RTEMS 5.2
bsp.h
1
9/*===============================================================*\
10| Project: RTEMS generic mcf548x BSP |
11+-----------------------------------------------------------------+
12| File: bsp.h |
13+-----------------------------------------------------------------+
14| The file contains the BSP header of generic MCF548x BSP. |
15+-----------------------------------------------------------------+
16| Copyright (c) 2007 |
17| Embedded Brains GmbH |
18| Obere Lagerstr. 30 |
19| D-82178 Puchheim |
20| Germany |
21| rtems@embedded-brains.de |
22+-----------------------------------------------------------------+
23| |
24| Parts of the code has been derived from the "dBUG source code" |
25| package Freescale is providing for M548X EVBs. The usage of |
26| the modified or unmodified code and it's integration into the |
27| generic mcf548x BSP has been done according to the Freescale |
28| license terms. |
29| |
30| The Freescale license terms can be reviewed in the file |
31| |
32| Freescale_license.txt |
33| |
34+-----------------------------------------------------------------+
35| |
36| The generic mcf548x BSP has been developed on the basic |
37| structures and modules of the av5282 BSP. |
38| |
39+-----------------------------------------------------------------+
40| |
41| The license and distribution terms for this file may be |
42| found in the file LICENSE in this distribution or at |
43| |
44| http://www.rtems.org/license/LICENSE. |
45| |
46+-----------------------------------------------------------------+
47| |
48| date history ID |
49| ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ |
50| 12.11.07 1.0 ras |
51| |
52\*===============================================================*/
53
54#ifndef LIBBSP_M68K_GENMCF548X_BSP_H
55#define LIBBSP_M68K_GENMCF548X_BSP_H
56
57#include <bspopts.h>
59
70#include <rtems.h>
71#include <rtems/bspIo.h>
72
73/***************************************************************************/
75#include <mcf548x/mcf548x.h>
76
77#ifdef __cplusplus
78extern "C" {
79#endif
80
81/***************************************************************************/
84/* define which port the console should use - all other ports are then defined as general purpose */
85#define CONSOLE_PORT 0
86
87/* functions */
88
89uint32_t get_CPU_clock_speed(void);
90
91rtems_isr_entry set_vector(
92 rtems_isr_entry handler,
94 int type
95);
96
97/* Initial values for the interrupt level and priority registers (INTC_ICRn) */
98extern const uint8_t mcf548x_intc_icr_init_values[64];
99
100/*
101 * Network driver configuration
102 */
103struct rtems_bsdnet_ifconfig;
104extern int rtems_mcf548x_fec_driver_attach_detach(struct rtems_bsdnet_ifconfig *config,int attaching);
105#define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_mcf548x_fec_driver_attach_detach
106
107#define RTEMS_BSP_NETWORK_DRIVER_NAME "fec1"
108#define RTEMS_BSP_NETWORK_DRIVER_NAME2 "fec2"
109
110#ifdef HAS_DBUG
111 typedef struct {
112 uint32_t console_baudrate;
113 uint8_t server_ip [4];
114 uint8_t client_ip [4];
115 uint8_t gateway_ip[4];
116 uint8_t netmask [4];
117 uint8_t spare[4];
118 uint8_t macaddr [6];
119 uint32_t ethport; /* default fec port: 1 = fec1, 2 = fec2 */
120 uint32_t uartport; /* default fec port: 1 = psc0, 2 = psc1... */
121 } dbug_settings_t;
122
123#define DBUG_SETTINGS (*(const dbug_settings_t *)0xFC020000)
124#endif /* HAS_DBUG */
125
126void bsp_cacr_set_flags(uint32_t flags);
127
128void bsp_cacr_set_self_clear_flags(uint32_t flags);
129
130void bsp_cacr_clear_flags(uint32_t flags);
131
132#ifdef __cplusplus
133}
134#endif
135
138#endif
Interface to Kernel Print Methods.
DEFAULT_INITIAL_EXTENSION Support.
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
rtems_isr_entry set_vector(rtems_isr_entry handler, rtems_vector_number vector, int type)
Install an interrupt handler.
Definition: setvec.c:28
Definition: deflate.c:115
