_entry handler,
81 int type
82);
83
84/*
85 * Interrupt assignments
86 * Highest-priority listed first
87 */
88
89#define PIT3_IRQ_LEVEL 4
90#define PIT3_IRQ_PRIORITY 0
91
92#define UART0_IRQ_LEVEL 3
93#define UART0_IRQ_PRIORITY 7
94#define UART1_IRQ_LEVEL 3
95#define UART1_IRQ_PRIORITY 6
96#define UART2_IRQ_LEVEL 3
97#define UART2_IRQ_PRIORITY 5
98
99/*
100 * Prototypes for BSP methods which cross file boundaries
101 */
102void Init5225x(void);
103
104#ifdef __cplusplus
105}
106#endif
107
110#endif
Interface to Kernel Print Methods.
DEFAULT_INITIAL_EXTENSION Support.
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
rtems_isr_entry set_vector(rtems_isr_entry handler, rtems_vector_number vector, int type)
Install an interrupt handler.
Definition: setvec.c:28
