RTEMS  5.1
cpu.h
1
10 /*
11  * COPYRIGHT (c) 1989-2012.
12  * On-Line Applications Research Corporation (OAR).
13  *
14  * The license and distribution terms for this file may be
15  * found in the file LICENSE in this distribution or at
16  * http://www.rtems.org/license/LICENSE.
17  */
18
19 #ifndef _RTEMS_SCORE_CPU_H
20 #define _RTEMS_SCORE_CPU_H
21
22 #ifdef __cplusplus
23 extern "C" {
24 #endif
25
26 #include <rtems/score/basedefs.h>
27 #include <rtems/score/v850.h>
28
29 /* conditional compilation parameters */
30
42 #define CPU_SIMPLE_VECTORED_INTERRUPTS FALSE
43
44 #define CPU_HARDWARE_FP FALSE
45
46 #define CPU_SOFTWARE_FP FALSE
47
48 #define CPU_ALL_TASKS_ARE_FP FALSE
49
50 #define CPU_IDLE_TASK_IS_FP FALSE
51
52 #define CPU_USE_DEFERRED_FP_SWITCH FALSE
53
54 #define CPU_ENABLE_ROBUST_THREAD_DISPATCH FALSE
55
67 #define CPU_STACK_GROWS_UP FALSE
68
69 /* FIXME: Is this the right value? */
70 #define CPU_CACHE_LINE_BYTES 32
71
72 #define CPU_STRUCTURE_ALIGNMENT
73
84 #define CPU_MODES_INTERRUPT_MASK 0x00000001
85
86 #define CPU_MAXIMUM_PROCESSORS 32
87
139 typedef struct {
140  uint32_t r1;
143  uint32_t r20;
144  uint32_t r21;
145  uint32_t r22;
146  uint32_t r23;
147  uint32_t r24;
148  uint32_t r25;
149  uint32_t r26;
150  uint32_t r27;
151  uint32_t r28;
152  uint32_t r29;
153  uint32_t r31;
154  uint32_t psw;
156
164 #define _CPU_Context_Get_SP( _context ) \
165  (_context)->r3_stack_pointer
166
172 typedef struct {
177  uint32_t special_interrupt_register;
179
199 #define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0
200
205 #define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
206
218 #define CPU_STACK_MINIMUM_SIZE (1024*4)
219
220 #define CPU_SIZEOF_POINTER 4
221
230 #define CPU_ALIGNMENT 8
231
255 #define CPU_HEAP_ALIGNMENT CPU_ALIGNMENT
256
271 #define CPU_STACK_ALIGNMENT 4
272
273 #define CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES
274
275 /*
276  * ISR handler macros
277  */
278
294 #define _CPU_ISR_Disable( _isr_cookie ) \
295  do { \
296  unsigned int _psw; \
297  \
298  v850_get_psw( _psw ); \
299  __asm__ __volatile__( "di" ); \
300  _isr_cookie = _psw; \
301  } while (0)
302
314 #define _CPU_ISR_Enable( _isr_cookie ) \
315  do { \
316  unsigned int _psw = (_isr_cookie); \
317  \
318  v850_set_psw( _psw ); \
319  } while (0)
320
333 #define _CPU_ISR_Flash( _isr_cookie ) \
334  do { \
335  unsigned int _psw = (_isr_cookie); \
336  v850_set_psw( _psw ); \
337  __asm__ __volatile__( "di" ); \
338  } while (0)
339
341 {
342  return ( level & V850_PSW_INTERRUPT_DISABLE_MASK )
343  != V850_PSW_INTERRUPT_DISABLE;
344 }
345
361 #define _CPU_ISR_Set_level( new_level ) \
362  do { \
363  if ( new_level ) \
364  __asm__ __volatile__( "di" ); \
365  else \
366  __asm__ __volatile__( "ei" ); \
367  } while (0)
368
379 uint32_t _CPU_ISR_Get_level( void );
380
381 /* end of ISR handler macros */
382
385 /* Context handler macros */
386
420  Context_Control *the_context,
421  uint32_t *stack_base,
422  uint32_t size,
423  uint32_t new_level,
424  void *entry_point,
425  bool is_fp,
426  void *tls_area
427 );
428
444 #define _CPU_Context_Restart_self( _the_context ) \
445  _CPU_Context_restore( (_the_context) );
446
447 /* XXX this should be possible to remove */
448 #if 0
449
467 #define _CPU_Context_Initialize_fp( _destination ) \
468  { \
469  }
470 #endif
471
472 /* end of Context handler macros */
473
474 /* Fatal Error manager macros */
475
485 #define _CPU_Fatal_halt( _source, _error ) \
486  do { \
487  __asm__ __volatile__ ( "di" ); \
488  __asm__ __volatile__ ( "mov %0, r10; " : "=r" ((_error)) ); \
489  __asm__ __volatile__ ( "halt" ); \
490  } while (0)
491
492 /* end of Fatal Error manager macros */
493
494 #define CPU_USE_GENERIC_BITFIELD_CODE TRUE
495
496 /* functions */
497
508 void _CPU_Initialize(void);
509
510 void *_CPU_Thread_Idle_body( uintptr_t ignored );
511
528  Context_Control *run,
529  Context_Control *heir
530 );
531
545  Context_Control *new_context
547
548 /* XXX this should be possible to remove */
549 #if 0
550
564  Context_Control_fp **fp_context_ptr
565 );
566 #endif
567
568 /* XXX this should be possible to remove */
569 #if 0
570
584  Context_Control_fp **fp_context_ptr
585 );
586 #endif
587
590 /* FIXME */
592
594
631 static inline uint32_t CPU_swap_u32(
632  uint32_t value
633 )
634 {
635  unsigned int swapped;
636
637  #if (V850_HAS_BYTE_SWAP_INSTRUCTION == 1)
638  unsigned int v;
639
640  v = value;
641  __asm__ __volatile__ ("bsw %0, %1" : "=r" (v), "=&r" (swapped) );
642  #else
643  uint32_t byte1, byte2, byte3, byte4;
644
645  byte4 = (value >> 24) & 0xff;
646  byte3 = (value >> 16) & 0xff;
647  byte2 = (value >> 8) & 0xff;
648  byte1 = value & 0xff;
649
650  swapped = (byte1 << 24) | (byte2 << 16) | (byte3 << 8) | byte4;
651  #endif
652  return swapped;
653 }
654
665 static inline uint16_t CPU_swap_u16( uint16_t value )
666 {
667  unsigned int swapped;
668
669  #if (V850_HAS_BYTE_SWAP_INSTRUCTION == 1)
670  unsigned int v;
671
672  v = value;
673  __asm__ __volatile__ ("bsh %0, %1" : "=r" (v), "=&r" (swapped) );
674  #else
675  swapped = ((value & 0xff) << 8) | ((value >> 8) & 0xff);
676  #endif
677  return swapped;
678 }
679
682 typedef uint32_t CPU_Counter_ticks;
683
684 uint32_t _CPU_Counter_frequency( void );
685
686 CPU_Counter_ticks _CPU_Counter_read( void );
687
688 static inline CPU_Counter_ticks _CPU_Counter_difference(
689  CPU_Counter_ticks second,
690  CPU_Counter_ticks first
691 )
692 {
693  return second - first;
694 }
695
697 typedef uintptr_t CPU_Uint32ptr;
698
699 #ifdef __cplusplus
700 }
701 #endif
702
703 #endif
#define _CPU_Context_restore_fp(_fp_context_ptr)
Nothing to do due to the synchronous or lazy floating point switch.
Definition: cpu.h:904
void _CPU_Exception_frame_print(const CPU_Exception_frame *frame)
Prints the exception frame via printk().
Definition: vectorexceptions.c:45
uint32_t r3_stack_pointer
Definition: cpu.h:142
CPU_Counter_ticks _CPU_Counter_read(void)
Returns the current CPU counter value.
Definition: system-clocks.c:117
Thread register context.
Definition: cpu.h:194
void * _CPU_Thread_Idle_body(uintptr_t ignored)
Definition: idle-mcf5272.c:20
Interrupt stack frame (ISF).
Definition: cpu.h:191
#define RTEMS_NO_RETURN
Definition: basedefs.h:102
void _CPU_Context_Initialize(Context_Control *context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area)
Initializes the CPU context.
Definition: epiphany-context-initialize.c:40
void _CPU_Context_switch(Context_Control *run, Context_Control *heir)
CPU switch context.
Definition: cpu_asm.c:91
#define _CPU_Context_save_fp(_fp_context_ptr)
Definition: cpu.h:898
CPU initialization.
Definition: cpu.c:45
#define CPU_swap_u16(value)
Definition: cpu.h:642
SPARC basic context.
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
Unsigned integer type for CPU counter values.
Definition: cpu.h:1210
uint32_t _CPU_ISR_Get_level(void)
Definition: cpu.c:88
V850 Set up Basic CPU Dependency Settings Based on Compiler Settings.
bool _CPU_ISR_Is_enabled(uint32_t level)
Returns true if interrupts are enabled in the specified ISR level, otherwise returns false.
Definition: cpu.h:375
void _CPU_Context_restore(Context_Control *new_context) RTEMS_NO_RETURN
Definition: cpu_asm.c:111
Definition: cpu.h:662
uint32_t _CPU_Counter_frequency(void)
Returns the current CPU counter frequency in Hz.
Definition: system-clocks.c:112
Basic Definitions.
unsigned size
Definition: tte.h:74
unsigned v
Definition: tte.h:73
The set of registers that specifies the complete processor state.
Definition: cpu.h:629
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
